[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Wed Sep 6 13:59:42 CDT 2023
I tried with different examples and all are working later.
As you said there may be a license issue.
I will try with latest matlab version.
Thanks and regards
Srinivas
On Thu, Sep 7, 2023, 00:24 Satish Balay <balay at mcs.anl.gov> wrote:
> I'm still curios why the first [c++] attempt failed but the second one
> succeeded.
> The only difference I can spot is myEngineApp.cpp vs myEngineApp2.cpp.
> What is the difference here between these 2 source files?
> Or is it some random error [the same source code worked failed before -
> but works now - and might fail again later?]
> Maybe there is some issue with matlab license here - that prevents some
> usages (or usage patterns) to fail?
> Satish
> On Wed, 6 Sep 2023, Barry Smith wrote:
> >    Ok, so the C++ binding for Matlab engine is working on your machine.
> PETSc uses the C binding which links against different libraries but, one
> would think the C binding would work for sure if the C++ binding works. Can
> you try a Matlab Engine C example provided by Matlab?
> > > On Sep 6, 2023, at 3:58 AM, INTURU SRINIVAS 20PHD0548 <
> inturu.srinivas2020 at vitstudent.ac.in> wrote:
> > > Hi Amneet,
> > > I repeated the same procedure again and this time it is working.
> > > $g++ -std=c++11 -I /usr/local/MATLAB/R2020b/extern/include/ -L
> /usr/local/MATLAB/R2020b/extern/bin/glnxa64/ -pthread myEngineApp2.cpp
> -lMatlabDataArray -lMatlabEngine
> $LD_LIBRARY_PATH=/usr/local/MATLAB/R2020b/extern/bin/glnxa64:/usr/local/MATLAB/R2020b/sys/os/glnxa64
> > > $export LD_LIBRARY_PATH
> > > $./a.out
> > > Square root of -2 is 0 + 1.41421i
> > > Square root of 2 is 1.41421 + 0i
> > > Square root of 6 is 2.44949 + 0i
> > > Square root of 8 is 2.82843 + 0i
> > > I don't know how it is working this time?
> > > Thanks and regards
> > > Srinivas
> > > On Wed, Sep 6, 2023 at 12:17 PM INTURU SRINIVAS 20PHD0548 <
> inturu.srinivas2020 at vitstudent.ac.in <mailto:
> inturu.srinivas2020 at vitstudent.ac.in>> wrote:
> > >> Hi Amneet,
> > >> I tried the following example to run a matlab engine.
> > >> #include "MatlabDataArray.hpp"
> > >> #include "MatlabEngine.hpp"
> > >> #include <iostream>
> > >> void callSQRT() {
> > >>     using namespace matlab::engine;
> > >>     // Start MATLAB engine synchronously
> > >>     std::unique_ptr<MATLABEngine> matlabPtr = startMATLAB();
> > >>     //Create MATLAB data array factory
> > >>     matlab::data::ArrayFactory factory;
> > >>     // Define a four-element typed array
> > >>     matlab::data::TypedArray<double> const argArray =
> > >>         factory.createArray({ 1,4 }, { -2.0, 2.0, 6.0, 8.0 });
> > >>     // Call MATLAB sqrt function on the data array
> > >>     matlab::data::Array const results = matlabPtr->feval(u"sqrt",
> argArray);
> > >>     // Display results
> > >>     for (int i = 0; i < results.getNumberOfElements(); i++) {
> > >>         double a = argArray[i];
> > >>         std::complex<double> v = results[i];
> > >>         double realPart = v.real();
> > >>         double imgPart = v.imag();
> > >>         std::cout << "Square root of " << a << " is " <<
> > >>             realPart << " + " << imgPart << "i" << std::endl;
> > >> int main() {
> > >>     callSQRT();
> > >>     return 0;
> /usr/local/MATLAB/R2020b/extern/bin/glnxa64/ -pthread myEngineApp.cpp
> > >> $./a.out
> > >> Starting
> > >> Error: The import statement 'import matlab.internal.engine.input'
> cannot be found or cannot be imported. Imported names must end with '.*' or
> be fully qualified.
> > >> terminate called after throwing an instance of
> 'matlab::engine::EngineException'
> > >>   what():  MATLAB process cannot be created.
> > >> Aborted (core dumped)
> > >> I got the above error for Matlab R2020b. Please help me to sort out
> this.
> > >> Thanks and regards
> > >> Srinivas
> > >> On Tue, Sep 5, 2023 at 11:39 PM Amneet Bhalla <mail2amneet at gmail.com
> <mailto:mail2amneet at gmail.com>> wrote:
> > >>> BTW, what Barry is suggesting is the following:
> > >>> Compile a sample code with a command line this:
> > >>> g++ -std=c++11 -I matlabroot/extern/include/ -L
> matlabroot/extern/bin/glnxa64/
> > >>>     -pthread myEngineApp.cpp -lMatlabDataArray -lMatlabEngine
> > >>> This command is provided here:
> https://www.mathworks.com/help/matlab/matlab_external/build-c-engine-programs.html
> > >>> A sample MATLAB code is here:
> https://www.mathworks.com/help/matlab/matlab_external/call-matlab-functions-from-c-1.html
> > >>> (You can just pick a few lines of code from here to create a
> barebone example)
> > >>> On Tue, Sep 5, 2023 at 11:02 AM Amneet Bhalla <mail2amneet at gmail.com
> > >>>> Srinivas --- Do you have a different version of MATLAB that you can
> install? If your organization has a MATLAB license, you can install recent
> versions of MATLAB from mathworks.com <http://mathworks.com/>
> > >>>> On Tue, Sep 5, 2023 at 10:37 AM Barry Smith <bsmith at petsc.dev
> <mailto:bsmith at petsc.dev>> wrote:
> > >>>>>    Ok, I have no suggestions. It seems to be more an issue with
> the Matlab than PETSc. You could find a pure Matlab example of using the
> engine (in the Matlab documentation) and try it to see if it works.
> > >>>>>    Barry
> > >>>>>> On Sep 5, 2023, at 12:27 PM, INTURU SRINIVAS 20PHD0548 <
> > >>>>>> I replaced e->ep = engOpen(buffer); with e->ep = engOpen("");
> > >>>>>> I got the same errors for petsc 3.17.5
> > >>>>>> make all
> > >>>>>>    CC linux-opt/obj/sys/classes/matlabengine/matlab.o
> > >>>>>>      CLINKER linux-opt/lib/libpetsc.so.3.17.5
> > >>>>>> BEGINNING TO COMPILE MATLAB INTERFACE
> > >>>>>> Building with 'gcc'.
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
> In function ‘PetscBinaryWrite’:
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
> warning: ‘err’ may be used uninitialized in this function
> [-Wmaybe-uninitialized]
> > >>>>>>   164 |   if (err < 0) PETSC_MEX_ERROR("Error writing to
> socket\n");
> > >>>>>> MEX completed successfully.
> socket\n");
> > >>>>>> Now to check if the libraries are working do:
> > >>>>>> make PETSC_DIR=/home/vit/sfw/petsc/3.17.5 PETSC_ARCH=linux-opt
> check
> > >>>>>> make test query=requires queryval=matlab
> DATAFILESPATH=/home/vit/datafiles/
> > >>>>>> Using MAKEFLAGS: -- DATAFILESPATH=/home/vit/datafiles/
> queryval=matlab query=requires
> > >>>>>>      CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
> > >>>>>>         TEST
> linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
> > >>>>>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 85
> > >>>>>> # [0]PETSC ERROR: --------------------- Error Message
> > >>>>>> # [0]PETSC ERROR: Error in external library
> > >>>>>> # [0]PETSC ERROR: Unable to start MATLAB engine with
> /usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash
> > >>>>>> # [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
> shooting.
> > >>>>>> # [0]PETSC ERROR: Petsc Release Version 3.17.5, Sep 30, 2022
> > >>>>>> # [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by
> vit Tue Sep  5 21:39:22 2023
> > >>>>>> # [0]PETSC ERROR: Configure options
> --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
> --with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
> --with-matlab-engine=1 -with-blaslapack-dir=/usr/local/MATLAB/R2020b
> --known-64-bit-blas-indices=1
> > >>>>>> # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() at
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:83
> > >>>>>> # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() at
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:332
> > >>>>>> # [0]PETSC ERROR: #3 PetscMatlabEnginePut() at
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:245
> > >>>>>> # [0]PETSC ERROR: #4 MatLUFactorNumeric_Matlab() at
> /home/vit/sfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
> > >>>>>> # [0]PETSC ERROR: #5 MatLUFactorNumeric() at
> /home/vit/sfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
> > >>>>>> # [0]PETSC ERROR: #6 PCSetUp_LU() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
> > >>>>>> # [0]PETSC ERROR: #7 PCSetUp() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
> > >>>>>> # [0]PETSC ERROR: #8 KSPSetUp() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
> > >>>>>> # [0]PETSC ERROR: #9 main() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
> > >>>>>> # [0]PETSC ERROR: PETSc Option Table entries:
> > >>>>>> # [0]PETSC ERROR: -check_pointer_intensity 0
> > >>>>>> # [0]PETSC ERROR: -error_output_stdout
> > >>>>>> # [0]PETSC ERROR: -f0 /home/vit/datafiles//matrices/arco1
> > >>>>>> # [0]PETSC ERROR: -malloc_dump
> > >>>>>> # [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
> > >>>>>> # [0]PETSC ERROR: -pc_type lu
> > >>>>>> # [0]PETSC ERROR: -use_gpu_aware_mpi 0
> > >>>>>> # [0]PETSC ERROR: ----------------End of Error Message
> -------send entire error message to petsc-maint at mcs.anl.gov----------
> > >>>>>> # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> > >>>>>> # with errorcode 85.
> > >>>>>> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
> processes.
> > >>>>>> # You may or may not see output from other processes, depending on
> > >>>>>> # exactly when Open MPI kills them.
> > >>>>>>  ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
> > >>>>>> # FAILED ksp_ksp_tutorials-ex72_12
> > >>>>>> # To rerun failed tests:
> > >>>>>> #     /usr/bin/make -f gmakefile test test-fail=1
> > >>>>>> Thanks and regards
> > >>>>>> Srinivas
> > >>>>>> On Tue, Sep 5, 2023 at 9:05 PM Barry Smith <bsmith at petsc.dev
> > >>>>>>>     The error is occuring during
> > >>>>>>> Since the direct launch of /usr/local/MATLAB/R2020b/bin/matlab
> -glnxa64 -nodisplay  -nosplash from your terminal shell worked we have to
> assume the problem is occuring when engOpen() is attempting to connect the
> stdout and stdin from the Matlab session that is launched to the
> executable.
> > >>>>>>> You can try the following. In 3.17.5 edit the file
> src/sys/classes/matlabengine/matlab.c and locate the line
> > >>>>>>> replace it with
> > >>>>>>> Now in the PETSc directory do make all (it should recompile one
> file) and then run the
> > >>>>>>> again
> > >>>>>>>> On Sep 5, 2023, at 3:39 AM, INTURU SRINIVAS 20PHD0548 via
> petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> wrote:
> > >>>>>>>> Hi Amneeth,
> > >>>>>>>> I think the errors are different with petsc 3.17.5
> > >>>>>>>> ./configure --CC=/usr/bin/mpicc --CXX=/usr/bin/mpicxx
> --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
> PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
> --with-blaslapack-dir=/usr/local/MATLAB/R2020b
> --known-64-bit-blas-indices=1 --with-matlab-engine=1
> > >>>>>>>> The version of PETSc you are using is out-of-date, we recommend
> updating to the new release
> > >>>>>>>>  Available Version: 3.19.5   Installed Version: 3.17.5
> > >>>>>>>> https://petsc.org/release/download/
> > >>>>>>>>                          Configuring PETSc to compile on your
> system
> > >>>>>>>> Compilers:
> > >>>>>>>>   C Compiler:         /usr/bin/mpicc  -fPIC -Wall
> -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch
> -fstack-protector -fvisibility=hidden -O3
> > >>>>>>>>     Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
> > >>>>>>>>   C++ Compiler:         /usr/bin/mpicxx  -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch
> -fstack-protector -fvisibility=hidden -O3  -std=gnu++17 -fPIC
> > >>>>>>>>     Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
> > >>>>>>>>   Fortran Compiler:         /usr/bin/mpif90  -fPIC -Wall
> -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3
> > >>>>>>>>     Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
> > >>>>>>>> Linkers:
> > >>>>>>>>   Shared linker:   /usr/bin/mpicc  -shared  -fPIC -Wall
> > >>>>>>>>   Dynamic linker:   /usr/bin/mpicc  -shared  -fPIC -Wall
> > >>>>>>>>   Libraries linked against:   -lquadmath -lstdc++ -ldl
> > >>>>>>>> BlasLapack:
> > >>>>>>>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64
> /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so -liomp5 -lpthread
> > >>>>>>>>   uses OpenMP; use export OMP_NUM_THREADS=<p> or
> -omp_num_threads <p> to control the number of threads
> > >>>>>>>>   uses 8 byte integers
> > >>>>>>>> MPI:
> > >>>>>>>>   Version:  3
> > >>>>>>>>   mpiexec: /usr/bin/mpiexec
> > >>>>>>>>   Implementation: openmpi
> > >>>>>>>>   OMPI_VERSION: 4.0.3
> > >>>>>>>> pthread:
> > >>>>>>>> cmake:
> > >>>>>>>>   Version:  3.16.3
> > >>>>>>>>   /usr/bin/cmake
> > >>>>>>>> regex:
> > >>>>>>>> Matlab:
> > >>>>>>>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
> > >>>>>>>> MatlabEngine:
> > >>>>>>>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/bin/glnxa64
> -L/usr/local/MATLAB/R2020b/bin/glnxa64
> -Wl,-rpath,/usr/local/MATLAB/R2020b/extern/lib/glnxa64
> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat
> -lmwm_dispatcher -lmwopcmodel -lmwservices -lmwopcmodel -lmwm_dispatcher
> -lmwmpath -lmwopcmodel -lmwservices -lmwopcmodel -lmwservices -lxerces-c
> > >>>>>>>>   Language used to compile PETSc: C
> > >>>>>>>> PETSc:
> > >>>>>>>>   PETSC_ARCH: linux-opt
> > >>>>>>>>   PETSC_DIR: /home/vit/ibamrsfw/petsc/3.17.5
> > >>>>>>>>   Prefix: <inplace installation>
> > >>>>>>>>   Scalar type: real
> > >>>>>>>>   Precision: double
> > >>>>>>>>   Support for __float128
> > >>>>>>>>   Integer size: 4 bytes
> > >>>>>>>>   Single library: yes
> > >>>>>>>>   Shared libraries: yes
> > >>>>>>>>   Memory alignment from malloc(): 16 bytes
> > >>>>>>>>   Using GNU make: /usr/bin/make
> xxx=========================================================================xxx
> > >>>>>>>>  Configure stage complete. Now build PETSc libraries with:
> > >>>>>>>>    make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5
> PETSC_ARCH=linux-opt all
> > >>>>>>>> $make
> > >>>>>>>> FC linux-opt/obj/tao/f90-mod/petsctaomod.o
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
> socket\n");
> socket\n");
> PETSC_ARCH=linux-opt check
> > >>>>>>>> $make test query=requires queryval=matlab
> > >>>>>>>> /usr/bin/python3
> /home/vit/ibamrsfw/petsc/3.17.5/config/gmakegentest.py
> --petsc-dir=/home/vit/ibamrsfw/petsc/3.17.5 --petsc-arch=linux-opt
> --testdir=./linux-opt/tests
> > >>>>>>>>           CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
> > >>>>>>>>         TEST
> trouble shooting.
> vit Tue Sep  5 10:15:57 2023
> > >>>>>>>> # [0]PETSC ERROR: Configure options --CC=/usr/bin/mpicc
> --CXX=/usr/bin/mpicxx --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
> FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:82
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:331
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:244
> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
> processes.
> on
> > >>>>>>>> To get the info of the error there is no specific probe id
> reported.
> > >>>>>>>> How to check error info and proceed further?
> > >>>>>>>> Thanks and regards
> > >>>>>>>> Srinivas
> > >>>>>>>> On Tue, Sep 5, 2023 at 1:08 AM Amneet Bhalla <
> mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
> > >>>>>>>>> Do you get similar errors with petsc 3.17.5 using the new
> configure options that Satish mentioned?
> > >>>>>>>>> On Sun, Sep 3, 2023 at 10:19 PM INTURU SRINIVAS 20PHD0548 via
> wrote:
> > >>>>>>>>>> Sorry for missing that.
> -nosplash
> > >>>>>>>>>>                             < M A T L A B (R) >
> > >>>>>>>>>>                   Copyright 1984-2020 The MathWorks, Inc.
> > >>>>>>>>>>               R2020b Update 3 (9.9.0.1538559) 64-bit (glnxa64)
> > >>>>>>>>>>                              November 23, 2020
> > >>>>>>>>>> To get started, type doc.
> > >>>>>>>>>> For product information, visit www.mathworks.com <
> http://www.mathworks.com/>.
> > >>>>>>>>>> Thanks and regards
> > >>>>>>>>>> Srinivas
> > >>>>>>>>>> On Mon, Sep 4, 2023 at 10:19 AM Satish Balay <
> balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>> wrote:
> > >>>>>>>>>>> You are missing one more step:
> > >>>>>>>>>>> > [0] PetscInitialize(): Running on machine: MB108SMEC028
> > >>>>>>>>>>> > [0] PetscMatlabEngineCreate(): Starting MATLAB engine with
> command /usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash
> > >>>>>>>>>>> No run matlab manually on "MB108SMEC028" with the command
> "/usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash"
> > >>>>>>>>>>> Does this work for you? As the message indicates this
> command is invoked by "matlab_ls_test" - and that is failing.
> > >>>>>>>>>>> Satish
> > >>>>>>>>>>> On Mon, 4 Sep 2023, INTURU SRINIVAS 20PHD0548 via
> petsc-users wrote:
> > >>>>>>>>>>> > Hi Sathish,
> > >>>>>>>>>>> > I tried the following procedure
> > >>>>>>>>>>> > *$make *
> > >>>>>>>>>>> > CLINKER linux-opt/lib/libpetsc.so.3.13.4
> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
> > >>>>>>>>>>> >   167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to
> socket\n");
> socket\n");
> > >>>>>>>>>>> > make PETSC_DIR=/home/vit/sfw/petsc/3.13.4
> > >>>>>>>>>>> > *$make test query=requires queryval=matlab
> > >>>>>>>>>>> > DATAFILESPATH=/home/vit/datafiles/*
> queryval=matlab
> > >>>>>>>>>>> > query=requires
> > >>>>>>>>>>> >         TEST
> > >>>>>>>>>>> > not ok ksp_ksp_tutorials-ex72_12 # Error code: 139
> > >>>>>>>>>>> > # [0]PETSC ERROR: Unable to start MATLAB engine on
> https://www.mcs.anl.gov/petsc/documentation/faq.html
> > >>>>>>>>>>> > for trouble shooting.
> > >>>>>>>>>>> > # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01,
> 2020
> MB108SMEC028 by vit Mon Sep
> > >>>>>>>>>>> >  4 10:02:32 2023
> COPTFLAGS=-O3
> --with-debugging=0
> > >>>>>>>>>>> > # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
> /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
> > >>>>>>>>>>> > # [0]PETSC ERROR: Petsc has generated inconsistent data
> > >>>>>>>>>>> > # [0]PETSC ERROR:
> 2020
> > >>>>>>>>>>> >  4 10:02:32 2023
> COPTFLAGS=-O3
> --with-debugging=0
> > >>>>>>>>>>> > # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() line 316 in
> > >>>>>>>>>>> > # [0]PETSC ERROR:
> > >>>>>>>>>>> > # [0]PETSC ERROR: Caught signal number 11 SEGV:
> Segmentation Violation,
> > >>>>>>>>>>> > probably memory access out of range
> > >>>>>>>>>>> > # [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > >>>>>>>>>>> > # [0]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > >>>>>>>>>>> > # [0]PETSC ERROR: or try http://valgrind.org <
> http://valgrind.org/> on GNU/linux and Apple Mac OS
> > >>>>>>>>>>> > X to find memory corruption errors
> > >>>>>>>>>>> > # [0]PETSC ERROR: configure using --with-debugging=yes,
> recompile, link,
> > >>>>>>>>>>> > and run
> > >>>>>>>>>>> > # [0]PETSC ERROR: to get more information on the crash.
> > >>>>>>>>>>> > # [0]PETSC ERROR: Signal received
> 2020
> > >>>>>>>>>>> >  4 10:02:32 2023
> COPTFLAGS=-O3
> --with-debugging=0
> > >>>>>>>>>>> > # [0]PETSC ERROR: #3 User provided function() line 0 in
> unknown file
> MPI_COMM_WORLD
> > >>>>>>>>>>> > # with errorcode 50162059.
> processes.
> depending on
> diff
> > >>>>>>>>>>> >           CC
> linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
> > >>>>>>>>>>> >      CLINKER
> > >>>>>>>>>>> >         TEST
> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
> > >>>>>>>>>>> > not ok tao_leastsquares_tutorials_matlab-matlab_ls_test #
> Error code: 124
> > >>>>>>>>>>> > # Running problem 5
> 2020
> > >>>>>>>>>>> > # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named
> MB108SMEC028 by
> > >>>>>>>>>>> > vit Mon Sep  4 10:02:34 2023
> COPTFLAGS=-O3
> --with-debugging=0
> > >>>>>>>>>>> > # [0]PETSC ERROR: #2 main() line 126 in
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
> > >>>>>>>>>>> > # [0]PETSC ERROR: -prob_id 5
> > >>>>>>>>>>> > # [0]PETSC ERROR: -tao_smonitor
> -------send entire
> MPI_COMM_SELF
> > >>>>>>>>>>> > # with errorcode 126076.
> processes.
> depending on
> SKIP Command failed
> > >>>>>>>>>>> > so no diff
> > >>>>>>>>>>> > #   Summary
> > >>>>>>>>>>> > # success 0/2 tests (0.0%)
> > >>>>>>>>>>> > # failed 2/2 tests (100.0%)
> > >>>>>>>>>>> > # todo 0/2 tests (0.0%)
> > >>>>>>>>>>> > # skip 0/2 tests (0.0%)
> > >>>>>>>>>>> > # Wall clock time for tests: 4 sec
> > >>>>>>>>>>> > # Approximate CPU time (not incl. build time): 0.03 sec
> > >>>>>>>>>>> > # Timing summary (actual test time / total CPU time):
> > >>>>>>>>>>> > #   ksp_ksp_tutorials-ex72_12: 0.01 sec / 0.02 sec
> > >>>>>>>>>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.01
> sec / 0.01 sec
> > >>>>>>>>>>> > *$cd src/tao/leastsquares/tutorials/matlab/*
> > >>>>>>>>>>> > *$make matlab_ls_test*
> > >>>>>>>>>>> > /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall
> -Wwrite-strings
> > >>>>>>>>>>> > -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
> > >>>>>>>>>>> > -fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings
> > >>>>>>>>>>> > -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden
> -O3
> > >>>>>>>>>>> >  -I/home/vit/sfw/petsc/3.13.4/include
> > >>>>>>>>>>> > -I/home/vit/sfw/petsc/3.13.4/linux-opt/include
> > >>>>>>>>>>> > -I/home/vit/sfw/linux/openmpi/4.1.4/include
> matlab_ls_test.c
> > >>>>>>>>>>> >  -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
> > >>>>>>>>>>> > -L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
> > >>>>>>>>>>> > -Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
> > >>>>>>>>>>> > -L/home/vit/sfw/linux/openmpi/4.1.4/lib
> > >>>>>>>>>>> > -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
> > >>>>>>>>>>> > -L/usr/lib/gcc/x86_64-linux-gnu/9
> -Wl,-rpath,/usr/lib/x86_64-linux-gnu
> > >>>>>>>>>>> > -L/usr/lib/x86_64-linux-gnu
> -Wl,-rpath,/lib/x86_64-linux-gnu
> > >>>>>>>>>>> > -L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm
> -leng -lmex -lmx
> > >>>>>>>>>>> > -lmat -lstdc++ -ldl -lmpi_usempif08
> -lmpi_usempi_ignore_tkr -lmpi_mpifh
> > >>>>>>>>>>> > -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
> -lpthread -lquadmath
> > >>>>>>>>>>> > -lstdc++ -ldl -o matlab_ls_test
> > >>>>>>>>>>> > *$LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5
> ./matlab_ls_test
> > >>>>>>>>>>> >  -tao_smonitor -prob_id 5 -info*
> > >>>>>>>>>>> > [0] PetscInitialize(): PETSc successfully started: number
> of processors = 1
> > >>>>>>>>>>> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
> > >>>>>>>>>>> > MB108SMEC028.(none)
> > >>>>>>>>>>> > Running problem 5
> > >>>>>>>>>>> > [0] PetscCommDuplicate(): Duplicating a communicator
> 140155238476992
> > >>>>>>>>>>> > 94202473157392 max tags = 2147483647
> command
> -nosplash
> > >>>>>>>>>>> > [0]PETSC ERROR: See
> > >>>>>>>>>>> > [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
> > >>>>>>>>>>> > [0]PETSC ERROR: ./matlab_ls_test on a linux-opt named
> MB108SMEC028 by vit
> > >>>>>>>>>>> > Mon Sep  4 10:09:56 2023
> COPTFLAGS=-O3
> --with-debugging=0
> > >>>>>>>>>>> > [0]PETSC ERROR: #2 main() line 126 in matlab_ls_test.c
> > >>>>>>>>>>> > [0]PETSC ERROR: -info
> -------send entire
> MPI_COMM_SELF
> processes.
> depending on
> > >>>>>>>>>>> > Please find the attachment for configure.log and make.log
> files
> > >>>>>>>>>>> > On Sun, Sep 3, 2023 at 8:00 PM Satish Balay <
> > >>>>>>>>>>> > > To use datafiles in the test suite:
> > >>>>>>>>>>> > > cd $HOME
> > >>>>>>>>>>> > > git clone https://gitlab.com/petsc/datafiles
> > >>>>>>>>>>> > > <configure should now pick up this location and set
> DATAFILESPATH - or set
> > >>>>>>>>>>> > > manually with make>
> DATAFILESPATH=$HOME/datafiles
> > >>>>>>>>>>> > > Satish
> > >>>>>>>>>>> > > On Sun, 3 Sep 2023, Matthew Knepley wrote:
> > >>>>>>>>>>> > > > On Sun, Sep 3, 2023 at 8:47 AM INTURU SRINIVAS
> 20PHD0548 <
> > >>>>>>>>>>> > > > > Hi Matthew,
> > >>>>>>>>>>> > > > > I am using PETSc to simulate the problems using
> IBAMR. I do not have
> > >>>>>>>>>>> > > any
> > >>>>>>>>>>> > > > > separate test files to test PETSc alone. Can you
> please help me how to
> > >>>>>>>>>>> > > > > define this DATAFILESPATH?
> > >>>>>>>>>>> > > > That test you tried uses a certain matrix. On our
> machine, we point to
> > >>>>>>>>>>> > > this
> > >>>>>>>>>>> > > > matrix using an environment variable, DATAFILESPATH.
> You don't have those
> > >>>>>>>>>>> > > > matrices, since they are just for testing here. That
> > >>>>>>>>>>> > > > is why I suggested just using a different matrix, or
> running a problem
> > >>>>>>>>>>> > > you
> > >>>>>>>>>>> > > > care about in IBAMR.
> > >>>>>>>>>>> > > >   Thanks,
> > >>>>>>>>>>> > > >      Matt
> > >>>>>>>>>>> > > > > Thanks and regards
> > >>>>>>>>>>> > > > > Srinivas.
> > >>>>>>>>>>> > > > > On Sun, Sep 3, 2023 at 6:06 PM Matthew Knepley <
> knepley at gmail.com <mailto:knepley at gmail.com>>
> > >>>>>>>>>>> > > wrote:
> > >>>>>>>>>>> > > > >> On Sun, Sep 3, 2023 at 3:04 AM INTURU SRINIVAS
> 20PHD0548 via
> > >>>>>>>>>>> > > petsc-users <
> petsc-users at mcs.anl.gov>> wrote:
> > >>>>>>>>>>> > > > >>> Hi Sathish,
> > >>>>>>>>>>> > > > >>> Thank you so much for your efforts and the support
> you are giving me
> > >>>>>>>>>>> > > to
> > >>>>>>>>>>> > > > >>> sort this out.
> > >>>>>>>>>>> > > > >>> I tried to follow the same procedure which you
> followed to build
> > >>>>>>>>>>> > > Petsc
> > >>>>>>>>>>> > > > >>> 3.13.4 with Matlab-R2020b on Ubuntu20.04.
> > >>>>>>>>>>> > > > >>> *$./configure
> --with-matlab-engine=1*
> > >>>>>>>>>>> > > > >>> Using python3 for Python
> system
> > >>>>>>>>>>> > > > >>>                                         It appears
> you do not have
> > >>>>>>>>>>> > > valgrind
> > >>>>>>>>>>> > > > >>> installed on your system.
> > >>>>>>>>>>> > > > >>>   We HIGHLY recommend you install it from
> www.valgrind.org <http://www.valgrind.org/>
> > >>>>>>>>>>> > > > >>>                                              Or
> install
> > >>>>>>>>>>> > > valgrind-devel or
> > >>>>>>>>>>> > > > >>> equivalent using your package manager.
> > >>>>>>>>>>> > > > >>>           Then rerun ./configure
> > >>>>>>>>>>> > > > >>>                                   Compilers:
> > >>>>>>>>>>> > > > >>>   C Compiler:
> > >>>>>>>>>>> > > -fPIC
> > >>>>>>>>>>> > > > >>> -Wall -Wwrite-strings -Wno-strict-aliasing
> 9.4.0
> > >>>>>>>>>>> > > > >>>   C++ Compiler:
>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
> > >>>>>>>>>>> > > > >>> -fstack-protector -fvisibility=hidden -O3  -fPIC
> 11.4.0
> > >>>>>>>>>>> > > > >>>   Fortran Compiler:
>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
> > >>>>>>>>>>> > > > >>>  -fPIC -Wall -ffree-line-length-0
> > >>>>>>>>>>> > > > >>> Linkers:
> > >>>>>>>>>>> > > > >>>   Shared linker:
> > >>>>>>>>>>> > > -shared
> > >>>>>>>>>>> > > > >>>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
> > >>>>>>>>>>> > > > >>>   Dynamic linker:
> > >>>>>>>>>>> > > -shared
> -ldl
> > >>>>>>>>>>> > > > >>> make:
> > >>>>>>>>>>> > > > >>>   Version:  4.2
> > >>>>>>>>>>> > > > >>>   /usr/bin/make
> > >>>>>>>>>>> > > > >>> BlasLapack:
> > >>>>>>>>>>> > > > >>>   Library:
> > >>>>>>>>>>> > > > >>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5
> -lpthread
> -omp_num_threads
> > >>>>>>>>>>> > > <p> to
> > >>>>>>>>>>> > > > >>> MPI:
> > >>>>>>>>>>> > > > >>>   Version:  3
> > >>>>>>>>>>> > > > >>>   Includes:
> > >>>>>>>>>>> > > > >>>   Mpiexec:
> /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec
> > >>>>>>>>>>> > > --oversubscribe
> > >>>>>>>>>>> > > > >>>   OMPI_VERSION: 4.1.4
> > >>>>>>>>>>> > > > >>> pthread:
> > >>>>>>>>>>> > > > >>> cmake:
> > >>>>>>>>>>> > > > >>>   Version:  3.16.3
> > >>>>>>>>>>> > > > >>>   /usr/bin/cmake
> > >>>>>>>>>>> > > > >>> regex:
> > >>>>>>>>>>> > > > >>> Matlab:
> > >>>>>>>>>>> > > > >>>   Includes:
> > >>>>>>>>>>> > > > >>> MatlabEngine:
> > >>>>>>>>>>> > > > >>>   Library:
> > >>>>>>>>>>> > > -lut
> > >>>>>>>>>>> > > > >>> -licudata -licui18n -licuuc
> > >>>>>>>>>>> > > > >>> PETSc:
> > >>>>>>>>>>> > > > >>>   PETSC_DIR: /home/vit/sfw/petsc/3.13.4
> > >>>>>>>>>>> > > > >>>   Scalar type: real
> > >>>>>>>>>>> > > > >>>   Precision: double
> > >>>>>>>>>>> > > > >>>   shared libraries: enabled
> libraries with:
> > >>>>>>>>>>> > > > >>> Then I removed all occurrences of -lut -licudata
> -licui18n -licuuc as
> > >>>>>>>>>>> > > > >>> you suggested earlier.
> > >>>>>>>>>>> > > > >>> *$make*
> function
> writing to socket\n");
> function
> > >>>>>>>>>>> > > > >>> *$make test query=requires queryval=matlab*
> > >>>>>>>>>>> > > > >>> Using MAKEFLAGS: -- queryval=matlab query=requires
> > >>>>>>>>>>> > > > >>>           CC
> > >>>>>>>>>>> > > > >>>         TEST
> > >>>>>>>>>>> > > > >>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
> Message
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: Unable to open file
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: Cannot locate file:
> /matrices/arco1
> > >>>>>>>>>>> > > > >> No, the problem is that you do not have
> DATAFILESPATH defined, so it
> > >>>>>>>>>>> > > > >> cannot find the matrix to test. Try running some
> test of yours.
> > >>>>>>>>>>> > > > >>   Thanks,
> > >>>>>>>>>>> > > > >>      Matt
> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> > >>>>>>>>>>> > > > >>> shooting.
> Aug 01, 2020
> MB108SMEC028 by vit
> > >>>>>>>>>>> > > Sun
> > >>>>>>>>>>> > > > >>> Sep  3 11:51:03 2023
> COPTFLAGS=-O3
> --with-debugging=0
> > >>>>>>>>>>> > > > >>> --with-x=0
> PetscViewerFileSetUp_BinarySTDIO() line 1444 in
> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: #2 PetscViewerSetUp_Binary()
> line 1511 in
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
> /home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: #5 MatLoad() line 1225 in
> /home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: #6 main() line 113 in
> /home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
> > >>>>>>>>>>> > > > >>> # [0]PETSC ERROR: -f0 /matrices/arco1
> Message -------send
> MPI_COMM_SELF
> > >>>>>>>>>>> > > > >>> # with errorcode 113065.
> all MPI processes.
> failed so no diff
> > >>>>>>>>>>> > > > >>>           CC
> > >>>>>>>>>>> > > > >>>      CLINKER
> > >>>>>>>>>>> > > > >>>         TEST
> > >>>>>>>>>>> > > > >>> not ok
> tao_leastsquares_tutorials_matlab-matlab_ls_test # Error
> > >>>>>>>>>>> > > code: 124
> > >>>>>>>>>>> > > > >>> # Running problem 5
> Message
**Disclaimer:*
This message was sent from Vellore Institute of Technology.
The contents of this email may contain legally protected confidential or
privileged information of “Vellore Institute of Technology”.  If you are
not the intended recipient, you should not disseminate, distribute or copy
this e-mail. Please notify the sender immediately and destroy all copies of
this message and any attachments. If you have received this email in error,
please promptly notify the sender by reply email and delete the original
email and any backup copies without reading them.*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230907/11ac0e28/attachment-0001.html>
