[petsc-users] OpenMP doesn't work anymore with PETSc building rules
Qiyue Lu qiyuelu1 at gmail.com
Wed Oct 25 11:35:35 CDT 2023
Even with
CXXFLAGS=-Xcompiler -fopenmp -std=c++17
LDFLAGS= -Xcompiler -fopenmp
CXXPPFLAGS=-I/u/qiyuelu1/cuda/cuda-samples/Common
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
won't work.
On Wed, Oct 25, 2023 at 11:06 AM Qiyue Lu <qiyuelu1 at gmail.com> wrote:
> Thanks for your reply, using this configurations:
> *--with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> --download-f2cblaslapack=1 --with-cudac=nvcc --with-cuda=1 --with-openmp=1
> --with-threadsafety=1*
> However, I got an error like:
> *nvcc fatal   : Unknown option '-fopenmp'*
> Previously, when I don't have --with-openmp for the configuration, the
> PETSc make system can build my *.cu code using nvcc and g++, of course,
> OpenMP doesn't work. Now with this --with-openmp option, it cannot even
> build. The interesting thing is, I got this error even after removing the
> *-fopenmp* from *CXXFLAGS* contents:
> CXXFLAGS=-std=c++17
> LDFLAGS=
> Thanks,
> Qiyue Lu
> On Wed, Oct 25, 2023 at 10:54 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> On Wed, 25 Oct 2023, Qiyue Lu wrote:
>> > Hello,
>> > I have an in-house code enabled OpenMP and it works. Now I am trying to
>> > incorporate PETSc as the linear solver and build together using the
>> > building rules in $PETSC_HOME/lib/petsc/conf/rules. However, I found the
>> > OpenMP part doesn't work anymore.
>> If you are looking at building only your sources with openmp - using
>> petsc formatted makefile [using petsc build rules],
>> you can specify it via CFLAGS - either in makefile - or on command line.
>> For ex: [this example is using src/ksp/ksp/tutorials/makefile - with the
>> corresponding make fules]
>> [balay at pj01 tutorials]$ make ex2
>> mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas
>> -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector
>> -fvisibility=hidden -g3 -O0  -I/home/balay/petsc/include
>> -I/home/balay/petsc/arch-linux-c-debug/include     -Wl,-export-dynamic
>> ex2.c  -Wl,-rpath,/home/balay/petsc/arch-linux-c-debug/lib
>> -L/home/balay/petsc/arch-linux-c-debug/lib
>> -Wl,-rpath,/software/mpich-4.1.1/lib -L/software/mpich-4.1.1/lib
>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/13
>> -L/usr/lib/gcc/x86_64-redhat-linux/13 -lpetsc -llapack -lblas -lm -lX11
>> -lmpifort -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++
>> -lquadmath -o ex2
>> [balay at pj01 tutorials]$ make clean
>> [balay at pj01 tutorials]$ make ex2 CFLAGS=-fopenmp
>> -fvisibility=hidden -g3 -O0 -fopenmp -I/home/balay/petsc/include
>> -lquadmath -o ex2
>> Satish
>> > Should I re-configure the petsc installation with --with-openmp=1
>> option? I
>> > wonder are the building rules affected by this missing option?
>> > Thanks,
>> > Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231025/04c7ac3e/attachment.html>
