[petsc-users] Kokkos PtAP error
Mark Adams mfadams at lbl.gov
Tue Oct 31 14:03:57 CDT 2023
In reading the error message I see that I did not clone A, to get P, so P
was the wrong type with a device.
On Tue, Oct 31, 2023 at 2:24 PM Mark Adams <mfadams at lbl.gov> wrote:
> Correction, I get the same message with -mat_type aijcusparse.
> Thanks,
> Mark
> On Tue, Oct 31, 2023 at 9:29 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I am getting this error.
>> This is in GAMG/HEM setup. PtAP for the coarse grid construction works,
>> but I call this in a graph routine
>> (/global/u2/m/madams/petsc/src/mat/coarsen/impls/hem/hem.c:1043).
>> Also, this PtAP does not need to be on the GPU anyway because P is
>> extremely sparse ... can I pin, say P, to the CPU to keep this all on the
>> host?
>> Thanks,
>> Mark
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> [0]PETSC ERROR: Unspecified symbolic phase for product AB with A
>> mpiaijkokkos, B mpiaij. Call MatProductSetFromOptions() first
>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
>> program crashed before usage or a spelling mistake, etc!
>> [0]PETSC ERROR:   Option left: name:-ksp_converged_reason (no value)
>> source: command line
>> [0]PETSC ERROR:   Option left: name:-ksp_viewxx (no value) source:
>> command line
>> [0]PETSC ERROR:   Option left: name:-log_view_gpu_timexxx (no value)
>> [0]PETSC ERROR:   Option left: name:-options_left (no value) source:
>> command line
>> [0]PETSC ERROR:   Option left: name:-pc_gamg_use_aggressive_square_graph
>> value: true source: command line
>> [0]PETSC ERROR:   Option left: name:-pc_gamg_use_minimum_degree_ordering
>> value: false source: command line
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.20.0-168-ga7898f52c39
>>  GIT Date: 2023-10-28 10:07:38 -0500
>> [0]PETSC ERROR: /global/u2/m/madams/petsc/src/snes/tests/./ex13 on a
>> arch-perlmutter-dbg-gcc-kokkos-cuda named nid001680 by madams Tue Oct 31
>> 06:21:25 2023
>> [0]PETSC ERROR: Configure options --CFLAGS="   -g" --CXXFLAGS=" -g"
>> --CUDAFLAGS="-g -Xcompiler -rdynamic" --with-cc=cc --with-cxx=CC
>> --with-fc=ftn --LDFLAGS=-lmpifort_gnu_91 --FFLAGS="   -g " --COPTFLAGS="
>> -O0" --CXXOPTFLAGS=" -O0" --FOPTFLAGS="   -O0" --download-triangle=1
>> --with-debugging=1 --with-cuda=1 --with-cuda-arch=80 --with-mpiexec="srun
>> -G4" --with-batch=0 --download-kokkos --download-kokkos-kernels
>> --with-kokkos-kernels-tpl=0 --with-make-np=8
>> PETSC_ARCH=arch-perlmutter-dbg-gcc-kokkos-cuda
>> [0]PETSC ERROR: #1 MatProductSymbolic() at
>> /global/u2/m/madams/petsc/src/mat/interface/matproduct.c:807
>> [0]PETSC ERROR: #2 MatProductSymbolic_PtAP_Unsafe() at
>> /global/u2/m/madams/petsc/src/mat/interface/matproduct.c:73
>> [0]PETSC ERROR: #3 MatProductSymbolic_Unsafe() at
>> /global/u2/m/madams/petsc/src/mat/interface/matproduct.c:185
>> [0]PETSC ERROR: #4 MatProductSymbolic() at
>> /global/u2/m/madams/petsc/src/mat/interface/matproduct.c:795
>> [0]PETSC ERROR: #5 MatPtAP() at
>> /global/u2/m/madams/petsc/src/mat/interface/matrix.c:9938
>> [0]PETSC ERROR: #6 MatCoarsenApply_HEM_private() at
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231031/7b6f1b48/attachment.html>
