[petsc-users] Configure error while building PETSc with CUDA/MVAPICH2-GDR
Sreeram R Venkat srvenkat at utexas.edu
Tue Apr 16 20:35:07 CDT 2024
I finally figured out a way to make it work. I had to build PETSc and my
application using the (non GPU-aware) Intel MPI. Then, before running, I
switch to the MVAPICH2-GDR.
I'm not sure why that works, but it's the only way I've found to compile
and run successfully without throwing any errors about not having a
GPU-aware MPI.
On Fri, Dec 8, 2023 at 5:30 PM Mark Adams <mfadams at lbl.gov> wrote:
> You may need to set some env variables. This can be system specific so you
> might want to look at docs or ask TACC how to run with GPU-aware MPI.
> Mark
> On Fri, Dec 8, 2023 at 5:17 PM Sreeram R Venkat <srvenkat at utexas.edu>
> wrote:
>> Actually, when I compile my program with this build of PETSc and run, I
>> still get the error:
>> PETSC ERROR: PETSc is configured with GPU support, but your MPI is not
>> GPU-aware. For better performance, please use a GPU-aware MPI.
>> I have the mvapich2-gdr module loaded and MV2_USE_CUDA=1.
>> Is there anything else I need to do?
>> Thanks,
>> Sreeram
>> On Fri, Dec 8, 2023 at 3:29 PM Sreeram R Venkat <srvenkat at utexas.edu>
>> wrote:
>>> Thank you, changing to CUDA 11.4 fixed the issue. The mvapich2-gdr
>>> module didn't require CUDA 11.4 as a dependency, so I was using 12.0
>>> On Fri, Dec 8, 2023 at 1:15 PM Satish Balay <balay at mcs.anl.gov> wrote:
>>>> Executing: mpicc -show
>>>> stdout: icc -I/opt/apps/cuda/11.4/include -I/opt/apps/cuda/11.4/include
>>>> -lcuda -L/opt/apps/cuda/11.4/lib64/stubs -L/opt/apps/cuda/11.4/lib64
>>>> -lcudart -lrt -Wl,-rpath,/opt/apps/cuda/11.4/lib64
>>>> -Wl,-rpath,XORIGIN/placeholder -Wl,--build-id -L/opt/apps/cuda/11.4/lib64/
>>>> -lm -I/opt/apps/intel19/mvapich2-gdr/2.3.7/include
>>>> -L/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,-rpath
>>>> -Wl,/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,--enable-new-dtags -lmpi
>>>>     Checking for program /opt/apps/cuda/12.0/bin/nvcc...found
>>>> Looks like you are trying to mix in 2 different cuda versions in this
>>>> build.
>>>> Perhaps you need to use cuda-11.4 - with this install of mvapich..
>>>> Satish
>>>> On Fri, 8 Dec 2023, Matthew Knepley wrote:
>>>> > On Fri, Dec 8, 2023 at 1:54 PM Sreeram R Venkat <srvenkat at utexas.edu>
>>>> wrote:
>>>> > > I am trying to build PETSc with CUDA using the CUDA-Aware
>>>> MVAPICH2-GDR.
>>>> > > Here is my configure command:
>>>> > > ./configure PETSC_ARCH=linux-c-debug-mvapich2-gdr --download-hypre
>>>> > >  --with-cuda=true --cuda-dir=$TACC_CUDA_DIR --with-hdf5=true
>>>> > > --with-hdf5-dir=$TACC_PHDF5_DIR --download-elemental
>>>> --download-metis
>>>> > > --download-parmetis --with-cc=mpicc --with-cxx=mpicxx
>>>> --with-fc=mpif90
>>>> > > which errors with:
>>>> > >           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
>>>> for
>>>> > > details):
>>>> > >   CUDA compile failed with arch flags " -ccbin mpic++ -std=c++14
>>>> > > -Xcompiler -fPIC
>>>> > >   -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
>>>> > > arch=compute_80,code=sm_80"
>>>> > >   generated from "--with-cuda-arch=80"
>>>> > > The same configure command works when I use the Intel MPI and I can
>>>> build
>>>> > > with CUDA. The full config.log file is attached. Please let me know
>>>> if you
>>>> > > need any other information. I appreciate your help with this.
>>>> > The proximate error is
>>>> > Executing: nvcc -c -o
>>>> /tmp/petsc-kn3f29gl/config.packages.cuda/conftest.o
>>>> > -I/tmp/petsc-kn3f29gl/config.setCompilers
>>>> > -I/tmp/petsc-kn3f29gl/config.types
>>>> > -I/tmp/petsc-kn3f29gl/config.packages.cuda  -ccbin mpic++ -std=c++14
>>>> > -Xcompiler -fPIC -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
>>>> > arch=compute_80,code=sm_80  /tmp/petsc-kn3f29gl/config.packages.cuda/
>>>> > conftest.cu
>>>> > stdout:
>>>> > /opt/apps/cuda/11.4/include/crt/sm_80_rt.hpp(141): error: more than
>>>> one
>>>> > instance of overloaded function "__nv_associate_access_property_impl"
>>>> has
>>>> > "C" linkage
>>>> > 1 error detected in the compilation of
>>>> > "/tmp/petsc-kn3f29gl/config.packages.cuda/conftest.cu".
>>>> > Possible ERROR while running compiler: exit code 1
>>>> > stderr:
>>>> one
>>>> has
>>>> > "C" linkage
>>>> > This looks like screwed up headers to me, but I will let someone that
>>>> > understands CUDA compilation reply.
>>>> >   Thanks,
>>>> >      Matt
>>>> > Thanks,
>>>> > > Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240416/a38de9fa/attachment.html>
