[petsc-users] MatDenseSetLDA Documentation Clarification
Barry Smith bsmith at petsc.dev
Fri Oct 27 10:11:59 CDT 2023
   Damian,
    Thanks for the report. Fixing in https://gitlab.com/petsc/petsc/-/merge_requests/6972
  Barry
> On Oct 27, 2023, at 9:12 AM, Damian Marek <damian.marek at mail.utoronto.ca> wrote:
> Hello,
> I found a minor issue with the documentation for MatDenseSetLDA, which ended up causing my program to idle unexpectedly. In the documentation it is specified as "Not Collective". However, in the MPIDense implementation it is possible for PetscLayoutSetUp to be called, which is a collective. (Lines 201-202: https://petsc.org/main/src/mat/impls/dense/mpi/mpidense.c.html#MatDenseSetLDA_MPIDense)
> Regards,
> Damian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231027/a1530fcc/attachment.html>
