[petsc-users] Error while running with -pc_type gamg on NVIDIA GPU
Maruthi NH maruthinh at gmail.com
Wed Sep 13 01:06:27 CDT 2023
Hi Junchao Zhang,
I also build petsc with --download-hypre and I too have 2.29.0 version. Not
sure why I am facing this issue. This is the configuration file I created
for building petsc.
#!/usr/bin/env python3
import os
petsc_hash_pkgs=os.path.join(os.getenv('HOME'),'petsc-hash-pkgs')
if __name__ == '__main__':
  import sys
  import os
  sys.path.insert(0, os.path.abspath('config'))
  import configure
  configure_options = [
    '--package-prefix-hash='+petsc_hash_pkgs,
    '--with-debugging=0',
    '--with-shared-libraries=0',
    '--with-cc=mpiicc',
    '--with-cxx=mpiicpc',
    '--with-fc=mpiifort',
    '--with-mpiexec=mpiexec.hydra',
    '--with-cudac=nvcc', # nvcc-12.2 via ccache
    '--with-cuda-dir=/usr/local/cuda-12.2',
    # Intel compilers enable GCC/clangs equivalent of -ffast-math *by
default*. This is
    # bananas, so we make sure they use the same model as everyone else
    'COPTFLAGS=-O3 -fPIE -fp-model=precise',
    'FOPTFLAGS=-O3 -fPIE -fp-model=precise',
    'CXXOPTFLAGS=-O3 -fPIE -fp-model=precise',
    'CUDAOPTFLAGS=-O3',
    '--with-precision=double',
    '--with-blaslapack-dir='+os.environ['MKLROOT'],
    '--with-mkl_pardiso-dir='+os.environ['MKLROOT'],
    '--with-mkl_cpardiso-dir='+os.environ['MKLROOT'],
    '--download-hypre',
  configure.petsc_configure(configure_options)
Maruthi
On Tue, Sep 12, 2023 at 10:20 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Which version of hypre do you use?  I used petsc's --download-hypre, which
> automatically installed hypre-2.29.0. I did not see the error.
> $ ./heat_diff_cu -ksp_type gmres -pc_type hypre -pc_hypre_type boomeramg
> -use_gpu_aware_mpi 0 -mat_type aijcusparse -vec_type cuda
> The start and end indices of mat for each rank: 0       100
> Total time taken for KSP solve: rank: 0 0.0112464
> --Junchao Zhang
> On Tue, Sep 12, 2023 at 10:15 AM Maruthi NH <maruthinh at gmail.com> wrote:
>> Hi Junchao Zhang,
>> Thanks for the help. Updating PETSc fixed the problem. However, if I use
>> boomeramg from hypre as follows, I get a similar error.
>> ./heat_diff_cu --ksp_type gmres -pc_type hypre -pc_hypre_type boomeramg
>> ** On entry to cusparseCreateCsr() parameter number 5 (csrRowOffsets) had
>> an illegal value: NULL pointer
>> CUSPARSE ERROR (code = 3, invalid value) at csr_matrix_cuda_utils.c:57
>> Regards,
>> Maruthi
>> On Tue, Sep 12, 2023 at 1:09 AM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Hi, Maruthi,
>>>   I could run your example on my machine.  BTW,  I added these at the
>>> end of main() to free petsc objects.
>>> VecDestroy(&vout);
>>> VecDestroy(&x);
>>> VecDestroy(&b);
>>> VecDestroy(&u);
>>> MatDestroy(&A);
>>> VecScatterDestroy(&ctx);
>>> KSPDestroy(&ksp);
>>> If you use cuda-12.2, maybe the problem is already fixed by MR
>>> https://gitlab.com/petsc/petsc/-/merge_requests/6828
>>> You can use petsc/main branch to try.  Note your petsc version is from
>>> Date: 2023-08-13
>>> Thanks.
>>> --Junchao Zhang
>>> On Mon, Sep 11, 2023 at 12:10 PM Maruthi NH <maruthinh at gmail.com> wrote:
>>>> Hi Barry Smith,
>>>> Thanks for the quick response.
>>>> Here is the code I used to test PETSc on GPU.
>>>> This is the command I used to run
>>>> mpiexec.hydra -n 1 ./heat_diff_cu -Nx 10000000 -ksp_type gmres
>>>> -mat_type aijcusparse -vec_type cuda -use_gpu_aware_mpi 0 -pc_type gamg
>>>> -ksp_converged_reason
>>>> Regards,
>>>> Maruthi
>>>> On Sun, Sep 10, 2023 at 11:37 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>> On Sep 10, 2023, at 5:54 AM, Maruthi NH <maruthinh at gmail.com> wrote:
>>>>> Hi all,
>>>>> I am trying to accelerate the linear solver with PETSc GPU backend.
>>>>> For testing I have a simple 1D heat diffusion solver, here are some
>>>>> observations.
>>>>> 1. If I use -pc_type gamg it throws the following error
>>>>> had an illegal value: NULL pointer
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: GPU error
>>>>> [0]PETSC ERROR: cuSPARSE errorcode 3 (CUSPARSE_STATUS_INVALID_VALUE) :
>>>>> invalid value
>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>> shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>> v3.19.4-959-g92f1e92e88  GIT Date: 2023-08-13 19:43:04 +0000
>>>>>    Can you share the code that triggers this?
>>>>> 2. Default pc ilu takes about 1.2 seconds on a single CPU and it takes
>>>>> about 105.9 seconds on a GPU. Similar observations with pc_type asm
>>>>> I have NVIDIA RTX A2000 8GB Laptop GPU
>>>>>   This is expected. The triangular solves sequentialize on the GPU so
>>>>> naturally are extremely slow since they cannot take advantage of the
>>>>> massive parallelism of the GPU.
>>>>> 3. What I could be missing? Also, are there any general guidelines for
>>>>> better GPU performance using PETSc?
>>>>> Regards,
>>>>> Maruthi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230913/bf2d2a15/attachment.html>
