[petsc-users] Error loading data coming from a .hdf5 file into a DMSwarm
MIGUEL MOLINOS PEREZ mmolinos at us.es
Mon Apr 1 10:13:39 CDT 2024
Dear Matthew,
Thank you for your suggestion. I tried to update the vector with the information coming from the hdf5 file inside the main function. Then I print the vector two times (see the lines below), the first time it has the correct data. However, the second time, it has the same values like I never updated it with VecLoad.
It is an alternative way of initialise a vector coming from DMSWarm with previously stored information (keeping the parallel structure)?
Miguel
//! Load Hdf5 viewer
PetscViewer viewer_hdf5;
REQUIRE_NOTHROW(PetscViewerHDF5Open(MPI_COMM_WORLD, Output_hdf5_file,
FILE_MODE_READ, &viewer_hdf5));
REQUIRE_NOTHROW(PetscViewerHDF5PushTimestepping(viewer_hdf5));
//! Load the vector and fill it with the information from the .hdf5 file
Vec stdv_q;
REQUIRE_NOTHROW(DMSwarmCreateGlobalVectorFromField(
Simulation.atomistic_data, "stdv-q", &stdv_q));
REQUIRE_NOTHROW(PetscViewerHDF5PushGroup(viewer_hdf5, "/particle_fields"));
REQUIRE_NOTHROW(VecLoad(stdv_q, viewer_hdf5));
REQUIRE_NOTHROW(VecView(stdv_q, PETSC_VIEWER_STDOUT_WORLD));
REQUIRE_NOTHROW(PetscViewerHDF5PopGroup(viewer_hdf5));
REQUIRE_NOTHROW(DMSwarmDestroyGlobalVectorFromField(
//! Destoy HDF5 context
REQUIRE_NOTHROW(PetscViewerDestroy(&viewer_hdf5));
//! Load the vector again and print
Best,
Miguel
Miguel Molinos
Investigador postdoctoral
Juan de la Cierva
Dpto. Mecánica de Medios Continuos y Teoría de Estructuras - ETSI
Universidad de Sevilla
Camino de los descubrimientos, s/n
41092 Sevilla
[us_logo.jpg]
https://urldefense.us/v3/__http://www.us.es__;!!G_uCfscf7eWS!cBA1ckF1ChOi-Bgd9vd_TbaJmDZbonuQUNk2GOtfDnlYlIyTsO0mIZDspS-H1SopQFNhXZr5udHSOKQPUNQ-Xw$
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo, contiene información de carácter confidencial exclusivamente dirigida a su destinatario o destinatarios. Si no es UD. el destinatario del mensaje, le ruego lo destruya sin hacer copia digital o física, comunicando al emisor por esta misma vía la recepción del presente mensaje. Gracias
On 1 Apr 2024, at 16:28, Matthew Knepley <knepley at gmail.com> wrote:
>From the description, my guess is that this is pointer confusion. The vector inside the function is different from the vector outside the function.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240401/8e00fcdb/attachment-0001.html>
Type: image/jpeg
Desc: us_logo.jpg
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240401/8e00fcdb/attachment-0001.jpg>
