[petsc-users] Exposing further detail in -log_view for Hypre withe PETSc
Mark Adams mfadams at lbl.gov
Wed Apr 10 08:21:21 CDT 2024
Ask hypre how to do this and we can figure out how to get it in PETSc.
On Wed, Apr 10, 2024 at 9:09 AM Khurana, Parv <p.khurana22 at imperial.ac.uk>
wrote:
> Hi Mark,
> I have had a look at these, and I could only find these ones that looked
> relevant:
> -pc_hypre_boomeramg_print_statistics: Print statistics (None)
>   -pc_hypre_boomeramg_print_debug: Print debug information (None)
> -pc_hypre_boomeramg_print_statistics prints information about the V-cycle
> (number of levels, Dofs per level etc.) It also gave this information
> (which is something I can potentially work with?)
> Proc = 0    Level = 0    Coarsen Time = 0.022089
> Proc = 0    Level = 0    Build Interp Time = 0.138844
> Proc = 0    Level = 0    Build Coarse Operator Time = 0.354488
> Proc = 0    Level = 1    Coarsen Time = 0.009334
> Proc = 0    Level = 1    Build Interp Time = 0.074119
> Proc = 0    Level = 1    Build Coarse Operator Time = 0.097702
> Proc = 0    Level = 2    Coarsen Time = 0.004301
> Proc = 0    Level = 2    Build Interp Time = 0.035835
> Proc = 0    Level = 2    Build Coarse Operator Time = 0.030501
> Proc = 0    Level = 3    Coarsen Time = 0.001876
> Proc = 0    Level = 3    Build Interp Time = 0.014711
> Proc = 0    Level = 3    Build Coarse Operator Time = 0.008681
> Proc = 0    Level = 4    Coarsen Time = 0.000557
> Proc = 0    Level = 4    Build Interp Time = 0.004307
> Proc = 0    Level = 4    Build Coarse Operator Time = 0.002373
> Proc = 0    Level = 5    Coarsen Time = 0.000268
> Proc = 0    Level = 5    Build Interp Time = 0.001061
> Proc = 0    Level = 5    Build Coarse Operator Time = 0.000589
> Proc = 0    Level = 6    Coarsen Time = 0.000149
> Proc = 0    Level = 6    Build Interp Time = 0.000339
> Proc = 0    Level = 6    Build Coarse Operator Time = 0.000206
> Proc = 0    Level = 7    Coarsen Time = 0.000090
> Proc = 0    Level = 7    Build Interp Time = 0.000148
> Proc = 0    Level = 7    Build Coarse Operator Time = 0.000085
> Proc = 0    Level = 8    Coarsen Time = 0.000054
> Proc = 0    Level = 8    Build Interp Time = 0.000100
> Proc = 0    Level = 8    Build Coarse Operator Time = 0.000053
> I have not tried -pc_hypre_boomeramg_print_debug yet.
> Think I can get the total coarsen time by summing up the time from all the
> levels here. I am still trying to understand how to get the time spent to
> solve the problem at the coarsest level.
> Best
> Parv
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Wednesday, April 10, 2024 2:01 PM
> *To:* Khurana, Parv <p.khurana22 at imperial.ac.uk>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Exposing further detail in -log_view for
> Hypre withe PETSc
> This email from mfadams at lbl.gov originates from outside Imperial. Do not
> click on links and attachments unless you recognise the sender. If you
> trust the sender, add them to your safe senders list
> <https://urldefense.us/v3/__https://spam.ic.ac.uk/SpamConsole/Senders.aspx__;!!G_uCfscf7eWS!YS2WBZEKqf7TxLkwZdEHcQVn7ovrUUklX2wN90WJl3d8l_VEtJlZDHqPrTpyZKIzmxCtb9_wiTbKdjRwSMDX4R4$ > to disable email
> stamping for this address.
> I believe there is an option to get hypre to print its performance data.
> Run with -help and grep on "pc_hypre" and look for something that looks
> like a logging or view parameter.
> Mark
> On Wed, Apr 10, 2024 at 7:49 AM Khurana, Parv <p.khurana22 at imperial.ac.uk>
> wrote:
> Hello PETSc users community, Thank you in advance for your help as always.
> I am using BoomerAMG from Hypre via PETSc as a part of preconditioner in my
> software (Nektar++). I am trying to understand the time profiling
> information that is printed
> ZjQcmQRYFpfptBannerStart
> *This Message Is From an External Sender *
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> my software (Nektar++). I am trying to understand the time profiling
> information that is printed using the -log_view option.
> I want to understand how much time is spent in the smoothening step vs the
> time to solve on the coarsest grid I reach. The output that I get from
> -log_view (pasted below) gives me information of the KSPSolve and MatMult,
> but I think I need more granular time information to see a further
> breakdown of time spent within my routines. I would like to hear if anyone
> has any recommendations on obtaining this information?
> Best
> Parv Khurana
> PETSc database options used for solve:
> -ksp_monitor # (source: file)
> -ksp_type preonly # (source: file)
> -log_view # (source: file)
> -pc_hypre_boomeramg_coarsen_type hmis # (source: file)
> -pc_hypre_boomeramg_grid_sweeps_all 2 # (source: file)
> -pc_hypre_boomeramg_interp_type ext+i # (source: file)
> -pc_hypre_boomeramg_max_iter 1 # (source: file)
> -pc_hypre_boomeramg_P_max 2 # (source: file)
> -pc_hypre_boomeramg_print_debug 1 # (source: file)
> -pc_hypre_boomeramg_print_statistics 1 # (source: file)
> -pc_hypre_boomeramg_relax_type_all sor/jacobi # (source: file)
> -pc_hypre_boomeramg_strong_threshold 0.7 # (source: file)
> -pc_hypre_boomeramg_truncfactor 0.3 # (source: file)
> -pc_hypre_type boomeramg # (source: file)
> -pc_type hypre # (source: file)
> PETSc log_view output:
> Event                Count      Time (sec)     Flop
>        --- Global ---  --- Stage ----  Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> BuildTwoSided          1 1.0 9.6900e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatMult               14 1.0 1.6315e-01 1.0 1.65e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 86  0  0  0   0 86  0  0  0  1011
> MatConvert             1 1.0 4.3092e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyBegin       3 1.0 3.1680e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd         3 1.0 9.4178e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetRowIJ            2 1.0 1.1630e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatSetPreallCOO        1 1.0 3.2132e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatSetValuesCOO        1 1.0 2.9956e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNorm               28 1.0 1.3981e-02 1.0 2.10e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 11  0  0  0   0 11  0  0  0  1499
> VecSet                13 1.0 6.5185e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAYPX               14 1.0 7.1511e-03 1.0 5.24e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  3  0  0  0   0  3  0  0  0   733
> VecAssemblyBegin      14 1.0 1.3998e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd        14 1.0 4.2560e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin       14 1.0 8.2761e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterEnd         14 1.0 4.4665e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SFSetGraph             1 1.0 6.5993e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SFSetUp                1 1.0 7.9212e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SFPack                14 1.0 5.8690e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SFUnpack              14 1.0 4.3370e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSetUp               1 1.0 2.4910e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve              14 1.0 2.1922e+00 1.0 1.91e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 100  0  0  0   0 100  0  0  0    87
> PCSetUp                1 1.0 1.3165e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply               14 1.0 1.9990e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240410/63c37736/attachment-0001.html>
