[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Tue Sep 5 11:27:06 CDT 2023
I replaced e->ep = engOpen(buffer); with e->ep = engOpen("");
I got the same errors for petsc 3.17.5
*make all*
   CC linux-opt/obj/sys/classes/matlabengine/matlab.o
     CLINKER linux-opt/lib/libpetsc.so.3.17.5
BEGINNING TO COMPILE MATLAB INTERFACE
Building with 'gcc'.
/home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
In function ‘PetscBinaryWrite’:
/home/vit/sfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
warning: ‘err’ may be used uninitialized in this function
[-Wmaybe-uninitialized]
  164 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
MEX completed successfully.
Now to check if the libraries are working do:
make PETSC_DIR=/home/vit/sfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
*make test query=requires queryval=matlab
DATAFILESPATH=/home/vit/datafiles/*
Using MAKEFLAGS: -- DATAFILESPATH=/home/vit/datafiles/ queryval=matlab
query=requires
     CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
        TEST linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
not ok ksp_ksp_tutorials-ex72_12 # Error code: 85
# [0]PETSC ERROR: --------------------- Error Message
# [0]PETSC ERROR: Error in external library
# [0]PETSC ERROR: Unable to start MATLAB engine with
/usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash
# [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
# [0]PETSC ERROR: Petsc Release Version 3.17.5, Sep 30, 2022
# [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by vit Tue Sep
 5 21:39:22 2023
# [0]PETSC ERROR: Configure options
--with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
--with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
--with-matlab-engine=1 -with-blaslapack-dir=/usr/local/MATLAB/R2020b
--known-64-bit-blas-indices=1
# [0]PETSC ERROR: #1 PetscMatlabEngineCreate() at
/home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:83
# [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() at
/home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:332
# [0]PETSC ERROR: #3 PetscMatlabEnginePut() at
/home/vit/sfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:245
# [0]PETSC ERROR: #4 MatLUFactorNumeric_Matlab() at
/home/vit/sfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
# [0]PETSC ERROR: #5 MatLUFactorNumeric() at
/home/vit/sfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
# [0]PETSC ERROR: #6 PCSetUp_LU() at
/home/vit/sfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
# [0]PETSC ERROR: #7 PCSetUp() at
/home/vit/sfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
# [0]PETSC ERROR: #8 KSPSetUp() at
/home/vit/sfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
# [0]PETSC ERROR: #9 main() at
/home/vit/sfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
# [0]PETSC ERROR: PETSc Option Table entries:
# [0]PETSC ERROR: -check_pointer_intensity 0
# [0]PETSC ERROR: -error_output_stdout
# [0]PETSC ERROR: -f0 /home/vit/datafiles//matrices/arco1
# [0]PETSC ERROR: -malloc_dump
# [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
# [0]PETSC ERROR: -pc_type lu
# [0]PETSC ERROR: -use_gpu_aware_mpi 0
# [0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
# MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
# with errorcode 85.
# NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
# You may or may not see output from other processes, depending on
# exactly when Open MPI kills them.
 ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
# FAILED ksp_ksp_tutorials-ex72_12
# To rerun failed tests:
#     /usr/bin/make -f gmakefile test test-fail=1
Thanks and regards
Srinivas
On Tue, Sep 5, 2023 at 9:05 PM Barry Smith <bsmith at petsc.dev> wrote:
>     The error is occuring during
> Since the direct launch of /usr/local/MATLAB/R2020b/bin/matlab -glnxa64
> -nodisplay  -nosplash from your terminal shell worked we have to assume the
> problem is occuring when engOpen() is attempting to connect the stdout and
> stdin from the Matlab session that is launched to the executable.
> You can try the following. In 3.17.5 edit the
> file src/sys/classes/matlabengine/matlab.c and locate the line
> replace it with
> Now in the PETSc directory do make all (it should recompile one file) and
> then run the
> make test query=requires queryval=matlab DATAFILESPATH=/home/vit/datafiles/
> again
> On Sep 5, 2023, at 3:39 AM, INTURU SRINIVAS 20PHD0548 via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi Amneeth,
> I think the errors are different with petsc 3.17.5
> *./configure --CC=/usr/bin/mpicc --CXX=/usr/bin/mpicxx
> --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
> PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
> --with-blaslapack-dir=/usr/local/MATLAB/R2020b
> --known-64-bit-blas-indices=1 --with-matlab-engine=1*
> The version of PETSc you are using is out-of-date, we recommend updating
> to the new release
>  Available Version: 3.19.5   Installed Version: 3.17.5
> https://petsc.org/release/download/
>                          Configuring PETSc to compile on your system
> Compilers:
>   C Compiler:         /usr/bin/mpicc  -fPIC -Wall -Wwrite-strings
> -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector
> -fvisibility=hidden -O3
>     Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>   C++ Compiler:         /usr/bin/mpicxx  -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch
> -fstack-protector -fvisibility=hidden -O3  -std=gnu++17 -fPIC
>     Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
>   Fortran Compiler:         /usr/bin/mpif90  -fPIC -Wall
> -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3
>     Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
> Linkers:
>   Shared linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>   Dynamic linker:   /usr/bin/mpicc  -shared  -fPIC -Wall -Wwrite-strings
>   Libraries linked against:   -lquadmath -lstdc++ -ldl
> BlasLapack:
>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64
> /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so -liomp5 -lpthread
>   uses OpenMP; use export OMP_NUM_THREADS=<p> or -omp_num_threads <p> to
> control the number of threads
>   uses 8 byte integers
> MPI:
>   Version:  3
>   mpiexec: /usr/bin/mpiexec
>   Implementation: openmpi
>   OMPI_VERSION: 4.0.3
> pthread:
> cmake:
>   Version:  3.16.3
>   /usr/bin/cmake
> regex:
> Matlab:
>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
> MatlabEngine:
>   Library:  -Wl,-rpath,/usr/local/MATLAB/R2020b/bin/glnxa64
> -L/usr/local/MATLAB/R2020b/bin/glnxa64
> -Wl,-rpath,/usr/local/MATLAB/R2020b/extern/lib/glnxa64
> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat
> -lmwm_dispatcher -lmwopcmodel -lmwservices -lmwopcmodel -lmwm_dispatcher
> -lmwmpath -lmwopcmodel -lmwservices -lmwopcmodel -lmwservices -lxerces-c
>   Language used to compile PETSc: C
> PETSc:
>   PETSC_ARCH: linux-opt
>   PETSC_DIR: /home/vit/ibamrsfw/petsc/3.17.5
>   Prefix: <inplace installation>
>   Scalar type: real
>   Precision: double
>   Support for __float128
>   Integer size: 4 bytes
>   Single library: yes
>   Shared libraries: yes
>   Memory alignment from malloc(): 16 bytes
>   Using GNU make: /usr/bin/make
> xxx=========================================================================xxx
>  Configure stage complete. Now build PETSc libraries with:
>    make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt all
> *$make*
> FC linux-opt/obj/tao/f90-mod/petsctaomod.o
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/viewer/impls/socket/matlab/bread.c:164:6:
> make PETSC_DIR=/home/vit/ibamrsfw/petsc/3.17.5 PETSC_ARCH=linux-opt check
> *$make test query=requires queryval=matlab
> /usr/bin/python3 /home/vit/ibamrsfw/petsc/3.17.5/config/gmakegentest.py
> --petsc-dir=/home/vit/ibamrsfw/petsc/3.17.5 --petsc-arch=linux-opt
> --testdir=./linux-opt/tests
> query=requires
>           CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
>  5 10:15:57 2023
> # [0]PETSC ERROR: Configure options --CC=/usr/bin/mpicc
> --CXX=/usr/bin/mpicxx --FC=/usr/bin/mpif90 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
> FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0 --with-x=0
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:82
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:331
> /home/vit/ibamrsfw/petsc/3.17.5/src/sys/classes/matlabengine/matlab.c:244
> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/impls/aij/seq/matlab/aijmatlab.c:144
> /home/vit/ibamrsfw/petsc/3.17.5/src/mat/interface/matrix.c:3020
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/impls/factor/lu/lu.c:131
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/pc/interface/precon.c:990
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/interface/itfunc.c:407
> /home/vit/ibamrsfw/petsc/3.17.5/src/ksp/ksp/tutorials/ex72.c:305
> To get the info of the error there is no specific probe id reported.
> How to check error info and proceed further?
> Thanks and regards
> Srinivas
> On Tue, Sep 5, 2023 at 1:08 AM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
>> Do you get similar errors with petsc 3.17.5 using the new configure
>> options that Satish mentioned?
>> On Sun, Sep 3, 2023 at 10:19 PM INTURU SRINIVAS 20PHD0548 via petsc-users
>> <petsc-users at mcs.anl.gov> wrote:
>>> Sorry for missing that.
>>> */usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash*
>>>                             < M A T L A B (R) >
>>>                   Copyright 1984-2020 The MathWorks, Inc.
>>>               R2020b Update 3 (9.9.0.1538559) 64-bit (glnxa64)
>>>                              November 23, 2020
>>> To get started, type doc.
>>> For product information, visit www.mathworks.com.
>>> Thanks and regards
>>> Srinivas
>>> On Mon, Sep 4, 2023 at 10:19 AM Satish Balay <balay at mcs.anl.gov> wrote:
>>>> You are missing one more step:
>>>> > [0] PetscInitialize(): Running on machine: MB108SMEC028
>>>> > [0] PetscMatlabEngineCreate(): Starting MATLAB engine with command
>>>> No run matlab manually on "MB108SMEC028" with the command
>>>> "/usr/local/MATLAB/R2020b/bin/matlab -glnxa64 -nodisplay  -nosplash"
>>>> Does this work for you? As the message indicates this command is
>>>> invoked by "matlab_ls_test" - and that is failing.
>>>> Satish
>>>> On Mon, 4 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
>>>> > Hi Sathish,
>>>> > I tried the following procedure
>>>> > *$make *
>>>> > CLINKER linux-opt/lib/libpetsc.so.3.13.4
>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>> >   167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
>>>> > make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt check
>>>> > query=requires
>>>> > not ok ksp_ksp_tutorials-ex72_12 # Error code: 139
>>>> > # [0]PETSC ERROR: Unable to start MATLAB engine on
>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> > # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
>>>> Mon Sep
>>>> >  4 10:02:32 2023
>>>> > # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
>>>> > /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
>>>> > # [0]PETSC ERROR: Petsc has generated inconsistent data
>>>> > # [0]PETSC ERROR:
>>>> Mon Sep
>>>> >  4 10:02:32 2023
>>>> > # [0]PETSC ERROR: #2 PETSC_MATLAB_ENGINE_() line 316 in
>>>> > # [0]PETSC ERROR:
>>>> > # [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>> Violation,
>>>> > probably memory access out of range
>>>> > # [0]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> > # [0]PETSC ERROR: or see
>>>> > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>> > # [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>> Mac OS
>>>> > X to find memory corruption errors
>>>> > # [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>> link,
>>>> > and run
>>>> > # [0]PETSC ERROR: to get more information on the crash.
>>>> > # [0]PETSC ERROR: Signal received
>>>> Mon Sep
>>>> >  4 10:02:32 2023
>>>> > # [0]PETSC ERROR: #3 User provided function() line 0 in  unknown file
>>>> > # with errorcode 50162059.
>>>> >           CC
>>>> > linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
>>>> >      CLINKER
>>>> >         TEST
>>>> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>> > not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error code:
>>>> 124
>>>> > # Running problem 5
>>>> > # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named MB108SMEC028
>>>> by
>>>> > vit Mon Sep  4 10:02:34 2023
>>>> > # [0]PETSC ERROR: #2 main() line 126 in
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
>>>> > # [0]PETSC ERROR: -prob_id 5
>>>> > # [0]PETSC ERROR: -tao_smonitor
>>>> entire
>>>> > # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>>>> > # with errorcode 126076.
>>>> >  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP Command
>>>> failed
>>>> > so no diff
>>>> > #   Summary
>>>> > # success 0/2 tests (0.0%)
>>>> > # failed 2/2 tests (100.0%)
>>>> > # todo 0/2 tests (0.0%)
>>>> > # skip 0/2 tests (0.0%)
>>>> > # Wall clock time for tests: 4 sec
>>>> > # Approximate CPU time (not incl. build time): 0.03 sec
>>>> > # Timing summary (actual test time / total CPU time):
>>>> > #   ksp_ksp_tutorials-ex72_12: 0.01 sec / 0.02 sec
>>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.01 sec / 0.01
>>>> sec
>>>> > *$cd src/tao/leastsquares/tutorials/matlab/*
>>>> > *$make matlab_ls_test*
>>>> > /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall
>>>> -Wwrite-strings
>>>> > -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>> > -fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings
>>>> > -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
>>>> >  -I/home/vit/sfw/petsc/3.13.4/include
>>>> > -I/home/vit/sfw/petsc/3.13.4/linux-opt/include
>>>> > -I/home/vit/sfw/linux/openmpi/4.1.4/include      matlab_ls_test.c
>>>> >  -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>> > -L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>>>> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>>>> > -Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>> > -L/home/vit/sfw/linux/openmpi/4.1.4/lib
>>>> > -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
>>>> > -L/usr/lib/gcc/x86_64-linux-gnu/9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>>>> > -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>>>> > -L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm -leng -lmex -lmx
>>>> > -lmat -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr
>>>> -lmpi_mpifh
>>>> > -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread
>>>> -lquadmath
>>>> > -lstdc++ -ldl -o matlab_ls_test
>>>> > *$LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 ./matlab_ls_test
>>>> >  -tao_smonitor -prob_id 5 -info*
>>>> > [0] PetscInitialize(): PETSc successfully started: number of
>>>> processors = 1
>>>> > [0] PetscGetHostName(): Rejecting domainname, likely is NIS
>>>> > MB108SMEC028.(none)
>>>> > Running problem 5
>>>> > [0] PetscCommDuplicate(): Duplicating a communicator 140155238476992
>>>> > 94202473157392 max tags = 2147483647
>>>> > [0]PETSC ERROR: See
>>>> > [0]PETSC ERROR: ./matlab_ls_test on a linux-opt named MB108SMEC028 by
>>>> vit
>>>> > Mon Sep  4 10:09:56 2023
>>>> > [0]PETSC ERROR: #2 main() line 126 in matlab_ls_test.c
>>>> > [0]PETSC ERROR: -info
>>>> entire
>>>> > Please find the attachment for configure.log and make.log files
>>>> > On Sun, Sep 3, 2023 at 8:00 PM Satish Balay <balay at mcs.anl.gov>
>>>> wrote:
>>>> > > To use datafiles in the test suite:
>>>> > > cd $HOME
>>>> > > git clone https://gitlab.com/petsc/datafiles
>>>> > > <configure should now pick up this location and set DATAFILESPATH -
>>>> or set
>>>> > > manually with make>
>>>> DATAFILESPATH=$HOME/datafiles
>>>> > > Satish
>>>> > > On Sun, 3 Sep 2023, Matthew Knepley wrote:
>>>> > > > On Sun, Sep 3, 2023 at 8:47 AM INTURU SRINIVAS 20PHD0548 <
>>>> > > > inturu.srinivas2020 at vitstudent.ac.in> wrote:
>>>> > > > > Hi Matthew,
>>>> > > > > I am using PETSc to simulate the problems using IBAMR. I do not
>>>> have
>>>> > > any
>>>> > > > > separate test files to test PETSc alone. Can you please help me
>>>> how to
>>>> > > > > define this DATAFILESPATH?
>>>> > > > That test you tried uses a certain matrix. On our machine, we
>>>> point to
>>>> > > this
>>>> > > > matrix using an environment variable, DATAFILESPATH. You don't
>>>> have those
>>>> > > > matrices, since they are just for testing here. That
>>>> > > > is why I suggested just using a different matrix, or running a
>>>> problem
>>>> > > you
>>>> > > > care about in IBAMR.
>>>> > > >   Thanks,
>>>> > > >      Matt
>>>> > > > > Thanks and regards
>>>> > > > > Srinivas.
>>>> > > > > On Sun, Sep 3, 2023 at 6:06 PM Matthew Knepley <
>>>> knepley at gmail.com>
>>>> > > wrote:
>>>> > > > >> On Sun, Sep 3, 2023 at 3:04 AM INTURU SRINIVAS 20PHD0548 via
>>>> > > petsc-users <
>>>> > > > >>> Hi Sathish,
>>>> > > > >>> Thank you so much for your efforts and the support you are
>>>> giving me
>>>> > > to
>>>> > > > >>> sort this out.
>>>> > > > >>> I tried to follow the same procedure which you followed to
>>>> build
>>>> > > Petsc
>>>> > > > >>> 3.13.4 with Matlab-R2020b on Ubuntu20.04.
>>>> > > > >>> *$./configure --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4
>>>> > > > >>> Using python3 for Python
>>>> > > > >>>                                         It appears you do not
>>>> have
>>>> > > valgrind
>>>> > > > >>> installed on your system.
>>>> > > > >>>   We HIGHLY recommend you install it from www.valgrind.org
>>>> > > > >>>                                              Or install
>>>> > > valgrind-devel or
>>>> > > > >>> equivalent using your package manager.
>>>> > > > >>>           Then rerun ./configure
>>>> > > > >>>                                   Compilers:
>>>> > > > >>>   C Compiler:
>>>> > > -fPIC
>>>> > > > >>> -Wall -Wwrite-strings -Wno-strict-aliasing
>>>> > > > >>>   C++ Compiler:
>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>> > > > >>> -fstack-protector -fvisibility=hidden -O3  -fPIC
>>>> > > > >>>   Fortran Compiler:
>>>>  /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>> > > > >>>  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument
>>>> -O3
>>>> > > > >>> Linkers:
>>>> > > > >>>   Shared linker:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>>> > > -shared
>>>> > > > >>>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>>> > > > >>>   Dynamic linker:
>>>> > > -shared
>>>> > > > >>> make:
>>>> > > > >>>   Version:  4.2
>>>> > > > >>>   /usr/bin/make
>>>> > > > >>> BlasLapack:
>>>> > > > >>>   Library:  /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so
>>>> > > > >>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5 -lpthread
>>>> -omp_num_threads
>>>> > > <p> to
>>>> > > > >>> MPI:
>>>> > > > >>>   Version:  3
>>>> > > > >>>   Includes: -I/home/vit/sfw/linux/openmpi/4.1.4/include
>>>> > > > >>>   Mpiexec: /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec
>>>> > > --oversubscribe
>>>> > > > >>>   OMPI_VERSION: 4.1.4
>>>> > > > >>> pthread:
>>>> > > > >>> cmake:
>>>> > > > >>>   Version:  3.16.3
>>>> > > > >>>   /usr/bin/cmake
>>>> > > > >>> regex:
>>>> > > > >>> Matlab:
>>>> > > > >>> MatlabEngine:
>>>> > > > >>>   Library:
>>>> -lmx -lmat
>>>> > > -lut
>>>> > > > >>> -licudata -licui18n -licuuc
>>>> > > > >>> PETSc:
>>>> > > > >>>   PETSC_DIR: /home/vit/sfw/petsc/3.13.4
>>>> > > > >>>   Scalar type: real
>>>> > > > >>>   Precision: double
>>>> > > > >>>   shared libraries: enabled
>>>> > > > >>> Then I removed all occurrences of -lut -licudata -licui18n
>>>> -licuuc as
>>>> > > > >>> you suggested earlier.
>>>> > > > >>> *$make*
>>>> socket\n");
>>>> socket\n");
>>>> > > > >>> *$make test query=requires queryval=matlab*
>>>> > > > >>> Using MAKEFLAGS: -- queryval=matlab query=requires
>>>> > > > >>>         TEST
>>>> > > > >>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
>>>> > > > >>> # [0]PETSC ERROR: Unable to open file
>>>> > > > >>> # [0]PETSC ERROR: Cannot locate file: /matrices/arco1
>>>> > > > >> No, the problem is that you do not have DATAFILESPATH defined,
>>>> so it
>>>> > > > >> cannot find the matrix to test. Try running some test of yours.
>>>> > > > >>   Thanks,
>>>> > > > >>      Matt
>>>> > > > >>> https://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>> trouble
>>>> > > > >>> shooting.
>>>> by vit
>>>> > > Sun
>>>> > > > >>> Sep  3 11:51:03 2023
>>>> --with-debugging=0
>>>> > > > >>> # [0]PETSC ERROR: #1 PetscViewerFileSetUp_BinarySTDIO() line
>>>> 1444 in
>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
>>>> > > > >>> # [0]PETSC ERROR: #2 PetscViewerSetUp_Binary() line 1511 in
>>>> > > > >>> # [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
>>>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
>>>> > > > >>> # [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
>>>> > > > >>> # [0]PETSC ERROR: #5 MatLoad() line 1225 in
>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
>>>> > > > >>> # [0]PETSC ERROR: #6 main() line 113 in
>>>> > > > >>> /home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
>>>> > > > >>> # [0]PETSC ERROR: -f0 /matrices/arco1
>>>> -------send
>>>> > > > >>> entire error message to petsc-maint at mcs.anl.gov----------
>>>> MPI_COMM_SELF
>>>> > > > >>> # with errorcode 113065.
>>>> processes.
>>>> depending on
>>>> > > > >>>           CC
>>>> > > > >>>      CLINKER
>>>> > > > >>>         TEST
>>>> Error
>>>> > > code: 124
>>>> > > > >>> # Running problem 5
>>>> trouble
>>>> > > > >>> shooting.
>>>> > > MB108SMEC028 by
>>>> > > > >>> vit Sun Sep  3 11:51:05 2023
>>>> --with-debugging=0
>>>> -------send
>>>> MPI_COMM_SELF
>>>> processes.
>>>> depending on
>>>> Command
>>>> > > > >>> failed so no diff
>>>> > > > >>> #   Summary
>>>> > > > >>> # Wall clock time for tests: 3 sec
>>>> > > > >>> # Approximate CPU time (not incl. build time): 0.05 sec
>>>> > > > >>> #   ksp_ksp_tutorials-ex72_12: 0.02 sec / 0.03 sec
>>>> > > > >>> #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.02
>>>> sec /
>>>> > > 0.02 sec
>>>> > > > >>> *How to sort out this error?*
>>>> > > -Wwrite-strings
>>>> matlab_ls_test.c
>>>> -lmex
>>>> > > -lmx
>>>> > > -lmpi_mpifh
>>>> -lpthread
>>>> > > -lquadmath
>>>> > > > >>> I think there is a problem with the Matlab-R2020b version.
>>>> > > > >>> I am sharing the configure.log and make.log files. Please
>>>> find the
>>>> > > > >>> attachment and do the needful.
>>>> > > > >>> Thanks and regards
>>>> > > > >>> Srinivas
>>>> > > > >>> On Sat, Sep 2, 2023 at 11:15 PM Satish Balay <
>>>> > > wrote:
>>>> > > > >>>> Perhaps you can try the following to get additional info -
>>>> and debug
>>>> > > > >>>> Satish
>>>> > > > >>>> balay at compute-386-07:/scratch/balay/petsc$ cd
>>>> > > :/scratch/balay/petsc/src/tao/leastsquares/tutorials/matlab$
>>>> > > > >>>> make matlab_ls_test
>>>> > > > >>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc
>>>> -fPIC
>>>> > > -Wall
>>>> > > > >>>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>>>> > > -fstack-protector
>>>> -O3
>>>> > > > >>>> -I/scratch/balay/petsc/include
>>>> > > -I/scratch/balay/petsc/linux-opt/include
>>>> -I/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/include
>>>> > > > >>>> -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
>>>> > > > >>>> matlab_ls_test.c
>>>> -Wl,-rpath,/scratch/balay/petsc/linux-opt/lib
>>>> > > > >>>> -L/scratch/balay/petsc/linux-opt/lib
>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64
>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>>> -Wl,-rpath,/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>> > > > >>>> -L/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>>> > > > >>>> -L/lib/x86_64-linux-gnu -lpetsc -llapack -lblas -lpthread
>>>> -lm -leng
>>>> > > -lmex
>>>> > > > >>>> -lmx -lmat -lut -licudata -licui18n -licuuc -lstdc++ -ldl
>>>> -lmpifort
>>>> > > -lmpi
>>>> > > > >>>> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++
>>>> -ldl -o
>>>> > > > >>>> matlab_ls_test
>>>> ./matlab_ls_test
>>>> > > processors
>>>> > > > >>>> = 1
>>>> > > > >>>> compute-386-07.(none)
>>>> > > > >>>> [0] PetscInitialize(): Running on machine: compute-386-07
>>>> > > > >>>> Running problem 5
>>>> 1140850689
>>>> > > > >>>> -2080374784 max tags = 268435455
>>>> command
>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/matlab
>>>> > > > >>>> [0] PetscMatlabEngineCreate(): Started MATLAB engine
>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Evaluating MATLAB string:
>>>> > > > >>>> TestingInitialize
>>>> > > > >>>> [0] PetscMatlabEngineEvaluate(): Done evaluating Matlab
>>>> string:
>>>> > > > >>>> TestingInitialize
>>>> > > > >>>> 5
>>>> > > > >>>> <snip>
>>>> > > > >>>> <<<< Now verify if the above matlab command actually works
>>>> for you
>>>> > > - on
>>>> > > > >>>> this machine..>>>>>
>>>> > > > >>>>                                    < M A T L A B (R) >
>>>> > > > >>>>                          Copyright 1984-2021 The MathWorks,
>>>> Inc.
>>>> > > > >>>>                          R2021a (9.10.0.1602886) 64-bit
>>>> (glnxa64)
>>>> > > > >>>>                                     February 17, 2021
>>>> > > > >>>> On Sat, 2 Sep 2023, Satish Balay via petsc-users wrote:
>>>> > > > >>>> > Please don't cc: both petsc-users and petsc-maint
>>>> [reverting
>>>> > > thread
>>>> > > > >>>> to petsc-users only]
>>>> > > > >>>> > I'm not sure what is happening here. Can you send the
>>>> > > corresponding
>>>> > > > >>>> configure.log, make.log [compressed]?
>>>> > > > >>>> > Here is my attempt to reproduce (with petsc-3.13) on
>>>> Ubuntu-20.04,
>>>> > > > >>>> with Matlab-R2021a - and that works:
>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ git branch
>>>> > > > >>>> >   main
>>>> > > > >>>> >   release
>>>> > > > >>>> > * release-3.13
>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ module load
>>>> > > matlab/R2021a
>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ which matlab
>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ ./configure
>>>> --with-mpi-dir=/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/
>>>> --with-matlab-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>> --with-blaslapack-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>>> > > > >>>> > <snip>
>>>> > > > >>>> > Compilers:
>>>> > > > >>>> >   C Compiler:
>>>> -fPIC
>>>> > > -Wall
>>>> > > -fstack-protector
>>>> > > > >>>> >   C++ Compiler:
>>>> > > > >>>>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicxx
>>>> -Wall
>>>> > > -fstack-protector
>>>> > > > >>>> >     Version: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>>> > > > >>>> >   Fortran Compiler:
>>>> > > > >>>>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpif90
>>>> -fPIC
>>>> > > -Wall
>>>> > > > >>>> -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>>> 9.4.0
>>>> > > > >>>> > Linkers:
>>>> > > > >>>> >   Shared linker:
>>>> > > -shared  -fPIC
>>>> > > > >>>> >   Dynamic linker:
>>>> > > -shared  -fPIC
>>>> > > > >>>> > make:
>>>> > > > >>>> >   Version:  4.2
>>>> > > > >>>> >   /usr/bin/make
>>>> > > > >>>> > BlasLapack:
>>>> > > > >>>> >   Library:
>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64/mkl.so
>>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64
>>>> > > > >>>> -liomp5 -lpthread
>>>> -omp_num_threads
>>>> > > <p>
>>>> > > > >>>> to control the number of threads
>>>> > > > >>>> > MPI:
>>>> > > > >>>> >   Version:  4
>>>> > > > >>>> >   Includes:
>>>> > > > >>>> >   Mpiexec:
>>>> > > /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpiexec
>>>> > > > >>>> >   MPICH_NUMVERSION: 40002300
>>>> > > > >>>> > pthread:
>>>> > > > >>>> >   Library:  -lpthread
>>>> > > > >>>> > cmake:
>>>> > > > >>>> >   Version:  3.16.3
>>>> > > > >>>> >   /usr/bin/cmake
>>>> > > > >>>> > regex:
>>>> > > > >>>> > Matlab:
>>>> > > > >>>> >   Includes:
>>>> > > > >>>> > MatlabEngine:
>>>> > > > >>>> >   Library:
>>>> > > > >>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>> > > > >>>> > sowing:
>>>> > > > >>>> >   Version:  1.1.25
>>>> > > > >>>> >   /scratch/balay/petsc/linux-opt/bin/bfort
>>>> > > > >>>> > valgrind:
>>>> > > > >>>> > PETSc:
>>>> > > > >>>> >   PETSC_DIR: /scratch/balay/petsc
>>>> > > > >>>> >   Scalar type: real
>>>> > > > >>>> >   Precision: double
>>>> > > > >>>> >    make PETSC_DIR=/scratch/balay/petsc
>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make
>>>> > > > >>>> > <snip>
>>>> > > > >>>> >      CLINKER linux-opt/lib/libpetsc.so.3.13.6
>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c: In
>>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>>> > > socket\n");
>>>> > > socket\n");
>>>> > > > >>>> > make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt
>>>> check
>>>> > > > >>>> > balay at compute-386-07:/scratch/balay/petsc$ make test
>>>> > > query=requires
>>>> > > > >>>> queryval=matlab
>>>> > > > >>>> >         TEST
>>>> > > > >>>> > #     ../ex72:
>>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64/libgfortran.so.5:
>>>> > > > >>>> version `GFORTRAN_9' not found (required by
>>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib/libmpifort.so.12)
>>>> diff
>>>> > > > >>>> >           CC
>>>> > > > >>>> >      CLINKER
>>>> > > > >>>> >         TEST
>>>> Error
>>>> > > code:
>>>> > > > >>>> 1
>>>> > > > >>>> > #     ../matlab_ls_test:
>>>> > > Command
>>>> > > > >>>> failed so no diff
>>>> > > > >>>> > <snip>
>>>> > > > >>>> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 make test
>>>> > > query=requires
>>>> > > > >>>> queryval=matlab
>>>> > > > >>>> >         TEST
>>>> > > > >>>> >  ok diff-ksp_ksp_tutorials-ex72_12
>>>> > > > >>>> >         TEST
>>>> > > > >>>> >  ok diff-tao_leastsquares_tutorials_matlab-matlab_ls_test
>>>> > > > >>>> > #   Summary
>>>> > > > >>>> > # success 4/4 tests (100.0%)
>>>> > > > >>>> > # failed 0/4 tests (0.0%)
>>>> > > > >>>> > # todo 0/4 tests (0.0%)
>>>> > > > >>>> > # skip 0/4 tests (0.0%)
>>>> > > > >>>> > # Wall clock time for tests: 27 sec
>>>> 15.190000000000001
>>>> > > sec
>>>> > > > >>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 6.47
>>>> sec /
>>>> > > 7.54
>>>> > > > >>>> sec
>>>> > > > >>>> > #   ksp_ksp_tutorials-ex72_12: 6.46 sec / 7.65 sec
>>>> > > > >>>> > On Sat, 2 Sep 2023, INTURU SRINIVAS 20PHD0548 wrote:
>>>> > > > >>>> > > Based on the suggestions given by Sathish, I have tried
>>>> to
>>>> > > > >>>> configure petsc
>>>> > > > >>>> > > 3.13.4 with Matlab-R2020b. But, it was not successful.
>>>> After
>>>> > > > >>>> running make
>>>> > > > >>>> > > -j 10 test command I have got the following error
>>>> message.
>>>> # Error
>>>> > > > >>>> code: 124
>>>> > > > >>>> > > # Running problem 5
>>>> 2020
>>>> > > > >>>> MB108SMEC028 by
>>>> > > > >>>> > > vit Sat Sep  2 12:27:22 2023
>>>> COPTFLAGS=-O3
>>>> > > > >>>> --with-debugging=0
>>>> > > -------send
>>>> > > > >>>> entire
>>>> MPI_COMM_SELF
>>>> MPI
>>>> > > > >>>> processes.
>>>> depending
>>>> > > on
>>>> > > > >>>> > > I request you to help me to sort out this error.
>>>> > > > >>>> > > Thanks
>>>> > > > >>>> > > Srinivas
>>>> > > > >>>> > > On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <
>>>> > > > >>>> mail2amneet at gmail.com> wrote:
>>>> > > > >>>> > > > I think there should be two hyphens in
>>>> > > > >>>> > > > i.e.:
>>>> > > > >>>> > > > On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS
>>>> 20PHD0548 via
>>>> > > > >>>> petsc-users <
>>>> > > > >>>> > > >> Thank you Sathish.I will try this
>>>> > > > >>>> > > >> On Fri, Sep 1, 2023, 22:53 Satish Balay <
>>>> > > > >>>> wrote:
>>>> > > > >>>> > > >>> yes [and remove fblaslapack. don't know if hypre
>>>> will work
>>>> > > > >>>> here].
>>>> > > > >>>> > > >>> i.e:
>>>> > > > >>>> > > >>> ./configure
>>>> > > > >>>> > > >>> --with-debugging=0 --with-x=0 \
>>>> > > > >>>> > > >>> Satish
>>>> > > > >>>> > > >>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via
>>>> > > petsc-users
>>>> > > > >>>> wrote:
>>>> > > > >>>> > > >>> > Hi Satish,
>>>> > > > >>>> > > >>> > -with-blaslapack-dir=/path/to/matlab_dir
>>>> > > > >>>> > > >>> > Is this what you are suggesting?
>>>> > > > >>>> > > >>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <
>>>> > > > >>>> wrote:
>>>> > > > >>>> > > >>> > > Also:
>>>> > > > >>>> > > >>> > >     '-known-64-bit-blas-indices=1',
>>>> > > > >>>> > > >>> > > Note: most externalpackages might not work in
>>>> this mode.
>>>> > > > >>>> > > >>> > > [we can't really over come such
>>>> dependency/conflicts
>>>> > > across
>>>> > > > >>>> packages]
>>>> > > > >>>> > > >>> > > Satish
>>>> > > > >>>> > > >>> > > On Fri, 1 Sep 2023, Satish Balay via petsc-users
>>>> wrote:
>>>> > > > >>>> > > >>> > > > Here is the matlab test that runs in CI
>>>> https://gitlab.com/petsc/petsc/-/jobs/4904566768
>>>> > > > >>>> > > >>> > > > config/examples/arch-ci-linux-matlab-ilp64.py
>>>> > > > >>>> > > >>> > > > # Note: regular BLAS [with 32-bit integers]
>>>> conflict
>>>> > > with
>>>> > > > >>>> > > >>> > > > # MATLAB BLAS - hence requiring
>>>> > > > >>>> > > >>> > > > Ah - so you need to use the ilp64 blas/lapack
>>>> with
>>>> > > > >>>> matlab  - to
>>>> > > > >>>> > > >>> have a
>>>> > > > >>>> > > >>> > > compatible build
>>>> > > > >>>> > > >>> > > >     '--with-blaslapack-dir='+matlab_dir,
>>>> > > > >>>> > > >>> > > > Satish
>>>> via
>>>> > > > >>>> petsc-users
>>>> > > > >>>> > > >>> wrote:
>>>> > > > >>>> > > >>> > > > > Hi Amneet,
>>>> > > > >>>> > > >>> > > > > Without libmesh, even for PETSc with MATLAB
>>>> is not
>>>> > > > >>>> working. It is
>>>> > > > >>>> > > >>> > > showing
>>>> > > > >>>> > > >>> > > > > error for both 3.13.4 and 3.17.5 versions.
>>>> > > > >>>> > > >>> > > > > I am trying to install IBAMR in HPC cluster
>>>> with
>>>> > > > >>>> libmesh and
>>>> > > > >>>> > > >>> this is
>>>> > > > >>>> > > >>> > > for
>>>> > > > >>>> > > >>> > > > > general usage not only for WEC. This I tried
>>>> without
>>>> > > > >>>> linking
>>>> > > > >>>> > > >>> Matlab
>>>> > > > >>>> > > >>> > > with
>>>> > > > >>>> > > >>> > > > > PETSc. Here also I got the error while
>>>> configuring
>>>> > > > >>>> libmesh 1.6.2
>>>> > > > >>>> > > >>> that
>>>> > > > >>>> > > >>> > > PETSc
>>>> > > > >>>> > > >>> > > > > was not found but --enable-petsc-required is
>>>> > > specified.
>>>> > > > >>>> > > >>> > > > > The reason for specifically asking for
>>>> libmesh with
>>>> > > > >>>> PETSc and
>>>> > > > >>>> > > >>> Matlab
>>>> > > > >>>> > > >>> > > is in
>>>> > > > >>>> > > >>> > > > > the cfd-mpc-wecs application for complicated
>>>> > > geometries
>>>> > > > >>>> it is
>>>> > > > >>>> > > >>> > > mentioned to
>>>> > > > >>>> > > >>> > > > > build cfd-mpc-wecs with libmesh construct.
>>>> > > > >>>> > > >>> > > > > For the past 10 days I am trying these
>>>> various
>>>> > > things
>>>> > > > >>>> and ended
>>>> > > > >>>> > > >>> up with
>>>> > > > >>>> > > >>> > > > > errors.
>>>> > > > >>>> > > >>> > > > > I want to solve this and proceed further to
>>>> do my
>>>> > > > >>>> research work.
>>>> > > > >>>> > > >>> > > > > Please help me to solve this as soon as
>>>> possible.
>>>> > > > >>>> > > >>> > > > > Thanks and Regards
>>>> > > > >>>> > > >>> > > > > Srinivas
>>>> > > > >>>> > > >>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <
>>>> > > > >>>> > > >>> > > wrote:
>>>> > > > >>>> > > >>> > > > > > Hi Srinivas,
>>>> > > > >>>> > > >>> > > > > > As discussed earlier you don’t need
>>>> libMesh for
>>>> > > the
>>>> > > > >>>> WEC
>>>> > > > >>>> > > >>> application.
>>>> > > > >>>> > > >>> > > You
>>>> > > > >>>> > > >>> > > > > > can just work with PETSc 3.17.5 that
>>>> builds with
>>>> > > > >>>> Matlab.
>>>> > > > >>>> > > >>> > > > > > Do you have a specific reason for wanting
>>>> to build
>>>> > > > >>>> libMesh?
>>>> > > > >>>> > > >>> > > > > > Thanks,
>>>> > > > >>>> > > >>> > > > > > —Amneet
>>>> > > > >>>> > > >>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU
>>>> SRINIVAS
>>>> > > > >>>> 20PHD0548 via
>>>> > > > >>>> > > >>> > > petsc-users
>>>> > > > >>>> > > >>> > > > > >> Hi,
>>>> > > > >>>> > > >>> > > > > >> I ran "make all" for petsc 3.13.4 by
>>>> removing all
>>>> > > > >>>> occurrences
>>>> > > > >>>> > > >>> of
>>>> > > > >>>> > > >>> > > "-lut
>>>> > > > >>>> > > >>> > > > > >> -licudata -licui18n -licuuc". When I ran
>>>> "make
>>>> > > test"
>>>> > > > >>>> got the
>>>> > > > >>>> > > >>> > > following
>>>> > > > >>>> > > >>> > > > > >> errors
>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-debug:
>>>> > > > >>>> > > >>> > > > > >> TEST
>>>> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>>> > > > >>>> > > >>> > > > > >> not ok
>>>> > > > >>>> > > >>> Error
>>>> > > > >>>> > > >>> > > code: 124
>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>> Error
>>>> > > Message
>>>> library
>>>> engine
>>>> > > on
>>>> > > > >>>> for
>>>> > > > >>>> > > >>> trouble
>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>> 3.13.4,
>>>> > > Aug
>>>> > > > >>>> 01, 2020
>>>> > > linux-debug
>>>> > > > >>>> named
>>>> > > > >>>> > > >>> > > MB108SMEC028
>>>> > > > >>>> > > >>> > > > > >> by vit Fri Sep  1 10:01:11 2023
>>>> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>>> > > --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>>> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>>> > > > >>>> > > >>> --with-debugging=1
>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1
>>>> --download-fblaslapack=1
>>>> > > > >>>> --with-x=0
>>>> --with-matlab-dir=/usr/local/MATLAB/R2020b/
>>>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
>>>> > > line
>>>> > > > >>>> 67 in
>>>> entries:
>>>> Error
>>>> > > > >>>> Message
>>>> > > > >>>> > > >>> -------send
>>>> > > > >>>> > > >>> > > entire
>>>> > > > >>>> > > >>> > > > > >> error message to
>>>> communicator
>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>> MPI to
>>>> > > kill
>>>> > > > >>>> all MPI
>>>> > > > >>>> > > >>> > > processes.
>>>> > > processes,
>>>> > > > >>>> > > >>> depending on
>>>> > > > >>>> > > >>> > > > > >>  ok
>>>> > > > >>>> # SKIP
>>>> > > > >>>> > > >>> Command
>>>> > > > >>>> > > >>> > > > > >> failed so no diff
>>>> > > > >>>> > > >>> > > > > >> in petsc/3.13.4/linux-opt
>>>> > > > >>>> > > >>> > > > > >>  TEST
>>>> > > > >>>> > > >>> > > > > >> not ok
>>>> > > > >>>> > > >>> Error
>>>> > > > >>>> > > >>> > > code: 124
>>>> > > > >>>> > > >>> > > > > >> # Running problem 5
>>>> Error
>>>> > > Message
>>>> library
>>>> engine
>>>> > > on
>>>> > > > >>>> for
>>>> > > > >>>> > > >>> trouble
>>>> > > > >>>> > > >>> > > > > >> shooting.
>>>> 3.13.4,
>>>> > > Aug
>>>> > > > >>>> 01, 2020
>>>> > > linux-opt
>>>> > > > >>>> named
>>>> > > > >>>> > > >>> > > MB108SMEC028 by
>>>> > > > >>>> > > >>> > > > > >> vit Fri Sep  1 10:34:12 2023
>>>> > > > >>>> > > >>> --COPTFLAGS=-O3
>>>> > > > >>>> > > >>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>>> > > > >>>> --PETSC_ARCH=linux-opt
>>>> > > > >>>> > > >>> > > --with-debugging=0
>>>> > > > >>>> > > >>> > > > > >> --download-hypre=1 --with-x=0
>>>> > > line
>>>> > > > >>>> 67 in
>>>> entries:
>>>> Error
>>>> > > > >>>> Message
>>>> > > > >>>> > > >>> -------send
>>>> > > > >>>> > > >>> > > entire
>>>> > > > >>>> > > >>> > > > > >> error message to
>>>> communicator
>>>> > > > >>>> > > >>> MPI_COMM_SELF
>>>> MPI to
>>>> > > kill
>>>> > > > >>>> all MPI
>>>> > > > >>>> > > >>> > > processes.
>>>> > > processes,
>>>> > > > >>>> > > >>> depending on
>>>> > > > >>>> > > >>> > > > > >>  ok
>>>> > > > >>>> # SKIP
>>>> > > > >>>> > > >>> Command
>>>> > > > >>>> > > >>> > > > > >> failed so no diff.
>>>> > > > >>>> > > >>> > > > > >> The same errors occurred for petsc 3.17.5
>>>> > > version. I
>>>> > > > >>>> am
>>>> > > > >>>> > > >>> sharing the
>>>> > > > >>>> > > >>> > > > > >> config.log and make.log for both petsc
>>>> 3.13.4 and
>>>> > > > >>>> petsc
>>>> > > > >>>> > > >>> 3.17.5.
>>>> > > > >>>> > > >>> > > Please find
>>>> > > > >>>> > > >>> > > > > >> the attachment and do the needful.
>>>> > > > >>>> > > >>> > > > > >> Thanks and regards
>>>> > > > >>>> > > >>> > > > > >> Srinivas
>>>> > > > >>>> > > >>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish
>>>> Balay <
>>>> > > > >>>> > > >>> > > wrote:
>>>> > > > >>>> > > >>> > > > > >>> Well - you sent in libmesh log not
>>>> petsc's
>>>> > > > >>>> > > >>> configure.log/make.log
>>>> > > > >>>> > > >>> > > for
>>>> > > > >>>> > > >>> > > > > >>> petsc-3.17
>>>> > > > >>>> > > >>> > > > > >>> Anyway - with petsc-3.13 - you have:
>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>> > > > >>>> > > >>> > > > > >>> MatlabEngine:
>>>> > > > >>>> > > >>> > > > > >>>   Library:
>>>> > > -leng
>>>> > > > >>>> -lmex
>>>> > > > >>>> > > >>> -lmx
>>>> > > > >>>> > > >>> > > -lmat -lut
>>>> > > > >>>> > > >>> > > > > >>> With petsc-3.19 (and matlab-R2022a) - we
>>>> are
>>>> > > seeing:
>>>> > > > >>>> > > >>> > > > > >>> Matlab:
>>>> > > > >>>> > > >>> > > > > >>>   Includes:
>>>> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
>>>> > > > >>>> > > >>> > > > > >>>   Libraries:
>>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>>> > > > >>>> > > >>> > > > > >>>   Executable:
>>>> > > > >>>> > > >>> > > > > >>>   mex:
>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
>>>> > > > >>>> > > >>> > > > > >>>   matlab:
>>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
>>>> > > > >>>> > > >>> > > > > >>> -glnxa64
>>>> > > > >>>> > > >>> > > > > >>> I.e "-lut -licudata -licui18n -licuuc"
>>>> are not
>>>> > > > >>>> preset here.
>>>> > > > >>>> > > >>> This
>>>> > > > >>>> > > >>> > > might
>>>> > > > >>>> > > >>> > > > > >>> be a change wrt newer matlab versions.
>>>> > > > >>>> > > >>> > > > > >>> You can:
>>>> > > > >>>> > > >>> > > > > >>> - edit
>>>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
>>>> > > > >>>> > > >>> > > and
>>>> > > > >>>> > > >>> > > > > >>> remove all occurrences of "-lut -licudata
>>>> > > -licui18n
>>>> > > > >>>> -licuuc"
>>>> > > > >>>> > > >>> > > > > >>> - now run 'make all' in
>>>> > > '/home/vit/sfw/petsc/3.13.4'
>>>> > > > >>>> > > >>> > > > > >>> And see if the build works now.
>>>> > > > >>>> > > >>> > > > > >>> Satish
>>>> > > > >>>> > > >>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS
>>>> 20PHD0548
>>>> > > via
>>>> > > > >>>> > > >>> petsc-users
>>>> > > > >>>> > > >>> > > wrote:
>>>> > > > >>>> > > >>> > > > > >>> > I am sharing the log files while
>>>> building
>>>> > > > >>>> petsc3.13.4 with
>>>> > > > >>>> > > >>> > > matlab and
>>>> > > > >>>> > > >>> > > > > >>> also
>>>> > > > >>>> > > >>> > > > > >>> > the log file while building libmesh
>>>> with
>>>> > > > >>>> petsc3.17.5 and
>>>> > > > >>>> > > >>> matlab.
>>>> > > > >>>> > > >>> > > > > >>> Building
>>>> > > > >>>> > > >>> > > > > >>> > petsc 3.17.5 with matlab was done
>>>> > > successfully.
>>>> > > > >>>> But
>>>> > > > >>>> > > >>> libmesh is
>>>> > > > >>>> > > >>> > > not
>>>> > > > >>>> > > >>> > > > > >>> able to
>>>> > > > >>>> > > >>> > > > > >>> > find the petsc
>>>> > > > >>>> > > >>> > > > > >>> > Please find the attachments.
>>>> > > > >>>> > > >>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM Satish
>>>> Balay <
>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>> > > > >>>> > > >>> > > > > >>> > > Send configure.log, make.log from
>>>> both
>>>> > > > >>>> petsc-3.13 and
>>>> > > > >>>> > > >>> 3.17 [or
>>>> > > > >>>> > > >>> > > 3.19].
>>>> > > > >>>> > > >>> > > > > >>> > > [you can gzip them to make the logs
>>>> > > friendly to
>>>> > > > >>>> mailing
>>>> > > > >>>> > > >>> list -
>>>> > > > >>>> > > >>> > > or
>>>> > > > >>>> > > >>> > > > > >>> send
>>>> > > > >>>> > > >>> > > > > >>> > > them to petsc-maint]
>>>> > > > >>>> > > >>> > > > > >>> > > And does test suite work with 3.17?
>>>> [or
>>>> > > 3.19?]
>>>> > > > >>>> > > >>> > > > > >>> > > Satish
>>>> > > 20PHD0548
>>>> > > > >>>> via
>>>> > > > >>>> > > >>> petsc-users
>>>> > > > >>>> > > >>> > > wrote:
>>>> > > > >>>> > > >>> > > > > >>> > > > I am sharing the make.log file
>>>> while
>>>> > > building
>>>> > > > >>>> > > >>> petsc-3.13.4
>>>> > > > >>>> > > >>> > > with
>>>> > > > >>>> > > >>> > > > > >>> Matlab.
>>>> > > > >>>> > > >>> > > > > >>> > > > Please find the attachment and do
>>>> the
>>>> > > needful.
>>>> > > > >>>> > > >>> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM
>>>> INTURU
>>>> > > > >>>> SRINIVAS
>>>> > > > >>>> > > >>> 20PHD0548 <
>>>> > > wrote:
>>>> > > > >>>> > > >>> > > > > >>> > > > > I tried with petsc-3.17.5. During
>>>> > > building
>>>> > > > >>>> of
>>>> > > > >>>> > > >>> libmesh, the
>>>> > > > >>>> > > >>> > > error
>>>> > > > >>>> > > >>> > > > > >>> shows
>>>> > > > >>>> > > >>> > > > > >>> > > > > petsc was not found
>>>> > > > >>>> > > >>> > > > > >>> > > > > On Mon, Aug 28, 2023 at 9:43 PM
>>>> Satish
>>>> > > > >>>> Balay <
>>>> > > > >>>> > > >>> > > > > >>> > > wrote:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> https://ibamr.github.io/linux
>>>> says
>>>> > > > >>>> petsc-3.17
>>>> > > > >>>> > > >>> > > > > >>> > > > >> Here you are using 3.13
>>>> > > > >>>> > > >>> > > > > >>> > > > >> Can you retry with petsc-3.17.5?
>>>> > > > >>>> > > >>> > > > > >>> > > > >> Satish
>>>> > > > >>>> > > >>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU
>>>> SRINIVAS
>>>> > > > >>>> 20PHD0548 via
>>>> > > > >>>> > > >>> > > petsc-users
>>>> > > > >>>> > > >>> > > > > >>> wrote:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Hello,
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I want to build PETSc with
>>>> MATLAB for
>>>> > > > >>>> working on
>>>> > > > >>>> > > >>> the
>>>> > > > >>>> > > >>> > > > > >>> simulation
>>>> > > > >>>> > > >>> > > > > >>> > > using
>>>> > > > >>>> > > >>> > > > > >>> > > > >> IBAMR
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > open software. While building
>>>> the
>>>> > > PETSc,
>>>> > > > >>>> using the
>>>> > > > >>>> > > >>> > > following
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > export PETSC_ARCH=linux-debug
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > ./configure \
>>>> > > > >>>>  --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>>>> > > > >>>>  --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>>>> > > > >>>>  --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-debugging=1 \
>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-hypre=1 \
>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --download-fblaslapack=1 \
>>>> > > > >>>> > > >>> > > > > >>> > > > >> >   --with-x=0 \
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make -j4 test
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > I got the following error
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > CLINKER
>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `EvaluateResidual':
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > undefined reference to
>>>> > > > >>>> `PetscMatlabEnginePut'
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
>>>> > > > >>>> `PetscMatlabEngineEvaluate'
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
>>>> > > > >>>> `PetscMatlabEngineGet'
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `EvaluateJacobian':
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `TaoPounders':
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > function `main':
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
>>>> > > > >>>> `PetscMatlabEngineCreate'
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
>>>> > > > >>>> `PetscMatlabEngineGetArray'
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
>>>> > > > >>>> `PetscMatlabEngineDestroy'
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > collect2: error: ld returned
>>>> 1 exit
>>>> > > > >>>> status
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: *** [gmakefile.test:185:
>>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
>>>> > > > >>>> > > >>> > > > > >>> > > > >> Error 1
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > make: *** Waiting for
>>>> unfinished
>>>> > > jobs....
>>>> issue
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Thank you
>>>> > > > >>>> > > >>> > > > > >>> > > > >> > Srinivas
>>>> > > > >>>> > > >>> > > > > >> *Disclaimer:This message was sent from
>>>> Vellore
>>>> > > > >>>> Institute of
>>>> > > > >>>> > > >>> > > Technology.
>>>> > > > >>>> > > >>> > > > > >> The contents of this email may contain
>>>> legally
>>>> > > > >>>> protected
>>>> > > > >>>> > > >>> > > confidential or
>>>> > > > >>>> > > >>> > > > > >> privileged information of “Vellore
>>>> Institute of
>>>> > > > >>>> Technology”.
>>>> > > > >>>> > > >>> If
>>>> > > > >>>> > > >>> > > you are
>>>> > > > >>>> > > >>> > > > > >> not the intended recipient, you should not
>>>> > > > >>>> disseminate,
>>>> > > > >>>> > > >>> distribute
>>>> > > > >>>> > > >>> > > or copy
>>>> > > > >>>> > > >>> > > > > >> this e-mail. Please notify the sender
>>>> immediately
>>>> > > > >>>> and destroy
>>>> > > > >>>> > > >>> all
>>>> > > > >>>> > > >>> > > copies of
>>>> > > > >>>> > > >>> > > > > >> this message and any attachments. If you
>>>> have
>>>> > > > >>>> received this
>>>> > > > >>>> > > >>> email
>>>> > > > >>>> > > >>> > > in error,
>>>> > > > >>>> > > >>> > > > > >> please promptly notify the sender by
>>>> reply email
>>>> > > and
>>>> > > > >>>> delete
>>>> > > > >>>> > > >>> the
>>>> > > > >>>> > > >>> > > original
>>>> > > > >>>> > > >>> > > > > >> email and any backup copies without
>>>> reading
>>>> > > them.*
>>>> > > > >>>> > > >> *Disclaimer:This message was sent from Vellore
>>>> Institute of
>>>> > > > >>>> Technology.
>>>> > > > >>>> > > >> The contents of this email may contain legally
>>>> protected
>>>> > > > >>>> confidential or
>>>> > > > >>>> > > >> privileged information of “Vellore Institute of
>>>> > > Technology”.  If
>>>> > > > >>>> you are
>>>> disseminate,
>>>> > > > >>>> distribute or copy
>>>> > > > >>>> > > >> this e-mail. Please notify the sender immediately and
>>>> destroy
>>>> > > > >>>> all copies of
>>>> > > > >>>> > > >> this message and any attachments. If you have
>>>> received this
>>>> > > > >>>> email in error,
>>>> > > > >>>> > > >> please promptly notify the sender by reply email and
>>>> delete
>>>> > > the
>>>> > > > >>>> original
>>>> > > > >>>> > > >> email and any backup copies without reading them.*
>>>> > > > >>>> > > > --Amneet
>>>> > > > >>> *Disclaimer:This message was sent from Vellore Institute of
>>>> > > Technology.
>>>> > > > >>> The contents of this email may contain legally protected
>>>> > > confidential or
>>>> > > > >>> privileged information of “Vellore Institute of Technology”.
>>>> If you
>>>> > > are
>>>> > > > >>> not the intended recipient, you should not disseminate,
>>>> distribute
>>>> > > or copy
>>>> > > > >>> this e-mail. Please notify the sender immediately and destroy
>>>> all
>>>> > > copies of
>>>> > > > >>> this message and any attachments. If you have received this
>>>> email in
>>>> > > error,
>>>> > > > >>> please promptly notify the sender by reply email and delete
>>>> the
>>>> > > original
>>>> > > > >> What most experimenters take for granted before they begin
>>>> their
>>>> > > > >> experiments is infinitely more interesting than any results to
>>>> which
>>>> > > their
>>>> > > > >> experiments lead.
>>>> > > > >> -- Norbert Wiener
>>>> > > > >> https://www.cse.buffalo.edu/~knepley/
>>>> > > > >> <http://www.cse.buffalo.edu/~knepley/>
>>>> Technology.
>>>> confidential
>>>> > > or
>>>> If you
>>>> > > are
>>>> distribute or
>>>> > > copy
>>>> all
>>>> > > copies of
>>>> email in
>>>> > > error,
>>>> > > > > please promptly notify the sender by reply email and delete the
>>>> > > original
>>> *Disclaimer:This message was sent from Vellore Institute of Technology.
>>> The contents of this email may contain legally protected confidential or
>>> privileged information of “Vellore Institute of Technology”.  If you are
>>> not the intended recipient, you should not disseminate, distribute or copy
>>> this e-mail. Please notify the sender immediately and destroy all copies of
>>> this message and any attachments. If you have received this email in error,
>>> please promptly notify the sender by reply email and delete the original
>> --Amneet
**Disclaimer:*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230905/d97614ca/attachment-0001.html>
