[petsc-users] Is precondition works for ill-conditioned jacobian matrix
Zhang, Hong hzhang at mcs.anl.gov
Fri Sep 15 09:27:12 CDT 2023
Gong,
Iterative refinement might help, i.e., more than one MatSolve ( LU x = b) is applied. If you use superlu_dist, this operation can be activated at runtime by the option '-pc_type lu -pc_factor_mat_solver_type superlu_dist -mat_superlu_dist_iterrefine' (run your code withe '-help' for available options).
Using mumps, the iterative refinement can be activated by
-mat_mumps_icntl_10: <now 0 : formerly 0>: ICNTL(10): max num of refinements (None)
i.e., '-mat_mumps_icntl_10 1' applies one refinement.
I suspect the LU solver would be called again if one MatSolve() does not reach the required tolerance. Check your runs with '-snes_monitor -ksp_monitor' to get more understanding.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Gong Ding <gongding at cn.cogenda.com>
Sent: Thursday, September 14, 2023 10:29 PM
To: Barry Smith <bsmith at petsc.dev>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Is precondition works for ill-conditioned jacobian matrix
The matrix has a bad condition number, but not singular. It comes from real physical problem and the floating zone is weekly controlled by remote boundary condition.
Yes, I am also afraid that with 64 bit floating number, the matrix is numerically singular since the construction of jacaobian has already lost precision.
Anyway, I can build the jacobian at 128 bit precision and then truncate to 64 bit. Our solution x and function f can also be evaluated at 128 bit precision.
The main purpose is, always do LU factorization at 64 bit for performance issue.
Method 1 tries to "precondition" a direct solver. I don't know if possible.
Method 2 wants to use post refinement to improve the accuracy of a direct solver. Theoretically, I think it should work.
On 2023/9/15 01:37, Barry Smith wrote:
  Method 1 and 2 are unlikely to work.
  It sounds like your matrix is (in exact precision) singular, but using 128 bit floats allows a "stable" factorization to go through giving you a descent direction for Newton.
  I think you really need to fix the singularity at the modeling level, it is not robust to fix it at the numerical algorithm level. If you know the exact form of the null spaces you can use MatSetNullSpace() but you cannot use a direct solver for the system since the factorization will still see the singular matrix.
   Barry
On Sep 14, 2023, at 12:30 PM, Gong Ding <gongding at cn.cogenda.com><mailto:gongding at cn.cogenda.com> wrote:
The physical problem itself is ill-conditioned since there are floating regions in the simulation domain.
I use MUMPS as 64 bit LU solver, and a special improved SuperLU as 128 bit LU solver (https://github.com/cogenda/superlu, added float128 support).
Although 128 bit solver works, it is 10x slower.
I'd like to try, if  jacobian can be processed under 64 bit precision while keeps the Newton iteration convergence.
Method 1:
Use a block inversion of the main diagonal of jacobian as preconditioner  (or ILU? ). Then factorize M*J.
Both the precondition matrix and jacobian matrix are 64 bit.
Method 2:
Do a 64 bit LU factorization of jacobian matrix, and use the factorization result as a preconditioner for higher precision krylov solver (such as iterative refinement)
On 2023/9/14 23:05, Zhang, Hong wrote:
Gong Ding,
When you use a LU solver, the preconditioner M = inv(LU) = inv (J) on theory. I suspect your jacobian evaluation by 64bit might be inaccurate. What LU solver did you use? Run your code with option '-snes_view -snes_monitor -ksp_monitor' and compare the displays.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov><mailto:petsc-users-bounces at mcs.anl.gov> on behalf of Mark Adams <mfadams at lbl.gov><mailto:mfadams at lbl.gov>
Sent: Thursday, September 14, 2023 5:35 AM
To: Gong Ding <gongding at cn.cogenda.com><mailto:gongding at cn.cogenda.com>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov>
I would first verify that you are happy with the solution that works.
Next, I would worry about losing accuracy in computing M*J, but you could try it and search for any related work. There may be some tricks.
And MUMPS is good at high accuracy, you might try that and if it fails look at the MUMPS docs for any flags for high-accuracy.
Good luck,
On Thu, Sep 14, 2023 at 5:35 AM Gong Ding <gongding at cn.cogenda.com<mailto:gongding at cn.cogenda.com>> wrote:
Hi all
I find such a nonlinear problem, the jacobian matrix is ill conditioned.
Solve the jacobian matrix by 64bit LU  solver, the Newton method failed
to convergence.
However, when solve the jacobian matrix by 128bit LU solver , Newton
iteration will convergence.
I think this phenomena indicate that , the jacobian matrix is ill
conditioned.
The question is, if I do a precondition as M*J*dx = -M*f(x), here M is
the precondition matrix, . then I solve the matrix A=M*J by a LU solver.
Can I expect that solve A=M*J has a better precision result that help
the convergence of Newton iteration?
Gong Ding
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230915/5378491a/attachment-0001.html>
