[petsc-users] Problem with matrix and vector using GPU
Ramoni Z. Sedano Azevedo ramoni.zsedano at gmail.com
Wed Sep 20 10:21:12 CDT 2023
Hey!
I am using PETSc in a Fortran code and we use MPI parallelization. We would
like to use GPU parallelization, but we are encountering an error.
PETSc is configured as follows:
#!/bin/bash
./configure \
 --prefix=${PWD}/installdir \
 --with-fortran \
 --with-fortran-kernels=true \
 --with-cuda \
 --download-fblaslapack \
 --with-scalar-type=complex \
 --with-precision=double \
 --with-debugging=yes \
 --with-x=0 \
 --with-gnu-compilers=1 \
 --with-cc=mpicc \
 --with-cxx=mpicxx \
 --with-fc=mpif90 \
 --with-make-exec=make
Within my code, matrices and vectors are allocated with the following
commands:
PetscCallA( DMDACreate3d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE,
DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, DMDA_STENCIL_BOX, l+1, m+1, nzn,
PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE, i3, i1, PETSC_NULL_INTEGER,
PETSC_NULL_INTEGER, PETSC_NULL_INTEGER, da, ierr) )
PetscCallA( DMSetUp(da,ierr) )
PetscCallA( DMCreateGlobalVector(da,b,ierr) )
PetscCallA( VecDuplicate(b,xsol,ierr) )
PetscCallA( VecDuplicate(b,src,ierr) )
PetscCallA( VecDuplicate(b,rhoxyz,ierr) )
PetscCallA( DMCreateLocalVector(da,localx,ierr) )
PetscCallA( VecDuplicate(localx,localb,ierr) )
PetscCallA( VecDuplicate(localx,localsrc,ierr) )
PetscCallA( VecDuplicate(localx,lrhoxyz,ierr) )
PetscCallA( VecGetLocalSize(xsol,mloc,ierr) )
ngrow=3*(l+1)*(m+1)*nzn
PetscCallA( MatCreate(PETSC_COMM_WORLD,A,ierr) )
PetscCallA( MatSetOptionsPrefix(A,'A_',ierr) )
PetscCallA( MatSetSizes(A,mloc,mloc,ngrow,ngrow,ierr) )
PetscCallA( MatSetFromOptions(A,ierr) )
PetscCallA( MatSeqAIJSetPreallocation(A,i15,PETSC_NULL_INTEGER,ierr) )
PetscCallA( MatSeqBAIJSetPreallocation(A, i3, i15, PETSC_NULL_INTEGER,
ierr) )
PetscCallA( MatMPIAIJSetPreallocation(A, i15, PETSC_NULL_INTEGER, i15,
PETSC_NULL_INTEGER, ierr) )
PetscCallA( MatMPIBAIJSetPreallocation(A, i3, i15, PETSC_NULL_INTEGER, i15,
PetscCallA( MatCreate(PETSC_COMM_WORLD, P, ierr) )
PetscCallA( MatSetOptionsPrefix(P, 'P_', ierr) )
PetscCallA( MatSetSizes(P, mloc, mloc, ngrow, ngrow, ierr) )
PetscCallA( MatSetFromOptions(P, ierr) )
PetscCallA( MatSeqAIJSetPreallocation(P, i15, PETSC_NULL_INTEGER, ierr) )
PetscCallA( MatSeqBAIJSetPreallocation(P, i3, i15, PETSC_NULL_INTEGER,
ierr) )
PetscCallA( MatMPIAIJSetPreallocation(P, i15, PETSC_NULL_INTEGER, i15,
PetscCallA( MatMPIBAIJSetPreallocation(P, i3, i15, PETSC_NULL_INTEGER, i15,
PetscCallA( DMDAGetInfo(da, PETSC_NULL_INTEGER, mx, my, mz,
PETSC_NULL_INTEGER, PETSC_NULL_INTEGER, PETSC_NULL_INTEGER,
PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,ierr)
PetscCallA( DMDAGetCorners(da,xs,ys,zs,xm,ym,zm,ierr) )
PetscCallA( DMDAGetGhostCorners(da,gxs,gys,gzs,gxm,gym,gzm,ierr) )
PetscCallA( DMLocalToGlobal(da,localsrc,INSERT_VALUES,src,ierr) )
PetscCallA( DMGlobalToLocalBegin(da, src, INSERT_VALUES, localsrc, ierr) )
PetscCallA( DMGlobalToLocalEnd(da,src,INSERT_VALUES,localsrc,ierr) )
PetscCallA( DMLocalToGlobal(da,localb,INSERT_VALUES,b,ierr) )
When calling the solver function
PetscCallA( KSPSolve(ksp,b,xsol,ierr) )
the following error occurs:
[0]PETSC ERROR: --------------------- Error Message
--------------------------------------------------------------[0]PETSC
ERROR: Invalid argument[0]PETSC ERROR: Object (seq) is not seqcuda or
mpicuda[0]PETSC ERROR: WARNING! There are option(s) set that were not
used! Could be the program crashed before they were used or a spelling
mistake, etc![0]PETSC ERROR: Option left: name:-vec_type value:
cuda[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
shooting.[0]PETSC ERROR: Petsc Release Version 3.18.4, unknown
The code is executed with the following flags:
./${executable} \
 -A_mat_type aijcusparse \
 -P_mat_type aijcusparse \
 -vec_type cuda \
 -use_gpu_aware_mpi 0 \
 -em_ksp_monitor_true_residual \
 -em_ksp_type bcgs \
 -em_pc_type bjacobi \
 -em_sub_pc_type ilu \
 -em_sub_pc_factor_levels 3 \
 -em_sub_pc_factor_fill 6 \
 < ./Parameters.inp \
I've already tested using mpiaijcusparse for matrix and mpicuda for vector
and the error continues.
Would anyone have an idea what I might be doing wrong?
Sincerely,
Ramoni Z. S. Azevedo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230920/bb34fe00/attachment-0001.html>
