[petsc-users] Copying PETSc Objects Across MPI Communicators
Thu Oct 26 11:01:42 CDT 2023
On Wed, Oct 25, 2023 at 11:55 PM Damyn Chipman <
damynchipman at u.boisestate.edu> wrote:
> Great thanks, that seemed to work well. This is something my algorithm
> will do fairly often (“elevating” a node’s communicator to a communicator
> that includes siblings). The matrices formed are dense but low rank. With
> MatCreateSubMatrix, it appears I do a lot of copying from one Mat to
> another. Is there a way to do it with array copying or pointer movement
> instead of copying entries?
We could make a fast path for dense that avoids MatSetValues(). Can you
make an issue for this? The number one thing that would make this faster is
to contribute a small test. Then we could run it continually when putting
in the fast path to make sure we are preserving correctness.
    Matt
> -Damyn
> On Oct 24, 2023, at 9:51 PM, Jed Brown <jed at jedbrown.org> wrote:
> You can place it in a parallel Mat (that has rows or columns on only one
> rank or a subset of ranks) and then MatCreateSubMatrix with all new
> rows/columns on a different rank or subset of ranks.
> That said, you usually have a function that assembles the matrix and you
> can just call that on the new communicator.
> Damyn Chipman <damynchipman at u.boisestate.edu> writes:
> Hi PETSc developers,
> In short, my question is this: Does PETSc provide a way to move or copy an
> object (say a Mat) from one communicator to another?
> The more detailed scenario is this: I’m working on a linear algebra solver
> on quadtree meshes (i.e., p4est). I use communicator subsets in order to
> facilitate communication between siblings or nearby neighbors. When
> performing linear algebra across siblings (a group of 4), I need to copy a
> node’s data (i.e., a Mat object) from a sibling’s communicator to the
> communicator that includes the four siblings. From what I can tell, I can
> only copy a PETSc object onto the same communicator.
> My current approach will be to copy the raw data from the Mat on one
> communicator to a new Mat on the new communicator, but I wanted to see if
> there is a more “elegant” approach within PETSc.
> Thanks in advance,
> Damyn Chipman
> Boise State University
> PhD Candidate
> Computational Sciences and Engineering
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231026/3ac37ce9/attachment.html>
