[petsc-users] Error while building PETSc with MATLAB
Amneet Bhalla mail2amneet at gmail.com
Tue Sep 5 13:02:32 CDT 2023
Srinivas --- Do you have a different version of MATLAB that you can
install? If your organization has a MATLAB license, you can install recent
versions of MATLAB from mathworks.com
On Tue, Sep 5, 2023 at 10:37 AM Barry Smith <bsmith at petsc.dev> wrote:
>    Ok, I have no suggestions. It seems to be more an issue with the Matlab
> than PETSc. You could find a pure Matlab example of using the engine (in
> the Matlab documentation) and try it to see if it works.
>    Barry
> On Sep 5, 2023, at 12:27 PM, INTURU SRINIVAS 20PHD0548 <
> inturu.srinivas2020 at vitstudent.ac.in> wrote:
> I replaced e->ep = engOpen(buffer); with e->ep = engOpen("");
> I got the same errors for petsc 3.17.5
> *make all*
>    CC linux-opt/obj/sys/classes/matlabengine/matlab.o
>      CLINKER linux-opt/lib/libpetsc.so.3.17.5
> BEGINNING TO COMPILE MATLAB INTERFACE
> Building with 'gcc'.
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
> In function ‘PetscBinaryWrite’:
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
> warning: ‘err’ may be used uninitialized in this function
> [-Wmaybe-uninitialized]
>   164 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
> MEX completed successfully.
> Now to check if the libraries are working do:
> make PETSC_DIR=/home/vit/sfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
> *make test query=requires queryval=matlab
> DATAFILESPATH=/home/vit/datafiles/*
> Using MAKEFLAGS: -- DATAFILESPATH=/home/vit/datafiles/ queryval=matlab
> query=requires
>      CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
>         TEST linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
> not ok ksp_ksp_tutorials-ex72_12 # Error code: 85
> # [0]PETSC ERROR: --------------------- Error Message
> # [0]PETSC ERROR: Error in external library
> # [0]PETSC ERROR: Unable to start MATLAB engine with
> /usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash
> # [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> # [0]PETSC ERROR: Petsc Release Version 3.17.5, Sep 30, 2022
> # [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by vit Tue Sep
>  5 21:39:22 2023
> # [0]PETSC ERROR: Configure options
> --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
> --with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
> --with-matlab-engine=1 -with-blaslapack-dir=/usr/local/MATLAB/R2020b
> --known-64-bit-blas-indices=1
> # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() at
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:83
> # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() at
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:332
> # [0]PETSC ERROR: #3 PetscMatlabEnginePut() at
> /home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:245
> # [0]PETSC ERROR: #4 MatLUFactorNumeric_Matlab() at
> /home/vit/sfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
> # [0]PETSC ERROR: #5 MatLUFactorNumeric() at
> /home/vit/sfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
> # [0]PETSC ERROR: #6 PCSetUp_LU() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
> # [0]PETSC ERROR: #7 PCSetUp() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
> # [0]PETSC ERROR: #8 KSPSetUp() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
> # [0]PETSC ERROR: #9 main() at
> /home/vit/sfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
> # [0]PETSC ERROR: PETSc Option Table entries:
> # [0]PETSC ERROR: -check_pointer_intensity 0
> # [0]PETSC ERROR: -error_output_stdout
> # [0]PETSC ERROR: -f0 /home/vit/datafiles//matrices/arco1
> # [0]PETSC ERROR: -malloc_dump
> # [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
> # [0]PETSC ERROR: -pc_type lu
> # [0]PETSC ERROR: -use_gpu_aware_mpi 0
> # [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> # with errorcode 85.
> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> # You may or may not see output from other processes, depending on
> # exactly when Open MPI kills them.
>  ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
> # FAILED ksp_ksp_tutorials-ex72_12
> # To rerun failed tests:
> #     /usr/bin/make -f gmakefile test test-fail=1
> Thanks and regards
> Srinivas
> On Tue, Sep 5, 2023 at 9:05 PM Barry Smith <bsmith at petsc.dev> wrote:
>>     The error is occuring during
>> Since the direct launch of /usr/local/MATLAB/R2020b/bin/matlab -glnxa64
>> -nodisplay  -nosplash from your terminal shell worked we have to assume the
>> problem is occuring when engOpen() is attempting to connect the stdout and
>> stdin from the Matlab session that is launched to the executable.
>> You can try the following. In 3.17.5 edit the
>> file src/sys/classes/matlabengine/matlab.c and locate the line
>> replace it with
>> Now in the PETSc directory do make all (it should recompile one file) and
>> then run the
>> again
>> On Sep 5, 2023, at 3:39 AM, INTURU SRINIVAS 20PHD0548 via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> Hi Amneeth,
>> I think the errors are different with petsc 3.17.5
>> *./configure --CC=/usr/bin/mpicc --CXX=/usr/bin/mpicxx
>> --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
>> PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
>> --with-blaslapack-dir=/usr/local/MATLAB/R2020b
>> --known-64-bit-blas-indices=1 --with-matlab-engine=1*
>> The version of PETSc you are using is out-of-date, we recommend updating
>> to the new release
>>  Available Version: 3.19.5   Installed Version: 3.17.5
>> https://petsc.org/release/download/
>>                          Configuring PETSc to compile on your system
>> Compilers:
>>   C Compiler:         /usr/bin/mpicc  -fPIC -Wall -Wwrite-strings
>> -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector
>> -fvisibility=hidden -O3
>>     Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>   C++ Compiler:         /usr/bin/mpicxx  -Wall -Wwrite-strings
>> -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch
>> -fstack-protector -fvisibility=hidden -O3  -std=gnu++17 -fPIC
>>     Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
>>   Fortran Compiler:         /usr/bin/mpif90  -fPIC -Wall
>> -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3
>>     Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>> Linkers:
>>   Shared linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>>   Dynamic linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>>   Libraries linked against:   -lquadmath -lstdc++ -ldl
>> BlasLapack:
>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64
>> /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so -liomp5 -lpthread
>>   uses OpenMP; use export OMP_NUM_THREADS=<p> or -omp_num_threads <p> to
>> control the number of threads
>>   uses 8 byte integers
>> MPI:
>>   Version:  3
>>   mpiexec: /usr/bin/mpiexec
>>   Implementation: openmpi
>>   OMPI_VERSION: 4.0.3
>> pthread:
>> cmake:
>>   Version:  3.16.3
>>   /usr/bin/cmake
>> regex:
>> Matlab:
>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
>> MatlabEngine:
>>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/bin/glnxa64
>> -L/usr/local/MATLAB/R2020b/bin/glnxa64
>> -Wl,-rpath,/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat
>> -lmwm_dispatcher -lmwopcmodel -lmwservices -lmwopcmodel -lmwm_dispatcher
>> -lmwmpath -lmwopcmodel -lmwservices -lmwopcmodel -lmwservices -lxerces-c
>>   Language used to compile PETSc: C
>> PETSc:
>>   PETSC_ARCH: linux-opt
>>   PETSC_DIR: /home/vit/ibamrsfw/petsc/3.17.5
>>   Prefix: <inplace installation>
>>   Scalar type: real
>>   Precision: double
>>   Support for __float128
>>   Integer size: 4 bytes
>>   Single library: yes
>>   Shared libraries: yes
>>   Memory alignment from malloc(): 16 bytes
>>   Using GNU make: /usr/bin/make
>> xxx=========================================================================xxx
>>  Configure stage complete. Now build PETSc libraries with:
>>    make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt all
>> *$make*
>> FC linux-opt/obj/tao/f90-mod/petsctaomod.o
>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
>> make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
>> *$make test query=requires queryval=matlab
>> /usr/bin/python3 /home/vit/ibamrsfw/petsc/3.17.5/config/gmakegentest.py
>> --petsc-dir=/home/vit/ibamrsfw/petsc/3.17.5 --petsc-arch=linux-opt
>> --testdir=./linux-opt/tests
>> query=requires
>>           CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
>> shooting.
>> Sep  5 10:15:57 2023
>> # [0]PETSC ERROR: Configure options --CC=/usr/bin/mpicc
>> --CXX=/usr/bin/mpicxx --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
>> FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:82
>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:331
>> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:244
>> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
>> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
>> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
>> To get the info of the error there is no specific probe id reported.
>> How to check error info and proceed further?
>> Thanks and regards
>> Srinivas
>> On Tue, Sep 5, 2023 at 1:08 AM Amneet Bhalla <mail2amneet at gmail.com>
>> wrote:
>>> Do you get similar errors with petsc 3.17.5 using the new configure
>>> options that Satish mentioned?
>>> On Sun, Sep 3, 2023 at 10:19 PM INTURU SRINIVAS 20PHD0548 via
>>> petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>> Sorry for missing that.
>>>> */usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash*
>>>>                             < M A T L A B (R) >
>>>>                   Copyright 1984-2020 The MathWorks, Inc.
>>>>               R2020b Update 3 (9.9.0.1538559) 64-bit (glnxa64)
>>>>                              November 23, 2020
>>>> To get started, type doc.
>>>> For product information, visit www.mathworks.com.
>>>> Thanks and regards
>>>> Srinivas
>>>> On Mon, Sep 4, 2023 at 10:19 AM Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> You are missing one more step:
>>>>> > [0] PetscInitialize(): Running on machine: MB108SMEC028
>>>>> > [0] PetscMatlabEngineCreate(): Starting MATLAB engine with command
>>>>> No run matlab manually on "MB108SMEC028" with the command
>>>>> "/usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash"
>>>>> Does this work for you? As the message indicates this command is
>>>>> invoked by "matlab_ls_test" - and that is failing.
>>>>> Satish
>>>>> On Mon, 4 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
>>>>> > Hi Sathish,
>>>>> > I tried the following procedure
>>>>> > *$make *
>>>>> > CLINKER linux-opt/lib/libpetsc.so.3.13.4
>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>>> >   167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
>>>>> > make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt check
>>>>> queryval=matlab
>>>>> > query=requires
>>>>> > not ok ksp_ksp_tutorials-ex72_12 # Error code: 139
>>>>> > # [0]PETSC ERROR: Unable to start MATLAB engine on
>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> > # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
>>>>> Mon Sep
>>>>> >  4 10:02:32 2023
>>>>> > # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
>>>>> > /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
>>>>> > # [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>> > # [0]PETSC ERROR:
>>>>> Mon Sep
>>>>> >  4 10:02:32 2023
>>>>> > # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() line 316 in
>>>>> > # [0]PETSC ERROR:
>>>>> > # [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>> Violation,
>>>>> > probably memory access out of range
>>>>> > # [0]PETSC ERROR: Try option -start_in_debugger or
>>>>> -on_error_attach_debugger
>>>>> > # [0]PETSC ERROR: or see
>>>>> > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>> > # [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>> Mac OS
>>>>> > X to find memory corruption errors
>>>>> > # [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>>> link,
>>>>> > and run
>>>>> > # [0]PETSC ERROR: to get more information on the crash.
>>>>> > # [0]PETSC ERROR: Signal received
>>>>> Mon Sep
>>>>> >  4 10:02:32 2023
>>>>> > # [0]PETSC ERROR: #3 User provided function() line 0 in  unknown file
>>>>> > # with errorcode 50162059.
>>>>> >           CC
>>>>> > linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
>>>>> >      CLINKER
>>>>> >         TEST
>>>>> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>>> > not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error
>>>>> code: 124
>>>>> > # Running problem 5
>>>>> > # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named
>>>>> MB108SMEC028 by
>>>>> > vit Mon Sep  4 10:02:34 2023
>>>>> > # [0]PETSC ERROR: #2 main() line 126 in
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
>>>>> > # [0]PETSC ERROR: -prob_id 5
>>>>> > # [0]PETSC ERROR: -tao_smonitor
>>>>> entire
>>>>> > # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>>>>> > # with errorcode 126076.
>>>>> >  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP Command
>>>>> failed
>>>>> > so no diff
>>>>> > #   Summary
>>>>> > # success 0/2 tests (0.0%)
>>>>> > # failed 2/2 tests (100.0%)
>>>>> > # todo 0/2 tests (0.0%)
>>>>> > # skip 0/2 tests (0.0%)
>>>>> > # Wall clock time for tests: 4 sec
>>>>> > # Approximate CPU time (not incl. build time): 0.03 sec
>>>>> > # Timing summary (actual test time / total CPU time):
>>>>> > #   ksp_ksp_tutorials-ex72_12: 0.01 sec / 0.02 sec
>>>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.01 sec /
>>>>> 0.01 sec
>>>>> > *$cd src/tao/leastsquares/tutorials/matlab/*
>>>>> > *$make matlab_ls_test*
>>>>> > /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall
>>>>> -Wwrite-strings
>>>>> > -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>>> > -fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings
>>>>> > -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
>>>>> >  -I/home/vit/sfw/petsc/3.13.4/include
>>>>> > -I/home/vit/sfw/petsc/3.13.4/linux-opt/include
>>>>> > -I/home/vit/sfw/linux/openmpi/4.1.4/include      matlab_ls_test.c
>>>>> >  -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>>> > -L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>>>> > -Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>>> > -L/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>>> > -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
>>>>> > -L/usr/lib/gcc/x86_64-linux-gnu/9
>>>>> -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>>>>> > -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>>>>> > -L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm -leng -lmex
>>>>> -lmx
>>>>> > -lmat -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr
>>>>> -lmpi_mpifh
>>>>> > -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread
>>>>> -lquadmath
>>>>> > -lstdc++ -ldl -o matlab_ls_test
>>>>> > *$LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 ./matlab_ls_test
>>>>> >  -tao_smonitor -prob_id 5 -info*
>>>>> > [0] PetscInitialize(): PETSc successfully started: number of
>>>>> processors = 1
>>>>> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
>>>>> > MB108SMEC028.(none)
>>>>> > Running problem 5
>>>>> > [0] PetscCommDuplicate(): Duplicating a communicator 140155238476992
>>>>> > 94202473157392 max tags = 2147483647
>>>>> > [0]PETSC ERROR: See
>>>>> > [0]PETSC ERROR: ./matlab_ls_test on a linux-opt named MB108SMEC028
>>>>> by vit
>>>>> > Mon Sep  4 10:09:56 2023
>>>>> > [0]PETSC ERROR: #2 main() line 126 in matlab_ls_test.c
>>>>> > [0]PETSC ERROR: -info
>>>>> entire
>>>>> > Please find the attachment for configure.log and make.log files
>>>>> > On Sun, Sep 3, 2023 at 8:00 PM Satish Balay <balay at mcs.anl.gov>
>>>>> wrote:
>>>>> > > To use datafiles in the test suite:
>>>>> > > cd $HOME
>>>>> > > git clone https://gitlab.com/petsc/datafiles
>>>>> > > <configure should now pick up this location and set DATAFILESPATH
>>>>> - or set
>>>>> > > manually with make>
>>>>> DATAFILESPATH=$HOME/datafiles
>>>>> > > Satish
>>>>> > > On Sun, 3 Sep 2023, Matthew Knepley wrote:
>>>>> > > > On Sun, Sep 3, 2023 at 8:47 AM INTURU SRINIVAS 20PHD0548 <
>>>>> > > > > Hi Matthew,
>>>>> > > > > I am using PETSc to simulate the problems using IBAMR. I do
>>>>> not have
>>>>> > > any
>>>>> > > > > separate test files to test PETSc alone. Can you please help
>>>>> me how to
>>>>> > > > > define this DATAFILESPATH?
>>>>> > > > That test you tried uses a certain matrix. On our machine, we
>>>>> point to
>>>>> > > this
>>>>> > > > matrix using an environment variable, DATAFILESPATH. You don't
>>>>> have those
>>>>> > > > matrices, since they are just for testing here. That
>>>>> > > > is why I suggested just using a different matrix, or running a
>>>>> problem
>>>>> > > you
>>>>> > > > care about in IBAMR.
>>>>> > > >   Thanks,
>>>>> > > >      Matt
>>>>> > > > > Thanks and regards
>>>>> > > > > Srinivas.
>>>>> > > > > On Sun, Sep 3, 2023 at 6:06 PM Matthew Knepley <
>>>>> knepley at gmail.com>
>>>>> > > wrote:
>>>>> > > > >> On Sun, Sep 3, 2023 at 3:04 AM INTURU SRINIVAS 20PHD0548 via
>>>>> > > petsc-users <
>>>>> > > > >>> Hi Sathish,
>>>>> > > > >>> Thank you so much for your efforts and the support you are
>>>>> giving me
>>>>> > > to
>>>>> > > > >>> sort this out.
>>>>> > > > >>> I tried to follow the same procedure which you followed to
>>>>> build
>>>>> > > Petsc
>>>>> > > > >>> 3.13.4 with Matlab-R2020b on Ubuntu20.04.
>>>>> > > > >>> *$./configure
>>>>> > > > >>> Using python3 for Python
>>>>> > > > >>>                                         It appears you do
>>>>> not have
>>>>> > > valgrind
>>>>> > > > >>> installed on your system.
>>>>> > > > >>>   We HIGHLY recommend you install it from www.valgrind.org
>>>>> > > > >>>                                              Or install
>>>>> > > valgrind-devel or
>>>>> > > > >>> equivalent using your package manager.
>>>>> > > > >>>           Then rerun ./configure
>>>>> > > > >>>                                   Compilers:
>>>>> > > > >>>   C Compiler:
>>>>> > > -fPIC
>>>>> > > > >>> -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>> > > > >>>   C++ Compiler:
>>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>>> > > > >>> -fstack-protector -fvisibility=hidden -O3  -fPIC
>>>>> > > > >>>   Fortran Compiler:
>>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>>> > > > >>>  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument
>>>>> -O3
>>>>> 9.4.0
>>>>> > > > >>> Linkers:
>>>>> > > > >>>   Shared linker:
>>>>> > > -shared
>>>>> > > > >>>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>> > > > >>>   Dynamic linker:
>>>>> > > -shared
>>>>> > > > >>> make:
>>>>> > > > >>>   Version:  4.2
>>>>> > > > >>>   /usr/bin/make
>>>>> > > > >>> BlasLapack:
>>>>> > > > >>>   Library:  /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so
>>>>> > > > >>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5 -lpthread
>>>>> -omp_num_threads
>>>>> > > <p> to
>>>>> > > > >>> MPI:
>>>>> > > > >>>   Version:  3
>>>>> > > > >>>   Includes: -I/home/vit/sfw/linux/openmpi/4.1.4/include
>>>>> > > > >>>   Mpiexec: /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec
>>>>> > > --oversubscribe
>>>>> > > > >>>   OMPI_VERSION: 4.1.4
>>>>> > > > >>> pthread:
>>>>> > > > >>> cmake:
>>>>> > > > >>>   Version:  3.16.3
>>>>> > > > >>>   /usr/bin/cmake
>>>>> > > > >>> regex:
>>>>> > > > >>> Matlab:
>>>>> > > > >>> MatlabEngine:
>>>>> > > > >>>   Library:
>>>>> -lmx -lmat
>>>>> > > -lut
>>>>> > > > >>> -licudata -licui18n -licuuc
>>>>> > > > >>> PETSc:
>>>>> > > > >>>   PETSC_DIR: /home/vit/sfw/petsc/3.13.4
>>>>> > > > >>>   Scalar type: real
>>>>> > > > >>>   Precision: double
>>>>> > > > >>>   shared libraries: enabled
>>>>> > > > >>> Then I removed all occurrences of -lut -licudata -licui18n
>>>>> -licuuc as
>>>>> > > > >>> you suggested earlier.
>>>>> > > > >>> *$make*
>>>>> socket\n");
>>>>> socket\n");
>>>>> > > > >>> *$make test query=requires queryval=matlab*
>>>>> > > > >>> Using MAKEFLAGS: -- queryval=matlab query=requires
>>>>> > > > >>>         TEST
>>>>> > > > >>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
>>>>> > > > >>> # [0]PETSC ERROR: Unable to open file
>>>>> > > > >>> # [0]PETSC ERROR: Cannot locate file: /matrices/arco1
>>>>> > > > >> No, the problem is that you do not have DATAFILESPATH
>>>>> defined, so it
>>>>> > > > >> cannot find the matrix to test. Try running some test of
>>>>> yours.
>>>>> > > > >>   Thanks,
>>>>> > > > >>      Matt
>>>>> > > > >>> https://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>>> trouble
>>>>> > > > >>> shooting.
>>>>> by vit
>>>>> > > Sun
>>>>> > > > >>> Sep  3 11:51:03 2023
>>>>> COPTFLAGS=-O3
>>>>> --with-debugging=0
>>>>> > > > >>> # [0]PETSC ERROR: #1 PetscViewerFileSetUp_BinarySTDIO() line
>>>>> 1444 in
>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
>>>>> > > > >>> # [0]PETSC ERROR: #2 PetscViewerSetUp_Binary() line 1511 in
>>>>> > > > >>> # [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
>>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
>>>>> > > > >>> # [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
>>>>> > > > >>> # [0]PETSC ERROR: #5 MatLoad() line 1225 in
>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
>>>>> > > > >>> # [0]PETSC ERROR: #6 main() line 113 in
>>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
>>>>> > > > >>> # [0]PETSC ERROR: -f0 /matrices/arco1
>>>>> -------send
>>>>> > > > >>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>> MPI_COMM_SELF
>>>>> > > > >>> # with errorcode 113065.
>>>>> processes.
>>>>> depending on
>>>>> diff
>>>>> > > > >>>           CC
>>>>> > > > >>>      CLINKER
>>>>> > > > >>>         TEST
>>>>> Error
>>>>> > > code: 124
>>>>> > > > >>> # Running problem 5
>>>>> trouble
>>>>> > > > >>> shooting.
>>>>> > > MB108SMEC028 by
>>>>> > > > >>> vit Sun Sep  3 11:51:05 2023
>>>>> COPTFLAGS=-O3
>>>>> --with-debugging=0
>>>>> -------send
>>>>> MPI_COMM_SELF
>>>>> processes.
>>>>> depending on
>>>>> Command
>>>>> > > > >>> failed so no diff
>>>>> > > > >>> #   Summary
>>>>> > > > >>> # Wall clock time for tests: 3 sec
>>>>> > > > >>> # Approximate CPU time (not incl. build time): 0.05 sec
>>>>> > > > >>> #   ksp_ksp_tutorials-ex72_12: 0.02 sec / 0.03 sec
>>>>> > > > >>> #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.02
>>>>> sec /
>>>>> > > 0.02 sec
>>>>> > > > >>> *How to sort out this error?*
>>>>> > > -Wwrite-strings
>>>>> -O3
>>>>> matlab_ls_test.c
>>>>> -lmex
>>>>> > > -lmx
>>>>> > > -lmpi_mpifh
>>>>> -lpthread
>>>>> > > -lquadmath
>>>>> > > > >>> I think there is a problem with the Matlab-R2020b version.
>>>>> > > > >>> I am sharing the configure.log and make.log files. Please
>>>>> find the
>>>>> > > > >>> attachment and do the needful.
>>>>> > > > >>> Thanks and regards
>>>>> > > > >>> Srinivas
>>>>> > > > >>> On Sat, Sep 2, 2023 at 11:15 PM Satish Balay <
>>>>> > > wrote:
>>>>> > > > >>>> Perhaps you can try the following to get additional info -
>>>>> and debug
>>>>> > > > >>>> Satish
>>>>> > > > >>>> balay at compute-386-07:/scratch/balay/petsc$ cd
>>>>> > > :/scratch/balay/petsc/src/tao/leastsquares/tutorials/matlab$
>>>>> > > > >>>> make matlab_ls_test
>>>>> > > > >>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc
>>>>> -fPIC
>>>>> > > -Wall
>>>>> > > > >>>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>>>>> > > -fstack-protector
>>>>> -O3
>>>>> > > > >>>> -I/scratch/balay/petsc/include
>>>>> > > -I/scratch/balay/petsc/linux-opt/include
>>>>> -I/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/include
>>>>> > > > >>>> -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
>>>>> > > > >>>> matlab_ls_test.c
>>>>> -Wl,-rpath,/scratch/balay/petsc/linux-opt/lib
>>>>> > > > >>>> -L/scratch/balay/petsc/linux-opt/lib
>>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64
>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>>> -Wl,-rpath,/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>>> > > > >>>> -L/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>>> > > > >>>> -L/lib/x86_64-linux-gnu -lpetsc -llapack -lblas -lpthread
>>>>> -lm -leng
>>>>> > > -lmex
>>>>> > > > >>>> -lmx -lmat -lut -licudata -licui18n -licuuc -lstdc++ -ldl
>>>>> -lmpifort
>>>>> > > -lmpi
>>>>> > > > >>>> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++
>>>>> -ldl -o
>>>>> > > > >>>> matlab_ls_test
>>>>> ./matlab_ls_test
>>>>> > > processors
>>>>> > > > >>>> = 1
>>>>> > > > >>>> compute-386-07.(none)
>>>>> > > > >>>> [0] PetscInitialize(): Running on machine: compute-386-07
>>>>> > > > >>>> Running problem 5
>>>>> 1140850689
>>>>> > > > >>>> -2080374784 max tags = 268435455
>>>>> command
>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/matlab
>>>>> > > > >>>> [0] PetscMatlabEngineCreate(): Started MATLAB engine
>>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Evaluating MATLAB string:
>>>>> > > > >>>> TestingInitialize
>>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Done evaluating Matlab
>>>>> string:
>>>>> > > > >>>> TestingInitialize
>>>>> > > > >>>> 5
>>>>> > > > >>>> <snip>
>>>>> > > > >>>> <<<< Now verify if the above matlab command actually works
>>>>> for you
>>>>> > > - on
>>>>> > > > >>>> this machine..>>>>>
>>>>> > > > >>>>                                    < M A T L A B (R) >
>>>>> > > > >>>>                          Copyright 1984-2021 The MathWorks,
>>>>> Inc.
>>>>> > > > >>>>                          R2021a (9.10.0.1602886) 64-bit
>>>>> (glnxa64)
>>>>> > > > >>>>                                     February 17, 2021
>>>>> > > > >>>> On Sat, 2 Sep 2023, Satish Balay via petsc-users wrote:
>>>>> > > > >>>> > Please don't cc: both petsc-users and petsc-maint
>>>>> [reverting
>>>>> > > thread
>>>>> > > > >>>> to petsc-users only]
>>>>> > > > >>>> > I'm not sure what is happening here. Can you send the
>>>>> > > corresponding
>>>>> > > > >>>> configure.log, make.log [compressed]?
>>>>> > > > >>>> > Here is my attempt to reproduce (with petsc-3.13) on
>>>>> Ubuntu-20.04,
>>>>> > > > >>>> with Matlab-R2021a - and that works:
>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ git branch
>>>>> > > > >>>> >   main
>>>>> > > > >>>> >   release
>>>>> > > > >>>> > * release-3.13
>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ module load
>>>>> > > matlab/R2021a
>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ which matlab
>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ ./configure
>>>>> --with-mpi-dir=/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/
>>>>> --with-matlab-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>>> --with-blaslapack-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>>> > > > >>>> > <snip>
>>>>> > > > >>>> > Compilers:
>>>>> > > > >>>> >   C Compiler:
>>>>> -fPIC
>>>>> > > -Wall
>>>>> > > -fstack-protector
>>>>> > > > >>>> >   C++ Compiler:
>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicxx  -Wall
>>>>> > > -fstack-protector
>>>>> > > > >>>> >     Version: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>>> > > > >>>> >   Fortran Compiler:
>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpif90  -fPIC
>>>>> > > -Wall
>>>>> > > > >>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>>> 9.4.0
>>>>> > > > >>>> > Linkers:
>>>>> > > > >>>> >   Shared linker:
>>>>> > > -shared  -fPIC
>>>>> > > > >>>> >   Dynamic linker:
>>>>> > > -shared  -fPIC
>>>>> > > > >>>> > make:
>>>>> > > > >>>> >   Version:  4.2
>>>>> > > > >>>> >   /usr/bin/make
>>>>> > > > >>>> > BlasLapack:
>>>>> > > > >>>> >   Library:
>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64/mkl.so
>>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64
>>>>> > > > >>>> -liomp5 -lpthread
>>>>> -omp_num_threads
>>>>> > > <p>
>>>>> > > > >>>> to control the number of threads
>>>>> > > > >>>> > MPI:
>>>>> > > > >>>> >   Version:  4
>>>>> > > > >>>> >   Includes:
>>>>> > > > >>>> >   Mpiexec:
>>>>> > > /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpiexec
>>>>> > > > >>>> >   MPICH_NUMVERSION: 40002300
>>>>> > > > >>>> > pthread:
>>>>> > > > >>>> >   Library:  -lpthread
>>>>> > > > >>>> > cmake:
>>>>> > > > >>>> >   Version:  3.16.3
>>>>> > > > >>>> >   /usr/bin/cmake
>>>>> > > > >>>> > regex:
>>>>> > > > >>>> > Matlab:
>>>>> > > > >>>> >   Includes:
>>>>> > > > >>>> > MatlabEngine:
>>>>> > > > >>>> >   Library:
>>>>> > > > >>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>> > > > >>>> > sowing:
>>>>> > > > >>>> >   Version:  1.1.25
>>>>> > > > >>>> >   /scratch/balay/petsc/linux-opt/bin/bfort
>>>>> > > > >>>> > valgrind:
>>>>> > > > >>>> > PETSc:
>>>>> > > > >>>> >   PETSC_DIR: /scratch/balay/petsc
>>>>> > > > >>>> >   Scalar type: real
>>>>> > > > >>>> >   Precision: double
>>>>> > > > >>>> >    make PETSC_DIR=/scratch/balay/petsc
>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make
>>>>> > > > >>>> > <snip>
>>>>> > > > >>>> >      CLINKER linux-opt/lib/libpetsc.so.3.13.6
>>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c: In
>>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>>> > > socket\n");
>>>>> > > socket\n");
>>>>> > > > >>>> > make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt
>>>>> check
>>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make test
>>>>> > > query=requires
>>>>> > > > >>>> queryval=matlab
>>>>> > > > >>>> >         TEST
>>>>> > > > >>>> > #     ../ex72:
>>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64/libgfortran.so.5:
>>>>> > > > >>>> version `GFORTRAN_9' not found (required by
>>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib/libmpifort.so.12)
>>>>> diff
>>>>> > > > >>>> >           CC
>>>>> > > > >>>> >      CLINKER
>>>>> > > > >>>> >         TEST
>>>>> Error
>>>>> > > code:
>>>>> > > > >>>> 1
>>>>> > > > >>>> > #     ../matlab_ls_test:
>>>>> SKIP
>>>>> > > Command
>>>>> > > > >>>> failed so no diff
>>>>> > > > >>>> > <snip>
>>>>> > > > >>>> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 make test
>>>>> > > query=requires
>>>>> > > > >>>> queryval=matlab
>>>>> > > > >>>> >         TEST
>>>>> > > > >>>> >  ok diff-ksp_ksp_tutorials-ex72_12
>>>>> > > > >>>> >         TEST
>>>>> > > > >>>> >  ok diff-tao_leastsquares_tutorials_matlab-matlab_ls_test
>>>>> > > > >>>> > #   Summary
>>>>> > > > >>>> > # success 4/4 tests (100.0%)
>>>>> > > > >>>> > # failed 0/4 tests (0.0%)
>>>>> > > > >>>> > # todo 0/4 tests (0.0%)
>>>>> > > > >>>> > # skip 0/4 tests (0.0%)
>>>>> > > > >>>> > # Wall clock time for tests: 27 sec
>>>>> 15.190000000000001
>>>>> > > sec
>>>>> 6.47 sec /
>>>>> > > 7.54
>>>>> > > > >>>> sec
>>>>> > > > >>>> > #   ksp_ksp_tutorials-ex72_12: 6.46 sec / 7.65 sec
>>>>> > > > >>>> > On Sat, 2 Sep 2023, INTURU SRINIVAS 20PHD0548 wrote:
>>>>> > > > >>>> > > Based on the suggestions given by Sathish, I have tried
>>>>> to
>>>>> > > > >>>> configure petsc
>>>>> > > > >>>> > > 3.13.4 with Matlab-R2020b. But, it was not successful.
>>>>> After
>>>>> > > > >>>> running make
>>>>> > > > >>>> > > -j 10 test command I have got the following error
>>>>> message.
>>>>> # Error
>>>>> > > > >>>> code: 124
>>>>> > > > >>>> > > # Running problem 5
>>>>> 2020
>>>>> > > > >>>> MB108SMEC028 by
>>>>> > > > >>>> > > vit Sat Sep  2 12:27:22 2023
>>>>> COPTFLAGS=-O3
>>>>> > > > >>>> --with-debugging=0
>>>>> in
>>>>> > > -------send
>>>>> > > > >>>> entire
>>>>> MPI_COMM_SELF
>>>>> MPI
>>>>> > > > >>>> processes.
>>>>> depending
>>>>> > > on
>>>>> > > > >>>> > > I request you to help me to sort out this error.
>>>>> > > > >>>> > > Thanks
>>>>> > > > >>>> > > Srinivas
>>>>> > > > >>>> > > On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <
>>>>> > > > >>>> mail2amneet at gmail.com> wrote:
>>>>> > > > >>>> > > > I think there should be two hyphens in
>>>>> > > > >>>> > > > i.e.:
>>>>> > > > >>>> > > > On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS
>>>>> 20PHD0548 via
>>>>> > > > >>>> petsc-users <
>>>>> > > > >>>> > > >> Thank you Sathish.I will try this
>>>>> > > > >>>> > > >> On Fri, Sep 1, 2023, 22:53 Satish Balay <
>>>>> > > > >>>> wrote:
>>>>> > > > >>>> > > >>> yes [and remove fblaslapack. don't know if hypre
>>>>> will work
>>>>> > > > >>>> here].
>>>>> > > > >>>> > > >>> i.e:
>>>>> > > > >>>> > > >>> ./configure
>>>>> > > > >>>> > > >>> --with-debugging=0 --with-x=0 \
>>>>> > > > >>>> > > >>> Satish
>>>>> > > > >>>> > > >>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via
>>>>> > > petsc-users
>>>>> > > > >>>> wrote:
>>>>> > > > >>>> > > >>> > Hi Satish,
>>>>> > > > >>>> > > >>> > -with-blaslapack-dir=/path/to/matlab_dir
>>>>> > > > >>>> > > >>> > Is this what you are suggesting?
>>>>> > > > >>>> > > >>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <
>>>>> > > > >>>> wrote:
>>>>> > > > >>>> > > >>> > > Also:
>>>>> > > > >>>> > > >>> > >     '-known-64-bit-blas-indices=1',
>>>>> > > > >>>> > > >>> > > Note: most externalpackages might not work in
>>>>> this mode.
>>>>> > > > >>>> > > >>> > > [we can't really over come such
>>>>> dependency/conflicts
>>>>> > > across
>>>>> > > > >>>> packages]
>>>>> > > > >>>> > > >>> > > Satish
>>>>> > > > >>>> > > >>> > > On Fri, 1 Sep 2023, Satish Balay via
>>>>> petsc-users wrote:
>>>>> > > > >>>> > > >>> > > > Here is the matlab test that runs in CI
>>>>> https://gitlab.com/petsc/petsc/-/jobs/4904566768
>>>>> > > > >>>> > > >>> > > > config/examples/arch-ci-linux-matlab-ilp64.py
>>>>> > > > >>>> > > >>> > > > # Note: regular BLAS [with 32-bit integers]
>>>>> conflict
>>>>> > > with
>>>>> > > > >>>> > > >>> > > > # MATLAB BLAS - hence requiring
>>>>> > > > >>>> > > >>> > > > Ah - so you need to use the ilp64 blas/lapack
>>>>> with
>>>>> > > > >>>> matlab  - to
>>>>> > > > >>>> > > >>> have a
>>>>> > > > >>>> > > >>> > > compatible build
>>>>> > > > >>>> > > >>> > > >     '--with-blaslapack-dir='+matlab_dir,
>>>>> > > > >>>> > > >>> > > > Satish
>>>>> via
>>>>> > > > >>>> petsc-users
>>>>> > > > >>>> > > >>> wrote:
>>>>> > > > >>>> > > >>> > > > > Hi Amneet,
>>>>> > > > >>>> > > >>> > > > > Without libmesh, even for PETSc with MATLAB
>>>>> is not
>>>>> > > > >>>> working. It is
>>>>> > > > >>>> > > >>> > > showing
>>>>> > > > >>>> > > >>> > > > > error for both 3.13.4 and 3.17.5 versions.
>>>>> > > > >>>> > > >>> > > > > I am trying to install IBAMR in HPC cluster
>>>>> with
>>>>> > > > >>>> libmesh and
>>>>> > > > >>>> > > >>> this is
>>>>> > > > >>>> > > >>> > > for
>>>>> > > > >>>> > > >>> > > > > general usage not only for WEC. This I
>>>>> tried without
>>>>> > > > >>>> linking
>>>>> > > > >>>> > > >>> Matlab
>>>>> > > > >>>> > > >>> > > with
>>>>> > > > >>>> > > >>> > > > > PETSc. Here also I got the error while
>>>>> configuring
>>>>> > > > >>>> libmesh 1.6.2
>>>>> > > > >>>> > > >>> that
>>>>> > > > >>>> > > >>> > > PETSc
>>>>> > > > >>>> > > >>> > > > > was not found but --enable-petsc-required is
>>>>> > > specified.
>>>>> > > > >>>> > > >>> > > > > The reason for specifically asking for
>>>>> libmesh with
>>>>> > > > >>>> PETSc and
>>>>> > > > >>>> > > >>> Matlab
>>>>> > > > >>>> > > >>> > > is in
>>>>> > > > >>>> > > >>> > > > > the cfd-mpc-wecs application for complicated
>>>>> > > geometries
>>>>> > > > >>>> it is
>>>>> > > > >>>> > > >>> > > mentioned to
>>>>> > > > >>>> > > >>> > > > > build cfd-mpc-wecs with libmesh construct.
>>>>> > > > >>>> > > >>> > > > > For the past 10 days I am trying these
>>>>> various
>>>>> > > things
>>>>> > > > >>>> and ended
>>>>> > > > >>>> > > >>> up with
>>>>> > > > >>>> > > >>> > > > > errors.
>>>>> > > > >>>> > > >>> > > > > I want to solve this and proceed further to
>>>>> do my
>>>>> > > > >>>> research work.
>>>>> > > > >>>> > > >>> > > > > Please help me to solve this as soon as
>>>>> possible.
>>>>> > > > >>>> > > >>> > > > > Thanks and Regards
>>>>> > > > >>>> > > >>> > > > > Srinivas
>>>>> > > > >>>> > > >>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <
>>>>> > > > >>>> > > >>> > > wrote:
>>>>> > > > >>>> > > >>> > > > > > Hi Srinivas,
>>>>> > > > >>>> > > >>> > > > > > As discussed earlier you don’t need
>>>>> libMesh for
>>>>> > > the
>>>>> > > > >>>> WEC
>>>>> > > > >>>> > > >>> application.
>>>>> > > > >>>> > > >>> > > You
>>>>> > > > >>>> > > >>> > > > > > can just work with PETSc 3.17.5 that
>>>>> builds with
>>>>> > > > >>>> Matlab.
>>>>> > > > >>>> > > >>> > > > > > Do you have a specific reason for wanting
>>>>> to build
>>>>> > > > >>>> libMesh?
>>>>> > > > >>>> > > >>> > > > > > Thanks,
>>>>> > > > >>>> > > >>> > > > > > —Amneet
>>>>> > > > >>>> > > >>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU
>>>>> SRINIVAS
>>>>> > > > >>>> 20PHD0548 via
>>>>> > > > >>>> > > >>> > > petsc-users
>>>>> > > > >>>> > > >>> > > > > >> Hi,
>>>>> > > > >>>> > > >>> > > > > >> I ran "make all" for petsc 3.13.4 by
>>>>> removing all
>>>>> > > > >>>> occurrences
>>>>> > > > >>>> > > >>> of
>>>>> > > > >>>> > > >>> > > "-lut
>>>>> > > > >>>> > > >>> > > > > >> -licudata -licui18n -licuuc". When I ran
>>>>> "make
>>>>> > > test"
>>>>> > > > >>>> got the
>>>>> > > > >>>> > > >>> > > following
>>>>> > > > >>>> > > >>> > > > > >> errors
>>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-debug:
>>>>> > > > >>>> > > >>> > > > > >> TEST
>>>>> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>>> > > > >>>> > > >>> > > > > >> not ok
>>>>> > > > >>>> > > >>> Error
>>>>> > > > >>>> > > >>> > > code: 124
>>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>>> Error
>>>>> > > Message
>>>>> library
>>>>> engine
>>>>> > > on
>>>>> > > > >>>> for
>>>>> > > > >>>> > > >>> trouble
>>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>>> 3.13.4,
>>>>> > > Aug
>>>>> > > > >>>> 01, 2020
>>>>> > > linux-debug
>>>>> > > > >>>> named
>>>>> > > > >>>> > > >>> > > MB108SMEC028
>>>>> > > > >>>> > > >>> > > > > >> by vit Fri Sep  1 10:01:11 2023
>>>>> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>>>> > > --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>>> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>>> > > > >>>> > > >>> --with-debugging=1
>>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1
>>>>> --download-fblaslapack=1
>>>>> > > > >>>> --with-x=0
>>>>> --with-matlab-dir=/usr/local/MATLAB/R2020b/
>>>>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
>>>>> > > line
>>>>> > > > >>>> 67 in
>>>>> entries:
>>>>> Error
>>>>> > > > >>>> Message
>>>>> > > > >>>> > > >>> -------send
>>>>> > > > >>>> > > >>> > > entire
>>>>> > > > >>>> > > >>> > > > > >> error message to
>>>>> communicator
>>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>>> MPI to
>>>>> > > kill
>>>>> > > > >>>> all MPI
>>>>> > > > >>>> > > >>> > > processes.
>>>>> other
>>>>> > > processes,
>>>>> > > > >>>> > > >>> depending on
>>>>> > > > >>>> > > >>> > > > > >>  ok
>>>>> > > > >>>> # SKIP
>>>>> > > > >>>> > > >>> Command
>>>>> > > > >>>> > > >>> > > > > >> failed so no diff
>>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-opt
>>>>> > > > >>>> > > >>> > > > > >>  TEST
>>>>> > > > >>>> > > >>> > > > > >> not ok
>>>>> > > > >>>> > > >>> Error
>>>>> > > > >>>> > > >>> > > code: 124
>>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>>> Error
>>>>> > > Message
>>>>> library
>>>>> engine
>>>>> > > on
>>>>> > > > >>>> for
>>>>> > > > >>>> > > >>> trouble
>>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>>> 3.13.4,
>>>>> > > Aug
>>>>> > > > >>>> 01, 2020
>>>>> > > linux-opt
>>>>> > > > >>>> named
>>>>> > > > >>>> > > >>> > > MB108SMEC028 by
>>>>> > > > >>>> > > >>> > > > > >> vit Fri Sep  1 10:34:12 2023
>>>>> > > > >>>> > > >>> --COPTFLAGS=-O3
>>>>> > > > >>>> > > >>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>>> > > > >>>> --PETSC_ARCH=linux-opt
>>>>> > > > >>>> > > >>> > > --with-debugging=0
>>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1 --with-x=0
>>>>> > > line
>>>>> > > > >>>> 67 in
>>>>> entries:
>>>>> Error
>>>>> > > > >>>> Message
>>>>> > > > >>>> > > >>> -------send
>>>>> > > > >>>> > > >>> > > entire
>>>>> > > > >>>> > > >>> > > > > >> error message to
>>>>> communicator
>>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>>> MPI to
>>>>> > > kill
>>>>> > > > >>>> all MPI
>>>>> > > > >>>> > > >>> > > processes.
>>>>> other
>>>>> > > processes,
>>>>> > > > >>>> > > >>> depending on
>>>>> > > > >>>> > > >>> > > > > >>  ok
>>>>> > > > >>>> # SKIP
>>>>> > > > >>>> > > >>> Command
>>>>> > > > >>>> > > >>> > > > > >> failed so no diff.
>>>>> > > > >>>> > > >>> > > > > >> The same errors occurred for petsc 3.17.5
>>>>> > > version. I
>>>>> > > > >>>> am
>>>>> > > > >>>> > > >>> sharing the
>>>>> > > > >>>> > > >>> > > > > >> config.log and make.log for both petsc
>>>>> 3.13.4 and
>>>>> > > > >>>> petsc
>>>>> > > > >>>> > > >>> 3.17.5.
>>>>> > > > >>>> > > >>> > > Please find
>>>>> > > > >>>> > > >>> > > > > >> the attachment and do the needful.
>>>>> > > > >>>> > > >>> > > > > >> Thanks and regards
>>>>> > > > >>>> > > >>> > > > > >> Srinivas
>>>>> > > > >>>> > > >>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish
>>>>> Balay <
>>>>> > > > >>>> > > >>> > > wrote:
>>>>> > > > >>>> > > >>> > > > > >>> Well - you sent in libmesh log not
>>>>> petsc's
>>>>> > > > >>>> > > >>> configure.log/make.log
>>>>> > > > >>>> > > >>> > > for
>>>>> > > > >>>> > > >>> > > > > >>> petsc-3.17
>>>>> > > > >>>> > > >>> > > > > >>> Anyway - with petsc-3.13 - you have:
>>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>>> > > > >>>> > > >>> > > > > >>> MatlabEngine:
>>>>> > > > >>>> > > >>> > > > > >>>   Library:
>>>>> > > -leng
>>>>> > > > >>>> -lmex
>>>>> > > > >>>> > > >>> -lmx
>>>>> > > > >>>> > > >>> > > -lmat -lut
>>>>> > > > >>>> > > >>> > > > > >>> With petsc-3.19 (and matlab-R2022a) -
>>>>> we are
>>>>> > > seeing:
>>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>>> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
>>>>> > > > >>>> > > >>> > > > > >>>   Libraries:
>>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>>> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>>> > > > >>>> > > >>> > > > > >>>   Executable:
>>>>> > > > >>>> > > >>> > > > > >>>   mex:
>>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
>>>>> > > > >>>> > > >>> > > > > >>>   matlab:
>>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
>>>>> > > > >>>> > > >>> > > > > >>> -glnxa64
>>>>> > > > >>>> > > >>> > > > > >>> I.e "-lut -licudata -licui18n -licuuc"
>>>>> are not
>>>>> > > > >>>> preset here.
>>>>> > > > >>>> > > >>> This
>>>>> > > > >>>> > > >>> > > might
>>>>> > > > >>>> > > >>> > > > > >>> be a change wrt newer matlab versions.
>>>>> > > > >>>> > > >>> > > > > >>> You can:
>>>>> > > > >>>> > > >>> > > > > >>> - edit
>>>>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
>>>>> > > > >>>> > > >>> > > and
>>>>> > > > >>>> > > >>> > > > > >>> remove all occurrences of "-lut
>>>>> -licudata
>>>>> > > -licui18n
>>>>> > > > >>>> -licuuc"
>>>>> > > > >>>> > > >>> > > > > >>> - now run 'make all' in
>>>>> > > '/home/vit/sfw/petsc/3.13.4'
>>>>> > > > >>>> > > >>> > > > > >>> And see if the build works now.
>>>>> > > > >>>> > > >>> > > > > >>> Satish
>>>>> > > > >>>> > > >>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS
>>>>> 20PHD0548
>>>>> > > via
>>>>> > > > >>>> > > >>> petsc-users
>>>>> > > > >>>> > > >>> > > wrote:
>>>>> > > > >>>> > > >>> > > > > >>> > I am sharing the log files while
>>>>> building
>>>>> > > > >>>> petsc3.13.4 with
>>>>> > > > >>>> > > >>> > > matlab and
>>>>> > > > >>>> > > >>> > > > > >>> also
>>>>> > > > >>>> > > >>> > > > > >>> > the log file while building libmesh
>>>>> with
>>>>> > > > >>>> petsc3.17.5 and
>>>>> > > > >>>> > > >>> matlab.
>>>>> > > > >>>> > > >>> > > > > >>> Building
>>>>> > > > >>>> > > >>> > > > > >>> > petsc 3.17.5 with matlab was done
>>>>> > > successfully.
>>>>> > > > >>>> But
>>>>> > > > >>>> > > >>> libmesh is
>>>>> > > > >>>> > > >>> > > not
>>>>> > > > >>>> > > >>> > > > > >>> able to
>>>>> > > > >>>> > > >>> > > > > >>> > find the petsc
>>>>> > > > >>>> > > >>> > > > > >>> > Please find the attachments.
>>>>> > > > >>>> > > >>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM
>>>>> Satish Balay <
>>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>>> > > > >>>> > > >>> > > > > >>> > > Send configure.log, make.log from
>>>>> both
>>>>> > > > >>>> petsc-3.13 and
>>>>> > > > >>>> > > >>> 3.17 [or
>>>>> > > > >>>> > > >>> > > 3.19].
>>>>> > > > >>>> > > >>> > > > > >>> > > [you can gzip them to make the logs
>>>>> > > friendly to
>>>>> > > > >>>> mailing
>>>>> > > > >>>> > > >>> list -
>>>>> > > > >>>> > > >>> > > or
>>>>> > > > >>>> > > >>> > > > > >>> send
>>>>> > > > >>>> > > >>> > > > > >>> > > them to petsc-maint]
>>>>> > > > >>>> > > >>> > > > > >>> > > And does test suite work with 3.17?
>>>>> [or
>>>>> > > 3.19?]
>>>>> > > > >>>> > > >>> > > > > >>> > > Satish
>>>>> > > 20PHD0548
>>>>> > > > >>>> via
>>>>> > > > >>>> > > >>> petsc-users
>>>>> > > > >>>> > > >>> > > wrote:
>>>>> > > > >>>> > > >>> > > > > >>> > > > I am sharing the make.log file
>>>>> while
>>>>> > > building
>>>>> > > > >>>> > > >>> petsc-3.13.4
>>>>> > > > >>>> > > >>> > > with
>>>>> > > > >>>> > > >>> > > > > >>> Matlab.
>>>>> > > > >>>> > > >>> > > > > >>> > > > Please find the attachment and do
>>>>> the
>>>>> > > needful.
>>>>> > > > >>>> > > >>> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM
>>>>> INTURU
>>>>> > > > >>>> SRINIVAS
>>>>> > > > >>>> > > >>> 20PHD0548 <
>>>>> > > wrote:
>>>>> > > > >>>> > > >>> > > > > >>> > > > > I tried with petsc-3.17.5.
>>>>> During
>>>>> > > building
>>>>> > > > >>>> of
>>>>> > > > >>>> > > >>> libmesh, the
>>>>> > > > >>>> > > >>> > > error
>>>>> > > > >>>> > > >>> > > > > >>> shows
>>>>> > > > >>>> > > >>> > > > > >>> > > > > petsc was not found
>>>>> > > > >>>> > > >>> > > > > >>> > > > > On Mon, Aug 28, 2023 at 9:43 PM
>>>>> Satish
>>>>> > > > >>>> Balay <
>>>>> > > > >>>> > > >>> > > > > >>> > > wrote:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> https://ibamr.github.io/linux
>>>>> says
>>>>> > > > >>>> petsc-3.17
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Here you are using 3.13
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Can you retry with
>>>>> petsc-3.17.5?
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Satish
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU
>>>>> SRINIVAS
>>>>> > > > >>>> 20PHD0548 via
>>>>> > > > >>>> > > >>> > > petsc-users
>>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Hello,
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I want to build PETSc with
>>>>> MATLAB for
>>>>> > > > >>>> working on
>>>>> > > > >>>> > > >>> the
>>>>> > > > >>>> > > >>> > > > > >>> simulation
>>>>> > > > >>>> > > >>> > > > > >>> > > using
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> IBAMR
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > open software. While
>>>>> building the
>>>>> > > PETSc,
>>>>> > > > >>>> using the
>>>>> > > > >>>> > > >>> > > following
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export PETSC_ARCH=linux-debug
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > ./configure \
>>>>> > > > >>>>  --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>>>>> > > > >>>>  --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>>>>> > > > >>>>  --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-debugging=1 \
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-hypre=1 \
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-fblaslapack=1 \
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-x=0 \
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4 test
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I got the following error
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > CLINKER
>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `EvaluateResidual':
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > undefined reference to
>>>>> > > > >>>> `PetscMatlabEnginePut'
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
>>>>> > > > >>>> `PetscMatlabEngineEvaluate'
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
>>>>> > > > >>>> `PetscMatlabEngineGet'
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `EvaluateJacobian':
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `TaoPounders':
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `main':
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
>>>>> > > > >>>> `PetscMatlabEngineCreate'
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
>>>>> > > > >>>> `PetscMatlabEngineGetArray'
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
>>>>> > > > >>>> `PetscMatlabEngineDestroy'
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > collect2: error: ld returned
>>>>> 1 exit
>>>>> > > > >>>> status
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: ***
>>>>> [gmakefile.test:185:
>>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> Error 1
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: *** Waiting for
>>>>> unfinished
>>>>> > > jobs....
>>>>> issue
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Thank you
>>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Srinivas
>>>>> > > > >>>> > > >>> > > > > >> *Disclaimer:This message was sent from
>>>>> Vellore
>>>>> > > > >>>> Institute of
>>>>> > > > >>>> > > >>> > > Technology.
>>>>> > > > >>>> > > >>> > > > > >> The contents of this email may contain
>>>>> legally
>>>>> > > > >>>> protected
>>>>> > > > >>>> > > >>> > > confidential or
>>>>> > > > >>>> > > >>> > > > > >> privileged information of “Vellore
>>>>> Institute of
>>>>> > > > >>>> Technology”.
>>>>> > > > >>>> > > >>> If
>>>>> > > > >>>> > > >>> > > you are
>>>>> > > > >>>> > > >>> > > > > >> not the intended recipient, you should
>>>>> not
>>>>> > > > >>>> disseminate,
>>>>> > > > >>>> > > >>> distribute
>>>>> > > > >>>> > > >>> > > or copy
>>>>> > > > >>>> > > >>> > > > > >> this e-mail. Please notify the sender
>>>>> immediately
>>>>> > > > >>>> and destroy
>>>>> > > > >>>> > > >>> all
>>>>> > > > >>>> > > >>> > > copies of
>>>>> > > > >>>> > > >>> > > > > >> this message and any attachments. If you
>>>>> have
>>>>> > > > >>>> received this
>>>>> > > > >>>> > > >>> email
>>>>> > > > >>>> > > >>> > > in error,
>>>>> > > > >>>> > > >>> > > > > >> please promptly notify the sender by
>>>>> reply email
>>>>> > > and
>>>>> > > > >>>> delete
>>>>> > > > >>>> > > >>> the
>>>>> > > > >>>> > > >>> > > original
>>>>> > > > >>>> > > >>> > > > > >> email and any backup copies without
>>>>> reading
>>>>> > > them.*
>>>>> > > > >>>> > > >> *Disclaimer:This message was sent from Vellore
>>>>> Institute of
>>>>> > > > >>>> Technology.
>>>>> > > > >>>> > > >> The contents of this email may contain legally
>>>>> protected
>>>>> > > > >>>> confidential or
>>>>> > > > >>>> > > >> privileged information of “Vellore Institute of
>>>>> > > Technology”.  If
>>>>> > > > >>>> you are
>>>>> > > > >>>> > > >> not the intended recipient, you should not
>>>>> disseminate,
>>>>> > > > >>>> distribute or copy
>>>>> > > > >>>> > > >> this e-mail. Please notify the sender immediately
>>>>> and destroy
>>>>> > > > >>>> all copies of
>>>>> > > > >>>> > > >> this message and any attachments. If you have
>>>>> received this
>>>>> > > > >>>> email in error,
>>>>> > > > >>>> > > >> please promptly notify the sender by reply email and
>>>>> delete
>>>>> > > the
>>>>> > > > >>>> original
>>>>> > > > >>>> > > >> email and any backup copies without reading them.*
>>>>> > > > >>>> > > > --Amneet
>>>>> > > > >>> *Disclaimer:This message was sent from Vellore Institute of
>>>>> > > Technology.
>>>>> > > > >>> The contents of this email may contain legally protected
>>>>> > > confidential or
>>>>> Technology”.  If you
>>>>> > > are
>>>>> > > > >>> not the intended recipient, you should not disseminate,
>>>>> distribute
>>>>> > > or copy
>>>>> > > > >>> this e-mail. Please notify the sender immediately and
>>>>> destroy all
>>>>> > > copies of
>>>>> > > > >>> this message and any attachments. If you have received this
>>>>> email in
>>>>> > > error,
>>>>> > > > >>> please promptly notify the sender by reply email and delete
>>>>> the
>>>>> > > original
>>>>> > > > >> What most experimenters take for granted before they begin
>>>>> their
>>>>> > > > >> experiments is infinitely more interesting than any results
>>>>> to which
>>>>> > > their
>>>>> > > > >> experiments lead.
>>>>> > > > >> -- Norbert Wiener
>>>>> > > > >> https://www.cse.buffalo.edu/~knepley/
>>>>> > > > >> <http://www.cse.buffalo.edu/~knepley/>
>>>>> Technology.
>>>>> confidential
>>>>> > > or
>>>>> > > > > privileged information of “Vellore Institute of Technology”.
>>>>> If you
>>>>> > > are
>>>>> distribute or
>>>>> > > copy
>>>>> > > > > this e-mail. Please notify the sender immediately and destroy
>>>>> all
>>>>> > > copies of
>>>>> email in
>>>>> > > error,
>>>>> > > > > please promptly notify the sender by reply email and delete the
>>>>> > > original
>>>> Technology.  The contents of this email may contain legally protected
>>>> confidential or privileged information of “Vellore Institute of
>>>> Technology”.  If you are not the intended recipient, you should not
>>>> disseminate, distribute or copy this e-mail. Please notify the sender
>>>> immediately and destroy all copies of this message and any attachments. If
>>>> you have received this email in error, please promptly notify the sender by
>>>> reply email and delete the original email and any backup copies without
>>>> reading them.*
>>> --Amneet
>> *Disclaimer:This message was sent from Vellore Institute of Technology.
>> The contents of this email may contain legally protected confidential or
>> privileged information of “Vellore Institute of Technology”.  If you are
>> not the intended recipient, you should not disseminate, distribute or copy
>> this e-mail. Please notify the sender immediately and destroy all copies of
>> this message and any attachments. If you have received this email in error,
>> please promptly notify the sender by reply email and delete the original
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230905/5bb1b31c/attachment-0001.html>
