[petsc-users] Issues with PETSc Configuration using gfortran-13 after Updating to Xcode 15 on MacOS Ventura 13.6
Felipe Caro msc.felipe.caro at gmail.com
Mon Sep 25 02:42:37 CDT 2023
Hello PETSc Support Team,
I hope this email finds you well. I need help configuring PETSc on my Mac
running MacOS Ventura 13.6 with Xcode 15. I have recently updated my
operating system and Xcode and am facing issues setting up PETSc with
gfortran-13.
Thank you for your assistance.
System Information
   - MacOS Version: Ventura 13.6
   - Xcode Version: 15
   - gfortran Version: 13 (installed via Homebrew)
   - PETSc Version: [Your PETSc Version]
Steps to Reproduce
I followed the standard installation steps as outlined in the PETSc
documentation. Below is the relevant section of the Bash script I used for
configuration:
#!/bin/bash
# PETSc environment variables
export PETSC_DIR=/path/to/petsc
export PETSC_ARCH=arch-cmplx-opt
# Configuration
cd $PETSC_DIR
./configure --with-cc=gcc-13 --with-cxx=g++-13 --with-fc=gfortran-13
--with-f90=gfortran-13 \
  --with-debugging=no --with-scalar-type=complex --with-openmp \
  --download-mpich --download-fblaslapack --download-scalapack \
  --download-mumps --download-metis --download-parmetis --download-hwloc \
  COPTFLAGS="-O3" CXXOPTFLAGS="-O3" FOPTFLAGS="-Ofast" $PETSC_ARCH
Error Message
The configure script throws the following error:
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
Fortran compiler you provided with --with-fc=gfortran-13 cannot be found or
does not work.
Cannot compile/link FC with gfortran-13.
To verify if gfortran-13 is working, I tested it by compiling a simple
Fortran program, and it worked despite a linker warning related to
duplicate libraries.
Additional Information
I also ran brew doctor to ensure my Homebrew setup was fine and no issues
were found.
Can you guide me on how to resolve this issue? I can also provide the
configure.log file if that would be helpful for debugging.
Thank you for your time and assistance.
I am attaching my config.log
Best Regards,
Felipe.
El dom, 24 sept 2023 a la(s) 18:38, Barry Smith (bsmith at petsc.dev) escribió:
>   Please send configure.log to petsc-maint at mcs.anl.gov
> On Sep 24, 2023, at 5:59 AM, Felipe Caro <msc.felipe.caro at gmail.com>
> gfortran-13.
> System Information
>    - Xcode Version: 15
> Steps to Reproduce
> configuration:
> #!/bin/bash
> # Configuration
> cd $PETSC_DIR
> Error Message
> or does not work.
> were found.
> Best regards,
> Felipe.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230925/926c418a/attachment-0001.html>
Type: application/x-sh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230925/926c418a/attachment-0001.sh>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230925/926c418a/attachment-0001.obj>
