[petsc-users] Error while building PETSc with MATLAB
Amneet Bhalla mail2amneet at gmail.com
Tue Sep 5 13:09:20 CDT 2023
BTW, what Barry is suggesting is the following:
Compile a sample code with a command line this:
g++ -std=c++11 -I *matlabroot*/extern/include/ -L
*matlabroot*/extern/bin/glnxa64/
    -pthread myEngineApp.cpp -lMatlabDataArray -lMatlabEngine
This command is provided here:
https://www.mathworks.com/help/matlab/matlab_external/build-c-engine-programs.html
A sample MATLAB code is here:
https://www.mathworks.com/help/matlab/matlab_external/call-matlab-functions-from-c-1.html
(You can just pick a few lines of code from here to create a barebone example)
On Tue, Sep 5, 2023 at 11:02 AM Amneet Bhalla <mail2amneet at gmail.com> wrote:
> Srinivas --- Do you have a different version of MATLAB that you can
> install? If your organization has a MATLAB license, you can install recent
> versions of MATLAB from mathworks.com
> On Tue, Sep 5, 2023 at 10:37 AM Barry Smith <bsmith at petsc.dev> wrote:
>>    Ok, I have no suggestions. It seems to be more an issue with the
>> Matlab than PETSc. You could find a pure Matlab example of using the engine
>> (in the Matlab documentation) and try it to see if it works.
>>    Barry
>> On Sep 5, 2023, at 12:27 PM, INTURU SRINIVAS 20PHD0548 <
>> inturu.srinivas2020 at vitstudent.ac.in> wrote:
>> I replaced e->ep = engOpen(buffer); with e->ep = engOpen("");
>> I got the same errors for petsc 3.17.5
>> *make all*
>>    CC linux-opt/obj/sys/classes/matlabengine/matlab.o
>>      CLINKER linux-opt/lib/libpetsc.so.3.17.5
>> BEGINNING TO COMPILE MATLAB INTERFACE
>> Building with 'gcc'.
>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>> In function ‘PetscBinaryWrite’:
>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
>> warning: ‘err’ may be used uninitialized in this function
>> [-Wmaybe-uninitialized]
>>   164 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
>> MEX completed successfully.
>> Now to check if the libraries are working do:
>> make PETSC_DIR=/home/vit/sfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
>> *make test query=requires queryval=matlab
>> DATAFILESPATH=/home/vit/datafiles/*
>> Using MAKEFLAGS: -- DATAFILESPATH=/home/vit/datafiles/ queryval=matlab
>> query=requires
>>      CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
>>         TEST linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 85
>> # [0]PETSC ERROR: --------------------- Error Message
>> # [0]PETSC ERROR: Error in external library
>> # [0]PETSC ERROR: Unable to start MATLAB engine with
>> /usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash
>> # [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>> shooting.
>> # [0]PETSC ERROR: Petsc Release Version 3.17.5, Sep 30, 2022
>> # [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by vit Tue
>> Sep  5 21:39:22 2023
>> # [0]PETSC ERROR: Configure options
>> --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
>> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
>> --with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
>> --with-matlab-engine=1 -with-blaslapack-dir=/usr/local/MATLAB/R2020b
>> --known-64-bit-blas-indices=1
>> # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() at
>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:83
>> # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() at
>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:332
>> # [0]PETSC ERROR: #3 PetscMatlabEnginePut() at
>> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:245
>> # [0]PETSC ERROR: #4 MatLUFactorNumeric_Matlab() at
>> /home/vit/sfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
>> # [0]PETSC ERROR: #5 MatLUFactorNumeric() at
>> /home/vit/sfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
>> # [0]PETSC ERROR: #6 PCSetUp_LU() at
>> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
>> # [0]PETSC ERROR: #7 PCSetUp() at
>> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
>> # [0]PETSC ERROR: #8 KSPSetUp() at
>> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
>> # [0]PETSC ERROR: #9 main() at
>> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
>> # [0]PETSC ERROR: PETSc Option Table entries:
>> # [0]PETSC ERROR: -check_pointer_intensity 0
>> # [0]PETSC ERROR: -error_output_stdout
>> # [0]PETSC ERROR: -f0 /home/vit/datafiles//matrices/arco1
>> # [0]PETSC ERROR: -malloc_dump
>> # [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
>> # [0]PETSC ERROR: -pc_type lu
>> # [0]PETSC ERROR: -use_gpu_aware_mpi 0
>> # [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> # with errorcode 85.
>> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> # You may or may not see output from other processes, depending on
>> # exactly when Open MPI kills them.
>>  ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
>> # FAILED ksp_ksp_tutorials-ex72_12
>> # To rerun failed tests:
>> #     /usr/bin/make -f gmakefile test test-fail=1
>> Thanks and regards
>> Srinivas
>> On Tue, Sep 5, 2023 at 9:05 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>     The error is occuring during
>>> Since the direct launch of /usr/local/MATLAB/R2020b/bin/matlab -glnxa64
>>> -nodisplay  -nosplash from your terminal shell worked we have to assume the
>>> problem is occuring when engOpen() is attempting to connect the stdout and
>>> stdin from the Matlab session that is launched to the executable.
>>> You can try the following. In 3.17.5 edit the
>>> file src/sys/classes/matlabengine/matlab.c and locate the line
>>> replace it with
>>> Now in the PETSc directory do make all (it should recompile one file)
>>> and then run the
>>> again
>>> On Sep 5, 2023, at 3:39 AM, INTURU SRINIVAS 20PHD0548 via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> Hi Amneeth,
>>> I think the errors are different with petsc 3.17.5
>>> *./configure --CC=/usr/bin/mpicc --CXX=/usr/bin/mpicxx
>>> --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
>>> PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
>>> --with-blaslapack-dir=/usr/local/MATLAB/R2020b
>>> --known-64-bit-blas-indices=1 --with-matlab-engine=1*
>>> The version of PETSc you are using is out-of-date, we recommend updating
>>> to the new release
>>>  Available Version: 3.19.5   Installed Version: 3.17.5
>>> https://petsc.org/release/download/
>>>                          Configuring PETSc to compile on your system
>>> Compilers:
>>>   C Compiler:         /usr/bin/mpicc  -fPIC -Wall -Wwrite-strings
>>> -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector
>>> -fvisibility=hidden -O3
>>>     Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>   C++ Compiler:         /usr/bin/mpicxx  -Wall -Wwrite-strings
>>> -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch
>>> -fstack-protector -fvisibility=hidden -O3  -std=gnu++17 -fPIC
>>>     Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
>>>   Fortran Compiler:         /usr/bin/mpif90  -fPIC -Wall
>>> -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3
>>>     Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>> Linkers:
>>>   Shared linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>>>   Dynamic linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>>>   Libraries linked against:   -lquadmath -lstdc++ -ldl
>>> BlasLapack:
>>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
>>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64
>>> /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so -liomp5 -lpthread
>>>   uses OpenMP; use export OMP_NUM_THREADS=<p> or -omp_num_threads <p> to
>>> control the number of threads
>>>   uses 8 byte integers
>>> MPI:
>>>   Version:  3
>>>   mpiexec: /usr/bin/mpiexec
>>>   Implementation: openmpi
>>>   OMPI_VERSION: 4.0.3
>>> pthread:
>>> cmake:
>>>   Version:  3.16.3
>>>   /usr/bin/cmake
>>> regex:
>>> Matlab:
>>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
>>> MatlabEngine:
>>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/bin/glnxa64
>>> -L/usr/local/MATLAB/R2020b/bin/glnxa64
>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat
>>> -lmwm_dispatcher -lmwopcmodel -lmwservices -lmwopcmodel -lmwm_dispatcher
>>> -lmwmpath -lmwopcmodel -lmwservices -lmwopcmodel -lmwservices -lxerces-c
>>>   Language used to compile PETSc: C
>>> PETSc:
>>>   PETSC_ARCH: linux-opt
>>>   PETSC_DIR: /home/vit/ibamrsfw/petsc/3.17.5
>>>   Prefix: <inplace installation>
>>>   Scalar type: real
>>>   Precision: double
>>>   Support for __float128
>>>   Integer size: 4 bytes
>>>   Single library: yes
>>>   Shared libraries: yes
>>>   Memory alignment from malloc(): 16 bytes
>>>   Using GNU make: /usr/bin/make
>>> xxx=========================================================================xxx
>>>  Configure stage complete. Now build PETSc libraries with:
>>>    make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt
>>> all
>>> *$make*
>>> FC linux-opt/obj/tao/f90-mod/petsctaomod.o
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
>>> make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
>>> *$make test query=requires queryval=matlab
>>> /usr/bin/python3 /home/vit/ibamrsfw/petsc/3.17.5/config/gmakegentest.py
>>> --petsc-dir=/home/vit/ibamrsfw/petsc/3.17.5 --petsc-arch=linux-opt
>>> --testdir=./linux-opt/tests
>>> query=requires
>>>           CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
>>> shooting.
>>> Sep  5 10:15:57 2023
>>> # [0]PETSC ERROR: Configure options --CC=/usr/bin/mpicc
>>> --CXX=/usr/bin/mpicxx --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
>>> FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:82
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:331
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:244
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
>>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
>>> entire error message to petsc-maint at mcs.anl.gov----------
>>> To get the info of the error there is no specific probe id reported.
>>> How to check error info and proceed further?
>>> Thanks and regards
>>> Srinivas
>>> On Tue, Sep 5, 2023 at 1:08 AM Amneet Bhalla <mail2amneet at gmail.com>
>>> wrote:
>>>> Do you get similar errors with petsc 3.17.5 using the new configure
>>>> options that Satish mentioned?
>>>> On Sun, Sep 3, 2023 at 10:19 PM INTURU SRINIVAS 20PHD0548 via
>>>> petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>>> Sorry for missing that.
>>>>> */usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash*
>>>>>                             < M A T L A B (R) >
>>>>>                   Copyright 1984-2020 The MathWorks, Inc.
>>>>>               R2020b Update 3 (9.9.0.1538559) 64-bit (glnxa64)
>>>>>                              November 23, 2020
>>>>> To get started, type doc.
>>>>> For product information, visit www.mathworks.com.
>>>>> Thanks and regards
>>>>> Srinivas
>>>>> On Mon, Sep 4, 2023 at 10:19 AM Satish Balay <balay at mcs.anl.gov>
>>>>> wrote:
>>>>>> You are missing one more step:
>>>>>> > [0] PetscInitialize(): Running on machine: MB108SMEC028
>>>>>> > [0] PetscMatlabEngineCreate(): Starting MATLAB engine with command
>>>>>> No run matlab manually on "MB108SMEC028" with the command
>>>>>> "/usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash"
>>>>>> Does this work for you? As the message indicates this command is
>>>>>> invoked by "matlab_ls_test" - and that is failing.
>>>>>> Satish
>>>>>> On Mon, 4 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
>>>>>> > Hi Sathish,
>>>>>> > I tried the following procedure
>>>>>> > *$make *
>>>>>> > CLINKER linux-opt/lib/libpetsc.so.3.13.4
>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>>>> >   167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
>>>>>> > make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt check
>>>>>> queryval=matlab
>>>>>> > query=requires
>>>>>> > not ok ksp_ksp_tutorials-ex72_12 # Error code: 139
>>>>>> > # [0]PETSC ERROR: Unable to start MATLAB engine on
>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>>> > for trouble shooting.
>>>>>> > # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
>>>>>> Mon Sep
>>>>>> >  4 10:02:32 2023
>>>>>> --with-debugging=0
>>>>>> > # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
>>>>>> > /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
>>>>>> > # [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>>> > # [0]PETSC ERROR:
>>>>>> Mon Sep
>>>>>> >  4 10:02:32 2023
>>>>>> --with-debugging=0
>>>>>> > # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() line 316 in
>>>>>> > # [0]PETSC ERROR:
>>>>>> > # [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>> Violation,
>>>>>> > probably memory access out of range
>>>>>> > # [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>> -on_error_attach_debugger
>>>>>> > # [0]PETSC ERROR: or see
>>>>>> > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>> > # [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>> Apple Mac OS
>>>>>> > X to find memory corruption errors
>>>>>> > # [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>>>> link,
>>>>>> > and run
>>>>>> > # [0]PETSC ERROR: to get more information on the crash.
>>>>>> > # [0]PETSC ERROR: Signal received
>>>>>> Mon Sep
>>>>>> >  4 10:02:32 2023
>>>>>> --with-debugging=0
>>>>>> > # [0]PETSC ERROR: #3 User provided function() line 0 in  unknown
>>>>>> file
>>>>>> > # with errorcode 50162059.
>>>>>> processes.
>>>>>> >           CC
>>>>>> > linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
>>>>>> >      CLINKER
>>>>>> >         TEST
>>>>>> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>>>> > not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error
>>>>>> code: 124
>>>>>> > # Running problem 5
>>>>>> > # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named
>>>>>> MB108SMEC028 by
>>>>>> > vit Mon Sep  4 10:02:34 2023
>>>>>> --with-debugging=0
>>>>>> > # [0]PETSC ERROR: #2 main() line 126 in
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
>>>>>> > # [0]PETSC ERROR: -prob_id 5
>>>>>> > # [0]PETSC ERROR: -tao_smonitor
>>>>>> entire
>>>>>> > # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>>>>>> > # with errorcode 126076.
>>>>>> processes.
>>>>>> >  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP Command
>>>>>> failed
>>>>>> > so no diff
>>>>>> > #   Summary
>>>>>> > # success 0/2 tests (0.0%)
>>>>>> > # failed 2/2 tests (100.0%)
>>>>>> > # todo 0/2 tests (0.0%)
>>>>>> > # skip 0/2 tests (0.0%)
>>>>>> > # Wall clock time for tests: 4 sec
>>>>>> > # Approximate CPU time (not incl. build time): 0.03 sec
>>>>>> > # Timing summary (actual test time / total CPU time):
>>>>>> > #   ksp_ksp_tutorials-ex72_12: 0.01 sec / 0.02 sec
>>>>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.01 sec /
>>>>>> 0.01 sec
>>>>>> > *$cd src/tao/leastsquares/tutorials/matlab/*
>>>>>> > *$make matlab_ls_test*
>>>>>> > /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall
>>>>>> -Wwrite-strings
>>>>>> > -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>>> > -fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings
>>>>>> > -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
>>>>>> >  -I/home/vit/sfw/petsc/3.13.4/include
>>>>>> > -I/home/vit/sfw/petsc/3.13.4/linux-opt/include
>>>>>> > -I/home/vit/sfw/linux/openmpi/4.1.4/include      matlab_ls_test.c
>>>>>> >  -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>>>> > -L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>>>>> > -Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>>>> > -L/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>>>> > -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
>>>>>> > -L/usr/lib/gcc/x86_64-linux-gnu/9
>>>>>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>>>>>> > -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>>>>>> > -L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm -leng -lmex
>>>>>> -lmx
>>>>>> > -lmat -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr
>>>>>> -lmpi_mpifh
>>>>>> > -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread
>>>>>> -lquadmath
>>>>>> > -lstdc++ -ldl -o matlab_ls_test
>>>>>> > *$LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 ./matlab_ls_test
>>>>>> >  -tao_smonitor -prob_id 5 -info*
>>>>>> > [0] PetscInitialize(): PETSc successfully started: number of
>>>>>> processors = 1
>>>>>> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
>>>>>> > MB108SMEC028.(none)
>>>>>> > Running problem 5
>>>>>> > [0] PetscCommDuplicate(): Duplicating a communicator 140155238476992
>>>>>> > 94202473157392 max tags = 2147483647
>>>>>> > [0]PETSC ERROR: See
>>>>>> > [0]PETSC ERROR: ./matlab_ls_test on a linux-opt named MB108SMEC028
>>>>>> by vit
>>>>>> > Mon Sep  4 10:09:56 2023
>>>>>> --with-debugging=0
>>>>>> > [0]PETSC ERROR: #2 main() line 126 in matlab_ls_test.c
>>>>>> > [0]PETSC ERROR: -info
>>>>>> entire
>>>>>> > Please find the attachment for configure.log and make.log files
>>>>>> > On Sun, Sep 3, 2023 at 8:00 PM Satish Balay <balay at mcs.anl.gov>
>>>>>> wrote:
>>>>>> > > To use datafiles in the test suite:
>>>>>> > > cd $HOME
>>>>>> > > git clone https://gitlab.com/petsc/datafiles
>>>>>> > > <configure should now pick up this location and set DATAFILESPATH
>>>>>> - or set
>>>>>> > > manually with make>
>>>>>> DATAFILESPATH=$HOME/datafiles
>>>>>> > > Satish
>>>>>> > > On Sun, 3 Sep 2023, Matthew Knepley wrote:
>>>>>> > > > On Sun, Sep 3, 2023 at 8:47 AM INTURU SRINIVAS 20PHD0548 <
>>>>>> > > > > Hi Matthew,
>>>>>> > > > > I am using PETSc to simulate the problems using IBAMR. I do
>>>>>> not have
>>>>>> > > any
>>>>>> > > > > separate test files to test PETSc alone. Can you please help
>>>>>> me how to
>>>>>> > > > > define this DATAFILESPATH?
>>>>>> > > > That test you tried uses a certain matrix. On our machine, we
>>>>>> point to
>>>>>> > > this
>>>>>> > > > matrix using an environment variable, DATAFILESPATH. You don't
>>>>>> have those
>>>>>> > > > matrices, since they are just for testing here. That
>>>>>> > > > is why I suggested just using a different matrix, or running a
>>>>>> problem
>>>>>> > > you
>>>>>> > > > care about in IBAMR.
>>>>>> > > >   Thanks,
>>>>>> > > >      Matt
>>>>>> > > > > Thanks and regards
>>>>>> > > > > Srinivas.
>>>>>> > > > > On Sun, Sep 3, 2023 at 6:06 PM Matthew Knepley <
>>>>>> knepley at gmail.com>
>>>>>> > > wrote:
>>>>>> > > > >> On Sun, Sep 3, 2023 at 3:04 AM INTURU SRINIVAS 20PHD0548 via
>>>>>> > > petsc-users <
>>>>>> > > > >>> Hi Sathish,
>>>>>> > > > >>> Thank you so much for your efforts and the support you are
>>>>>> giving me
>>>>>> > > to
>>>>>> > > > >>> sort this out.
>>>>>> > > > >>> I tried to follow the same procedure which you followed to
>>>>>> build
>>>>>> > > Petsc
>>>>>> > > > >>> 3.13.4 with Matlab-R2020b on Ubuntu20.04.
>>>>>> > > > >>> *$./configure
>>>>>> > > > >>> Using python3 for Python
>>>>>> > > > >>>                                         It appears you do
>>>>>> not have
>>>>>> > > valgrind
>>>>>> > > > >>> installed on your system.
>>>>>> > > > >>>   We HIGHLY recommend you install it from www.valgrind.org
>>>>>> > > > >>>                                              Or install
>>>>>> > > valgrind-devel or
>>>>>> > > > >>> equivalent using your package manager.
>>>>>> > > > >>>           Then rerun ./configure
>>>>>> > > > >>>                                   Compilers:
>>>>>> > > > >>>   C Compiler:
>>>>>> > > -fPIC
>>>>>> > > > >>> -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>> > > > >>>   C++ Compiler:
>>>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>>>> > > > >>> -fstack-protector -fvisibility=hidden -O3  -fPIC
>>>>>> > > > >>>   Fortran Compiler:
>>>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>>>> > > > >>>  -fPIC -Wall -ffree-line-length-0
>>>>>> 9.4.0
>>>>>> > > > >>> Linkers:
>>>>>> > > > >>>   Shared linker:
>>>>>> > > -shared
>>>>>> > > > >>>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>> > > > >>>   Dynamic linker:
>>>>>> > > -shared
>>>>>> > > > >>> make:
>>>>>> > > > >>>   Version:  4.2
>>>>>> > > > >>>   /usr/bin/make
>>>>>> > > > >>> BlasLapack:
>>>>>> > > > >>>   Library:  /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so
>>>>>> > > > >>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5 -lpthread
>>>>>> -omp_num_threads
>>>>>> > > <p> to
>>>>>> > > > >>> MPI:
>>>>>> > > > >>>   Version:  3
>>>>>> > > > >>>   Includes: -I/home/vit/sfw/linux/openmpi/4.1.4/include
>>>>>> > > > >>>   Mpiexec: /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec
>>>>>> > > --oversubscribe
>>>>>> > > > >>>   OMPI_VERSION: 4.1.4
>>>>>> > > > >>> pthread:
>>>>>> > > > >>> cmake:
>>>>>> > > > >>>   Version:  3.16.3
>>>>>> > > > >>>   /usr/bin/cmake
>>>>>> > > > >>> regex:
>>>>>> > > > >>> Matlab:
>>>>>> > > > >>> MatlabEngine:
>>>>>> > > > >>>   Library:
>>>>>> -lmx -lmat
>>>>>> > > -lut
>>>>>> > > > >>> -licudata -licui18n -licuuc
>>>>>> > > > >>> PETSc:
>>>>>> > > > >>>   PETSC_DIR: /home/vit/sfw/petsc/3.13.4
>>>>>> > > > >>>   Scalar type: real
>>>>>> > > > >>>   Precision: double
>>>>>> > > > >>>   shared libraries: enabled
>>>>>> PETSC_ARCH=linux-opt all
>>>>>> > > > >>> Then I removed all occurrences of -lut -licudata -licui18n
>>>>>> -licuuc as
>>>>>> > > > >>> you suggested earlier.
>>>>>> > > > >>> *$make*
>>>>>> socket\n");
>>>>>> socket\n");
>>>>>> > > > >>> *$make test query=requires queryval=matlab*
>>>>>> > > > >>> Using MAKEFLAGS: -- queryval=matlab query=requires
>>>>>> > > > >>>         TEST
>>>>>> > > > >>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
>>>>>> > > > >>> # [0]PETSC ERROR: Unable to open file
>>>>>> > > > >>> # [0]PETSC ERROR: Cannot locate file: /matrices/arco1
>>>>>> > > > >> No, the problem is that you do not have DATAFILESPATH
>>>>>> defined, so it
>>>>>> > > > >> cannot find the matrix to test. Try running some test of
>>>>>> yours.
>>>>>> > > > >>   Thanks,
>>>>>> > > > >>      Matt
>>>>>> > > > >>> https://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>>>> trouble
>>>>>> > > > >>> shooting.
>>>>>> by vit
>>>>>> > > Sun
>>>>>> > > > >>> Sep  3 11:51:03 2023
>>>>>> COPTFLAGS=-O3
>>>>>> --with-debugging=0
>>>>>> > > > >>> # [0]PETSC ERROR: #1 PetscViewerFileSetUp_BinarySTDIO()
>>>>>> line 1444 in
>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
>>>>>> > > > >>> # [0]PETSC ERROR: #2 PetscViewerSetUp_Binary() line 1511 in
>>>>>> > > > >>> # [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
>>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
>>>>>> > > > >>> # [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
>>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
>>>>>> > > > >>> # [0]PETSC ERROR: #5 MatLoad() line 1225 in
>>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
>>>>>> > > > >>> # [0]PETSC ERROR: #6 main() line 113 in
>>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
>>>>>> > > > >>> # [0]PETSC ERROR: -f0 /matrices/arco1
>>>>>> -------send
>>>>>> MPI_COMM_SELF
>>>>>> > > > >>> # with errorcode 113065.
>>>>>> processes.
>>>>>> depending on
>>>>>> diff
>>>>>> > > > >>>           CC
>>>>>> > > > >>>      CLINKER
>>>>>> > > > >>>         TEST
>>>>>> Error
>>>>>> > > code: 124
>>>>>> > > > >>> # Running problem 5
>>>>>> trouble
>>>>>> > > > >>> shooting.
>>>>>> > > MB108SMEC028 by
>>>>>> > > > >>> vit Sun Sep  3 11:51:05 2023
>>>>>> COPTFLAGS=-O3
>>>>>> --with-debugging=0
>>>>>> -------send
>>>>>> MPI_COMM_SELF
>>>>>> processes.
>>>>>> depending on
>>>>>> Command
>>>>>> > > > >>> failed so no diff
>>>>>> > > > >>> #   Summary
>>>>>> > > > >>> # Wall clock time for tests: 3 sec
>>>>>> > > > >>> # Approximate CPU time (not incl. build time): 0.05 sec
>>>>>> > > > >>> #   ksp_ksp_tutorials-ex72_12: 0.02 sec / 0.03 sec
>>>>>> > > > >>> #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.02
>>>>>> sec /
>>>>>> > > 0.02 sec
>>>>>> > > > >>> *How to sort out this error?*
>>>>>> > > -Wwrite-strings
>>>>>> -O3
>>>>>> matlab_ls_test.c
>>>>>> -lmex
>>>>>> > > -lmx
>>>>>> > > -lmpi_mpifh
>>>>>> -lpthread
>>>>>> > > -lquadmath
>>>>>> > > > >>> I think there is a problem with the Matlab-R2020b version.
>>>>>> > > > >>> I am sharing the configure.log and make.log files. Please
>>>>>> find the
>>>>>> > > > >>> attachment and do the needful.
>>>>>> > > > >>> Thanks and regards
>>>>>> > > > >>> Srinivas
>>>>>> > > > >>> On Sat, Sep 2, 2023 at 11:15 PM Satish Balay <
>>>>>> > > wrote:
>>>>>> > > > >>>> Perhaps you can try the following to get additional info -
>>>>>> and debug
>>>>>> > > > >>>> Satish
>>>>>> > > > >>>> balay at compute-386-07:/scratch/balay/petsc$ cd
>>>>>> > > :/scratch/balay/petsc/src/tao/leastsquares/tutorials/matlab$
>>>>>> > > > >>>> make matlab_ls_test
>>>>>> > > > >>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc
>>>>>> -fPIC
>>>>>> > > -Wall
>>>>>> > > > >>>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>>>>>> > > -fstack-protector
>>>>>> -O3
>>>>>> > > > >>>> -I/scratch/balay/petsc/include
>>>>>> > > -I/scratch/balay/petsc/linux-opt/include
>>>>>> -I/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/include
>>>>>> > > > >>>> -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
>>>>>> > > > >>>> matlab_ls_test.c
>>>>>> -Wl,-rpath,/scratch/balay/petsc/linux-opt/lib
>>>>>> > > > >>>> -L/scratch/balay/petsc/linux-opt/lib
>>>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64
>>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>>>> -Wl,-rpath,/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>>>> > > > >>>> -L/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>>>> > > > >>>> -L/lib/x86_64-linux-gnu -lpetsc -llapack -lblas -lpthread
>>>>>> -lm -leng
>>>>>> > > -lmex
>>>>>> > > > >>>> -lmx -lmat -lut -licudata -licui18n -licuuc -lstdc++ -ldl
>>>>>> -lmpifort
>>>>>> > > -lmpi
>>>>>> > > > >>>> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++
>>>>>> -ldl -o
>>>>>> > > > >>>> matlab_ls_test
>>>>>> ./matlab_ls_test
>>>>>> of
>>>>>> > > processors
>>>>>> > > > >>>> = 1
>>>>>> > > > >>>> compute-386-07.(none)
>>>>>> > > > >>>> [0] PetscInitialize(): Running on machine: compute-386-07
>>>>>> > > > >>>> Running problem 5
>>>>>> 1140850689
>>>>>> > > > >>>> -2080374784 max tags = 268435455
>>>>>> command
>>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/matlab
>>>>>> > > > >>>> [0] PetscMatlabEngineCreate(): Started MATLAB engine
>>>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Evaluating MATLAB string:
>>>>>> > > > >>>> TestingInitialize
>>>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Done evaluating Matlab
>>>>>> string:
>>>>>> > > > >>>> TestingInitialize
>>>>>> > > > >>>> 5
>>>>>> > > > >>>> <snip>
>>>>>> > > > >>>> <<<< Now verify if the above matlab command actually works
>>>>>> for you
>>>>>> > > - on
>>>>>> > > > >>>> this machine..>>>>>
>>>>>> > > > >>>>                                    < M A T L A B (R) >
>>>>>> > > > >>>>                          Copyright 1984-2021 The
>>>>>> MathWorks, Inc.
>>>>>> > > > >>>>                          R2021a (9.10.0.1602886) 64-bit
>>>>>> (glnxa64)
>>>>>> > > > >>>>                                     February 17, 2021
>>>>>> > > > >>>> On Sat, 2 Sep 2023, Satish Balay via petsc-users wrote:
>>>>>> > > > >>>> > Please don't cc: both petsc-users and petsc-maint
>>>>>> [reverting
>>>>>> > > thread
>>>>>> > > > >>>> to petsc-users only]
>>>>>> > > > >>>> > I'm not sure what is happening here. Can you send the
>>>>>> > > corresponding
>>>>>> > > > >>>> configure.log, make.log [compressed]?
>>>>>> > > > >>>> > Here is my attempt to reproduce (with petsc-3.13) on
>>>>>> Ubuntu-20.04,
>>>>>> > > > >>>> with Matlab-R2021a - and that works:
>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ git branch
>>>>>> > > > >>>> >   main
>>>>>> > > > >>>> >   release
>>>>>> > > > >>>> > * release-3.13
>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ module load
>>>>>> > > matlab/R2021a
>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ which matlab
>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ ./configure
>>>>>> --with-mpi-dir=/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/
>>>>>> --with-matlab-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>>>> --with-blaslapack-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>>>> > > > >>>> > <snip>
>>>>>> > > > >>>> > Compilers:
>>>>>> > > > >>>> >   C Compiler:
>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc  -fPIC
>>>>>> > > -Wall
>>>>>> > > -fstack-protector
>>>>>> > > > >>>> >   C++ Compiler:
>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicxx  -Wall
>>>>>> > > -fstack-protector
>>>>>> > > > >>>> >     Version: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>>>> > > > >>>> >   Fortran Compiler:
>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpif90  -fPIC
>>>>>> > > -Wall
>>>>>> > > > >>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>>> 9.4.0
>>>>>> > > > >>>> > Linkers:
>>>>>> > > > >>>> >   Shared linker:
>>>>>> > > -shared  -fPIC
>>>>>> > > > >>>> >   Dynamic linker:
>>>>>> > > -shared  -fPIC
>>>>>> > > > >>>> > make:
>>>>>> > > > >>>> >   Version:  4.2
>>>>>> > > > >>>> >   /usr/bin/make
>>>>>> > > > >>>> > BlasLapack:
>>>>>> > > > >>>> >   Library:
>>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64/mkl.so
>>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64
>>>>>> > > > >>>> -liomp5 -lpthread
>>>>>> -omp_num_threads
>>>>>> > > <p>
>>>>>> > > > >>>> to control the number of threads
>>>>>> > > > >>>> > MPI:
>>>>>> > > > >>>> >   Version:  4
>>>>>> > > > >>>> >   Includes:
>>>>>> > > > >>>> >   Mpiexec:
>>>>>> > > /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpiexec
>>>>>> > > > >>>> >   MPICH_NUMVERSION: 40002300
>>>>>> > > > >>>> > pthread:
>>>>>> > > > >>>> >   Library:  -lpthread
>>>>>> > > > >>>> > cmake:
>>>>>> > > > >>>> >   Version:  3.16.3
>>>>>> > > > >>>> >   /usr/bin/cmake
>>>>>> > > > >>>> > regex:
>>>>>> > > > >>>> > Matlab:
>>>>>> > > > >>>> >   Includes:
>>>>>> > > > >>>> > MatlabEngine:
>>>>>> > > > >>>> >   Library:
>>>>>> > > > >>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>>> > > > >>>> > sowing:
>>>>>> > > > >>>> >   Version:  1.1.25
>>>>>> > > > >>>> >   /scratch/balay/petsc/linux-opt/bin/bfort
>>>>>> > > > >>>> > valgrind:
>>>>>> > > > >>>> > PETSc:
>>>>>> > > > >>>> >   PETSC_DIR: /scratch/balay/petsc
>>>>>> > > > >>>> >   Scalar type: real
>>>>>> > > > >>>> >   Precision: double
>>>>>> with:
>>>>>> > > > >>>> >    make PETSC_DIR=/scratch/balay/petsc
>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make
>>>>>> > > > >>>> > <snip>
>>>>>> > > > >>>> >      CLINKER linux-opt/lib/libpetsc.so.3.13.6
>>>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c: In
>>>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>>>> > > socket\n");
>>>>>> > > socket\n");
>>>>>> > > > >>>> > make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt
>>>>>> check
>>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make test
>>>>>> > > query=requires
>>>>>> > > > >>>> queryval=matlab
>>>>>> > > > >>>> >         TEST
>>>>>> > > > >>>> > #     ../ex72:
>>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64/libgfortran.so.5:
>>>>>> > > > >>>> version `GFORTRAN_9' not found (required by
>>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib/libmpifort.so.12)
>>>>>> no diff
>>>>>> > > > >>>> >           CC
>>>>>> > > > >>>> >      CLINKER
>>>>>> > > > >>>> >         TEST
>>>>>> # Error
>>>>>> > > code:
>>>>>> > > > >>>> 1
>>>>>> > > > >>>> > #     ../matlab_ls_test:
>>>>>> SKIP
>>>>>> > > Command
>>>>>> > > > >>>> failed so no diff
>>>>>> > > > >>>> > <snip>
>>>>>> > > > >>>> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 make test
>>>>>> > > query=requires
>>>>>> > > > >>>> queryval=matlab
>>>>>> > > > >>>> >         TEST
>>>>>> > > > >>>> >  ok diff-ksp_ksp_tutorials-ex72_12
>>>>>> > > > >>>> >         TEST
>>>>>> > > > >>>> >  ok diff-tao_leastsquares_tutorials_matlab-matlab_ls_test
>>>>>> > > > >>>> > #   Summary
>>>>>> > > > >>>> > # success 4/4 tests (100.0%)
>>>>>> > > > >>>> > # failed 0/4 tests (0.0%)
>>>>>> > > > >>>> > # todo 0/4 tests (0.0%)
>>>>>> > > > >>>> > # skip 0/4 tests (0.0%)
>>>>>> > > > >>>> > # Wall clock time for tests: 27 sec
>>>>>> 15.190000000000001
>>>>>> > > sec
>>>>>> 6.47 sec /
>>>>>> > > 7.54
>>>>>> > > > >>>> sec
>>>>>> > > > >>>> > #   ksp_ksp_tutorials-ex72_12: 6.46 sec / 7.65 sec
>>>>>> > > > >>>> > On Sat, 2 Sep 2023, INTURU SRINIVAS 20PHD0548 wrote:
>>>>>> > > > >>>> > > Based on the suggestions given by Sathish, I have
>>>>>> tried to
>>>>>> > > > >>>> configure petsc
>>>>>> > > > >>>> > > 3.13.4 with Matlab-R2020b. But, it was not successful.
>>>>>> After
>>>>>> > > > >>>> running make
>>>>>> > > > >>>> > > -j 10 test command I have got the following error
>>>>>> message.
>>>>>> > > > >>>> > > not ok
>>>>>> > > > >>>> code: 124
>>>>>> > > > >>>> > > # Running problem 5
>>>>>> 01, 2020
>>>>>> named
>>>>>> > > > >>>> MB108SMEC028 by
>>>>>> > > > >>>> > > vit Sat Sep  2 12:27:22 2023
>>>>>> COPTFLAGS=-O3
>>>>>> > > > >>>> --with-debugging=0
>>>>>> in
>>>>>> > > -------send
>>>>>> > > > >>>> entire
>>>>>> MPI_COMM_SELF
>>>>>> MPI
>>>>>> > > > >>>> processes.
>>>>>> depending
>>>>>> > > on
>>>>>> > > > >>>> > > I request you to help me to sort out this error.
>>>>>> > > > >>>> > > Thanks
>>>>>> > > > >>>> > > Srinivas
>>>>>> > > > >>>> > > On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <
>>>>>> > > > >>>> > > > I think there should be two hyphens in
>>>>>> > > > >>>> > > > i.e.:
>>>>>> > > > >>>> > > > On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS
>>>>>> 20PHD0548 via
>>>>>> > > > >>>> petsc-users <
>>>>>> > > > >>>> > > >> Thank you Sathish.I will try this
>>>>>> > > > >>>> > > >> On Fri, Sep 1, 2023, 22:53 Satish Balay <
>>>>>> > > > >>>> wrote:
>>>>>> > > > >>>> > > >>> yes [and remove fblaslapack. don't know if hypre
>>>>>> will work
>>>>>> > > > >>>> here].
>>>>>> > > > >>>> > > >>> i.e:
>>>>>> > > > >>>> > > >>> ./configure
>>>>>> > > > >>>> > > >>> --with-debugging=0 --with-x=0 \
>>>>>> > > > >>>> > > >>> Satish
>>>>>> > > > >>>> > > >>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via
>>>>>> > > petsc-users
>>>>>> > > > >>>> wrote:
>>>>>> > > > >>>> > > >>> > Hi Satish,
>>>>>> > > > >>>> > > >>> > -with-blaslapack-dir=/path/to/matlab_dir
>>>>>> > > > >>>> > > >>> > Is this what you are suggesting?
>>>>>> > > > >>>> > > >>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <
>>>>>> > > > >>>> wrote:
>>>>>> > > > >>>> > > >>> > > Also:
>>>>>> > > > >>>> > > >>> > >     '-known-64-bit-blas-indices=1',
>>>>>> > > > >>>> > > >>> > > Note: most externalpackages might not work in
>>>>>> this mode.
>>>>>> > > > >>>> > > >>> > > [we can't really over come such
>>>>>> dependency/conflicts
>>>>>> > > across
>>>>>> > > > >>>> packages]
>>>>>> > > > >>>> > > >>> > > Satish
>>>>>> > > > >>>> > > >>> > > On Fri, 1 Sep 2023, Satish Balay via
>>>>>> petsc-users wrote:
>>>>>> > > > >>>> > > >>> > > > Here is the matlab test that runs in CI
>>>>>> https://gitlab.com/petsc/petsc/-/jobs/4904566768
>>>>>> > > > >>>> > > >>> > > > config/examples/arch-ci-linux-matlab-ilp64.py
>>>>>> > > > >>>> > > >>> > > > # Note: regular BLAS [with 32-bit integers]
>>>>>> conflict
>>>>>> > > with
>>>>>> > > > >>>> > > >>> > > > # MATLAB BLAS - hence requiring
>>>>>> > > > >>>> > > >>> > > > Ah - so you need to use the ilp64
>>>>>> blas/lapack with
>>>>>> > > > >>>> matlab  - to
>>>>>> > > > >>>> > > >>> have a
>>>>>> > > > >>>> > > >>> > > compatible build
>>>>>> > > > >>>> > > >>> > > >     '--with-blaslapack-dir='+matlab_dir,
>>>>>> > > > >>>> > > >>> > > > Satish
>>>>>> 20PHD0548 via
>>>>>> > > > >>>> petsc-users
>>>>>> > > > >>>> > > >>> wrote:
>>>>>> > > > >>>> > > >>> > > > > Hi Amneet,
>>>>>> > > > >>>> > > >>> > > > > Without libmesh, even for PETSc with
>>>>>> MATLAB is not
>>>>>> > > > >>>> working. It is
>>>>>> > > > >>>> > > >>> > > showing
>>>>>> > > > >>>> > > >>> > > > > error for both 3.13.4 and 3.17.5 versions.
>>>>>> > > > >>>> > > >>> > > > > I am trying to install IBAMR in HPC
>>>>>> cluster with
>>>>>> > > > >>>> libmesh and
>>>>>> > > > >>>> > > >>> this is
>>>>>> > > > >>>> > > >>> > > for
>>>>>> > > > >>>> > > >>> > > > > general usage not only for WEC. This I
>>>>>> tried without
>>>>>> > > > >>>> linking
>>>>>> > > > >>>> > > >>> Matlab
>>>>>> > > > >>>> > > >>> > > with
>>>>>> > > > >>>> > > >>> > > > > PETSc. Here also I got the error while
>>>>>> configuring
>>>>>> > > > >>>> libmesh 1.6.2
>>>>>> > > > >>>> > > >>> that
>>>>>> > > > >>>> > > >>> > > PETSc
>>>>>> > > > >>>> > > >>> > > > > was not found but --enable-petsc-required
>>>>>> is
>>>>>> > > specified.
>>>>>> > > > >>>> > > >>> > > > > The reason for specifically asking for
>>>>>> libmesh with
>>>>>> > > > >>>> PETSc and
>>>>>> > > > >>>> > > >>> Matlab
>>>>>> > > > >>>> > > >>> > > is in
>>>>>> > > > >>>> > > >>> > > > > the cfd-mpc-wecs application for
>>>>>> complicated
>>>>>> > > geometries
>>>>>> > > > >>>> it is
>>>>>> > > > >>>> > > >>> > > mentioned to
>>>>>> > > > >>>> > > >>> > > > > build cfd-mpc-wecs with libmesh construct.
>>>>>> > > > >>>> > > >>> > > > > For the past 10 days I am trying these
>>>>>> various
>>>>>> > > things
>>>>>> > > > >>>> and ended
>>>>>> > > > >>>> > > >>> up with
>>>>>> > > > >>>> > > >>> > > > > errors.
>>>>>> > > > >>>> > > >>> > > > > I want to solve this and proceed further
>>>>>> to do my
>>>>>> > > > >>>> research work.
>>>>>> > > > >>>> > > >>> > > > > Please help me to solve this as soon as
>>>>>> possible.
>>>>>> > > > >>>> > > >>> > > > > Thanks and Regards
>>>>>> > > > >>>> > > >>> > > > > Srinivas
>>>>>> > > > >>>> > > >>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <
>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>> > > > >>>> > > >>> > > > > > Hi Srinivas,
>>>>>> > > > >>>> > > >>> > > > > > As discussed earlier you don’t need
>>>>>> libMesh for
>>>>>> > > the
>>>>>> > > > >>>> WEC
>>>>>> > > > >>>> > > >>> application.
>>>>>> > > > >>>> > > >>> > > You
>>>>>> > > > >>>> > > >>> > > > > > can just work with PETSc 3.17.5 that
>>>>>> builds with
>>>>>> > > > >>>> Matlab.
>>>>>> > > > >>>> > > >>> > > > > > Do you have a specific reason for
>>>>>> wanting to build
>>>>>> > > > >>>> libMesh?
>>>>>> > > > >>>> > > >>> > > > > > Thanks,
>>>>>> > > > >>>> > > >>> > > > > > —Amneet
>>>>>> > > > >>>> > > >>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU
>>>>>> SRINIVAS
>>>>>> > > > >>>> 20PHD0548 via
>>>>>> > > > >>>> > > >>> > > petsc-users
>>>>>> > > > >>>> > > >>> > > > > >> Hi,
>>>>>> > > > >>>> > > >>> > > > > >> I ran "make all" for petsc 3.13.4 by
>>>>>> removing all
>>>>>> > > > >>>> occurrences
>>>>>> > > > >>>> > > >>> of
>>>>>> > > > >>>> > > >>> > > "-lut
>>>>>> > > > >>>> > > >>> > > > > >> -licudata -licui18n -licuuc". When I
>>>>>> ran "make
>>>>>> > > test"
>>>>>> > > > >>>> got the
>>>>>> > > > >>>> > > >>> > > following
>>>>>> > > > >>>> > > >>> > > > > >> errors
>>>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-debug:
>>>>>> > > > >>>> > > >>> > > > > >> TEST
>>>>>> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>>>> > > > >>>> > > >>> > > > > >> not ok
>>>>>> > > > >>>> > > >>> Error
>>>>>> > > > >>>> > > >>> > > code: 124
>>>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>>>> Error
>>>>>> > > Message
>>>>>> library
>>>>>> MATLAB engine
>>>>>> > > on
>>>>>> > > > >>>> for
>>>>>> > > > >>>> > > >>> trouble
>>>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>>>> 3.13.4,
>>>>>> > > Aug
>>>>>> > > > >>>> 01, 2020
>>>>>> > > linux-debug
>>>>>> > > > >>>> named
>>>>>> > > > >>>> > > >>> > > MB108SMEC028
>>>>>> > > > >>>> > > >>> > > > > >> by vit Fri Sep  1 10:01:11 2023
>>>>>> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>>>>> > > --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>>>> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>>>> > > > >>>> > > >>> --with-debugging=1
>>>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1
>>>>>> --download-fblaslapack=1
>>>>>> > > > >>>> --with-x=0
>>>>>> --with-matlab-dir=/usr/local/MATLAB/R2020b/
>>>>>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
>>>>>> > > line
>>>>>> > > > >>>> 67 in
>>>>>> entries:
>>>>>> of Error
>>>>>> > > > >>>> Message
>>>>>> > > > >>>> > > >>> -------send
>>>>>> > > > >>>> > > >>> > > entire
>>>>>> > > > >>>> > > >>> > > > > >> error message to
>>>>>> communicator
>>>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>>>> MPI to
>>>>>> > > kill
>>>>>> > > > >>>> all MPI
>>>>>> > > > >>>> > > >>> > > processes.
>>>>>> other
>>>>>> > > processes,
>>>>>> > > > >>>> > > >>> depending on
>>>>>> > > > >>>> > > >>> > > > > >>  ok
>>>>>> > > > >>>> # SKIP
>>>>>> > > > >>>> > > >>> Command
>>>>>> > > > >>>> > > >>> > > > > >> failed so no diff
>>>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-opt
>>>>>> > > > >>>> > > >>> > > > > >>  TEST
>>>>>> > > > >>>> > > >>> > > > > >> not ok
>>>>>> > > > >>>> > > >>> Error
>>>>>> > > > >>>> > > >>> > > code: 124
>>>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>>>> Error
>>>>>> > > Message
>>>>>> library
>>>>>> MATLAB engine
>>>>>> > > on
>>>>>> > > > >>>> for
>>>>>> > > > >>>> > > >>> trouble
>>>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>>>> 3.13.4,
>>>>>> > > Aug
>>>>>> > > > >>>> 01, 2020
>>>>>> > > linux-opt
>>>>>> > > > >>>> named
>>>>>> > > > >>>> > > >>> > > MB108SMEC028 by
>>>>>> > > > >>>> > > >>> > > > > >> vit Fri Sep  1 10:34:12 2023
>>>>>> > > > >>>> > > >>> --COPTFLAGS=-O3
>>>>>> > > > >>>> > > >>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>>> > > > >>>> --PETSC_ARCH=linux-opt
>>>>>> > > > >>>> > > >>> > > --with-debugging=0
>>>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1 --with-x=0
>>>>>> > > line
>>>>>> > > > >>>> 67 in
>>>>>> entries:
>>>>>> of Error
>>>>>> > > > >>>> Message
>>>>>> > > > >>>> > > >>> -------send
>>>>>> > > > >>>> > > >>> > > entire
>>>>>> > > > >>>> > > >>> > > > > >> error message to
>>>>>> communicator
>>>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>>>> MPI to
>>>>>> > > kill
>>>>>> > > > >>>> all MPI
>>>>>> > > > >>>> > > >>> > > processes.
>>>>>> other
>>>>>> > > processes,
>>>>>> > > > >>>> > > >>> depending on
>>>>>> > > > >>>> > > >>> > > > > >>  ok
>>>>>> > > > >>>> # SKIP
>>>>>> > > > >>>> > > >>> Command
>>>>>> > > > >>>> > > >>> > > > > >> failed so no diff.
>>>>>> > > > >>>> > > >>> > > > > >> The same errors occurred for petsc
>>>>>> 3.17.5
>>>>>> > > version. I
>>>>>> > > > >>>> am
>>>>>> > > > >>>> > > >>> sharing the
>>>>>> > > > >>>> > > >>> > > > > >> config.log and make.log for both petsc
>>>>>> 3.13.4 and
>>>>>> > > > >>>> petsc
>>>>>> > > > >>>> > > >>> 3.17.5.
>>>>>> > > > >>>> > > >>> > > Please find
>>>>>> > > > >>>> > > >>> > > > > >> the attachment and do the needful.
>>>>>> > > > >>>> > > >>> > > > > >> Thanks and regards
>>>>>> > > > >>>> > > >>> > > > > >> Srinivas
>>>>>> > > > >>>> > > >>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish
>>>>>> Balay <
>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> Well - you sent in libmesh log not
>>>>>> petsc's
>>>>>> > > > >>>> > > >>> configure.log/make.log
>>>>>> > > > >>>> > > >>> > > for
>>>>>> > > > >>>> > > >>> > > > > >>> petsc-3.17
>>>>>> > > > >>>> > > >>> > > > > >>> Anyway - with petsc-3.13 - you have:
>>>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>>>> > > > >>>> > > >>> > > > > >>> MatlabEngine:
>>>>>> > > > >>>> > > >>> > > > > >>>   Library:
>>>>>> > > -leng
>>>>>> > > > >>>> -lmex
>>>>>> > > > >>>> > > >>> -lmx
>>>>>> > > > >>>> > > >>> > > -lmat -lut
>>>>>> > > > >>>> > > >>> > > > > >>> With petsc-3.19 (and matlab-R2022a) -
>>>>>> we are
>>>>>> > > seeing:
>>>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>>>> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
>>>>>> > > > >>>> > > >>> > > > > >>>   Libraries:
>>>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>>>> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>>>> > > > >>>> > > >>> > > > > >>>   Executable:
>>>>>> > > > >>>> > > >>> > > > > >>>   mex:
>>>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
>>>>>> > > > >>>> > > >>> > > > > >>>   matlab:
>>>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
>>>>>> > > > >>>> > > >>> > > > > >>> -glnxa64
>>>>>> > > > >>>> > > >>> > > > > >>> I.e "-lut -licudata -licui18n -licuuc"
>>>>>> are not
>>>>>> > > > >>>> preset here.
>>>>>> > > > >>>> > > >>> This
>>>>>> > > > >>>> > > >>> > > might
>>>>>> > > > >>>> > > >>> > > > > >>> be a change wrt newer matlab versions.
>>>>>> > > > >>>> > > >>> > > > > >>> You can:
>>>>>> > > > >>>> > > >>> > > > > >>> - edit
>>>>>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
>>>>>> > > > >>>> > > >>> > > and
>>>>>> > > > >>>> > > >>> > > > > >>> remove all occurrences of "-lut
>>>>>> -licudata
>>>>>> > > -licui18n
>>>>>> > > > >>>> -licuuc"
>>>>>> > > > >>>> > > >>> > > > > >>> - now run 'make all' in
>>>>>> > > '/home/vit/sfw/petsc/3.13.4'
>>>>>> > > > >>>> > > >>> > > > > >>> And see if the build works now.
>>>>>> > > > >>>> > > >>> > > > > >>> Satish
>>>>>> > > > >>>> > > >>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS
>>>>>> 20PHD0548
>>>>>> > > via
>>>>>> > > > >>>> > > >>> petsc-users
>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> > I am sharing the log files while
>>>>>> building
>>>>>> > > > >>>> petsc3.13.4 with
>>>>>> > > > >>>> > > >>> > > matlab and
>>>>>> > > > >>>> > > >>> > > > > >>> also
>>>>>> > > > >>>> > > >>> > > > > >>> > the log file while building libmesh
>>>>>> with
>>>>>> > > > >>>> petsc3.17.5 and
>>>>>> > > > >>>> > > >>> matlab.
>>>>>> > > > >>>> > > >>> > > > > >>> Building
>>>>>> > > > >>>> > > >>> > > > > >>> > petsc 3.17.5 with matlab was done
>>>>>> > > successfully.
>>>>>> > > > >>>> But
>>>>>> > > > >>>> > > >>> libmesh is
>>>>>> > > > >>>> > > >>> > > not
>>>>>> > > > >>>> > > >>> > > > > >>> able to
>>>>>> > > > >>>> > > >>> > > > > >>> > find the petsc
>>>>>> > > > >>>> > > >>> > > > > >>> > Please find the attachments.
>>>>>> > > > >>>> > > >>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM
>>>>>> Satish Balay <
>>>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> > > Send configure.log, make.log from
>>>>>> both
>>>>>> > > > >>>> petsc-3.13 and
>>>>>> > > > >>>> > > >>> 3.17 [or
>>>>>> > > > >>>> > > >>> > > 3.19].
>>>>>> > > > >>>> > > >>> > > > > >>> > > [you can gzip them to make the logs
>>>>>> > > friendly to
>>>>>> > > > >>>> mailing
>>>>>> > > > >>>> > > >>> list -
>>>>>> > > > >>>> > > >>> > > or
>>>>>> > > > >>>> > > >>> > > > > >>> send
>>>>>> > > > >>>> > > >>> > > > > >>> > > them to petsc-maint]
>>>>>> > > > >>>> > > >>> > > > > >>> > > And does test suite work with
>>>>>> 3.17? [or
>>>>>> > > 3.19?]
>>>>>> > > > >>>> > > >>> > > > > >>> > > Satish
>>>>>> SRINIVAS
>>>>>> > > 20PHD0548
>>>>>> > > > >>>> via
>>>>>> > > > >>>> > > >>> petsc-users
>>>>>> > > > >>>> > > >>> > > wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > I am sharing the make.log file
>>>>>> while
>>>>>> > > building
>>>>>> > > > >>>> > > >>> petsc-3.13.4
>>>>>> > > > >>>> > > >>> > > with
>>>>>> > > > >>>> > > >>> > > > > >>> Matlab.
>>>>>> > > > >>>> > > >>> > > > > >>> > > > Please find the attachment and
>>>>>> do the
>>>>>> > > needful.
>>>>>> > > > >>>> > > >>> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM
>>>>>> INTURU
>>>>>> > > > >>>> SRINIVAS
>>>>>> > > > >>>> > > >>> 20PHD0548 <
>>>>>> > > wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > > I tried with petsc-3.17.5.
>>>>>> During
>>>>>> > > building
>>>>>> > > > >>>> of
>>>>>> > > > >>>> > > >>> libmesh, the
>>>>>> > > > >>>> > > >>> > > error
>>>>>> > > > >>>> > > >>> > > > > >>> shows
>>>>>> > > > >>>> > > >>> > > > > >>> > > > > petsc was not found
>>>>>> > > > >>>> > > >>> > > > > >>> > > > > On Mon, Aug 28, 2023 at
>>>>>> 9:43 PM Satish
>>>>>> > > > >>>> Balay <
>>>>>> > > > >>>> > > >>> > > > > >>> > > wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> https://ibamr.github.io/linux
>>>>>> says
>>>>>> > > > >>>> petsc-3.17
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Here you are using 3.13
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Can you retry with
>>>>>> petsc-3.17.5?
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Satish
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU
>>>>>> SRINIVAS
>>>>>> > > > >>>> 20PHD0548 via
>>>>>> > > > >>>> > > >>> > > petsc-users
>>>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Hello,
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I want to build PETSc with
>>>>>> MATLAB for
>>>>>> > > > >>>> working on
>>>>>> > > > >>>> > > >>> the
>>>>>> > > > >>>> > > >>> > > > > >>> simulation
>>>>>> > > > >>>> > > >>> > > > > >>> > > using
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> IBAMR
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > open software. While
>>>>>> building the
>>>>>> > > PETSc,
>>>>>> > > > >>>> using the
>>>>>> > > > >>>> > > >>> > > following
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export
>>>>>> PETSC_ARCH=linux-debug
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > ./configure \
>>>>>> > > > >>>>  --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>>>>>> > > > >>>>  --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>>>>>> > > > >>>>  --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-debugging=1 \
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-hypre=1 \
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-fblaslapack=1 \
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-x=0 \
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4 test
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I got the following error
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > CLINKER
>>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `EvaluateResidual':
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > undefined reference to
>>>>>> > > > >>>> `PetscMatlabEnginePut'
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
>>>>>> > > > >>>> `PetscMatlabEngineEvaluate'
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
>>>>>> > > > >>>> `PetscMatlabEngineGet'
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `EvaluateJacobian':
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `TaoPounders':
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `main':
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
>>>>>> > > > >>>> `PetscMatlabEngineCreate'
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
>>>>>> > > > >>>> `PetscMatlabEngineGetArray'
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
>>>>>> > > > >>>> `PetscMatlabEngineDestroy'
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > collect2: error: ld
>>>>>> returned 1 exit
>>>>>> > > > >>>> status
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: ***
>>>>>> [gmakefile.test:185:
>>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Error 1
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: *** Waiting for
>>>>>> unfinished
>>>>>> > > jobs....
>>>>>> this issue
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Thank you
>>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Srinivas
>>>>>> > > > >>>> > > >>> > > > > >> *Disclaimer:This message was sent from
>>>>>> Vellore
>>>>>> > > > >>>> Institute of
>>>>>> > > > >>>> > > >>> > > Technology.
>>>>>> > > > >>>> > > >>> > > > > >> The contents of this email may contain
>>>>>> legally
>>>>>> > > > >>>> protected
>>>>>> > > > >>>> > > >>> > > confidential or
>>>>>> > > > >>>> > > >>> > > > > >> privileged information of “Vellore
>>>>>> Institute of
>>>>>> > > > >>>> Technology”.
>>>>>> > > > >>>> > > >>> If
>>>>>> > > > >>>> > > >>> > > you are
>>>>>> > > > >>>> > > >>> > > > > >> not the intended recipient, you should
>>>>>> not
>>>>>> > > > >>>> disseminate,
>>>>>> > > > >>>> > > >>> distribute
>>>>>> > > > >>>> > > >>> > > or copy
>>>>>> > > > >>>> > > >>> > > > > >> this e-mail. Please notify the sender
>>>>>> immediately
>>>>>> > > > >>>> and destroy
>>>>>> > > > >>>> > > >>> all
>>>>>> > > > >>>> > > >>> > > copies of
>>>>>> > > > >>>> > > >>> > > > > >> this message and any attachments. If
>>>>>> you have
>>>>>> > > > >>>> received this
>>>>>> > > > >>>> > > >>> email
>>>>>> > > > >>>> > > >>> > > in error,
>>>>>> > > > >>>> > > >>> > > > > >> please promptly notify the sender by
>>>>>> reply email
>>>>>> > > and
>>>>>> > > > >>>> delete
>>>>>> > > > >>>> > > >>> the
>>>>>> > > > >>>> > > >>> > > original
>>>>>> > > > >>>> > > >>> > > > > >> email and any backup copies without
>>>>>> reading
>>>>>> > > them.*
>>>>>> > > > >>>> > > >> *Disclaimer:This message was sent from Vellore
>>>>>> Institute of
>>>>>> > > > >>>> Technology.
>>>>>> > > > >>>> > > >> The contents of this email may contain legally
>>>>>> protected
>>>>>> > > > >>>> confidential or
>>>>>> > > > >>>> > > >> privileged information of “Vellore Institute of
>>>>>> > > Technology”.  If
>>>>>> > > > >>>> you are
>>>>>> > > > >>>> > > >> not the intended recipient, you should not
>>>>>> disseminate,
>>>>>> > > > >>>> distribute or copy
>>>>>> > > > >>>> > > >> this e-mail. Please notify the sender immediately
>>>>>> and destroy
>>>>>> > > > >>>> all copies of
>>>>>> > > > >>>> > > >> this message and any attachments. If you have
>>>>>> received this
>>>>>> > > > >>>> email in error,
>>>>>> > > > >>>> > > >> please promptly notify the sender by reply email
>>>>>> and delete
>>>>>> > > the
>>>>>> > > > >>>> original
>>>>>> > > > >>>> > > >> email and any backup copies without reading them.*
>>>>>> > > > >>>> > > > --Amneet
>>>>>> > > > >>> *Disclaimer:This message was sent from Vellore Institute of
>>>>>> > > Technology.
>>>>>> > > > >>> The contents of this email may contain legally protected
>>>>>> > > confidential or
>>>>>> Technology”.  If you
>>>>>> > > are
>>>>>> > > > >>> not the intended recipient, you should not disseminate,
>>>>>> distribute
>>>>>> > > or copy
>>>>>> > > > >>> this e-mail. Please notify the sender immediately and
>>>>>> destroy all
>>>>>> > > copies of
>>>>>> > > > >>> this message and any attachments. If you have received this
>>>>>> email in
>>>>>> > > error,
>>>>>> > > > >>> please promptly notify the sender by reply email and delete
>>>>>> the
>>>>>> > > original
>>>>>> > > > >> What most experimenters take for granted before they begin
>>>>>> their
>>>>>> > > > >> experiments is infinitely more interesting than any results
>>>>>> to which
>>>>>> > > their
>>>>>> > > > >> experiments lead.
>>>>>> > > > >> -- Norbert Wiener
>>>>>> > > > >> https://www.cse.buffalo.edu/~knepley/
>>>>>> > > > >> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> Technology.
>>>>>> confidential
>>>>>> > > or
>>>>>> > > > > privileged information of “Vellore Institute of Technology”.
>>>>>> If you
>>>>>> > > are
>>>>>> distribute or
>>>>>> > > copy
>>>>>> > > > > this e-mail. Please notify the sender immediately and destroy
>>>>>> all
>>>>>> > > copies of
>>>>>> email in
>>>>>> > > error,
>>>>>> the
>>>>>> > > original
>>>>> Technology.  The contents of this email may contain legally protected
>>>>> confidential or privileged information of “Vellore Institute of
>>>>> Technology”.  If you are not the intended recipient, you should not
>>>>> disseminate, distribute or copy this e-mail. Please notify the sender
>>>>> immediately and destroy all copies of this message and any attachments. If
>>>>> you have received this email in error, please promptly notify the sender by
>>>>> reply email and delete the original email and any backup copies without
>>>>> reading them.*
>>>> --Amneet
>>> *Disclaimer:This message was sent from Vellore Institute of Technology.
>>> The contents of this email may contain legally protected confidential or
>>> privileged information of “Vellore Institute of Technology”.  If you are
>>> not the intended recipient, you should not disseminate, distribute or copy
>>> this e-mail. Please notify the sender immediately and destroy all copies of
>>> this message and any attachments. If you have received this email in error,
>>> please promptly notify the sender by reply email and delete the original
> --Amneet
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230905/f99e0b7e/attachment-0001.html>
