[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Sun Sep 3 02:16:44 CDT 2023
Hi Sathish,
Thank you so much for your efforts and the support you are giving me to
sort this out.
I tried to follow the same procedure which you followed to build Petsc
3.13.4 with Matlab-R2020b on Ubuntu20.04.
*$./configure --with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4
COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt
--with-debugging=0 --with-x=0 --with-matlab-dir=/usr/local/MATLAB/R2020b
--with-blaslapack-dir=/usr/local/MATLAB/R2020b
--known-64-bit-blas-indices=1 --with-matlab-engine=1*
Using python3 for Python
             Configuring PETSc to compile on your system
                                        It appears you do not have valgrind
installed on your system.
  We HIGHLY recommend you install it from www.valgrind.org
                                         Or install valgrind-devel or
equivalent using your package manager.
          Then rerun ./configure
                                  Compilers:
  C Compiler:         /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc  -fPIC
-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fstack-protector -fvisibility=hidden -O3
    Version: gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
  C++ Compiler:       /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx  -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
-fvisibility=hidden -O3  -fPIC
    Version: g++ (Ubuntu 11.4.0-2ubuntu1~20.04) 11.4.0
  Fortran Compiler:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90  -fPIC
-Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3
    Version: GNU Fortran (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
Linkers:
  Shared linker:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc  -shared
 -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
  Dynamic linker:   /home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc  -shared
  Libraries linked against:   -lquadmath -lstdc++ -ldl
make:
  Version:  4.2
  /usr/bin/make
BlasLapack:
  Library:  /usr/local/MATLAB/R2020b/bin/glnxa64/mkl.so
-Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64
-L/usr/local/MATLAB/R2020b/sys/os/glnxa64 -liomp5 -lpthread
  uses OpenMP; use export OMP_NUM_THREADS=<p> or -omp_num_threads <p> to
control the number of threads
  uses 8 byte integers
MPI:
  Version:  3
  Includes: -I/home/vit/sfw/linux/openmpi/4.1.4/include
  Mpiexec: /home/vit/sfw/linux/openmpi/4.1.4/bin/mpiexec --oversubscribe
  OMPI_VERSION: 4.1.4
pthread:
cmake:
  Version:  3.16.3
  /usr/bin/cmake
regex:
Matlab:
  Includes: -I/usr/local/MATLAB/R2020b/extern/include
MatlabEngine:
  Library:
 -Wl,-rpath,/usr/local/MATLAB/R2020b/sys/os/glnxa64:/usr/local/MATLAB/R2020b/bin/glnxa64:/usr/local/MATLAB/R2020b/extern/lib/glnxa64
-L/usr/local/MATLAB/R2020b/bin/glnxa64
-L/usr/local/MATLAB/R2020b/extern/lib/glnxa64 -leng -lmex -lmx -lmat -lut
-licudata -licui18n -licuuc
  Language used to compile PETSc: C
PETSc:
  PETSC_ARCH: linux-opt
  PETSC_DIR: /home/vit/sfw/petsc/3.13.4
  Scalar type: real
  Precision: double
  Support for __float128
  Integer size: 4 bytes
  shared libraries: enabled
  Memory alignment from malloc(): 16 bytes
xxx=========================================================================xxx
 Configure stage complete. Now build PETSc libraries with:
   make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt all
Then I removed all occurrences of -lut -licudata -licui18n -licuuc as you
suggested earlier.
*$make*
 FC linux-opt/obj/tao/f90-mod/petsctaomod.o
     CLINKER linux-opt/lib/libpetsc.so.3.13.4
BEGINNING TO COMPILE MATLAB INTERFACE
Building with 'gcc'.
/home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:
In function ‘PetscBinaryWrite’:
/home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
warning: ‘err’ may be used uninitialized in this function
[-Wmaybe-uninitialized]
  167 |   if (err < 0) PETSC_MEX_ERROR("Error writing to socket\n");
MEX completed successfully.
Now to check if the libraries are working do:
make PETSC_DIR=/home/vit/sfw/petsc/3.13.4 PETSC_ARCH=linux-opt check
*$make test query=requires queryval=matlab*
Using MAKEFLAGS: -- queryval=matlab query=requires
          CC linux-opt/tests/ksp/ksp/tutorials/ex72.o
     CLINKER linux-opt/tests/ksp/ksp/tutorials/ex72
        TEST linux-opt/tests/counts/ksp_ksp_tutorials-ex72_12.counts
not ok ksp_ksp_tutorials-ex72_12 # Error code: 169
# [0]PETSC ERROR: --------------------- Error Message
# [0]PETSC ERROR: Unable to open file
# [0]PETSC ERROR: Cannot locate file: /matrices/arco1
# [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
# [0]PETSC ERROR: Petsc Release Version 3.13.4, Aug 01, 2020
# [0]PETSC ERROR: ../ex72 on a linux-opt named MB108SMEC028 by vit Sun Sep
 3 11:51:03 2023
# [0]PETSC ERROR: Configure options
--with-mpi-dir=/home/vit/sfw/linux/openmpi/4.1.4 COPTFLAGS=-O3
CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=linux-opt --with-debugging=0
# [0]PETSC ERROR: #1 PetscViewerFileSetUp_BinarySTDIO() line 1444 in
/home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/impls/binary/binv.c
# [0]PETSC ERROR: #2 PetscViewerSetUp_Binary() line 1511 in
# [0]PETSC ERROR: #3 PetscViewerSetUp() line 328 in
/home/vit/sfw/petsc/3.13.4/src/sys/classes/viewer/interface/view.c
# [0]PETSC ERROR: #4 MatLoad_SeqAIJ() line 4563 in
/home/vit/sfw/petsc/3.13.4/src/mat/impls/aij/seq/aij.c
# [0]PETSC ERROR: #5 MatLoad() line 1225 in
/home/vit/sfw/petsc/3.13.4/src/mat/interface/matrix.c
# [0]PETSC ERROR: #6 main() line 113 in
/home/vit/sfw/petsc/3.13.4/src/ksp/ksp/tutorials/ex72.c
# [0]PETSC ERROR: PETSc Option Table entries:
# [0]PETSC ERROR: -f0 /matrices/arco1
# [0]PETSC ERROR: -pc_factor_mat_solver_type matlab
# [0]PETSC ERROR: -pc_type lu
# [0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
# MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
# with errorcode 113065.
# NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
# You may or may not see output from other processes, depending on
# exactly when Open MPI kills them.
 ok ksp_ksp_tutorials-ex72_12 # SKIP Command failed so no diff
          CC
linux-opt/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o
     CLINKER
        TEST
linux-opt/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
not ok tao_leastsquares_tutorials_matlab-matlab_ls_test # Error code: 124
# Running problem 5
# [0]PETSC ERROR: Error in external library
# [0]PETSC ERROR: Unable to start MATLAB engine on
# [0]PETSC ERROR: ../matlab_ls_test on a linux-opt named MB108SMEC028 by
vit Sun Sep  3 11:51:05 2023
# [0]PETSC ERROR: #1 PetscMatlabEngineCreate() line 67 in
/home/vit/sfw/petsc/3.13.4/src/sys/classes/matlabengine/matlab.c
# [0]PETSC ERROR: #2 main() line 126 in
/home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c
# [0]PETSC ERROR: -prob_id 5
# [0]PETSC ERROR: -tao_smonitor
# with errorcode 126076.
 ok tao_leastsquares_tutorials_matlab-matlab_ls_test # SKIP Command failed
so no diff
#   Summary
# FAILED ksp_ksp_tutorials-ex72_12
# success 0/2 tests (0.0%)
# failed 2/2 tests (100.0%)
# todo 0/2 tests (0.0%)
# skip 0/2 tests (0.0%)
# Wall clock time for tests: 3 sec
# Approximate CPU time (not incl. build time): 0.05 sec
# To rerun failed tests:
#     /usr/bin/make -f gmakefile test test-fail=1
# Timing summary (actual test time / total CPU time):
#   ksp_ksp_tutorials-ex72_12: 0.02 sec / 0.03 sec
#   tao_leastsquares_tutorials_matlab-matlab_ls_test: 0.02 sec / 0.02 sec
*How to sort out this error?*
*$cd src/tao/leastsquares/tutorials/matlab/*
*$make matlab_ls_test*
/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc -fPIC -Wall -Wwrite-strings
-fvisibility=hidden -O3 -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
 -I/home/vit/sfw/petsc/3.13.4/include
-I/home/vit/sfw/petsc/3.13.4/linux-opt/include
-I/home/vit/sfw/linux/openmpi/4.1.4/include      matlab_ls_test.c
 -Wl,-rpath,/home/vit/sfw/petsc/3.13.4/linux-opt/lib
-L/home/vit/sfw/petsc/3.13.4/linux-opt/lib
-Wl,-rpath,/home/vit/sfw/linux/openmpi/4.1.4/lib
-L/home/vit/sfw/linux/openmpi/4.1.4/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
-L/usr/lib/gcc/x86_64-linux-gnu/9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lpetsc -liomp5 -lpthread -lm -leng -lmex -lmx
-lmat -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh
-lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath
-lstdc++ -ldl -o matlab_ls_test
I think there is a problem with the Matlab-R2020b version.
I am sharing the configure.log and make.log files. Please find the
attachment and do the needful.
Thanks and regards
Srinivas
On Sat, Sep 2, 2023 at 11:15 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Perhaps you can try the following to get additional info - and debug
> Satish
> balay at compute-386-07:/scratch/balay/petsc$ cd
> balay at compute-386-07:/scratch/balay/petsc/src/tao/leastsquares/tutorials/matlab$
> make matlab_ls_test
> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc -fPIC -Wall
> -I/scratch/balay/petsc/include -I/scratch/balay/petsc/linux-opt/include
> -I/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/include
> -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
> matlab_ls_test.c  -Wl,-rpath,/scratch/balay/petsc/linux-opt/lib
> -L/scratch/balay/petsc/linux-opt/lib
> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64:/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64
> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/extern/lib/glnxa64
> -Wl,-rpath,/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
> -L/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib
> -L/lib/x86_64-linux-gnu -lpetsc -llapack -lblas -lpthread -lm -leng -lmex
> -lmx -lmat -lut -licudata -licui18n -licuuc -lstdc++ -ldl -lmpifort -lmpi
> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl -o
> matlab_ls_test
> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 ./matlab_ls_test
> -tao_smonitor -prob_id 5 -info
> [0] PetscInitialize(): PETSc successfully started: number of processors = 1
> [0] PetscGetHostName(): Rejecting domainname, likely is NIS
> compute-386-07.(none)
> [0] PetscInitialize(): Running on machine: compute-386-07
> Running problem 5
> [0] PetscCommDuplicate(): Duplicating a communicator 1140850689
> -2080374784 max tags = 268435455
> [0] PetscMatlabEngineCreate(): Starting MATLAB engine with command
> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/matlab
> -glnxa64 -nodisplay  -nosplash
> [0] PetscMatlabEngineCreate(): Started MATLAB engine
> [0] PetscMatlabEngineEvaluate(): Evaluating MATLAB string:
> TestingInitialize
> [0] PetscMatlabEngineEvaluate(): Done evaluating Matlab string:
> TestingInitialize
> 5
> <snip>
> <<<< Now verify if the above matlab command actually works for you - on
> this machine..>>>>>
>                                  < M A T L A B (R) >
>                        Copyright 1984-2021 The MathWorks, Inc.
>                        R2021a (9.10.0.1602886) 64-bit (glnxa64)
>                                   February 17, 2021
> To get started, type doc.
> For product information, visit www.mathworks.com.
> On Sat, 2 Sep 2023, Satish Balay via petsc-users wrote:
> > Please don't cc: both petsc-users and petsc-maint [reverting thread to
> petsc-users only]
> > I'm not sure what is happening here. Can you send the corresponding
> configure.log, make.log [compressed]?
> > Here is my attempt to reproduce (with petsc-3.13) on Ubuntu-20.04, with
> Matlab-R2021a - and that works:
> > balay at compute-386-07:/scratch/balay/petsc$ git branch
> >   main
> >   release
> > * release-3.13
> > balay at compute-386-07:/scratch/balay/petsc$ module load matlab/R2021a
> > balay at compute-386-07:/scratch/balay/petsc$ which matlab
> > balay at compute-386-07:/scratch/balay/petsc$ ./configure
> --with-mpi-dir=/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/
> --with-matlab-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
> --with-blaslapack-dir=/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a
> > <snip>
> > Compilers:
> >   C Compiler:
> >   C++ Compiler:
>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicxx  -Wall
> >     Version: g++ (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
> >   Fortran Compiler:
>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpif90  -fPIC -Wall
> > Linkers:
> >   Shared linker:
>  /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpicc  -shared  -fPIC
> >   Dynamic linker:
> > make:
> >   Version:  4.2
> >   /usr/bin/make
> > BlasLapack:
> >   Library:
> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/bin/glnxa64/mkl.so
> -L/nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64
> -liomp5 -lpthread
> > MPI:
> >   Version:  4
> >   Includes: -I/nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/include
> >   Mpiexec: /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/bin/mpiexec
> >   MPICH_NUMVERSION: 40002300
> > pthread:
> >   Library:  -lpthread
> > cmake:
> >   Version:  3.16.3
> >   /usr/bin/cmake
> > regex:
> > Matlab:
> >   Includes:
> > MatlabEngine:
> >   Library:
> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
> > sowing:
> >   Version:  1.1.25
> >   /scratch/balay/petsc/linux-opt/bin/bfort
> > valgrind:
> > PETSc:
> >   PETSC_DIR: /scratch/balay/petsc
> >   Scalar type: real
> >   Precision: double
> >    make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt all
> > balay at compute-386-07:/scratch/balay/petsc$ make
> > <snip>
> >      CLINKER linux-opt/lib/libpetsc.so.3.13.6
> > /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:
> /scratch/balay/petsc/src/sys/classes/viewer/impls/socket/matlab/bread.c:167:6:
> > make PETSC_DIR=/scratch/balay/petsc PETSC_ARCH=linux-opt check
> > balay at compute-386-07:/scratch/balay/petsc$ make test query=requires
> queryval=matlab
> > #     ../ex72:
> /nfs/gce/software/custom/linux-ubuntu20.04-x86_64/matlab/R2021a/sys/os/glnxa64/libgfortran.so.5:
> version `GFORTRAN_9' not found (required by
> /nfs/gce/projects/petsc/soft/u20.04/mpich-4.0.2/lib/libmpifort.so.12)
> >           CC
> >      CLINKER
> >         TEST
> > #     ../matlab_ls_test:
> failed so no diff
> > <snip>
> LD_PRELOAD=/lib/x86_64-linux-gnu/libgfortran.so.5 make test query=requires
> queryval=matlab
> >  ok diff-ksp_ksp_tutorials-ex72_12
> >         TEST
> >  ok diff-tao_leastsquares_tutorials_matlab-matlab_ls_test
> > #   Summary
> > # success 4/4 tests (100.0%)
> > # failed 0/4 tests (0.0%)
> > # todo 0/4 tests (0.0%)
> > # skip 0/4 tests (0.0%)
> > # Wall clock time for tests: 27 sec
> > # Approximate CPU time (not incl. build time): 15.190000000000001 sec
> > #   tao_leastsquares_tutorials_matlab-matlab_ls_test: 6.47 sec / 7.54 sec
> > #   ksp_ksp_tutorials-ex72_12: 6.46 sec / 7.65 sec
> > On Sat, 2 Sep 2023, INTURU SRINIVAS 20PHD0548 wrote:
> > > Based on the suggestions given by Sathish, I have tried to configure
> petsc
> > > 3.13.4 with Matlab-R2020b. But, it was not successful. After running
> make
> > > -j 10 test command I have got the following error message.
> 124
> > > # Running problem 5
> by
> > > vit Sat Sep  2 12:27:22 2023
> > > --with-matlab-engine=1 --with-blaslapack-dir=/usr/local/MATLAB/R2020b
> entire
> > > I request you to help me to sort out this error.
> > > Thanks
> > > Srinivas
> > > On Fri, Sep 1, 2023 at 11:42 PM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
> > > > I think there should be two hyphens in
> > > > i.e.:
> > > > On Fri, Sep 1, 2023 at 10:25 AM INTURU SRINIVAS 20PHD0548 via
> petsc-users <
> > > > petsc-users at mcs.anl.gov> wrote:
> > > >> Thank you Sathish.I will try this
> > > >> On Fri, Sep 1, 2023, 22:53 Satish Balay <balay at mcs.anl.gov> wrote:
> > > >>> yes [and remove fblaslapack. don't know if hypre will work here].
> > > >>> i.e:
> > > >>> --with-debugging=0 --with-x=0 \
> > > >>> --with-matlab-dir=/usr/local/MATLAB/R2020b --with-matlab-engine=1
> > > >>> Satish
> > > >>> On Fri, 1 Sep 2023, INTURU SRINIVAS 20PHD0548 via petsc-users
> wrote:
> > > >>> > Hi Satish,
> > > >>> > -with-blaslapack-dir=/path/to/matlab_dir
> > > >>> > Is this what you are suggesting?
> > > >>> > On Fri, Sep 1, 2023, 20:42 Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > >>> > > Also:
> > > >>> > >     '-known-64-bit-blas-indices=1',
> > > >>> > > Note: most externalpackages might not work in this mode.
> > > >>> > > [we can't really over come such dependency/conflicts across
> packages]
> > > >>> > > Satish
> > > >>> > > On Fri, 1 Sep 2023, Satish Balay via petsc-users wrote:
> > > >>> > > > Here is the matlab test that runs in CI
> > > >>> > > > https://gitlab.com/petsc/petsc/-/jobs/4904566768
> > > >>> > > > config/examples/arch-ci-linux-matlab-ilp64.py
> > > >>> > > > # Note: regular BLAS [with 32-bit integers] conflict with
> > > >>> > > > # MATLAB BLAS - hence requiring -known-64-bit-blas-indices=1
> > > >>> > > > Ah - so you need to use the ilp64 blas/lapack with matlab  -
> to
> > > >>> have a
> > > >>> > > compatible build
> > > >>> > > >     '--with-blaslapack-dir='+matlab_dir,
> > > >>> > > > Satish
> > > >>> wrote:
> > > >>> > > > > Hi Amneet,
> > > >>> > > > > Without libmesh, even for PETSc with MATLAB is not
> working. It is
> > > >>> > > showing
> > > >>> > > > > error for both 3.13.4 and 3.17.5 versions.
> > > >>> > > > > I am trying to install IBAMR in HPC cluster with libmesh
> and
> > > >>> this is
> > > >>> > > for
> > > >>> > > > > general usage not only for WEC. This I tried without
> linking
> > > >>> Matlab
> > > >>> > > with
> > > >>> > > > > PETSc. Here also I got the error while configuring libmesh
> 1.6.2
> > > >>> that
> > > >>> > > PETSc
> > > >>> > > > > was not found but --enable-petsc-required is specified.
> > > >>> > > > > The reason for specifically asking for libmesh with PETSc
> and
> > > >>> Matlab
> > > >>> > > is in
> > > >>> > > > > the cfd-mpc-wecs application for complicated geometries it
> is
> > > >>> > > mentioned to
> > > >>> > > > > build cfd-mpc-wecs with libmesh construct.
> > > >>> > > > > For the past 10 days I am trying these various things and
> ended
> > > >>> up with
> > > >>> > > > > errors.
> > > >>> > > > > I want to solve this and proceed further to do my research
> work.
> > > >>> > > > > Please help me to solve this as soon as possible.
> > > >>> > > > > Thanks and Regards
> > > >>> > > > > Srinivas
> > > >>> > > > > On Fri, Sep 1, 2023, 19:48 Amneet Bhalla <
> > > >>> > > wrote:
> > > >>> > > > > > Hi Srinivas,
> > > >>> > > > > > As discussed earlier you don’t need libMesh for the WEC
> > > >>> application.
> > > >>> > > You
> > > >>> > > > > > can just work with PETSc 3.17.5 that builds with Matlab.
> > > >>> > > > > > Do you have a specific reason for wanting to build
> libMesh?
> > > >>> > > > > > Thanks,
> > > >>> > > > > > —Amneet
> > > >>> > > > > > On Thu, Aug 31, 2023 at 10:16 PM INTURU SRINIVAS
> 20PHD0548 via
> > > >>> > > petsc-users
> > > >>> > > > > > <petsc-users at mcs.anl.gov> wrote:
> > > >>> > > > > >> Hi,
> > > >>> > > > > >> I ran "make all" for petsc 3.13.4 by removing all
> occurrences
> > > >>> of
> > > >>> > > "-lut
> > > >>> > > > > >> -licudata -licui18n -licuuc". When I ran "make test"
> got the
> > > >>> > > following
> > > >>> > > > > >> errors
> > > >>> > > > > >> in petsc/3.13.4/linux-debug:
> > > >>> > > > > >> TEST
> linux-debug/tests/counts/tao_leastsquares_tutorials_matlab-matlab_ls_test.counts
> > > >>> Error
> > > >>> > > code: 124
> > > >>> > > > > >> # Running problem 5
> for
> > > >>> trouble
> > > >>> > > > > >> shooting.
> 2020
> > > >>> > > > > >> # [0]PETSC ERROR: ../matlab_ls_test on a linux-debug
> named
> > > >>> > > MB108SMEC028
> > > >>> > > > > >> by vit Fri Sep  1 10:01:11 2023
> > > >>> > > > > >> --CC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicc
> > > >>> > > > > >> --CXX=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpicxx
> > > >>> > > > > >> --FC=/home/vit/sfw/linux/openmpi/4.1.4/bin/mpif90
> > > >>> --with-debugging=1
> > > >>> > > > > >> --download-hypre=1 --download-fblaslapack=1 --with-x=0
> > > >>> > > > > >> --with-matlab-dir=/usr/local/MATLAB/R2020b/
> > > >>> --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
> in
> > > >>> -------send
> > > >>> > > entire
> > > >>> MPI_COMM_SELF
> MPI
> > > >>> > > processes.
> > > >>> depending on
> SKIP
> > > >>> Command
> > > >>> > > > > >> failed so no diff
> > > >>> > > > > >> in petsc/3.13.4/linux-opt
> > > >>> > > > > >>  TEST
> > > >>> Error
> > > >>> > > code: 124
> > > >>> > > > > >> # Running problem 5
> for
> > > >>> trouble
> > > >>> > > > > >> shooting.
> 2020
> > > >>> > > MB108SMEC028 by
> > > >>> > > > > >> vit Fri Sep  1 10:34:12 2023
> > > >>> --COPTFLAGS=-O3
> > > >>> > > > > >> --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --PETSC_ARCH=linux-opt
> > > >>> > > --with-debugging=0
> > > >>> > > > > >> --download-hypre=1 --with-x=0 --download-fblaslapack=1
> in
> > > >>> -------send
> > > >>> > > entire
> > > >>> MPI_COMM_SELF
> MPI
> > > >>> > > processes.
> > > >>> depending on
> SKIP
> > > >>> Command
> > > >>> > > > > >> failed so no diff.
> > > >>> > > > > >> The same errors occurred for petsc 3.17.5 version. I am
> > > >>> sharing the
> > > >>> > > > > >> config.log and make.log for both petsc 3.13.4 and petsc
> > > >>> 3.17.5.
> > > >>> > > Please find
> > > >>> > > > > >> the attachment and do the needful.
> > > >>> > > > > >> Thanks and regards
> > > >>> > > > > >> Srinivas
> > > >>> > > > > >> On Tue, Aug 29, 2023 at 10:56 PM Satish Balay <
> > > >>> > > wrote:
> > > >>> > > > > >>> Well - you sent in libmesh log not petsc's
> > > >>> configure.log/make.log
> > > >>> > > for
> > > >>> > > > > >>> petsc-3.17
> > > >>> > > > > >>> Anyway - with petsc-3.13 - you have:
> > > >>> > > > > >>> Matlab:
> > > >>> > > > > >>> MatlabEngine:
> > > >>> > > > > >>>   Library:
> -lmex
> > > >>> -lmx
> > > >>> > > -lmat -lut
> > > >>> > > > > >>> With petsc-3.19 (and matlab-R2022a) - we are seeing:
> > > >>> > > > > >>> Matlab:
> > > >>> > > > > >>>   Includes:
> -I/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/extern/include
> > > >>> > > > > >>>   Libraries:
> -Wl,-rpath,/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
> -L/nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/glnxa64
> > > >>> > > > > >>>   Executable:
> > > >>> > > > > >>>   mex:
> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/mex
> > > >>> > > > > >>>   matlab:
> /nfs/gce/software/custom/linux-ubuntu22.04-x86_64/matlab/R2022a/bin/matlab
> > > >>> > > > > >>> -glnxa64
> > > >>> > > > > >>> I.e "-lut -licudata -licui18n -licuuc" are not preset
> here.
> > > >>> This
> > > >>> > > might
> > > >>> > > > > >>> be a change wrt newer matlab versions.
> > > >>> > > > > >>> You can:
> > > >>> > > > > >>> - edit
> > > >>> /home/vit/sfw/petsc/3.13.4/linux-opt/lib/petsc/conf/petscvariables
> > > >>> > > and
> > > >>> > > > > >>> remove all occurrences of "-lut -licudata -licui18n
> -licuuc"
> > > >>> > > > > >>> - now run 'make all' in '/home/vit/sfw/petsc/3.13.4'
> > > >>> > > > > >>> And see if the build works now.
> > > >>> > > > > >>> Satish
> > > >>> > > > > >>> On Tue, 29 Aug 2023, INTURU SRINIVAS 20PHD0548 via
> > > >>> petsc-users
> > > >>> > > wrote:
> > > >>> > > > > >>> > I am sharing the log files while building
> petsc3.13.4 with
> > > >>> > > matlab and
> > > >>> > > > > >>> also
> > > >>> > > > > >>> > the log file while building libmesh with petsc3.17.5
> and
> > > >>> matlab.
> > > >>> > > > > >>> Building
> > > >>> > > > > >>> > petsc 3.17.5 with matlab was done successfully. But
> > > >>> libmesh is
> > > >>> > > not
> > > >>> > > > > >>> able to
> > > >>> > > > > >>> > find the petsc
> > > >>> > > > > >>> > Please find the attachments.
> > > >>> > > > > >>> > On Tue, Aug 29, 2023 at 7:31 PM Satish Balay <
> > > >>> > > > > >>> wrote:
> > > >>> > > > > >>> > > Send configure.log, make.log from both petsc-3.13
> and
> > > >>> 3.17 [or
> > > >>> > > 3.19].
> > > >>> > > > > >>> > > [you can gzip them to make the logs friendly to
> mailing
> > > >>> list -
> > > >>> > > or
> > > >>> > > > > >>> send
> > > >>> > > > > >>> > > them to petsc-maint]
> > > >>> > > > > >>> > > And does test suite work with 3.17? [or 3.19?]
> > > >>> > > > > >>> > > Satish
> > > >>> petsc-users
> > > >>> > > wrote:
> > > >>> > > > > >>> > > > I am sharing the make.log file while building
> > > >>> petsc-3.13.4
> > > >>> > > with
> > > >>> > > > > >>> Matlab.
> > > >>> > > > > >>> > > > Please find the attachment and do the needful.
> > > >>> > > > > >>> > > > On Tue, Aug 29, 2023 at 10:19 AM INTURU SRINIVAS
> > > >>> 20PHD0548 <
> > > >>> > > > > >>> > > > inturu.srinivas2020 at vitstudent.ac.in> wrote:
> > > >>> > > > > >>> > > > > I tried with petsc-3.17.5. During building of
> > > >>> libmesh, the
> > > >>> > > error
> > > >>> > > > > >>> shows
> > > >>> > > > > >>> > > > > petsc was not found
> > > >>> > > > > >>> > > > > On Mon, Aug 28, 2023 at 9:43 PM Satish Balay <
> > > >>> > > > > >>> > > wrote:
> > > >>> > > > > >>> > > > >> https://ibamr.github.io/linux says petsc-3.17
> > > >>> > > > > >>> > > > >> Here you are using 3.13
> > > >>> > > > > >>> > > > >> Can you retry with petsc-3.17.5?
> > > >>> > > > > >>> > > > >> Satish
> > > >>> > > > > >>> > > > >> On Mon, 28 Aug 2023, INTURU SRINIVAS
> 20PHD0548 via
> > > >>> > > petsc-users
> > > >>> > > > > >>> wrote:
> > > >>> > > > > >>> > > > >> > Hello,
> > > >>> > > > > >>> > > > >> > I want to build PETSc with MATLAB for
> working on
> > > >>> the
> > > >>> > > > > >>> simulation
> > > >>> > > > > >>> > > using
> > > >>> > > > > >>> > > > >> IBAMR
> > > >>> > > > > >>> > > > >> > open software. While building the PETSc,
> using the
> > > >>> > > following
> > > >>> > > > > >>> > > > >> > export PETSC_DIR=$PWD
> > > >>> > > > > >>> > > > >> > export PETSC_ARCH=linux-debug
> > > >>> > > > > >>> > > > >> > ./configure \
>  --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
>  --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
>  --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
> > > >>> > > > > >>> > > > >> >   --with-debugging=1 \
> > > >>> > > > > >>> > > > >> >   --download-hypre=1 \
> > > >>> > > > > >>> > > > >> >   --download-fblaslapack=1 \
> > > >>> > > > > >>> > > > >> >   --with-x=0 \
> > > >>> > > > > >>> > > > >> > make -j4
> > > >>> > > > > >>> > > > >> > make -j4 test
> > > >>> > > > > >>> > > > >> > I got the following error
> > > >>> > > > > >>> > > > >> > CLINKER
> > > >>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
> > > >>> > > > > >>> > > > >> > function `EvaluateResidual':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
> > > >>> > > > > >>> > > > >> > undefined reference to
> `PetscMatlabEnginePut'
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
> `PetscMatlabEngineEvaluate'
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
> `PetscMatlabEngineGet'
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> > > >>> > > > > >>> > > > >> > function `EvaluateJacobian':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> > > >>> > > > > >>> > > > >> > function `TaoPounders':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> > > >>> > > > > >>> > > > >> > function `main':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
> `PetscMatlabEngineCreate'
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
> `PetscMatlabEngineGetArray'
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
> > > >>> > > > > >>> > > > >> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
> `PetscMatlabEngineDestroy'
> > > >>> > > > > >>> > > > >> > collect2: error: ld returned 1 exit status
> > > >>> > > > > >>> > > > >> > make: *** [gmakefile.test:185:
> > > >>> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
> > > >>> > > > > >>> > > > >> Error 1
> > > >>> > > > > >>> > > > >> > make: *** Waiting for unfinished jobs....
> > > >>> > > > > >>> > > > >> > Please help me to solve this issue
> > > >>> > > > > >>> > > > >> > Thank you
> > > >>> > > > > >>> > > > >> > Srinivas
> > > >>> > > > > >> *Disclaimer:This message was sent from Vellore
> Institute of
> > > >>> > > Technology.
> > > >>> > > > > >> The contents of this email may contain legally protected
> > > >>> > > confidential or
> > > >>> > > > > >> privileged information of “Vellore Institute of
> Technology”.
> > > >>> If
> > > >>> > > you are
> > > >>> > > > > >> not the intended recipient, you should not disseminate,
> > > >>> distribute
> > > >>> > > or copy
> > > >>> > > > > >> this e-mail. Please notify the sender immediately and
> destroy
> > > >>> all
> > > >>> > > copies of
> > > >>> > > > > >> this message and any attachments. If you have received
> this
> > > >>> email
> > > >>> > > in error,
> > > >>> > > > > >> please promptly notify the sender by reply email and
> delete
> > > >>> the
> > > >>> > > original
> > > >>> > > > > >> email and any backup copies without reading them.*
> > > >> *Disclaimer:This message was sent from Vellore Institute of
> Technology.
> confidential or
> > > >> privileged information of “Vellore Institute of Technology”.  If
> you are
> > > >> not the intended recipient, you should not disseminate, distribute
> or copy
> > > >> this e-mail. Please notify the sender immediately and destroy all
> copies of
> > > >> this message and any attachments. If you have received this email
> in error,
> > > >> please promptly notify the sender by reply email and delete the
> original
> > > > --Amneet
**Disclaimer:*
This message was sent from Vellore Institute of Technology.
The contents of this email may contain legally protected confidential or
privileged information of “Vellore Institute of Technology”.  If you are
not the intended recipient, you should not disseminate, distribute or copy
this e-mail. Please notify the sender immediately and destroy all copies of
this message and any attachments. If you have received this email in error,
please promptly notify the sender by reply email and delete the original
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230903/ab861847/attachment-0001.html>
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230903/ab861847/attachment-0002.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230903/ab861847/attachment-0003.bin>
