[petsc-users] Issue when configuring my petsc-3.20.0
Fri Sep 29 12:04:39 CDT 2023
Can you send us the complete configure.log file [as attachment] - perhaps to petsc-maint at mcs.anl.gov
Satish
On Sat, 30 Sep 2023, Ivan Luthfi wrote:
> Hi team,
> I have an issue when I configure my petsc with the following script:
> ./configure --with-fc=0 --download-f2cblaslapack=1 --with-blaslapack-lib=libsunperf.a --with-blas-lib=libblas.a --with-lapack-lib=liblapack.a --download-make --with-cc=gcc --with-cxx=/home/ivanluthfi1/openmpi/opt-4.1.1/bin/mpicxx --download-cmake --download-superlu_dist --with-superlud-lib=libsuperlu_dist_3.3.a --download-parmetis --with-parmetis-lib=libparmetis.a --with-cc=/home/ivanluthfi1/openmpi/opt-4.1.1/bin/mpicc --download-metis --with-metis-lib=libmetis.a
>  Here is the configure.log message:
>  PETSc Error: No output file produced
>               Rejecting compiler flag -std=c++11  due to nonzero status from link
>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>   Using C++ dialect C++11 as lower bound due to package(s):
>   - SuperLU_DIST
>   But C++ compiler (/home/ivanluthfi1/openmpi/opt-4.1.1/bin/mpicxx) appears non-compliant
>   with C++11 or didn't accept:
>   - -std=gnu++20
>   - -std=c++20
>   - -std=gnu++17
>   - -std=c++17
>   - -std=gnu++14
>   - -std=c++14
>   - -std=gnu++11
>   - -std=c++11
>   File "/home/ivanluthfi1/petsc/config/configure.py", line 462, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/home/ivanluthfi1/petsc/config/BuildSystem/config/framework.py", line 1447, in configure
>     self.processChildren()
>   File "/home/ivanluthfi1/petsc/config/BuildSystem/config/framework.py", line 1435, in processChildren
>     self.serialEvaluation(self.childGraph)
>   File "/home/ivanluthfi1/petsc/config/BuildSystem/config/framework.py", line 1410, in serialEvaluation
>     child.configure()
>   File "/home/ivanluthfi1/petsc/config/BuildSystem/config/setCompilers.py", line 2786, in configure
>     self.executeTest(self.checkCxxDialect,args=[LANG],kargs={'isGNUish':isGNUish})
>   File "/home/ivanluthfi1/petsc/config/BuildSystem/config/base.py", line 138, in executeTest
>     ret = test(*args,**kargs)
>   File "/home/ivanluthfi1/petsc/config/BuildSystem/config/setCompilers.py", line 1225, in checkCxxDialect
>     raise ConfigureSetupError(mess)
> Finishing configure run at Sat, 30 Sep 2023 00:52:35 +0800
> Please help me, I need to configure it with metis, parmetis, superlud, blas, and lapack.
