[petsc-users] Xcode 15.0 breaks PETSc configure?
Thu Sep 28 08:56:31 CDT 2023
petsc git repo main branch has fixes for xcode-15. Can you give it a try?
Satish
On Thu, 28 Sep 2023, Paul Tackley wrote:
> Hello,
> PETSc was working fine on my M1 Mac until I upgraded to Xcode 15.0 - now I can’t even configure it. There seems to be a problem related to C and C++ in Xcode 15.0. “Cxx libraries cannot directly be used with C as linker”. Stdout message pasted below and configure.log file attached.
> Thanks for any advice.
> Paul
> % gcc --version
> Apple clang version 15.0.0 (clang-1500.0.40.1)
> Target: arm64-apple-darwin22.6.0
> % g++ --version
>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>   Cxx libraries cannot directly be used with C as linker.
>   If you don't need the C++ compiler to build external packages or for you application you
>   can run
>   ./configure with --with-cxx=0. Otherwise you need a different combination of C and C++
>   compilers
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/configure.py", line 462, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/BuildSystem/config/framework.py", line 1438, in configure
>     self.processChildren()
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/BuildSystem/config/framework.py", line 1426, in processChildren
>     self.serialEvaluation(self.childGraph)
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/BuildSystem/config/framework.py", line 1401, in serialEvaluation
>     child.configure()
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/BuildSystem/config/compilers.py", line 1463, in configure
>     self.executeTest(self.checkCxxLibraries)
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/BuildSystem/config/base.py", line 138, in executeTest
>     ret = test(*args,**kargs)
>   File "/Users/pjt/Software/PETSc/petsc-3.19.5/config/BuildSystem/config/compilers.py", line 695, in checkCxxLibraries
>     raise RuntimeError("Cxx libraries cannot directly be used with C as linker.\n\
