[petsc-users] Problem with NVIDIA compiler and OpenACC
Barry Smith bsmith at petsc.dev
Thu Apr 4 11:09:13 CDT 2024
   Frank,
    Please try the PETSc git branch barry/2024-04-04/rm-lnvc-link-line/release
  This will hopefully resolve the -lnvc issue. Please let us know and we can add the fix to our current release.
     Barry
> On Apr 4, 2024, at 9:37 AM, Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear PETSC Team,
> I found the following problem:
> I compile petsc 3.20.5 with Nvidia compiler 23.7.
> I use a pretty standard configuration, including
> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort COPTFLAGS="-O2 -g" CXXOPTFLAGS="-O2 -g" FOPTFLAGS="-O2 -g"  --with-debugging=0 --with-log=1 --download-fblaslapack --with-cuda=0
> I exclude cuda, since I was not sure if the problem was cuda related.
> The problem is now, if I have s simple fortran program where I link the petsc library, but I actually do not use petsc in that program
> (Just for testing). I want to use OpenACC directives in my program, e.g. !$acc parallel loop .
> The problem is now, as soon I link with the petsc library, the openacc commands do not work anymore.
> It seems that openacc is not initialised and hence it cannot find a GPU.
> The problem seems that you link with -lnvc.
> In “petscvariables” => PETSC_WITH_EXTERNAL_LIB you include “-lnvc”.
> If I take this out, then openacc works. With “-lnvc” something gets messed up.
> The problem is also discussed here:
> https://urldefense.us/v3/__https://forums.developer.nvidia.com/t/failed-cuda-device-detection-when-explicitly-linking-libnvc/203225/1__;!!G_uCfscf7eWS!Z2uhPVP0GUrttP3rh6nLk6BQsoI2EIfKfoLVXcwQFksSvtvvRILt4Yq0y-FFYmi3ugybPdn-te0Pw5mfExHSw7Y$  <https://urldefense.us/v3/__https://forums.developer.nvidia.com/t/failed-cuda-device-detection-when-explicitly-linking-libnvc/203225/1__;!!G_uCfscf7eWS!dlXNyKBzSbximQ13OXxwO506OF71yRM_H5KEnarqXE75D6Vg-ePZr2u6SJ5V3YpRETatvb9pMOUVmpyN0-19SFlbug$>
> My understanding is that libnvc is more a runtime library that does not need to be included by the linker.
> Not sure if there is a specific reason to include libnvc (I am not so familiar what this library does).
> If I take out -lnvc from “petscvariables”, then my program with openacc works as expected. I did not try any more realistic program that includes petsc.
> 2)
> When compiling petsc with cuda support, I also found that in the petsc library the library libnvJitLink.so <https://urldefense.us/v3/__http://libnvjitlink.so/__;!!G_uCfscf7eWS!Z2uhPVP0GUrttP3rh6nLk6BQsoI2EIfKfoLVXcwQFksSvtvvRILt4Yq0y-FFYmi3ugybPdn-te0Pw5mfyCcUL9Q$ >.12
> Is not found. On my system this library is in $CUDA_ROOT/lib64
> I am not sure where this library is on your system ?!
> Thanks a lot, Frank Bramkamp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240404/0bf9e463/attachment-0001.html>
