[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Wed Sep 6 01:47:29 CDT 2023
Hi Amneet,
I tried the following example to run a matlab engine.
#include "MatlabDataArray.hpp"
#include "MatlabEngine.hpp"
#include <iostream>
void callSQRT() {
    using namespace matlab::engine;
    // Start MATLAB engine synchronously
    std::unique_ptr<MATLABEngine> matlabPtr = startMATLAB();
    //Create MATLAB data array factory
    matlab::data::ArrayFactory factory;
    // Define a four-element typed array
    matlab::data::TypedArray<double> const argArray =
        factory.createArray({ 1,4 }, { -2.0, 2.0, 6.0, 8.0 });
    // Call MATLAB sqrt function on the data array
    matlab::data::Array const results = matlabPtr->feval(u"sqrt", argArray);
    // Display results
    for (int i = 0; i < results.getNumberOfElements(); i++) {
        double a = argArray[i];
        std::complex<double> v = results[i];
        double realPart = v.real();
        double imgPart = v.imag();
        std::cout << "Square root of " << a << " is " <<
            realPart << " + " << imgPart << "i" << std::endl;
int main() {
    callSQRT();
    return 0;
*$g++ -std=c++11 -I /usr/local/MATLAB/R2020b/extern/include/ -L
/usr/local/MATLAB/R2020b/extern/bin/glnxa64/ -pthread myEngineApp.cpp
-lMatlabDataArray -lMatlabEngine*
*$LD_LIBRARY_PATH=/usr/local/MATLAB/R2020b/extern/bin/glnxa64:/usr/local/MATLAB/R2020b/sys/os/glnxa64*
*$export LD_LIBRARY_PATH*
*$./a.out*
Starting
Error: The import statement 'import matlab.internal.engine.input' cannot be
found or cannot be imported. Imported names must end with '.*' or be fully
qualified.
terminate called after throwing an instance of
'matlab::engine::EngineException'
  what():  MATLAB process cannot be created.
Aborted (core dumped)
I got the above error for Matlab R2020b. Please help me to sort out this.
Thanks and regards
Srinivas
On Tue, Sep 5, 2023 at 11:39 PM Amneet Bhalla <mail2amneet at gmail.com> wrote:
> BTW, what Barry is suggesting is the following:
> Compile a sample code with a command line this:
> g++ -std=c++11 -I *matlabroot*/extern/include/ -L *matlabroot*/extern/bin/glnxa64/
>     -pthread myEngineApp.cpp -lMatlabDataArray -lMatlabEngine
> This command is provided here:
> https://www.mathworks.com/help/matlab/matlab_external/build-c-engine-programs.html
> A sample MATLAB code is here:
> https://www.mathworks.com/help/matlab/matlab_external/call-matlab-functions-from-c-1.html
> (You can just pick a few lines of code from here to create a barebone example)
> On Tue, Sep 5, 2023 at 11:02 AM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
>> Srinivas --- Do you have a different version of MATLAB that you can
>> install? If your organization has a MATLAB license, you can install recent
>> versions of MATLAB from mathworks.com
>> On Tue, Sep 5, 2023 at 10:37 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>    Ok, I have no suggestions. It seems to be more an issue with the
>>> Matlab than PETSc. You could find a pure Matlab example of using the engine
>>> (in the Matlab documentation) and try it to see if it works.
>>>    Barry
>>> On Sep 5, 2023, at 12:27 PM, INTURU SRINIVAS 20PHD0548 <
>>> inturu.srinivas2020 at vitstudent.ac.in> wrote:
>>> I replaced e->ep = engOpen(buffer); with e->ep = engOpen("");
>>> I got the same errors for petsc 3.17.5
>>> *make all*
>>>    CC linux-opt/obj/sys/classes/matlabengine/matlab.o
>>>      CLINKER linux-opt/lib/libpetsc.so.3.17.5
>>> BEGINNING TO COMPILE MATLAB INTERFACE
>>> Building with 'gcc'.
>>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>> In function ‘PetscBinaryWrite’:
>>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
>>> warning: ‘err’ may be used uninitialized in this function
>>> [-Wmaybe-uninitialized]
>>>   164 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
>>> MEX completed successfully.
>>> Now to check if the libraries are working do:
>>> make PETSC_DIR=/home/vit/sfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
>>> *make test query=requires queryval=matlab
>>> DATAFILESPATH=/home/vit/datafiles/*
>>> Using MAKEFLAGS: -- DATAFILESPATH=/home/vit/datafiles/ queryval=matlab
>>> query=requires
>>>      CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
>>>         TEST linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
>>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 85
>>> # [0]PETSC ERROR: --------------------- Error Message
>>> # [0]PETSC ERROR: Error in external library
>>> # [0]PETSC ERROR: Unable to start MATLAB engine with
>>> /usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash
>>> # [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>> shooting.
>>> # [0]PETSC ERROR: Petsc Release Version 3.17.5, Sep 30, 2022
>>> # [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by vit Tue
>>> Sep  5 21:39:22 2023
>>> # [0]PETSC ERROR: Configure options
>>> --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
>>> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
>>> --with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
>>> --with-matlab-engine=1 -with-blaslapack-dir=/usr/local/MATLAB/R2020b
>>> --known-64-bit-blas-indices=1
>>> # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() at
>>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:83
>>> # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() at
>>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:332
>>> # [0]PETSC ERROR: #3 PetscMatlabEnginePut() at
>>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:245
>>> # [0]PETSC ERROR: #4 MatLUFactorNumeric_Matlab() at
>>> /home/vit/sfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
>>> # [0]PETSC ERROR: #5 MatLUFactorNumeric() at
>>> /home/vit/sfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
>>> # [0]PETSC ERROR: #6 PCSetUp_LU() at
>>> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
>>> # [0]PETSC ERROR: #7 PCSetUp() at
>>> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
>>> # [0]PETSC ERROR: #8 KSPSetUp() at
>>> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
>>> # [0]PETSC ERROR: #9 main() at
>>> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
>>> # [0]PETSC ERROR: PETSc Option Table entries:
>>> # [0]PETSC ERROR: -check_pointer_intensity 0
>>> # [0]PETSC ERROR: -error_output_stdout
>>> # [0]PETSC ERROR: -f0 /home/vit/datafiles//matrices/arco1
>>> # [0]PETSC ERROR: -malloc_dump
>>> # [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
>>> # [0]PETSC ERROR: -pc_type lu
>>> # [0]PETSC ERROR: -use_gpu_aware_mpi 0
>>> # [0]PETSC ERROR: ----------------End of Error Message -------send
>>> entire error message to petsc-maint at mcs.anl.gov----------
>>> # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>> # with errorcode 85.
>>> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> # You may or may not see output from other processes, depending on
>>> # exactly when Open MPI kills them.
>>>  ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
>>> # FAILED ksp_ksp_tutorials-ex72_12
>>> # To rerun failed tests:
>>> #     /usr/bin/make -f gmakefile test test-fail=1
>>> Thanks and regards
>>> Srinivas
>>> On Tue, Sep 5, 2023 at 9:05 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>     The error is occuring during
>>>> Since the direct launch of /usr/local/MATLAB/R2020b/bin/matlab -glnxa64
>>>> -nodisplay  -nosplash from your terminal shell worked we have to assume the
>>>> problem is occuring when engOpen() is attempting to connect the stdout and
>>>> stdin from the Matlab session that is launched to the executable.
>>>> You can try the following. In 3.17.5 edit the
>>>> file src/sys/classes/matlabengine/matlab.c and locate the line
>>>> replace it with
>>>> Now in the PETSc directory do make all (it should recompile one file)
>>>> and then run the
>>>> again
>>>> On Sep 5, 2023, at 3:39 AM, INTURU SRINIVAS 20PHD0548 via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hi Amneeth,
>>>> I think the errors are different with petsc 3.17.5
>>>> *./configure --CC=/usr/bin/mpicc --CXX=/usr/bin/mpicxx
>>>> --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
>>>> PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
>>>> --with-blaslapack-dir=/usr/local/MATLAB/R2020b
>>>> --known-64-bit-blas-indices=1 --with-matlab-engine=1*
>>>> The version of PETSc you are using is out-of-date, we recommend
>>>> updating to the new release
>>>>  Available Version: 3.19.5   Installed Version: 3.17.5
>>>> https://petsc.org/release/download/
>>>>                          Configuring PETSc to compile on your system
>>>> Compilers:
>>>>   C Compiler:         /usr/bin/mpicc  -fPIC -Wall -Wwrite-strings
>>>> -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector
>>>> -fvisibility=hidden -O3
>>>>     Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>>   C++ Compiler:         /usr/bin/mpicxx  -Wall -Wwrite-strings
>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch
>>>> -fstack-protector -fvisibility=hidden -O3  -std=gnu++17 -fPIC
>>>>     Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
>>>>   Fortran Compiler:         /usr/bin/mpif90  -fPIC -Wall
>>>> -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3
>>>>     Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>> Linkers:
>>>>   Shared linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>>>>   Dynamic linker:   /usr/bin/mpicc  -shared  -fPIC -Wall
>>>> -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch
>>>>   Libraries linked against:   -lquadmath -lstdc++ -ldl
>>>> BlasLapack:
>>>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
>>>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64
>>>> /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so -liomp5 -lpthread
>>>>   uses OpenMP; use export OMP_NUM_THREADS=<p> or -omp_num_threads <p>
>>>> to control the number of threads
>>>>   uses 8 byte integers
>>>> MPI:
>>>>   Version:  3
>>>>   mpiexec: /usr/bin/mpiexec
>>>>   Implementation: openmpi
>>>>   OMPI_VERSION: 4.0.3
>>>> pthread:
>>>> cmake:
>>>>   Version:  3.16.3
>>>>   /usr/bin/cmake
>>>> regex:
>>>> Matlab:
>>>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
>>>> MatlabEngine:
>>>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/bin/glnxa64
>>>> -L/usr/local/MATLAB/R2020b/bin/glnxa64
>>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>>> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat
>>>> -lmwm_dispatcher -lmwopcmodel -lmwservices -lmwopcmodel -lmwm_dispatcher
>>>> -lmwmpath -lmwopcmodel -lmwservices -lmwopcmodel -lmwservices -lxerces-c
>>>>   Language used to compile PETSc: C
>>>> PETSc:
>>>>   PETSC_ARCH: linux-opt
>>>>   PETSC_DIR: /home/vit/ibamrsfw/petsc/3.17.5
>>>>   Prefix: <inplace installation>
>>>>   Scalar type: real
>>>>   Precision: double
>>>>   Support for __float128
>>>>   Integer size: 4 bytes
>>>>   Single library: yes
>>>>   Shared libraries: yes
>>>>   Memory alignment from malloc(): 16 bytes
>>>>   Using GNU make: /usr/bin/make
>>>> xxx=========================================================================xxx
>>>>  Configure stage complete. Now build PETSc libraries with:
>>>>    make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt
>>>> all
>>>> *$make*
>>>> FC linux-opt/obj/tao/f90-mod/petsctaomod.o
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
>>>> check
>>>> *$make test query=requires queryval=matlab
>>>> /usr/bin/python3 /home/vit/ibamrsfw/petsc/3.17.5/config/gmakegentest.py
>>>> --petsc-dir=/home/vit/ibamrsfw/petsc/3.17.5 --petsc-arch=linux-opt
>>>> --testdir=./linux-opt/tests
>>>> query=requires
>>>>           CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
>>>> shooting.
>>>> Sep  5 10:15:57 2023
>>>> # [0]PETSC ERROR: Configure options --CC=/usr/bin/mpicc
>>>> --CXX=/usr/bin/mpicxx --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
>>>> FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:82
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:331
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:244
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
>>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
>>>> To get the info of the error there is no specific probe id reported.
>>>> How to check error info and proceed further?
>>>> Thanks and regards
>>>> Srinivas
>>>> On Tue, Sep 5, 2023 at 1:08 AM Amneet Bhalla <mail2amneet at gmail.com>
>>>> wrote:
>>>>> Do you get similar errors with petsc 3.17.5 using the new configure
>>>>> options that Satish mentioned?
>>>>> On Sun, Sep 3, 2023 at 10:19 PM INTURU SRINIVAS 20PHD0548 via
>>>>> petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>>>> Sorry for missing that.
>>>>>> */usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash*
>>>>>>                             < M A T L A B (R) >
>>>>>>                   Copyright 1984-2020 The MathWorks, Inc.
>>>>>>               R2020b Update 3 (9.9.0.1538559) 64-bit (glnxa64)
>>>>>>                              November 23, 2020
>>>>>> To get started, type doc.
>>>>>> For product information, visit www.mathworks.com.
>>>>>> Thanks and regards
>>>>>> Srinivas
>>>>>> On Mon, Sep 4, 2023 at 10:19 AM Satish Balay <balay at mcs.anl.gov>
>>>>>> wrote:
>>>>>>> You are missing one more step:
>>>>>>> > [0] PetscInitialize(): Running on machine: MB108SMEC028
>>>>>>> > [0] PetscMatlabEngineCreate(): Starting MATLAB engine with command
>>>>>>> No run matlab manually on "MB108SMEC028" with the command
>>>>>>> "/usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash"
>>>>>>> Does this work for you? As the message indicates this command is
>>>>>>> invoked by "matlab_ls_test" - and that is failing.
>>>>>>> Satish
>>>>>>> On Mon, 4 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
>>>>>>> > Hi Sathish,
>>>>>>> > I tried the following procedure
>>>>>>> > *$make *
>>>>>>> > CLINKER linux-opt/lib/libpetsc.so.3.13.4
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>>>>> >   167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to
>>>>>>> socket\n");
>>>>>>> socket\n");
>>>>>>> > make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt
>>>>>>> check
>>>>>>> queryval=matlab
>>>>>>> > query=requires
>>>>>>> >         TEST
>>>>>>> > not ok ksp_ksp_tutorials-ex72_12 # Error code: 139
>>>>>>> > # [0]PETSC ERROR: Unable to start MATLAB engine on
>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>>> > for trouble shooting.
>>>>>>> > # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
>>>>>>> Mon Sep
>>>>>>> >  4 10:02:32 2023
>>>>>>> --with-debugging=0
>>>>>>> > # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
>>>>>>> > /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
>>>>>>> > # [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>>>> > # [0]PETSC ERROR:
>>>>>>> Mon Sep
>>>>>>> >  4 10:02:32 2023
>>>>>>> --with-debugging=0
>>>>>>> > # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() line 316 in
>>>>>>> > # [0]PETSC ERROR:
>>>>>>> > # [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation,
>>>>>>> > probably memory access out of range
>>>>>>> > # [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> -on_error_attach_debugger
>>>>>>> > # [0]PETSC ERROR: or see
>>>>>>> > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>> > # [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>> Apple Mac OS
>>>>>>> > X to find memory corruption errors
>>>>>>> > # [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>>>>> link,
>>>>>>> > and run
>>>>>>> > # [0]PETSC ERROR: to get more information on the crash.
>>>>>>> > # [0]PETSC ERROR: Signal received
>>>>>>> Mon Sep
>>>>>>> >  4 10:02:32 2023
>>>>>>> --with-debugging=0
>>>>>>> > # [0]PETSC ERROR: #3 User provided function() line 0 in  unknown
>>>>>>> file
>>>>>>> > # with errorcode 50162059.
>>>>>>> processes.
>>>>>>> >           CC
>>>>>>> > linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
>>>>>>> >      CLINKER
>>>>>>> >         TEST
>>>>>>> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>>>>> > not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error
>>>>>>> code: 124
>>>>>>> > # Running problem 5
>>>>>>> > # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named
>>>>>>> MB108SMEC028 by
>>>>>>> > vit Mon Sep  4 10:02:34 2023
>>>>>>> --with-debugging=0
>>>>>>> > # [0]PETSC ERROR: #2 main() line 126 in
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
>>>>>>> > # [0]PETSC ERROR: -prob_id 5
>>>>>>> > # [0]PETSC ERROR: -tao_smonitor
>>>>>>> entire
>>>>>>> > # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>>>>>>> > # with errorcode 126076.
>>>>>>> processes.
>>>>>>> >  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP
>>>>>>> Command failed
>>>>>>> > so no diff
>>>>>>> > #   Summary
>>>>>>> > # success 0/2 tests (0.0%)
>>>>>>> > # failed 2/2 tests (100.0%)
>>>>>>> > # todo 0/2 tests (0.0%)
>>>>>>> > # skip 0/2 tests (0.0%)
>>>>>>> > # Wall clock time for tests: 4 sec
>>>>>>> > # Approximate CPU time (not incl. build time): 0.03 sec
>>>>>>> > # Timing summary (actual test time / total CPU time):
>>>>>>> > #   ksp_ksp_tutorials-ex72_12: 0.01 sec / 0.02 sec
>>>>>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.01 sec /
>>>>>>> 0.01 sec
>>>>>>> > *$cd src/tao/leastsquares/tutorials/matlab/*
>>>>>>> > *$make matlab_ls_test*
>>>>>>> > /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall
>>>>>>> -Wwrite-strings
>>>>>>> > -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>>>> > -fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings
>>>>>>> > -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
>>>>>>> >  -I/home/vit/sfw/petsc/3.13.4/include
>>>>>>> > -I/home/vit/sfw/petsc/3.13.4/linux-opt/include
>>>>>>> > -I/home/vit/sfw/linux/openmpi/4.1.4/include      matlab_ls_test.c
>>>>>>> >  -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>>>>> > -L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>>>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>>>>>> > -Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>>>>> > -L/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>>>>> > -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
>>>>>>> > -L/usr/lib/gcc/x86_64-linux-gnu/9
>>>>>>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>>>>>>> > -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>>>>>>> > -L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm -leng -lmex
>>>>>>> -lmx
>>>>>>> > -lmat -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr
>>>>>>> -lmpi_mpifh
>>>>>>> > -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread
>>>>>>> -lquadmath
>>>>>>> > -lstdc++ -ldl -o matlab_ls_test
>>>>>>> > *$LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5
>>>>>>> ./matlab_ls_test
>>>>>>> >  -tao_smonitor -prob_id 5 -info*
>>>>>>> > [0] PetscInitialize(): PETSc successfully started: number of
>>>>>>> processors = 1
>>>>>>> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
>>>>>>> > MB108SMEC028.(none)
>>>>>>> > Running problem 5
>>>>>>> > [0] PetscCommDuplicate(): Duplicating a communicator
>>>>>>> 140155238476992
>>>>>>> > 94202473157392 max tags = 2147483647
>>>>>>> > [0]PETSC ERROR: See
>>>>>>> > [0]PETSC ERROR: ./matlab_ls_test on a linux-opt named MB108SMEC028
>>>>>>> by vit
>>>>>>> > Mon Sep  4 10:09:56 2023
>>>>>>> --with-debugging=0
>>>>>>> > [0]PETSC ERROR: #2 main() line 126 in matlab_ls_test.c
>>>>>>> > [0]PETSC ERROR: -info
>>>>>>> entire
>>>>>>> > Please find the attachment for configure.log and make.log files
>>>>>>> > On Sun, Sep 3, 2023 at 8:00 PM Satish Balay <balay at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>> > > To use datafiles in the test suite:
>>>>>>> > > cd $HOME
>>>>>>> > > git clone https://gitlab.com/petsc/datafiles
>>>>>>> > > <configure should now pick up this location and set
>>>>>>> DATAFILESPATH - or set
>>>>>>> > > manually with make>
>>>>>>> DATAFILESPATH=$HOME/datafiles
>>>>>>> > > Satish
>>>>>>> > > On Sun, 3 Sep 2023, Matthew Knepley wrote:
>>>>>>> > > > On Sun, Sep 3, 2023 at 8:47 AM INTURU SRINIVAS 20PHD0548 <
>>>>>>> > > > > Hi Matthew,
>>>>>>> > > > > I am using PETSc to simulate the problems using IBAMR. I do
>>>>>>> not have
>>>>>>> > > any
>>>>>>> > > > > separate test files to test PETSc alone. Can you please help
>>>>>>> me how to
>>>>>>> > > > > define this DATAFILESPATH?
>>>>>>> > > > That test you tried uses a certain matrix. On our machine, we
>>>>>>> point to
>>>>>>> > > this
>>>>>>> > > > matrix using an environment variable, DATAFILESPATH. You don't
>>>>>>> have those
>>>>>>> > > > matrices, since they are just for testing here. That
>>>>>>> > > > is why I suggested just using a different matrix, or running a
>>>>>>> problem
>>>>>>> > > you
>>>>>>> > > > care about in IBAMR.
>>>>>>> > > >   Thanks,
>>>>>>> > > >      Matt
>>>>>>> > > > > Thanks and regards
>>>>>>> > > > > Srinivas.
>>>>>>> > > > > On Sun, Sep 3, 2023 at 6:06 PM Matthew Knepley <
>>>>>>> knepley at gmail.com>
>>>>>>> > > wrote:
>>>>>>> > > > >> On Sun, Sep 3, 2023 at 3:04 AM INTURU SRINIVAS 20PHD0548 via
>>>>>>> > > petsc-users <
>>>>>>> > > > >>> Hi Sathish,
>>>>>>> > > > >>> Thank you so much for your efforts and the support you are
>>>>>>> giving me
>>>>>>> > > to
>>>>>>> > > > >>> sort this out.
>>>>>>> > > > >>> I tried to follow the same procedure which you followed to
>>>>>>> build
>>>>>>> > > Petsc
>>>>>>> > > > >>> 3.13.4 with Matlab-R2020b on Ubuntu20.04.
>>>>>>> > > > >>> *$./configure
>>>>>>> > > > >>> Using python3 for Python
>>>>>>> > > > >>>                                         It appears you do
>>>>>>> not have
>>>>>>> > > valgrind
>>>>>>> > > > >>> installed on your system.
>>>>>>> > > > >>>   We HIGHLY recommend you install it from www.valgrind.org
>>>>>>> > > > >>>                                              Or install
>>>>>>> > > valgrind-devel or
>>>>>>> > > > >>> equivalent using your package manager.
>>>>>>> > > > >>>           Then rerun ./configure
>>>>>>> > > > >>>                                   Compilers:
>>>>>>> > > > >>>   C Compiler:
>>>>>>> > > -fPIC
>>>>>>> > > > >>> -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>>> > > > >>>   C++ Compiler:
>>>>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>>>>> > > > >>> -fstack-protector -fvisibility=hidden -O3  -fPIC
>>>>>>> > > > >>>   Fortran Compiler:
>>>>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>>>>> > > > >>>  -fPIC -Wall -ffree-line-length-0
>>>>>>> 9.4.0
>>>>>>> > > > >>> Linkers:
>>>>>>> > > > >>>   Shared linker:
>>>>>>> > > -shared
>>>>>>> > > > >>>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>>> > > > >>>   Dynamic linker:
>>>>>>> > > -shared
>>>>>>> > > > >>> make:
>>>>>>> > > > >>>   Version:  4.2
>>>>>>> > > > >>>   /usr/bin/make
>>>>>>> > > > >>> BlasLapack:
>>>>>>> > > > >>>   Library:  /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so
>>>>>>> > > > >>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5 -lpthread
>>>>>>> -omp_num_threads
>>>>>>> > > <p> to
>>>>>>> > > > >>> MPI:
>>>>>>> > > > >>>   Version:  3
>>>>>>> > > > >>>   Includes: -I/home/vit/sfw/linux/openmpi/4.1.4/include
>>>>>>> > > > >>>   Mpiexec: /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec
>>>>>>> > > --oversubscribe
>>>>>>> > > > >>>   OMPI_VERSION: 4.1.4
>>>>>>> > > > >>> pthread:
>>>>>>> > > > >>> cmake:
>>>>>>> > > > >>>   Version:  3.16.3
>>>>>>> > > > >>>   /usr/bin/cmake
>>>>>>> > > > >>> regex:
>>>>>>> > > > >>> Matlab:
>>>>>>> > > > >>> MatlabEngine:
>>>>>>> > > > >>>   Library:
>>>>>>> -lmx -lmat
>>>>>>> > > -lut
>>>>>>> > > > >>> -licudata -licui18n -licuuc
>>>>>>> > > > >>> PETSc:
>>>>>>> > > > >>>   PETSC_DIR: /home/vit/sfw/petsc/3.13.4
>>>>>>> > > > >>>   Scalar type: real
>>>>>>> > > > >>>   Precision: double
>>>>>>> > > > >>>   shared libraries: enabled
>>>>>>> PETSC_ARCH=linux-opt all
>>>>>>> > > > >>> Then I removed all occurrences of -lut -licudata -licui18n
>>>>>>> -licuuc as
>>>>>>> > > > >>> you suggested earlier.
>>>>>>> > > > >>> *$make*
>>>>>>> socket\n");
>>>>>>> socket\n");
>>>>>>> > > > >>> *$make test query=requires queryval=matlab*
>>>>>>> > > > >>> Using MAKEFLAGS: -- queryval=matlab query=requires
>>>>>>> > > > >>>         TEST
>>>>>>> > > > >>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
>>>>>>> > > > >>> # [0]PETSC ERROR: Unable to open file
>>>>>>> > > > >>> # [0]PETSC ERROR: Cannot locate file: /matrices/arco1
>>>>>>> > > > >> No, the problem is that you do not have DATAFILESPATH
>>>>>>> defined, so it
>>>>>>> > > > >> cannot find the matrix to test. Try running some test of
>>>>>>> yours.
>>>>>>> > > > >>   Thanks,
>>>>>>> > > > >>      Matt
>>>>>>> > > > >>> https://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>>>>> trouble
>>>>>>> > > > >>> shooting.
>>>>>>> 2020
>>>>>>> MB108SMEC028 by vit
>>>>>>> > > Sun
>>>>>>> > > > >>> Sep  3 11:51:03 2023
>>>>>>> COPTFLAGS=-O3
>>>>>>> --with-debugging=0
>>>>>>> > > > >>> # [0]PETSC ERROR: #1 PetscViewerFileSetUp_BinarySTDIO()
>>>>>>> line 1444 in
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
>>>>>>> > > > >>> # [0]PETSC ERROR: #2 PetscViewerSetUp_Binary() line 1511 in
>>>>>>> > > > >>> # [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
>>>>>>> > > > >>> # [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
>>>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
>>>>>>> > > > >>> # [0]PETSC ERROR: #5 MatLoad() line 1225 in
>>>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
>>>>>>> > > > >>> # [0]PETSC ERROR: #6 main() line 113 in
>>>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
>>>>>>> > > > >>> # [0]PETSC ERROR: -f0 /matrices/arco1
>>>>>>> -------send
>>>>>>> MPI_COMM_SELF
>>>>>>> > > > >>> # with errorcode 113065.
>>>>>>> processes.
>>>>>>> depending on
>>>>>>> diff
>>>>>>> > > > >>>           CC
>>>>>>> > > > >>>      CLINKER
>>>>>>> > > > >>>         TEST
>>>>>>> Error
>>>>>>> > > code: 124
>>>>>>> > > > >>> # Running problem 5
>>>>>>> trouble
>>>>>>> > > > >>> shooting.
>>>>>>> 2020
>>>>>>> > > MB108SMEC028 by
>>>>>>> > > > >>> vit Sun Sep  3 11:51:05 2023
>>>>>>> COPTFLAGS=-O3
>>>>>>> --with-debugging=0
>>>>>>> -------send
>>>>>>> MPI_COMM_SELF
>>>>>>> processes.
>>>>>>> depending on
>>>>>>> SKIP Command
>>>>>>> > > > >>> failed so no diff
>>>>>>> > > > >>> #   Summary
>>>>>>> > > > >>> # Wall clock time for tests: 3 sec
>>>>>>> > > > >>> # Approximate CPU time (not incl. build time): 0.05 sec
>>>>>>> > > > >>> #   ksp_ksp_tutorials-ex72_12: 0.02 sec / 0.03 sec
>>>>>>> > > > >>> #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.02
>>>>>>> sec /
>>>>>>> > > 0.02 sec
>>>>>>> > > > >>> *How to sort out this error?*
>>>>>>> > > -Wwrite-strings
>>>>>>> -O3
>>>>>>> matlab_ls_test.c
>>>>>>> -leng -lmex
>>>>>>> > > -lmx
>>>>>>> > > -lmpi_mpifh
>>>>>>> -lpthread
>>>>>>> > > -lquadmath
>>>>>>> > > > >>> I think there is a problem with the Matlab-R2020b version.
>>>>>>> > > > >>> I am sharing the configure.log and make.log files. Please
>>>>>>> find the
>>>>>>> > > > >>> attachment and do the needful.
>>>>>>> > > > >>> Thanks and regards
>>>>>>> > > > >>> Srinivas
>>>>>>> > > > >>> On Sat, Sep 2, 2023 at 11:15 PM Satish Balay <
>>>>>>> > > wrote:
>>>>>>> > > > >>>> Perhaps you can try the following to get additional info
>>>>>>> - and debug
>>>>>>> > > > >>>> Satish
>>>>>>> > > > >>>> balay at compute-386-07:/scratch/balay/petsc$ cd
>>>>>>> > > :/scratch/balay/petsc/src/tao/leastsquares/tutorials/matlab$
>>>>>>> > > > >>>> make matlab_ls_test
>>>>>>> > > > >>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc
>>>>>>> -fPIC
>>>>>>> > > -Wall
>>>>>>> > > > >>>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>>>>>>> > > -fstack-protector
>>>>>>> > > > >>>> -I/scratch/balay/petsc/include
>>>>>>> > > -I/scratch/balay/petsc/linux-opt/include
>>>>>>> -I/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/include
>>>>>>> > > > >>>> -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
>>>>>>> > > > >>>> matlab_ls_test.c
>>>>>>> -Wl,-rpath,/scratch/balay/petsc/linux-opt/lib
>>>>>>> > > > >>>> -L/scratch/balay/petsc/linux-opt/lib
>>>>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64
>>>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>>>>> -Wl,-rpath,/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>>>>> > > > >>>> -L/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>>>>> > > > >>>> -L/lib/x86_64-linux-gnu -lpetsc -llapack -lblas -lpthread
>>>>>>> -lm -leng
>>>>>>> > > -lmex
>>>>>>> > > > >>>> -lmx -lmat -lut -licudata -licui18n -licuuc -lstdc++ -ldl
>>>>>>> -lmpifort
>>>>>>> > > -lmpi
>>>>>>> > > > >>>> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++
>>>>>>> -ldl -o
>>>>>>> > > > >>>> matlab_ls_test
>>>>>>> ./matlab_ls_test
>>>>>>> of
>>>>>>> > > processors
>>>>>>> > > > >>>> = 1
>>>>>>> NIS
>>>>>>> > > > >>>> compute-386-07.(none)
>>>>>>> > > > >>>> [0] PetscInitialize(): Running on machine: compute-386-07
>>>>>>> > > > >>>> Running problem 5
>>>>>>> 1140850689
>>>>>>> > > > >>>> -2080374784 max tags = 268435455
>>>>>>> with command
>>>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/matlab
>>>>>>> > > > >>>> [0] PetscMatlabEngineCreate(): Started MATLAB engine
>>>>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Evaluating MATLAB string:
>>>>>>> > > > >>>> TestingInitialize
>>>>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Done evaluating Matlab
>>>>>>> string:
>>>>>>> > > > >>>> TestingInitialize
>>>>>>> > > > >>>> 5
>>>>>>> > > > >>>> <snip>
>>>>>>> > > > >>>> <<<< Now verify if the above matlab command actually
>>>>>>> works for you
>>>>>>> > > - on
>>>>>>> > > > >>>> this machine..>>>>>
>>>>>>> > > > >>>>                                    < M A T L A B (R) >
>>>>>>> > > > >>>>                          Copyright 1984-2021 The
>>>>>>> MathWorks, Inc.
>>>>>>> > > > >>>>                          R2021a (9.10.0.1602886) 64-bit
>>>>>>> (glnxa64)
>>>>>>> > > > >>>>                                     February 17, 2021
>>>>>>> > > > >>>> On Sat, 2 Sep 2023, Satish Balay via petsc-users wrote:
>>>>>>> > > > >>>> > Please don't cc: both petsc-users and petsc-maint
>>>>>>> [reverting
>>>>>>> > > thread
>>>>>>> > > > >>>> to petsc-users only]
>>>>>>> > > > >>>> > I'm not sure what is happening here. Can you send the
>>>>>>> > > corresponding
>>>>>>> > > > >>>> configure.log, make.log [compressed]?
>>>>>>> > > > >>>> > Here is my attempt to reproduce (with petsc-3.13) on
>>>>>>> Ubuntu-20.04,
>>>>>>> > > > >>>> with Matlab-R2021a - and that works:
>>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ git branch
>>>>>>> > > > >>>> >   main
>>>>>>> > > > >>>> >   release
>>>>>>> > > > >>>> > * release-3.13
>>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ module load
>>>>>>> > > matlab/R2021a
>>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ which matlab
>>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ ./configure
>>>>>>> --with-mpi-dir=/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/
>>>>>>> --with-matlab-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>>>>> --with-blaslapack-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>>>>> > > > >>>> > <snip>
>>>>>>> > > > >>>> > Compilers:
>>>>>>> > > > >>>> >   C Compiler:
>>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc  -fPIC
>>>>>>> > > -Wall
>>>>>>> > > -fstack-protector
>>>>>>> > > > >>>> >   C++ Compiler:
>>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicxx  -Wall
>>>>>>> > > -fstack-protector
>>>>>>> > > > >>>> >     Version: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>>>>> > > > >>>> >   Fortran Compiler:
>>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpif90  -fPIC
>>>>>>> > > -Wall
>>>>>>> > > > >>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>>> > > > >>>> > Linkers:
>>>>>>> > > > >>>> >   Shared linker:
>>>>>>> > > -shared  -fPIC
>>>>>>> > > > >>>> >   Dynamic linker:
>>>>>>> > > -shared  -fPIC
>>>>>>> > > > >>>> > make:
>>>>>>> > > > >>>> >   Version:  4.2
>>>>>>> > > > >>>> >   /usr/bin/make
>>>>>>> > > > >>>> > BlasLapack:
>>>>>>> > > > >>>> >   Library:
>>>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64/mkl.so
>>>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64
>>>>>>> > > > >>>> -liomp5 -lpthread
>>>>>>> -omp_num_threads
>>>>>>> > > <p>
>>>>>>> > > > >>>> > MPI:
>>>>>>> > > > >>>> >   Version:  4
>>>>>>> > > > >>>> >   Includes:
>>>>>>> > > > >>>> >   Mpiexec:
>>>>>>> > > /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpiexec
>>>>>>> > > > >>>> >   MPICH_NUMVERSION: 40002300
>>>>>>> > > > >>>> > pthread:
>>>>>>> > > > >>>> >   Library:  -lpthread
>>>>>>> > > > >>>> > cmake:
>>>>>>> > > > >>>> >   Version:  3.16.3
>>>>>>> > > > >>>> >   /usr/bin/cmake
>>>>>>> > > > >>>> > regex:
>>>>>>> > > > >>>> > Matlab:
>>>>>>> > > > >>>> >   Includes:
>>>>>>> > > > >>>> > MatlabEngine:
>>>>>>> > > > >>>> >   Library:
>>>>>>> > > > >>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>>>> > > > >>>> > sowing:
>>>>>>> > > > >>>> >   Version:  1.1.25
>>>>>>> > > > >>>> >   /scratch/balay/petsc/linux-opt/bin/bfort
>>>>>>> > > > >>>> > valgrind:
>>>>>>> > > > >>>> > PETSc:
>>>>>>> > > > >>>> >   PETSC_DIR: /scratch/balay/petsc
>>>>>>> > > > >>>> >   Scalar type: real
>>>>>>> > > > >>>> >   Precision: double
>>>>>>> with:
>>>>>>> > > > >>>> >    make PETSC_DIR=/scratch/balay/petsc
>>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make
>>>>>>> > > > >>>> > <snip>
>>>>>>> > > > >>>> >      CLINKER linux-opt/lib/libpetsc.so.3.13.6
>>>>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c: In
>>>>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>>>>> > > socket\n");
>>>>>>> > > socket\n");
>>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make test
>>>>>>> > > query=requires
>>>>>>> > > > >>>> queryval=matlab
>>>>>>> > > > >>>> >         TEST
>>>>>>> > > > >>>> > #     ../ex72:
>>>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64/libgfortran.so.5:
>>>>>>> > > > >>>> version `GFORTRAN_9' not found (required by
>>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib/libmpifort.so.12)
>>>>>>> no diff
>>>>>>> > > > >>>> >           CC
>>>>>>> > > > >>>> >      CLINKER
>>>>>>> > > > >>>> >         TEST
>>>>>>> # Error
>>>>>>> > > code:
>>>>>>> > > > >>>> 1
>>>>>>> > > > >>>> > #     ../matlab_ls_test:
>>>>>>> SKIP
>>>>>>> > > Command
>>>>>>> > > > >>>> failed so no diff
>>>>>>> > > > >>>> > <snip>
>>>>>>> > > > >>>> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 make
>>>>>>> test
>>>>>>> > > query=requires
>>>>>>> > > > >>>> queryval=matlab
>>>>>>> > > > >>>> >         TEST
>>>>>>> > > > >>>> >  ok diff-ksp_ksp_tutorials-ex72_12
>>>>>>> > > > >>>> >         TEST
>>>>>>> > > > >>>> >  ok
>>>>>>> diff-tao_leastsquares_tutorials_matlab-matlab_ls_test
>>>>>>> > > > >>>> > #   Summary
>>>>>>> > > > >>>> > # success 4/4 tests (100.0%)
>>>>>>> > > > >>>> > # failed 0/4 tests (0.0%)
>>>>>>> > > > >>>> > # todo 0/4 tests (0.0%)
>>>>>>> > > > >>>> > # skip 0/4 tests (0.0%)
>>>>>>> > > > >>>> > # Wall clock time for tests: 27 sec
>>>>>>> 15.190000000000001
>>>>>>> > > sec
>>>>>>> 6.47 sec /
>>>>>>> > > 7.54
>>>>>>> > > > >>>> sec
>>>>>>> > > > >>>> > #   ksp_ksp_tutorials-ex72_12: 6.46 sec / 7.65 sec
>>>>>>> > > > >>>> > On Sat, 2 Sep 2023, INTURU SRINIVAS 20PHD0548 wrote:
>>>>>>> > > > >>>> > > Based on the suggestions given by Sathish, I have
>>>>>>> tried to
>>>>>>> > > > >>>> configure petsc
>>>>>>> > > > >>>> > > 3.13.4 with Matlab-R2020b. But, it was not
>>>>>>> successful. After
>>>>>>> > > > >>>> running make
>>>>>>> > > > >>>> > > -j 10 test command I have got the following error
>>>>>>> message.
>>>>>>> > > > >>>> > > not ok
>>>>>>> > > > >>>> code: 124
>>>>>>> > > > >>>> > > # Running problem 5
>>>>>>> 01, 2020
>>>>>>> named
>>>>>>> > > > >>>> MB108SMEC028 by
>>>>>>> > > > >>>> > > vit Sat Sep  2 12:27:22 2023
>>>>>>> COPTFLAGS=-O3
>>>>>>> > > > >>>> --with-debugging=0
>>>>>>> 67 in
>>>>>>> > > -------send
>>>>>>> > > > >>>> entire
>>>>>>> MPI_COMM_SELF
>>>>>>> all MPI
>>>>>>> > > > >>>> processes.
>>>>>>> depending
>>>>>>> > > on
>>>>>>> > > > >>>> > > I request you to help me to sort out this error.
>>>>>>> > > > >>>> > > Thanks
>>>>>>> > > > >>>> > > Srinivas
>>>>>>> > > > >>>> > > On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <
>>>>>>> > > > >>>> > > > I think there should be two hyphens in
>>>>>>> > > > >>>> > > > i.e.:
>>>>>>> > > > >>>> > > > On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS
>>>>>>> 20PHD0548 via
>>>>>>> > > > >>>> petsc-users <
>>>>>>> > > > >>>> > > >> Thank you Sathish.I will try this
>>>>>>> > > > >>>> > > >> On Fri, Sep 1, 2023, 22:53 Satish Balay <
>>>>>>> > > > >>>> wrote:
>>>>>>> > > > >>>> > > >>> yes [and remove fblaslapack. don't know if hypre
>>>>>>> will work
>>>>>>> > > > >>>> here].
>>>>>>> > > > >>>> > > >>> i.e:
>>>>>>> > > > >>>> > > >>> ./configure
>>>>>>> > > > >>>> > > >>> --with-debugging=0 --with-x=0 \
>>>>>>> > > > >>>> > > >>> Satish
>>>>>>> > > > >>>> > > >>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via
>>>>>>> > > petsc-users
>>>>>>> > > > >>>> wrote:
>>>>>>> > > > >>>> > > >>> > Hi Satish,
>>>>>>> > > > >>>> > > >>> > -with-blaslapack-dir=/path/to/matlab_dir
>>>>>>> > > > >>>> > > >>> > Is this what you are suggesting?
>>>>>>> > > > >>>> > > >>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <
>>>>>>> > > > >>>> wrote:
>>>>>>> > > > >>>> > > >>> > > Also:
>>>>>>> > > > >>>> > > >>> > >     '-known-64-bit-blas-indices=1',
>>>>>>> > > > >>>> > > >>> > > Note: most externalpackages might not work in
>>>>>>> this mode.
>>>>>>> > > > >>>> > > >>> > > [we can't really over come such
>>>>>>> dependency/conflicts
>>>>>>> > > across
>>>>>>> > > > >>>> packages]
>>>>>>> > > > >>>> > > >>> > > Satish
>>>>>>> > > > >>>> > > >>> > > On Fri, 1 Sep 2023, Satish Balay via
>>>>>>> petsc-users wrote:
>>>>>>> > > > >>>> > > >>> > > > Here is the matlab test that runs in CI
>>>>>>> https://gitlab.com/petsc/petsc/-/jobs/4904566768
>>>>>>> config/examples/arch-ci-linux-matlab-ilp64.py
>>>>>>> > > > >>>> > > >>> > > > # Note: regular BLAS [with 32-bit integers]
>>>>>>> conflict
>>>>>>> > > with
>>>>>>> > > > >>>> > > >>> > > > # MATLAB BLAS - hence requiring
>>>>>>> > > > >>>> > > >>> > > > Ah - so you need to use the ilp64
>>>>>>> blas/lapack with
>>>>>>> > > > >>>> matlab  - to
>>>>>>> > > > >>>> > > >>> have a
>>>>>>> > > > >>>> > > >>> > > compatible build
>>>>>>> > > > >>>> > > >>> > > >     '--with-blaslapack-dir='+matlab_dir,
>>>>>>> > > > >>>> > > >>> > > > Satish
>>>>>>> 20PHD0548 via
>>>>>>> > > > >>>> petsc-users
>>>>>>> > > > >>>> > > >>> wrote:
>>>>>>> > > > >>>> > > >>> > > > > Hi Amneet,
>>>>>>> > > > >>>> > > >>> > > > > Without libmesh, even for PETSc with
>>>>>>> MATLAB is not
>>>>>>> > > > >>>> working. It is
>>>>>>> > > > >>>> > > >>> > > showing
>>>>>>> > > > >>>> > > >>> > > > > error for both 3.13.4 and 3.17.5 versions.
>>>>>>> > > > >>>> > > >>> > > > > I am trying to install IBAMR in HPC
>>>>>>> cluster with
>>>>>>> > > > >>>> libmesh and
>>>>>>> > > > >>>> > > >>> this is
>>>>>>> > > > >>>> > > >>> > > for
>>>>>>> > > > >>>> > > >>> > > > > general usage not only for WEC. This I
>>>>>>> tried without
>>>>>>> > > > >>>> linking
>>>>>>> > > > >>>> > > >>> Matlab
>>>>>>> > > > >>>> > > >>> > > with
>>>>>>> > > > >>>> > > >>> > > > > PETSc. Here also I got the error while
>>>>>>> configuring
>>>>>>> > > > >>>> libmesh 1.6.2
>>>>>>> > > > >>>> > > >>> that
>>>>>>> > > > >>>> > > >>> > > PETSc
>>>>>>> > > > >>>> > > >>> > > > > was not found but --enable-petsc-required
>>>>>>> is
>>>>>>> > > specified.
>>>>>>> > > > >>>> > > >>> > > > > The reason for specifically asking for
>>>>>>> libmesh with
>>>>>>> > > > >>>> PETSc and
>>>>>>> > > > >>>> > > >>> Matlab
>>>>>>> > > > >>>> > > >>> > > is in
>>>>>>> > > > >>>> > > >>> > > > > the cfd-mpc-wecs application for
>>>>>>> complicated
>>>>>>> > > geometries
>>>>>>> > > > >>>> it is
>>>>>>> > > > >>>> > > >>> > > mentioned to
>>>>>>> > > > >>>> > > >>> > > > > build cfd-mpc-wecs with libmesh construct.
>>>>>>> > > > >>>> > > >>> > > > > For the past 10 days I am trying these
>>>>>>> various
>>>>>>> > > things
>>>>>>> > > > >>>> and ended
>>>>>>> > > > >>>> > > >>> up with
>>>>>>> > > > >>>> > > >>> > > > > errors.
>>>>>>> > > > >>>> > > >>> > > > > I want to solve this and proceed further
>>>>>>> to do my
>>>>>>> > > > >>>> research work.
>>>>>>> > > > >>>> > > >>> > > > > Please help me to solve this as soon as
>>>>>>> possible.
>>>>>>> > > > >>>> > > >>> > > > > Thanks and Regards
>>>>>>> > > > >>>> > > >>> > > > > Srinivas
>>>>>>> > > > >>>> > > >>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <
>>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>>> > > > >>>> > > >>> > > > > > Hi Srinivas,
>>>>>>> > > > >>>> > > >>> > > > > > As discussed earlier you don’t need
>>>>>>> libMesh for
>>>>>>> > > the
>>>>>>> > > > >>>> WEC
>>>>>>> > > > >>>> > > >>> application.
>>>>>>> > > > >>>> > > >>> > > You
>>>>>>> > > > >>>> > > >>> > > > > > can just work with PETSc 3.17.5 that
>>>>>>> builds with
>>>>>>> > > > >>>> Matlab.
>>>>>>> > > > >>>> > > >>> > > > > > Do you have a specific reason for
>>>>>>> wanting to build
>>>>>>> > > > >>>> libMesh?
>>>>>>> > > > >>>> > > >>> > > > > > Thanks,
>>>>>>> > > > >>>> > > >>> > > > > > —Amneet
>>>>>>> > > > >>>> > > >>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU
>>>>>>> SRINIVAS
>>>>>>> > > > >>>> 20PHD0548 via
>>>>>>> > > > >>>> > > >>> > > petsc-users
>>>>>>> > > > >>>> > > >>> > > > > >> Hi,
>>>>>>> > > > >>>> > > >>> > > > > >> I ran "make all" for petsc 3.13.4 by
>>>>>>> removing all
>>>>>>> > > > >>>> occurrences
>>>>>>> > > > >>>> > > >>> of
>>>>>>> > > > >>>> > > >>> > > "-lut
>>>>>>> > > > >>>> > > >>> > > > > >> -licudata -licui18n -licuuc". When I
>>>>>>> ran "make
>>>>>>> > > test"
>>>>>>> > > > >>>> got the
>>>>>>> > > > >>>> > > >>> > > following
>>>>>>> > > > >>>> > > >>> > > > > >> errors
>>>>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-debug:
>>>>>>> > > > >>>> > > >>> > > > > >> TEST
>>>>>>> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>>>>> > > > >>>> > > >>> > > > > >> not ok
>>>>>>> > > > >>>> > > >>> Error
>>>>>>> > > > >>>> > > >>> > > code: 124
>>>>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>>>>> > > > >>>> > > >>> > > > > >> # [0]PETSC ERROR:
>>>>>>> > > Message
>>>>>>> library
>>>>>>> MATLAB engine
>>>>>>> > > on
>>>>>>> > > > >>>> for
>>>>>>> > > > >>>> > > >>> trouble
>>>>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>>>>> Version 3.13.4,
>>>>>>> > > Aug
>>>>>>> > > > >>>> 01, 2020
>>>>>>> a
>>>>>>> > > linux-debug
>>>>>>> > > > >>>> named
>>>>>>> > > > >>>> > > >>> > > MB108SMEC028
>>>>>>> > > > >>>> > > >>> > > > > >> by vit Fri Sep  1 10:01:11 2023
>>>>>>> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>>>>>> > > --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>>>>> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>>>>> > > > >>>> > > >>> --with-debugging=1
>>>>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1
>>>>>>> --download-fblaslapack=1
>>>>>>> > > > >>>> --with-x=0
>>>>>>> --with-matlab-dir=/usr/local/MATLAB/R2020b/
>>>>>>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
>>>>>>> > > line
>>>>>>> > > > >>>> 67 in
>>>>>>> entries:
>>>>>>> of Error
>>>>>>> > > > >>>> Message
>>>>>>> > > > >>>> > > >>> -------send
>>>>>>> > > > >>>> > > >>> > > entire
>>>>>>> > > > >>>> > > >>> > > > > >> error message to
>>>>>>> communicator
>>>>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>>>>> MPI to
>>>>>>> > > kill
>>>>>>> > > > >>>> all MPI
>>>>>>> > > > >>>> > > >>> > > processes.
>>>>>>> other
>>>>>>> > > processes,
>>>>>>> > > > >>>> > > >>> depending on
>>>>>>> > > > >>>> > > >>> > > > > >>  ok
>>>>>>> > > > >>>> # SKIP
>>>>>>> > > > >>>> > > >>> Command
>>>>>>> > > > >>>> > > >>> > > > > >> failed so no diff
>>>>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-opt
>>>>>>> > > > >>>> > > >>> > > > > >>  TEST
>>>>>>> > > > >>>> > > >>> > > > > >> not ok
>>>>>>> > > > >>>> > > >>> Error
>>>>>>> > > > >>>> > > >>> > > code: 124
>>>>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>>>>> > > > >>>> > > >>> > > > > >> # [0]PETSC ERROR:
>>>>>>> > > Message
>>>>>>> library
>>>>>>> MATLAB engine
>>>>>>> > > on
>>>>>>> > > > >>>> for
>>>>>>> > > > >>>> > > >>> trouble
>>>>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>>>>> Version 3.13.4,
>>>>>>> > > Aug
>>>>>>> > > > >>>> 01, 2020
>>>>>>> a
>>>>>>> > > linux-opt
>>>>>>> > > > >>>> named
>>>>>>> > > > >>>> > > >>> > > MB108SMEC028 by
>>>>>>> > > > >>>> > > >>> > > > > >> vit Fri Sep  1 10:34:12 2023
>>>>>>> > > > >>>> > > >>> --COPTFLAGS=-O3
>>>>>>> > > > >>>> > > >>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>>>> > > > >>>> --PETSC_ARCH=linux-opt
>>>>>>> > > > >>>> > > >>> > > --with-debugging=0
>>>>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1 --with-x=0
>>>>>>> > > line
>>>>>>> > > > >>>> 67 in
>>>>>>> entries:
>>>>>>> of Error
>>>>>>> > > > >>>> Message
>>>>>>> > > > >>>> > > >>> -------send
>>>>>>> > > > >>>> > > >>> > > entire
>>>>>>> > > > >>>> > > >>> > > > > >> error message to
>>>>>>> communicator
>>>>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>>>>> MPI to
>>>>>>> > > kill
>>>>>>> > > > >>>> all MPI
>>>>>>> > > > >>>> > > >>> > > processes.
>>>>>>> other
>>>>>>> > > processes,
>>>>>>> > > > >>>> > > >>> depending on
>>>>>>> > > > >>>> > > >>> > > > > >>  ok
>>>>>>> > > > >>>> # SKIP
>>>>>>> > > > >>>> > > >>> Command
>>>>>>> > > > >>>> > > >>> > > > > >> failed so no diff.
>>>>>>> > > > >>>> > > >>> > > > > >> The same errors occurred for petsc
>>>>>>> 3.17.5
>>>>>>> > > version. I
>>>>>>> > > > >>>> am
>>>>>>> > > > >>>> > > >>> sharing the
>>>>>>> > > > >>>> > > >>> > > > > >> config.log and make.log for both petsc
>>>>>>> 3.13.4 and
>>>>>>> > > > >>>> petsc
>>>>>>> > > > >>>> > > >>> 3.17.5.
>>>>>>> > > > >>>> > > >>> > > Please find
>>>>>>> > > > >>>> > > >>> > > > > >> the attachment and do the needful.
>>>>>>> > > > >>>> > > >>> > > > > >> Thanks and regards
>>>>>>> > > > >>>> > > >>> > > > > >> Srinivas
>>>>>>> > > > >>>> > > >>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM
>>>>>>> Satish Balay <
>>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>>> > > > >>>> > > >>> > > > > >>> Well - you sent in libmesh log not
>>>>>>> petsc's
>>>>>>> > > > >>>> > > >>> configure.log/make.log
>>>>>>> > > > >>>> > > >>> > > for
>>>>>>> > > > >>>> > > >>> > > > > >>> petsc-3.17
>>>>>>> > > > >>>> > > >>> > > > > >>> Anyway - with petsc-3.13 - you have:
>>>>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>>>>> > > > >>>> > > >>> > > > > >>> MatlabEngine:
>>>>>>> > > > >>>> > > >>> > > > > >>>   Library:
>>>>>>> > > -leng
>>>>>>> > > > >>>> -lmex
>>>>>>> > > > >>>> > > >>> -lmx
>>>>>>> > > > >>>> > > >>> > > -lmat -lut
>>>>>>> > > > >>>> > > >>> > > > > >>> With petsc-3.19 (and matlab-R2022a) -
>>>>>>> we are
>>>>>>> > > seeing:
>>>>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>>>>> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
>>>>>>> > > > >>>> > > >>> > > > > >>>   Libraries:
>>>>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>>>>> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>>>>> > > > >>>> > > >>> > > > > >>>   Executable:
>>>>>>> > > > >>>> > > >>> > > > > >>>   mex:
>>>>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
>>>>>>> > > > >>>> > > >>> > > > > >>>   matlab:
>>>>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
>>>>>>> > > > >>>> > > >>> > > > > >>> -glnxa64
>>>>>>> > > > >>>> > > >>> > > > > >>> I.e "-lut -licudata -licui18n
>>>>>>> -licuuc" are not
>>>>>>> > > > >>>> preset here.
>>>>>>> > > > >>>> > > >>> This
>>>>>>> > > > >>>> > > >>> > > might
>>>>>>> > > > >>>> > > >>> > > > > >>> be a change wrt newer matlab versions.
>>>>>>> > > > >>>> > > >>> > > > > >>> You can:
>>>>>>> > > > >>>> > > >>> > > > > >>> - edit
>>>>>>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
>>>>>>> > > > >>>> > > >>> > > and
>>>>>>> > > > >>>> > > >>> > > > > >>> remove all occurrences of "-lut
>>>>>>> -licudata
>>>>>>> > > -licui18n
>>>>>>> > > > >>>> -licuuc"
>>>>>>> > > > >>>> > > >>> > > > > >>> - now run 'make all' in
>>>>>>> > > '/home/vit/sfw/petsc/3.13.4'
>>>>>>> > > > >>>> > > >>> > > > > >>> And see if the build works now.
>>>>>>> > > > >>>> > > >>> > > > > >>> Satish
>>>>>>> > > > >>>> > > >>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS
>>>>>>> 20PHD0548
>>>>>>> > > via
>>>>>>> > > > >>>> > > >>> petsc-users
>>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>>> > > > >>>> > > >>> > > > > >>> > I am sharing the log files while
>>>>>>> building
>>>>>>> > > > >>>> petsc3.13.4 with
>>>>>>> > > > >>>> > > >>> > > matlab and
>>>>>>> > > > >>>> > > >>> > > > > >>> also
>>>>>>> > > > >>>> > > >>> > > > > >>> > the log file while building libmesh
>>>>>>> with
>>>>>>> > > > >>>> petsc3.17.5 and
>>>>>>> > > > >>>> > > >>> matlab.
>>>>>>> > > > >>>> > > >>> > > > > >>> Building
>>>>>>> > > > >>>> > > >>> > > > > >>> > petsc 3.17.5 with matlab was done
>>>>>>> > > successfully.
>>>>>>> > > > >>>> But
>>>>>>> > > > >>>> > > >>> libmesh is
>>>>>>> > > > >>>> > > >>> > > not
>>>>>>> > > > >>>> > > >>> > > > > >>> able to
>>>>>>> > > > >>>> > > >>> > > > > >>> > find the petsc
>>>>>>> > > > >>>> > > >>> > > > > >>> > Please find the attachments.
>>>>>>> > > > >>>> > > >>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM
>>>>>>> Satish Balay <
>>>>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > Send configure.log, make.log from
>>>>>>> both
>>>>>>> > > > >>>> petsc-3.13 and
>>>>>>> > > > >>>> > > >>> 3.17 [or
>>>>>>> > > > >>>> > > >>> > > 3.19].
>>>>>>> > > > >>>> > > >>> > > > > >>> > > [you can gzip them to make the
>>>>>>> logs
>>>>>>> > > friendly to
>>>>>>> > > > >>>> mailing
>>>>>>> > > > >>>> > > >>> list -
>>>>>>> > > > >>>> > > >>> > > or
>>>>>>> > > > >>>> > > >>> > > > > >>> send
>>>>>>> > > > >>>> > > >>> > > > > >>> > > them to petsc-maint]
>>>>>>> > > > >>>> > > >>> > > > > >>> > > And does test suite work with
>>>>>>> 3.17? [or
>>>>>>> > > 3.19?]
>>>>>>> > > > >>>> > > >>> > > > > >>> > > Satish
>>>>>>> SRINIVAS
>>>>>>> > > 20PHD0548
>>>>>>> > > > >>>> via
>>>>>>> > > > >>>> > > >>> petsc-users
>>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > I am sharing the make.log file
>>>>>>> while
>>>>>>> > > building
>>>>>>> > > > >>>> > > >>> petsc-3.13.4
>>>>>>> > > > >>>> > > >>> > > with
>>>>>>> > > > >>>> > > >>> > > > > >>> Matlab.
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > Please find the attachment and
>>>>>>> do the
>>>>>>> > > needful.
>>>>>>> 10:19 AM INTURU
>>>>>>> > > > >>>> SRINIVAS
>>>>>>> > > > >>>> > > >>> 20PHD0548 <
>>>>>>> > > wrote:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > > I tried with petsc-3.17.5.
>>>>>>> During
>>>>>>> > > building
>>>>>>> > > > >>>> of
>>>>>>> > > > >>>> > > >>> libmesh, the
>>>>>>> > > > >>>> > > >>> > > error
>>>>>>> > > > >>>> > > >>> > > > > >>> shows
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > > petsc was not found
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > > On Mon, Aug 28, 2023 at
>>>>>>> 9:43 PM Satish
>>>>>>> > > > >>>> Balay <
>>>>>>> > > > >>>> > > >>> > > > > >>> > > wrote:
>>>>>>> https://ibamr.github.io/linux says
>>>>>>> > > > >>>> petsc-3.17
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Here you are using 3.13
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Can you retry with
>>>>>>> petsc-3.17.5?
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Satish
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU
>>>>>>> SRINIVAS
>>>>>>> > > > >>>> 20PHD0548 via
>>>>>>> > > > >>>> > > >>> > > petsc-users
>>>>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Hello,
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I want to build PETSc with
>>>>>>> MATLAB for
>>>>>>> > > > >>>> working on
>>>>>>> > > > >>>> > > >>> the
>>>>>>> > > > >>>> > > >>> > > > > >>> simulation
>>>>>>> > > > >>>> > > >>> > > > > >>> > > using
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> IBAMR
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > open software. While
>>>>>>> building the
>>>>>>> > > PETSc,
>>>>>>> > > > >>>> using the
>>>>>>> > > > >>>> > > >>> > > following
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export
>>>>>>> PETSC_ARCH=linux-debug
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > ./configure \
>>>>>>> > > > >>>>  --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>>>>>>> > > > >>>>  --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>>>>>>> > > > >>>>  --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-debugging=1 \
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-hypre=1 \
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-x=0 \
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4 test
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I got the following error
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > CLINKER
>>>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function
>>>>>>> `EvaluateResidual':
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > undefined reference to
>>>>>>> > > > >>>> `PetscMatlabEnginePut'
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
>>>>>>> > > > >>>> `PetscMatlabEngineEvaluate'
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
>>>>>>> > > > >>>> `PetscMatlabEngineGet'
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function
>>>>>>> `EvaluateJacobian':
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `TaoPounders':
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `main':
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
>>>>>>> > > > >>>> `PetscMatlabEngineCreate'
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
>>>>>>> > > > >>>> `PetscMatlabEngineGetArray'
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
>>>>>>> > > > >>>> `PetscMatlabEngineDestroy'
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > collect2: error: ld
>>>>>>> returned 1 exit
>>>>>>> > > > >>>> status
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: ***
>>>>>>> [gmakefile.test:185:
>>>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Error 1
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: *** Waiting for
>>>>>>> unfinished
>>>>>>> > > jobs....
>>>>>>> this issue
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Thank you
>>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Srinivas
>>>>>>> > > > >>>> > > >>> > > > > >> *Disclaimer:This message was sent from
>>>>>>> Vellore
>>>>>>> > > > >>>> Institute of
>>>>>>> > > > >>>> > > >>> > > Technology.
>>>>>>> > > > >>>> > > >>> > > > > >> The contents of this email may contain
>>>>>>> legally
>>>>>>> > > > >>>> protected
>>>>>>> > > > >>>> > > >>> > > confidential or
>>>>>>> > > > >>>> > > >>> > > > > >> privileged information of “Vellore
>>>>>>> Institute of
>>>>>>> > > > >>>> Technology”.
>>>>>>> > > > >>>> > > >>> If
>>>>>>> > > > >>>> > > >>> > > you are
>>>>>>> > > > >>>> > > >>> > > > > >> not the intended recipient, you should
>>>>>>> not
>>>>>>> > > > >>>> disseminate,
>>>>>>> > > > >>>> > > >>> distribute
>>>>>>> > > > >>>> > > >>> > > or copy
>>>>>>> > > > >>>> > > >>> > > > > >> this e-mail. Please notify the sender
>>>>>>> immediately
>>>>>>> > > > >>>> and destroy
>>>>>>> > > > >>>> > > >>> all
>>>>>>> > > > >>>> > > >>> > > copies of
>>>>>>> > > > >>>> > > >>> > > > > >> this message and any attachments. If
>>>>>>> you have
>>>>>>> > > > >>>> received this
>>>>>>> > > > >>>> > > >>> email
>>>>>>> > > > >>>> > > >>> > > in error,
>>>>>>> > > > >>>> > > >>> > > > > >> please promptly notify the sender by
>>>>>>> reply email
>>>>>>> > > and
>>>>>>> > > > >>>> delete
>>>>>>> > > > >>>> > > >>> the
>>>>>>> > > > >>>> > > >>> > > original
>>>>>>> > > > >>>> > > >>> > > > > >> email and any backup copies without
>>>>>>> reading
>>>>>>> > > them.*
>>>>>>> > > > >>>> > > >> *Disclaimer:This message was sent from Vellore
>>>>>>> Institute of
>>>>>>> > > > >>>> Technology.
>>>>>>> > > > >>>> > > >> The contents of this email may contain legally
>>>>>>> protected
>>>>>>> > > > >>>> confidential or
>>>>>>> > > > >>>> > > >> privileged information of “Vellore Institute of
>>>>>>> > > Technology”.  If
>>>>>>> > > > >>>> you are
>>>>>>> > > > >>>> > > >> not the intended recipient, you should not
>>>>>>> disseminate,
>>>>>>> > > > >>>> distribute or copy
>>>>>>> > > > >>>> > > >> this e-mail. Please notify the sender immediately
>>>>>>> and destroy
>>>>>>> > > > >>>> all copies of
>>>>>>> > > > >>>> > > >> this message and any attachments. If you have
>>>>>>> received this
>>>>>>> > > > >>>> email in error,
>>>>>>> > > > >>>> > > >> please promptly notify the sender by reply email
>>>>>>> and delete
>>>>>>> > > the
>>>>>>> > > > >>>> original
>>>>>>> > > > >>>> > > >> email and any backup copies without reading them.*
>>>>>>> > > > >>>> > > > --Amneet
>>>>>>> > > > >>> *Disclaimer:This message was sent from Vellore Institute of
>>>>>>> > > Technology.
>>>>>>> > > > >>> The contents of this email may contain legally protected
>>>>>>> > > confidential or
>>>>>>> Technology”.  If you
>>>>>>> > > are
>>>>>>> > > > >>> not the intended recipient, you should not disseminate,
>>>>>>> distribute
>>>>>>> > > or copy
>>>>>>> > > > >>> this e-mail. Please notify the sender immediately and
>>>>>>> destroy all
>>>>>>> > > copies of
>>>>>>> > > > >>> this message and any attachments. If you have received
>>>>>>> this email in
>>>>>>> > > error,
>>>>>>> > > > >>> please promptly notify the sender by reply email and
>>>>>>> delete the
>>>>>>> > > original
>>>>>>> > > > >> What most experimenters take for granted before they begin
>>>>>>> their
>>>>>>> > > > >> experiments is infinitely more interesting than any results
>>>>>>> to which
>>>>>>> > > their
>>>>>>> > > > >> experiments lead.
>>>>>>> > > > >> -- Norbert Wiener
>>>>>>> > > > >> https://www.cse.buffalo.edu/~knepley/
>>>>>>> > > > >> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> Technology.
>>>>>>> confidential
>>>>>>> > > or
>>>>>>> Technology”.  If you
>>>>>>> > > are
>>>>>>> distribute or
>>>>>>> > > copy
>>>>>>> destroy all
>>>>>>> > > copies of
>>>>>>> > > > > this message and any attachments. If you have received this
>>>>>>> email in
>>>>>>> > > error,
>>>>>>> > > > > please promptly notify the sender by reply email and delete
>>>>>>> the
>>>>>>> > > original
>>>>>> Technology.  The contents of this email may contain legally protected
>>>>>> confidential or privileged information of “Vellore Institute of
>>>>>> Technology”.  If you are not the intended recipient, you should not
>>>>>> disseminate, distribute or copy this e-mail. Please notify the sender
>>>>>> immediately and destroy all copies of this message and any attachments. If
>>>>>> you have received this email in error, please promptly notify the sender by
>>>>>> reply email and delete the original email and any backup copies without
>>>>>> reading them.*
>>>>> --Amneet
>>>> reading them.*
>>> *Disclaimer:This message was sent from Vellore Institute of Technology.
>>> The contents of this email may contain legally protected confidential or
>>> privileged information of “Vellore Institute of Technology”.  If you are
>>> not the intended recipient, you should not disseminate, distribute or copy
>>> this e-mail. Please notify the sender immediately and destroy all copies of
>>> this message and any attachments. If you have received this email in error,
>>> please promptly notify the sender by reply email and delete the original
>> --Amneet
> --Amneet
**Disclaimer:*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230906/46e01526/attachment-0001.html>
