[petsc-users] Problem with BLASdot in 3.19.4
Thuc Bui bui at calcreek.com
Wed Sep 20 01:10:19 CDT 2023
Hi Satish and Barry,
Thank you very for getting back to me with the suggestion of the OMP_NUM_THREADS  environmental variable and how to set the option  no_signal_handler per Barry's suggestion.
Yes, I am using threaded Intel MKL. So, I first set the environmental variable  OMP_NUM_THREADS=1, and run the Visual Studio debugger. It still crashes at the same place with the same errors. I then set the PETSC_OPTIONS=-no_signal_handler, the debugger refuses to pass through the access exception, and I have to stop the debugger; consequently no PETSc errors were reported. I know there is an option somewhere in the VS debugger to bypass this access exception, but I didn't pursue further.
Finally, I removed Intel MKL 2000 (to uninstall it requires a 3rd party software!), and use Intel oneAPI MKL (2023) with PETSc 3.18.6 and Visual Studio 2022. Now my code with 1, 2  or 4 cores work!
I will try 3.19.4 next and will keep you posted.
Thank you again for your help,
Thuc Bui
./configure --with-cc='win32fe cl' --with-fc=0 --with-cxx='win32fe cl' --with-openmp \
--with-mpi-include='/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/MSMPI/latest/include:/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/MSMPI/latest/include/x64' \
--with-mpi-lib=[/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/MSMPI/latest/Lib/x64/msmpi.lib,/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/MSMPI/latest/Lib/x64/msmpifec.lib] \
--with-blas-lapack-lib=[/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/IntelMKL/latest/lib64/mkl_intel_lp64.lib,/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/IntelMKL/latest/lib64/mkl_core.lib,/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/IntelMKL/latest/lib64/mkl_intel_thread.lib,/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/IntelMKL/latest/lib64/mkl_rt.lib,/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/IntelMKL/latest/lib64/libiomp5md.lib] \
--with-mpiexec='/cygdrive/d/Users/bbwannabe/Documents/Petsc/externalpackages/MSMPI/latest/bin/x64/mpiexec' \
--with-shared-libraries=0
-----Original Message-----
Sent: Tuesday, September 19, 2023 10:01 AM
To: Thuc Bui
Cc: 'Barry Smith'; 'PETSc users list'
Subject: Re: [petsc-users] Problem with BLASdot in 3.19.4
Its a run time option to petsc (application) binary.
So you can either specify it via command line - at run time - or add it to env variable "PETSC_OPTIONS" - or add it to $HOME/.petscrc file
Satish
On Tue, 19 Sep 2023, Thuc Bui wrote:
> Hi Barry,
> Thanks for getting back to me. The diagnostics were generated when tracing under the VS debugger. To use the option –no_signal_handler, I believe I will need to reconfigure PETSc with this additional option. I will try it now.
> Thuc
> From: Barry Smith [mailto:bsmith at petsc.dev]
> Sent: Tuesday, September 19, 2023 8:24 AM
> To: Thuc Bui
> Cc: PETSc users list
>   Can you run in the Microsoft Visual Studio debugger? Use the additional PETSc option -no_signal_handler
>   It won't show exactly where the SEGV happens but might focus in a bit on it. For example it may be ddot() or ddot_().
>   Barry
> On Sep 19, 2023, at 2:04 AM, Thuc Bui <bui at calcreek.com> wrote:
> Hi Barry,
> Visual Studio 2022 is the problem! The code linked to Petsc 3.18.6 built with VS 2022 also crashes at the same place. The same errors are shown below. I don’t remember for sure, but I don’t think I was able to configure Petsc 3.19.4 with VS 2019. However, I will still try that next.
> Thanks for your help,
> Thuc
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see  <https://petsc.org/release/faq/#valgrind> https://petsc.org/release/faq/#valgrind and  <https://petsc.org/release/faq/> https://petsc.org/release/faq/
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: The line numbers in the error traceback are not always exact.
> [0]PETSC ERROR: #1 BLASdot()
> [0]PETSC ERROR: #2 VecNorm_Seq() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\vec\vec\impls\seq\bvec2.c:216
> [0]PETSC ERROR: #3 VecNorm() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\vec\vec\interface\rvector.c:237
> [0]PETSC ERROR: #4 VecNormalize() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\vec\vec\interface\rvector.c:318
> [0]PETSC ERROR: #5 KSPGMRESCycle() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\ksp\ksp\impls\gmres\gmres.c:111
> [0]PETSC ERROR: #6 KSPSolve_GMRES() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\ksp\ksp\impls\gmres\gmres.c:228
> [0]PETSC ERROR: #7 KSPSolve_Private() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\ksp\ksp\interface\itfunc.c:899
> [0]PETSC ERROR: #8 KSPSolve() at D:\Users\bbwannabe\Documents\Petsc\petsc-3.18.6\src\ksp\ksp\interface\itfunc.c:1071
> job aborted:
> [ranks] message
> [0] application aborted
> aborting MPI_COMM_WORLD (comm=0x44000000), error 59, comm rank 0
> From: petsc-users [ <mailto:petsc-users-bounces at mcs.anl.gov> mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Thuc Bui
> Sent: Monday, September 18, 2023 4:24 PM
> To: 'Barry Smith'
> Cc: 'PETSc users list'
> Thanks a lot Barry, for getting back to me. Will do what you have suggested, and get back with the results.
> Best regards,
> Thuc
> From: Barry Smith [ <mailto:bsmith at petsc.dev> mailto:bsmith at petsc.dev]
> Sent: Monday, September 18, 2023 3:43 PM
> To: Thuc Bui
>   Ok, two things are being changed at the same time: the version  of PETSc and the version of Visual Studio.
>   Could you please try with the new Visual Studio version but the same older PETSc version? If that works could you try with the old Visual Studio version but the new PETSc version?
>   Barry
> On Sep 18, 2023, at 6:26 PM, Thuc Bui < <mailto:bui at calcreek.com> bui at calcreek.com> wrote:
> Dear Petsc users and experts,
> If someone can direct me how to track this bug, I would really appreciate it.
> The Petsc DLL library version 3.19.4 was built on Windows 10 with Visual Studio 2022, and with Microsoft MPI 10.1.2 and Intel MKL 2020.3.279. The same code works fine with Petsc 3.18.6 using the same versions of MS MPI and Intel MKL, and built with Visual Studio 2019.
> When my code calls PetscCall(KSPSolve(...)), it gets to PetscCall(KSPGMRESCycle(...)), PetscCall(VecNormalize(VEC_VV(0), &res)), PetscCall(VecNorm(x, NORM_2, &norm)) and then crashes in VecNorm_Seq() at:
>                 PetscCallBLAS("BLASdot", ztmp[type == NORM_1_AND_2] = PetscSqrtReal(PetscRealPart(BLASdot_(&bn, xx, &one, xx, &one))));
> I tried to step into BLASdot_, but was unable to. I assume BLASdot_ belong to Intel MKL, and its library does not contain debug information. After the code exits, the errors are shown below the hash line.
> Should I install the latest Intel MKL to work with Petsc 3.19.4?
> Many thanks in advance for your help,
> Thuc Bui
> Senior R&D Engineer
> Calabazas Creek Research, Inc
> (650) 948-5361
> [0]PETSC ERROR: #2 VecNorm_Seq() at D:\Users\bbwannabe\Documents\Petsc\latest\src\vec\vec\impls\seq\bvec2.c:213
> [0]PETSC ERROR: #3 VecNorm() at D:\Users\bbwannabe\Documents\Petsc\latest\src\vec\vec\interface\rvector.c:237
> [0]PETSC ERROR: #4 VecNormalize() at D:\Users\bbwannabe\Documents\Petsc\latest\src\vec\vec\interface\rvector.c:318
> [0]PETSC ERROR: #5 KSPGMRESCycle() at D:\Users\bbwannabe\Documents\Petsc\latest\src\ksp\ksp\impls\gmres\gmres.c:110
> [0]PETSC ERROR: #6 KSPSolve_GMRES() at D:\Users\bbwannabe\Documents\Petsc\latest\src\ksp\ksp\impls\gmres\gmres.c:227
> [0]PETSC ERROR: #7 KSPSolve_Private() at D:\Users\bbwannabe\Documents\Petsc\latest\src\ksp\ksp\interface\itfunc.c:898
> [0]PETSC ERROR: #8 KSPSolve() at D:\Users\bbwannabe\Documents\Petsc\latest\src\ksp\ksp\interface\itfunc.c:1070
> job aborted:
> [ranks] message
