[petsc-users] use MATSEQAIJMKL in 64-bit indices
Di Miao miaodi1987 at gmail.com
Fri Oct 20 16:50:29 CDT 2023
Thanks, it worked.
Di
On Fri, Oct 20, 2023 at 1:52 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Try using the additional option --with-64-bit-blas-indices=1
> Satish
> On Fri, 20 Oct 2023, Di Miao wrote:
> > Hi,
> > I found that when compiled with '--with-64-bit-indices=1' option, the
> > following three definitions in petscconf.h will be removed:
> > #define PETSC_HAVE_MKL_SPARSE 1
> > #define PETSC_HAVE_MKL_SPARSE_OPTIMIZE 1
> > #define PETSC_HAVE_MKL_SPARSE_SP2M_FEATURE 1
> > I believe mkl can also use 64-bit indices (libmkl_intel_ilp64). I tried
> to
> > add ' --with-mkl_sparse=1 --with-mkl_sparse_optimize=1' into
> configuration
> > but does not succeed.
> > Would I know if it is possible to use MATSEQAIJMKL matrix type in 64-bit
> > mode?
> > Regards,
> > Di
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231020/59f6060f/attachment.html>
