[petsc-users] Can we force SNES solver to do at least Newton step?
Sat Sep 2 16:54:16 CDT 2023
On Sat, Sep 2, 2023 at 5:45 PM David Knezevic <david.knezevic at akselos.com>
wrote:
> OK, thanks, I'll look into the custom convergence test.
> I do not understand this comment. What do you mean by "inaccurate"? Since
>> we do not have the true solution, we usually say "inaccurate" for large
>> residual, but you already said that the residual is small. Why would you
>> want to do another iterate?
> I agree with your comments, but the specific case I'm considering is very
> numerically sensitive since it includes creep (which unfortunately has
> large exponential terms in it) which is the root cause of the issues I'm
> facing. Based on test cases with a known reference solution we're finding
> that we get inaccurate results due to steps with "zero iterations". We can
> fix this by tightening the tolerance but then we do an excessive number of
> iterations in other steps. So it seems to me that ensuring that we do at
> least one iteration will help here, so that's what I wanted to try.
Hmm, it sounds like the convergence measure is bad. Maybe using a weighted
norm would be better?
     Matt
> Thanks again for your help.
> Best,
> David
> On Sat, Sep 2, 2023 at 3:23 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Sep 2, 2023 at 3:05 PM David Knezevic via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi all,
>>> I'm using the SNES solver for a plasticity model, and the issue I've run
>>> into is that in some time steps the solver terminates after "NL step 0"
>>> since the initial residual (based on the solution from the previous time
>>> step) is below the specified tolerance.
>>> I gather that "NL step 0" only checks the residual and doesn't actually
>>> do a Newtown update, and hence it seems that this is leading to inaccurate
>>> results in some cases.
>> Why would you want to do another iterate?
>>> I can of course specify a smaller convergence tolerance to avoid this
>>> issue, but I've found it difficult to find a smaller tolerance that works
>>> well in all cases (e.g. it leads to too many iterations or
>>> non-convergence). So instead what I would like to do is ensure that the
>>> solver does at least 1 Newton iteration instead of terminating at "NL step
>>> 0". Is there a way to enforce this behavior, e.g. by skipping "NL step 0",
>>> or specifying a "minimum number of iterations"? I didn't see anything like
>>> this in the documentation, so I was wondering if there are any suggestions
>>> on how to proceed for this.
>> The easiest way to do this is to write a custom convergence test that
>> looks like this
>> PetscErrorCode SNESConvergedDefault(SNES snes, PetscInt it, PetscReal
>> xnorm, PetscReal snorm, PetscReal fnorm, SNESConvergedReason *reason, void
>> *dummy)
>>   PetscFunctionBeginUser;
>>   if (!it) {
>>     *reason = SNES_CONVERGED_ITERATING;
>>     PetscFunctionReturn(PETSC_SUCCESS);
>>   PetscCall(SNESConvergedDefault(snes, it, xnorm, snorm, fnorm, reason,
>> dummy));
>>   Thanks,
>>      Matt
>>> Thanks,
>>> David
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230902/bd8d2bf5/attachment.html>
