[petsc-users] 2D Partitioning matrix-shell and KSP
Sreeram R Venkat srvenkat at utexas.edu
Tue Sep 19 18:44:30 CDT 2023
With the example you have given, here is what I would like to do:
   - 12 MPI ranks
   - Each rank has one block (rank 0 has A, rank 1 has B, ..., rank 11 has
   L) - to make the rest of this easier I'll refer to the rank containing
   block A as "rank A", and so on
   - rank A, rank B, rank C, and rank D have w, x, y, z respectively - the
   first step of the custom matvec implementation broadcasts w to rank E and
   rank I (similarly x is broadcast to rank F and rank J ...)
   - at the end of the matvec computation, ranks D, H, and L have a, b, and
   c respectively
Sreeram
On Tue, Sep 19, 2023 at 6:23 PM Barry Smith <bsmith at petsc.dev> wrote:
>  (  a )       (  A  B  C  D ) (   w )
>  (  b )   =  (  E  F  G H  ) (  x )
>  (  c )        ( I    J   K L  )  ( y  )
>                                        ( z  )
> I have no idea what "The input vector is partitioned across each row, and
> the output vector is partitioned across each column" means.
> Anyways the shell matrix needs to live on MPI_COMM_WORLD, as do both the
> (a,b,c) and (w,x,y,z) vector.
> Now how many MPI ranks do you want to do the compution on? 12?
> Do you want one matrix A .. Z on each rank?
> Do you want the (a,b,c) vector spread over all ranks? What about the (w,x,y,z)
> vector?
>   Barry
> On Sep 19, 2023, at 4:42 PM, Sreeram R Venkat <srvenkat at utexas.edu> wrote:
> I have a custom implementation of a matrix-vector product that inherently
> relies on a 2D processor partitioning of the matrix. That is, if the matrix
> looks like:
> A B C D
> E F G H
> I  J K L
> in block form, we use 12 processors, each having one block. The input
> vector is partitioned across each row, and the output vector is partitioned
> across each column.
> Each processor has 3 communicators: the WORLD_COMM, a ROW_COMM, and a
> COL_COMM. The ROW/COL communicators are used to do reductions over
> rows/columns of processors.
> With this setup, I am a bit confused about how to set up the matrix shell.
> The "MatCreateShell" function only accepts one communicator. If I give the
> WORLD_COMM, the local/global sizes won't match since PETSc will try to
> multiply local_size * total_processors instead of local_size *
> processors_per_row (or col). I have gotten around this temporarily by
> giving ROW_COMM here instead. What I think happens is a different MatShell
> is created on each row, but when computing the matvec, they all work
> together.
> However, if I try to use KSP (CG) with this setup (giving ROW_COMM as the
> communicator), the process hangs. I believe this is due to the partitioning
> of the input/output vectors. The matvec itself is fine, but the inner
> products and other steps of CG fail. In fact, if I restrict to the case
> where I only have one row of processors, I am able to successfully use KSP.
> Is there a way to use KSP with this 2D partitioning setup when there are
> multiple rows of processors? I'd also prefer to work with one global
> MatShell object instead of this one object per row thing that I'm doing
> right now.
> Thanks for your help,
> Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230919/2cc926c3/attachment.html>
