[petsc-users] Error while running with -pc_type gamg on NVIDIA GPU
Junchao Zhang junchao.zhang at gmail.com
Mon Sep 11 14:39:29 CDT 2023
Hi, Maruthi,
  I could run your example on my machine.  BTW,  I added these at the end
of main() to free petsc objects.
VecDestroy(&vout);
VecDestroy(&x);
VecDestroy(&b);
VecDestroy(&u);
MatDestroy(&A);
VecScatterDestroy(&ctx);
KSPDestroy(&ksp);
If you use cuda-12.2, maybe the problem is already fixed by MR
https://gitlab.com/petsc/petsc/-/merge_requests/6828
You can use petsc/main branch to try.  Note your petsc version is from
Date: 2023-08-13
Thanks.
--Junchao Zhang
On Mon, Sep 11, 2023 at 12:10 PM Maruthi NH <maruthinh at gmail.com> wrote:
> Hi Barry Smith,
> Thanks for the quick response.
> Here is the code I used to test PETSc on GPU.
> This is the command I used to run
> mpiexec.hydra -n 1 ./heat_diff_cu -Nx 10000000 -ksp_type gmres -mat_type
> aijcusparse -vec_type cuda -use_gpu_aware_mpi 0 -pc_type gamg
> -ksp_converged_reason
> Regards,
> Maruthi
> On Sun, Sep 10, 2023 at 11:37 PM Barry Smith <bsmith at petsc.dev> wrote:
>> On Sep 10, 2023, at 5:54 AM, Maruthi NH <maruthinh at gmail.com> wrote:
>> Hi all,
>> I am trying to accelerate the linear solver with PETSc GPU backend. For
>> testing I have a simple 1D heat diffusion solver, here are some
>> observations.
>> 1. If I use -pc_type gamg it throws the following error
>>  ** On entry to cusparseCreateCsr() parameter number 5 (csrRowOffsets)
>> had an illegal value: NULL pointer
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: GPU error
>> [0]PETSC ERROR: cuSPARSE errorcode 3 (CUSPARSE_STATUS_INVALID_VALUE) :
>> invalid value
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.19.4-959-g92f1e92e88
>>  GIT Date: 2023-08-13 19:43:04 +0000
>>    Can you share the code that triggers this?
>> 2. Default pc ilu takes about 1.2 seconds on a single CPU and it takes
>> about 105.9 seconds on a GPU. Similar observations with pc_type asm
>> I have NVIDIA RTX A2000 8GB Laptop GPU
>>   This is expected. The triangular solves sequentialize on the GPU so
>> naturally are extremely slow since they cannot take advantage of the
>> massive parallelism of the GPU.
>> 3. What I could be missing? Also, are there any general guidelines for
>> better GPU performance using PETSc?
>> Regards,
>> Maruthi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230911/a29cb6c6/attachment.html>
