[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Sun Sep 3 08:00:04 CDT 2023
Hi Matthew,
I am using PETSc to simulate the problems using IBAMR. I do not have any
separate test files to test PETSc alone. Can you please help me how to
define this DATAFILESPATH?
Thanks and regards
Srinivas.
On Sun, Sep 3, 2023 at 6:06 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Sep 3, 2023 at 3:04 AM INTURU SRINIVAS 20PHD0548 via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi Sathish,
>> Thank you so much for your efforts and the support you are giving me to
>> sort this out.
>> I tried to follow the same procedure which you followed to build Petsc
>> 3.13.4 with Matlab-R2020b on Ubuntu20.04.
>> *$./configure --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4
>> COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt
>> --with-debugging=0 --with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
>> --with-blaslapack-dir=/usr/local/MATLAB/R2020b
>> --known-64-bit-blas-indices=1 --with-matlab-engine=1*
>> Using python3 for Python
>>              Configuring PETSc to compile on your system
>>                                         It appears you do not have valgrind
>> installed on your system.
>>   We HIGHLY recommend you install it from www.valgrind.org
>>                                            Or install valgrind-devel or
>> equivalent using your package manager.
>>           Then rerun ./configure
>>                                   Compilers:
>>   C Compiler:         /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc  -fPIC
>> -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>> -fstack-protector -fvisibility=hidden -O3
>>     Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>   C++ Compiler:       /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx  -Wall
>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>> -fvisibility=hidden -O3  -fPIC
>>     Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
>>   Fortran Compiler:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90  -fPIC
>> -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3
>>     Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>> Linkers:
>>   Shared linker:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc  -shared
>>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>>   Dynamic linker:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc  -shared
>>   Libraries linked against:   -lquadmath -lstdc++ -ldl
>> make:
>>   Version:  4.2
>>   /usr/bin/make
>> BlasLapack:
>>   Library:  /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so
>> -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
>> -L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5 -lpthread
>>   uses OpenMP; use export OMP_NUM_THREADS=<p> or -omp_num_threads <p> to
>> control the number of threads
>>   uses 8 byte integers
>> MPI:
>>   Version:  3
>>   Includes: -I/home/vit/sfw/linux/openmpi/4.1.4/include
>>   Mpiexec: /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec --oversubscribe
>>   OMPI_VERSION: 4.1.4
>> pthread:
>> cmake:
>>   Version:  3.16.3
>>   /usr/bin/cmake
>> regex:
>> Matlab:
>>   Includes: -I/usr/local/MATLAB/R2020b/extern/include
>> MatlabEngine:
>>   Library:
>>  -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
>> -L/usr/local/MATLAB/R2020b/bin/glnxa64
>> -L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat -lut
>> -licudata -licui18n -licuuc
>>   Language used to compile PETSc: C
>> PETSc:
>>   PETSC_ARCH: linux-opt
>>   PETSC_DIR: /home/vit/sfw/petsc/3.13.4
>>   Scalar type: real
>>   Precision: double
>>   Support for __float128
>>   Integer size: 4 bytes
>>   shared libraries: enabled
>>   Memory alignment from malloc(): 16 bytes
>> xxx=========================================================================xxx
>>  Configure stage complete. Now build PETSc libraries with:
>>    make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt all
>> Then I removed all occurrences of -lut -licudata -licui18n -licuuc as you
>> suggested earlier.
>> *$make*
>>  FC linux-opt/obj/tao/f90-mod/petsctaomod.o
>>      CLINKER linux-opt/lib/libpetsc.so.3.13.4
>> BEGINNING TO COMPILE MATLAB INTERFACE
>> Building with 'gcc'.
>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
>> In function ‘PetscBinaryWrite’:
>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>> warning: ‘err’ may be used uninitialized in this function
>> [-Wmaybe-uninitialized]
>>   167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
>> MEX completed successfully.
>> Now to check if the libraries are working do:
>> make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt check
>> *$make test query=requires queryval=matlab*
>> Using MAKEFLAGS: -- queryval=matlab query=requires
>>           CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
>>      CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
>>         TEST linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
>> not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
>> # [0]PETSC ERROR: --------------------- Error Message
>> # [0]PETSC ERROR: Unable to open file
>> # [0]PETSC ERROR: Cannot locate file: /matrices/arco1
> No, the problem is that you do not have DATAFILESPATH defined, so it
> cannot find the matrix to test. Try running some test of yours.
>   Thanks,
>      Matt
>> # [0]PETSC ERROR: See
>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> # [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
>> # [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by vit Sun
>> Sep  3 11:51:03 2023
>> # [0]PETSC ERROR: Configure options
>> --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
>> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
>> # [0]PETSC ERROR: #1 PetscViewerFileSetUp_BinarySTDIO() line 1444 in
>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
>> # [0]PETSC ERROR: #2 PetscViewerSetUp_Binary() line 1511 in
>> # [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
>> # [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
>> /home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
>> # [0]PETSC ERROR: #5 MatLoad() line 1225 in
>> /home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
>> # [0]PETSC ERROR: #6 main() line 113 in
>> /home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
>> # [0]PETSC ERROR: PETSc Option Table entries:
>> # [0]PETSC ERROR: -f0 /matrices/arco1
>> # [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
>> # [0]PETSC ERROR: -pc_type lu
>> # [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> # MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>> # with errorcode 113065.
>> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> # You may or may not see output from other processes, depending on
>> # exactly when Open MPI kills them.
>>  ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
>>           CC
>> linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
>>      CLINKER
>>         TEST
>> linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>> not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error code: 124
>> # Running problem 5
>> # [0]PETSC ERROR: Error in external library
>> # [0]PETSC ERROR: Unable to start MATLAB engine on
>> shooting.
>> # [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named MB108SMEC028 by
>> vit Sun Sep  3 11:51:05 2023
>> # [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
>> /home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
>> # [0]PETSC ERROR: #2 main() line 126 in
>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
>> # [0]PETSC ERROR: -prob_id 5
>> # [0]PETSC ERROR: -tao_smonitor
>> # with errorcode 126076.
>>  ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP Command
>> failed so no diff
>> #   Summary
>> # FAILED ksp_ksp_tutorials-ex72_12
>> # success 0/2 tests (0.0%)
>> # failed 2/2 tests (100.0%)
>> # todo 0/2 tests (0.0%)
>> # skip 0/2 tests (0.0%)
>> # Wall clock time for tests: 3 sec
>> # Approximate CPU time (not incl. build time): 0.05 sec
>> # To rerun failed tests:
>> #     /usr/bin/make -f gmakefile test test-fail=1
>> # Timing summary (actual test time / total CPU time):
>> #   ksp_ksp_tutorials-ex72_12: 0.02 sec / 0.03 sec
>> #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.02 sec / 0.02 sec
>> *How to sort out this error?*
>> *$cd src/tao/leastsquares/tutorials/matlab/*
>> *$make matlab_ls_test*
>> /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall -Wwrite-strings
>> -fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>> -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
>>  -I/home/vit/sfw/petsc/3.13.4/include
>> -I/home/vit/sfw/petsc/3.13.4/linux-opt/include
>> -I/home/vit/sfw/linux/openmpi/4.1.4/include      matlab_ls_test.c
>>  -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>> -L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
>> -Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
>> -L/home/vit/sfw/linux/openmpi/4.1.4/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
>> -L/usr/lib/gcc/x86_64-linux-gnu/9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
>> -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
>> -L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm -leng -lmex -lmx
>> -lmat -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh
>> -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath
>> -lstdc++ -ldl -o matlab_ls_test
>> I think there is a problem with the Matlab-R2020b version.
>> I am sharing the configure.log and make.log files. Please find the
>> attachment and do the needful.
>> Thanks and regards
>> Srinivas
>> On Sat, Sep 2, 2023 at 11:15 PM Satish Balay <balay at mcs.anl.gov> wrote:
>>> Perhaps you can try the following to get additional info - and debug
>>> Satish
>>> balay at compute-386-07:/scratch/balay/petsc$ cd
>>> balay at compute-386-07:/scratch/balay/petsc/src/tao/leastsquares/tutorials/matlab$
>>> make matlab_ls_test
>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc -fPIC -Wall
>>> -I/scratch/balay/petsc/include -I/scratch/balay/petsc/linux-opt/include
>>> -I/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/include
>>> -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
>>> matlab_ls_test.c  -Wl,-rpath,/scratch/balay/petsc/linux-opt/lib
>>> -L/scratch/balay/petsc/linux-opt/lib
>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64
>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
>>> -Wl,-rpath,/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>> -L/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
>>> -L/lib/x86_64-linux-gnu -lpetsc -llapack -lblas -lpthread -lm -leng -lmex
>>> -lmx -lmat -lut -licudata -licui18n -licuuc -lstdc++ -ldl -lmpifort -lmpi
>>> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl -o
>>> matlab_ls_test
>>> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 ./matlab_ls_test
>>> -tao_smonitor -prob_id 5 -info
>>> [0] PetscInitialize(): PETSc successfully started: number of processors
>>> = 1
>>> [0] PetscGetHostName(): Rejecting domainname, likely is NIS
>>> compute-386-07.(none)
>>> [0] PetscInitialize(): Running on machine: compute-386-07
>>> Running problem 5
>>> [0] PetscCommDuplicate(): Duplicating a communicator 1140850689
>>> -2080374784 max tags = 268435455
>>> [0] PetscMatlabEngineCreate(): Starting MATLAB engine with command
>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/matlab
>>> -glnxa64 -nodisplay  -nosplash
>>> [0] PetscMatlabEngineCreate(): Started MATLAB engine
>>> [0] PetscMatlabEngineEvaluate(): Evaluating MATLAB string:
>>> TestingInitialize
>>> [0] PetscMatlabEngineEvaluate(): Done evaluating Matlab string:
>>> TestingInitialize
>>> 5
>>> <snip>
>>> <<<< Now verify if the above matlab command actually works for you - on
>>> this machine..>>>>>
>>>                                    < M A T L A B (R) >
>>>                          Copyright 1984-2021 The MathWorks, Inc.
>>>                          R2021a (9.10.0.1602886) 64-bit (glnxa64)
>>>                                     February 17, 2021
>>> To get started, type doc.
>>> For product information, visit www.mathworks.com.
>>> On Sat, 2 Sep 2023, Satish Balay via petsc-users wrote:
>>> > Please don't cc: both petsc-users and petsc-maint [reverting thread to
>>> petsc-users only]
>>> > I'm not sure what is happening here. Can you send the corresponding
>>> configure.log, make.log [compressed]?
>>> > Here is my attempt to reproduce (with petsc-3.13) on Ubuntu-20.04,
>>> with Matlab-R2021a - and that works:
>>> > balay at compute-386-07:/scratch/balay/petsc$ git branch
>>> >   main
>>> >   release
>>> > * release-3.13
>>> > balay at compute-386-07:/scratch/balay/petsc$ module load matlab/R2021a
>>> > balay at compute-386-07:/scratch/balay/petsc$ which matlab
>>> > balay at compute-386-07:/scratch/balay/petsc$ ./configure
>>> --with-mpi-dir=/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/
>>> --with-matlab-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>> --with-blaslapack-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
>>> > <snip>
>>> > Compilers:
>>> >   C Compiler:
>>> >   C++ Compiler:
>>>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicxx  -Wall
>>> >     Version: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
>>> >   Fortran Compiler:
>>>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpif90  -fPIC -Wall
>>> > Linkers:
>>> >   Shared linker:
>>>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc  -shared  -fPIC
>>> >   Dynamic linker:
>>> > make:
>>> >   Version:  4.2
>>> >   /usr/bin/make
>>> > BlasLapack:
>>> >   Library:
>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64/mkl.so
>>> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64
>>> -liomp5 -lpthread
>>> to control the number of threads
>>> > MPI:
>>> >   Version:  4
>>> >   Includes: -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
>>> >   Mpiexec: /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpiexec
>>> >   MPICH_NUMVERSION: 40002300
>>> > pthread:
>>> >   Library:  -lpthread
>>> > cmake:
>>> >   Version:  3.16.3
>>> >   /usr/bin/cmake
>>> > regex:
>>> > Matlab:
>>> >   Includes:
>>> > MatlabEngine:
>>> >   Library:
>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>> > sowing:
>>> >   Version:  1.1.25
>>> >   /scratch/balay/petsc/linux-opt/bin/bfort
>>> > valgrind:
>>> > PETSc:
>>> >   PETSC_DIR: /scratch/balay/petsc
>>> >   Scalar type: real
>>> >   Precision: double
>>> >    make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt all
>>> > balay at compute-386-07:/scratch/balay/petsc$ make
>>> > <snip>
>>> >      CLINKER linux-opt/lib/libpetsc.so.3.13.6
>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c: In
>>> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
>>> > make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt check
>>> > balay at compute-386-07:/scratch/balay/petsc$ make test query=requires
>>> queryval=matlab
>>> > #     ../ex72:
>>> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64/libgfortran.so.5:
>>> version `GFORTRAN_9' not found (required by
>>> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib/libmpifort.so.12)
>>> >           CC
>>> >      CLINKER
>>> >         TEST
>>> > #     ../matlab_ls_test:
>>> failed so no diff
>>> > <snip>
>>> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 make test query=requires
>>> queryval=matlab
>>> >  ok diff-ksp_ksp_tutorials-ex72_12
>>> >         TEST
>>> >  ok diff-tao_leastsquares_tutorials_matlab-matlab_ls_test
>>> > #   Summary
>>> > # success 4/4 tests (100.0%)
>>> > # failed 0/4 tests (0.0%)
>>> > # todo 0/4 tests (0.0%)
>>> > # skip 0/4 tests (0.0%)
>>> > # Wall clock time for tests: 27 sec
>>> > # Approximate CPU time (not incl. build time): 15.190000000000001 sec
>>> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 6.47 sec / 7.54
>>> sec
>>> > #   ksp_ksp_tutorials-ex72_12: 6.46 sec / 7.65 sec
>>> > On Sat, 2 Sep 2023, INTURU SRINIVAS 20PHD0548 wrote:
>>> > > Based on the suggestions given by Sathish, I have tried to configure
>>> petsc
>>> > > 3.13.4 with Matlab-R2020b. But, it was not successful. After running
>>> make
>>> > > -j 10 test command I have got the following error message.
>>> code: 124
>>> > > # Running problem 5
>>> > > for trouble shooting.
>>> MB108SMEC028 by
>>> > > vit Sat Sep  2 12:27:22 2023
>>> > > --with-matlab-engine=1 --with-blaslapack-dir=/usr/local/MATLAB/R2020b
>>> entire
>>> > > I request you to help me to sort out this error.
>>> > > Thanks
>>> > > Srinivas
>>> > > On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <mail2amneet at gmail.com>
>>> wrote:
>>> > > > I think there should be two hyphens in
>>> > > > i.e.:
>>> > > > On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS 20PHD0548 via
>>> petsc-users <
>>> > > >> Thank you Sathish.I will try this
>>> > > >> On Fri, Sep 1, 2023, 22:53 Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>> > > >>> yes [and remove fblaslapack. don't know if hypre will work here].
>>> > > >>> i.e:
>>> > > >>> --with-debugging=0 --with-x=0 \
>>> > > >>> --with-matlab-dir=/usr/local/MATLAB/R2020b --with-matlab-engine=1
>>> > > >>> Satish
>>> > > >>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users
>>> wrote:
>>> > > >>> > Hi Satish,
>>> > > >>> > -with-blaslapack-dir=/path/to/matlab_dir
>>> > > >>> > Is this what you are suggesting?
>>> > > >>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>> > > >>> > > Also:
>>> > > >>> > >     '-known-64-bit-blas-indices=1',
>>> > > >>> > > Note: most externalpackages might not work in this mode.
>>> > > >>> > > [we can't really over come such dependency/conflicts across
>>> packages]
>>> > > >>> > > Satish
>>> > > >>> > > On Fri, 1 Sep 2023, Satish Balay via petsc-users wrote:
>>> > > >>> > > > Here is the matlab test that runs in CI
>>> > > >>> > > > https://gitlab.com/petsc/petsc/-/jobs/4904566768
>>> > > >>> > > > config/examples/arch-ci-linux-matlab-ilp64.py
>>> > > >>> > > > # Note: regular BLAS [with 32-bit integers] conflict with
>>> > > >>> > > > # MATLAB BLAS - hence requiring
>>> > > >>> > > > Ah - so you need to use the ilp64 blas/lapack with matlab
>>> - to
>>> > > >>> have a
>>> > > >>> > > compatible build
>>> > > >>> > > >     '--with-blaslapack-dir='+matlab_dir,
>>> > > >>> > > > Satish
>>> petsc-users
>>> > > >>> wrote:
>>> > > >>> > > > > Hi Amneet,
>>> > > >>> > > > > Without libmesh, even for PETSc with MATLAB is not
>>> working. It is
>>> > > >>> > > showing
>>> > > >>> > > > > error for both 3.13.4 and 3.17.5 versions.
>>> > > >>> > > > > I am trying to install IBAMR in HPC cluster with libmesh
>>> and
>>> > > >>> this is
>>> > > >>> > > for
>>> > > >>> > > > > general usage not only for WEC. This I tried without
>>> linking
>>> > > >>> Matlab
>>> > > >>> > > with
>>> > > >>> > > > > PETSc. Here also I got the error while configuring
>>> libmesh 1.6.2
>>> > > >>> that
>>> > > >>> > > PETSc
>>> > > >>> > > > > was not found but --enable-petsc-required is specified.
>>> > > >>> > > > > The reason for specifically asking for libmesh with
>>> PETSc and
>>> > > >>> Matlab
>>> > > >>> > > is in
>>> > > >>> > > > > the cfd-mpc-wecs application for complicated geometries
>>> it is
>>> > > >>> > > mentioned to
>>> > > >>> > > > > build cfd-mpc-wecs with libmesh construct.
>>> > > >>> > > > > For the past 10 days I am trying these various things
>>> and ended
>>> > > >>> up with
>>> > > >>> > > > > errors.
>>> > > >>> > > > > I want to solve this and proceed further to do my
>>> research work.
>>> > > >>> > > > > Please help me to solve this as soon as possible.
>>> > > >>> > > > > Thanks and Regards
>>> > > >>> > > > > Srinivas
>>> > > >>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <
>>> > > >>> > > wrote:
>>> > > >>> > > > > > Hi Srinivas,
>>> > > >>> > > > > > As discussed earlier you don’t need libMesh for the WEC
>>> > > >>> application.
>>> > > >>> > > You
>>> > > >>> > > > > > can just work with PETSc 3.17.5 that builds with
>>> Matlab.
>>> > > >>> > > > > > Do you have a specific reason for wanting to build
>>> libMesh?
>>> > > >>> > > > > > Thanks,
>>> > > >>> > > > > > —Amneet
>>> > > >>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU SRINIVAS
>>> 20PHD0548 via
>>> > > >>> > > petsc-users
>>> > > >>> > > > > > <petsc-users at mcs.anl.gov> wrote:
>>> > > >>> > > > > >> Hi,
>>> > > >>> > > > > >> I ran "make all" for petsc 3.13.4 by removing all
>>> occurrences
>>> > > >>> of
>>> > > >>> > > "-lut
>>> > > >>> > > > > >> -licudata -licui18n -licuuc". When I ran "make test"
>>> got the
>>> > > >>> > > following
>>> > > >>> > > > > >> errors
>>> > > >>> > > > > >> in petsc/3.13.4/linux-debug:
>>> > > >>> > > > > >> TEST
>>> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
>>> > > >>> > > > > >> not ok
>>> > > >>> Error
>>> > > >>> > > code: 124
>>> > > >>> > > > > >> # Running problem 5
>>> for
>>> > > >>> trouble
>>> > > >>> > > > > >> shooting.
>>> 01, 2020
>>> > > >>> > > > > >> # [0]PETSC ERROR: ../matlab_ls_test on a linux-debug
>>> named
>>> > > >>> > > MB108SMEC028
>>> > > >>> > > > > >> by vit Fri Sep  1 10:01:11 2023
>>> > > >>> > > > > >> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
>>> > > >>> > > > > >> --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
>>> > > >>> > > > > >> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
>>> > > >>> --with-debugging=1
>>> > > >>> > > > > >> --download-hypre=1 --download-fblaslapack=1 --with-x=0
>>> > > >>> > > > > >> --with-matlab-dir=/usr/local/MATLAB/R2020b/
>>> > > >>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
>>> 67 in
>>> > > >>> -------send
>>> > > >>> > > entire
>>> > > >>> MPI_COMM_SELF
>>> all MPI
>>> > > >>> > > processes.
>>> > > >>> depending on
>>> # SKIP
>>> > > >>> Command
>>> > > >>> > > > > >> failed so no diff
>>> > > >>> > > > > >> in petsc/3.13.4/linux-opt
>>> > > >>> > > > > >>  TEST
>>> > > >>> > > > > >> not ok
>>> > > >>> Error
>>> > > >>> > > code: 124
>>> > > >>> > > > > >> # Running problem 5
>>> for
>>> > > >>> trouble
>>> > > >>> > > > > >> shooting.
>>> 01, 2020
>>> named
>>> > > >>> > > MB108SMEC028 by
>>> > > >>> > > > > >> vit Fri Sep  1 10:34:12 2023
>>> > > >>> --COPTFLAGS=-O3
>>> > > >>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3
>>> --PETSC_ARCH=linux-opt
>>> > > >>> > > --with-debugging=0
>>> > > >>> > > > > >> --download-hypre=1 --with-x=0 --download-fblaslapack=1
>>> 67 in
>>> > > >>> -------send
>>> > > >>> > > entire
>>> > > >>> MPI_COMM_SELF
>>> all MPI
>>> > > >>> > > processes.
>>> > > >>> depending on
>>> # SKIP
>>> > > >>> Command
>>> > > >>> > > > > >> failed so no diff.
>>> > > >>> > > > > >> The same errors occurred for petsc 3.17.5 version. I
>>> am
>>> > > >>> sharing the
>>> > > >>> > > > > >> config.log and make.log for both petsc 3.13.4 and
>>> petsc
>>> > > >>> 3.17.5.
>>> > > >>> > > Please find
>>> > > >>> > > > > >> the attachment and do the needful.
>>> > > >>> > > > > >> Thanks and regards
>>> > > >>> > > > > >> Srinivas
>>> > > >>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish Balay <
>>> > > >>> > > wrote:
>>> > > >>> > > > > >>> Well - you sent in libmesh log not petsc's
>>> > > >>> configure.log/make.log
>>> > > >>> > > for
>>> > > >>> > > > > >>> petsc-3.17
>>> > > >>> > > > > >>> Anyway - with petsc-3.13 - you have:
>>> > > >>> > > > > >>> Matlab:
>>> > > >>> > > > > >>> MatlabEngine:
>>> > > >>> > > > > >>>   Library:
>>> -lmex
>>> > > >>> -lmx
>>> > > >>> > > -lmat -lut
>>> > > >>> > > > > >>> With petsc-3.19 (and matlab-R2022a) - we are seeing:
>>> > > >>> > > > > >>> Matlab:
>>> > > >>> > > > > >>>   Includes:
>>> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
>>> > > >>> > > > > >>>   Libraries:
>>> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
>>> > > >>> > > > > >>>   Executable:
>>> > > >>> > > > > >>>   mex:
>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
>>> > > >>> > > > > >>>   matlab:
>>> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
>>> > > >>> > > > > >>> -glnxa64
>>> > > >>> > > > > >>> I.e "-lut -licudata -licui18n -licuuc" are not
>>> preset here.
>>> > > >>> This
>>> > > >>> > > might
>>> > > >>> > > > > >>> be a change wrt newer matlab versions.
>>> > > >>> > > > > >>> You can:
>>> > > >>> > > > > >>> - edit
>>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
>>> > > >>> > > and
>>> > > >>> > > > > >>> remove all occurrences of "-lut -licudata -licui18n
>>> -licuuc"
>>> > > >>> > > > > >>> - now run 'make all' in '/home/vit/sfw/petsc/3.13.4'
>>> > > >>> > > > > >>> And see if the build works now.
>>> > > >>> > > > > >>> Satish
>>> > > >>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS 20PHD0548 via
>>> > > >>> petsc-users
>>> > > >>> > > wrote:
>>> > > >>> > > > > >>> > I am sharing the log files while building
>>> petsc3.13.4 with
>>> > > >>> > > matlab and
>>> > > >>> > > > > >>> also
>>> > > >>> > > > > >>> > the log file while building libmesh with
>>> petsc3.17.5 and
>>> > > >>> matlab.
>>> > > >>> > > > > >>> Building
>>> > > >>> > > > > >>> > petsc 3.17.5 with matlab was done successfully. But
>>> > > >>> libmesh is
>>> > > >>> > > not
>>> > > >>> > > > > >>> able to
>>> > > >>> > > > > >>> > find the petsc
>>> > > >>> > > > > >>> > Please find the attachments.
>>> > > >>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM Satish Balay <
>>> > > >>> > > > > >>> wrote:
>>> > > >>> > > > > >>> > > Send configure.log, make.log from both
>>> petsc-3.13 and
>>> > > >>> 3.17 [or
>>> > > >>> > > 3.19].
>>> > > >>> > > > > >>> > > [you can gzip them to make the logs friendly to
>>> mailing
>>> > > >>> list -
>>> > > >>> > > or
>>> > > >>> > > > > >>> send
>>> > > >>> > > > > >>> > > them to petsc-maint]
>>> > > >>> > > > > >>> > > And does test suite work with 3.17? [or 3.19?]
>>> > > >>> > > > > >>> > > Satish
>>> via
>>> > > >>> petsc-users
>>> > > >>> > > wrote:
>>> > > >>> > > > > >>> > > > I am sharing the make.log file while building
>>> > > >>> petsc-3.13.4
>>> > > >>> > > with
>>> > > >>> > > > > >>> Matlab.
>>> > > >>> > > > > >>> > > > Please find the attachment and do the needful.
>>> > > >>> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM INTURU
>>> SRINIVAS
>>> > > >>> 20PHD0548 <
>>> > > >>> > > > > >>> > > > inturu.srinivas2020 at vitstudent.ac.in> wrote:
>>> > > >>> > > > > >>> > > > > I tried with petsc-3.17.5. During building of
>>> > > >>> libmesh, the
>>> > > >>> > > error
>>> > > >>> > > > > >>> shows
>>> > > >>> > > > > >>> > > > > petsc was not found
>>> > > >>> > > > > >>> > > > > On Mon, Aug 28, 2023 at 9:43 PM Satish Balay
>>> > > >>> > > > > >>> > > wrote:
>>> > > >>> > > > > >>> > > > >> https://ibamr.github.io/linux says
>>> petsc-3.17
>>> > > >>> > > > > >>> > > > >> Here you are using 3.13
>>> > > >>> > > > > >>> > > > >> Can you retry with petsc-3.17.5?
>>> > > >>> > > > > >>> > > > >> Satish
>>> > > >>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU SRINIVAS
>>> 20PHD0548 via
>>> > > >>> > > petsc-users
>>> > > >>> > > > > >>> wrote:
>>> > > >>> > > > > >>> > > > >> > Hello,
>>> > > >>> > > > > >>> > > > >> > I want to build PETSc with MATLAB for
>>> working on
>>> > > >>> the
>>> > > >>> > > > > >>> simulation
>>> > > >>> > > > > >>> > > using
>>> > > >>> > > > > >>> > > > >> IBAMR
>>> > > >>> > > > > >>> > > > >> > open software. While building the PETSc,
>>> using the
>>> > > >>> > > following
>>> > > >>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
>>> > > >>> > > > > >>> > > > >> > export PETSC_ARCH=linux-debug
>>> > > >>> > > > > >>> > > > >> > ./configure \
>>>  --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>>>  --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>>>  --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
>>> > > >>> > > > > >>> > > > >> >   --with-debugging=1 \
>>> > > >>> > > > > >>> > > > >> >   --download-hypre=1 \
>>> > > >>> > > > > >>> > > > >> >   --download-fblaslapack=1 \
>>> > > >>> > > > > >>> > > > >> >   --with-x=0 \
>>> > > >>> > > > > >>> > > > >> > make -j4
>>> > > >>> > > > > >>> > > > >> > make -j4 test
>>> > > >>> > > > > >>> > > > >> > I got the following error
>>> > > >>> > > > > >>> > > > >> > CLINKER
>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
>>> > > >>> > > > > >>> > > > >> > function `EvaluateResidual':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
>>> > > >>> > > > > >>> > > > >> > undefined reference to
>>> `PetscMatlabEnginePut'
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
>>> `PetscMatlabEngineEvaluate'
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
>>> `PetscMatlabEngineGet'
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> > > >>> > > > > >>> > > > >> > function `EvaluateJacobian':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> > > >>> > > > > >>> > > > >> > function `TaoPounders':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> > > >>> > > > > >>> > > > >> > function `main':
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
>>> `PetscMatlabEngineCreate'
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
>>> `PetscMatlabEngineGetArray'
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
>>> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
>>> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
>>> `PetscMatlabEngineDestroy'
>>> > > >>> > > > > >>> > > > >> > collect2: error: ld returned 1 exit status
>>> > > >>> > > > > >>> > > > >> > make: *** [gmakefile.test:185:
>>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
>>> > > >>> > > > > >>> > > > >> Error 1
>>> > > >>> > > > > >>> > > > >> > make: *** Waiting for unfinished jobs....
>>> > > >>> > > > > >>> > > > >> > Please help me to solve this issue
>>> > > >>> > > > > >>> > > > >> > Thank you
>>> > > >>> > > > > >>> > > > >> > Srinivas
>>> > > >>> > > > > >> *Disclaimer:This message was sent from Vellore
>>> Institute of
>>> > > >>> > > Technology.
>>> > > >>> > > > > >> The contents of this email may contain legally
>>> protected
>>> > > >>> > > confidential or
>>> > > >>> > > > > >> privileged information of “Vellore Institute of
>>> Technology”.
>>> > > >>> If
>>> > > >>> > > you are
>>> > > >>> > > > > >> not the intended recipient, you should not
>>> disseminate,
>>> > > >>> distribute
>>> > > >>> > > or copy
>>> > > >>> > > > > >> this e-mail. Please notify the sender immediately and
>>> destroy
>>> > > >>> all
>>> > > >>> > > copies of
>>> > > >>> > > > > >> this message and any attachments. If you have
>>> received this
>>> > > >>> email
>>> > > >>> > > in error,
>>> > > >>> > > > > >> please promptly notify the sender by reply email and
>>> delete
>>> > > >>> the
>>> > > >>> > > original
>>> > > >>> > > > > >> email and any backup copies without reading them.*
>>> > > >> *Disclaimer:This message was sent from Vellore Institute of
>>> Technology.
>>> > > >> The contents of this email may contain legally protected
>>> confidential or
>>> > > >> privileged information of “Vellore Institute of Technology”.  If
>>> you are
>>> > > >> not the intended recipient, you should not disseminate,
>>> distribute or copy
>>> > > >> this e-mail. Please notify the sender immediately and destroy all
>>> copies of
>>> > > >> this message and any attachments. If you have received this email
>>> in error,
>>> > > >> please promptly notify the sender by reply email and delete the
>>> original
>>> > > > --Amneet
>> *Disclaimer:This message was sent from Vellore Institute of Technology.
>> The contents of this email may contain legally protected confidential or
>> privileged information of “Vellore Institute of Technology”.  If you are
>> not the intended recipient, you should not disseminate, distribute or copy
>> this e-mail. Please notify the sender immediately and destroy all copies of
>> this message and any attachments. If you have received this email in error,
>> please promptly notify the sender by reply email and delete the original
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
**Disclaimer:*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230903/f3693ec6/attachment-0001.html>
