[petsc-users] Issues with PETSc Configuration using gfortran-13 after Updating to Xcode 15 on MacOS Ventura 13.6
Felipe Caro msc.felipe.caro at gmail.com
Sun Sep 24 04:59:12 CDT 2023
Hello PETSc Support Team,
I hope this email finds you well. I need help configuring PETSc on my Mac
running MacOS Ventura 13.6 with Xcode 15. I have recently updated my
operating system and Xcode and am facing issues setting up PETSc with
gfortran-13.
Thank you for your assistance.
System Information
   - MacOS Version: Ventura 13.6
   - Xcode Version: 15
   - gfortran Version: 13 (installed via Homebrew)
   - PETSc Version: [Your PETSc Version]
Steps to Reproduce
I followed the standard installation steps as outlined in the PETSc
documentation. Below is the relevant section of the Bash script I used for
configuration:
#!/bin/bash
# PETSc environment variables
export PETSC_DIR=/path/to/petsc
export PETSC_ARCH=arch-cmplx-opt
# Configuration
cd $PETSC_DIR
./configure --with-cc=gcc-13 --with-cxx=g++-13 --with-fc=gfortran-13
--with-f90=gfortran-13 \
  --with-debugging=no --with-scalar-type=complex --with-openmp \
  --download-mpich --download-fblaslapack --download-scalapack \
  --download-mumps --download-metis --download-parmetis --download-hwloc \
  COPTFLAGS="-O3" CXXOPTFLAGS="-O3" FOPTFLAGS="-Ofast" $PETSC_ARCH
Error Message
The configure script throws the following error:
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
Fortran compiler you provided with --with-fc=gfortran-13 cannot be found or
does not work.
Cannot compile/link FC with gfortran-13.
To verify if gfortran-13 is working, I tested it by compiling a simple
Fortran program, and it worked despite a linker warning related to
duplicate libraries.
Additional Information
I also ran brew doctor to ensure my Homebrew setup was fine and no issues
were found.
Can you guide me on how to resolve this issue? I can also provide the
configure.log file if that would be helpful for debugging.
Thank you for your time and assistance.
Best regards,
Felipe.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230924/ba8d7a22/attachment.html>
