[petsc-users] Coordinate format internal reordering
Enrico degregori at dkrz.de
Fri Oct 20 02:05:41 CDT 2023
Yes but in the documentation it should be clear that if the global
indices are not contiguous in each process, even if the memory is
locally contiguous in each process, then there will be communication to
build the matrix and the vector.
Cheers,
Enrico
On 19/10/2023 20:41, Matthew Knepley wrote:
> On Thu, Oct 19, 2023 at 1:46 PM Enrico <degregori at dkrz.de
> <mailto:degregori at dkrz.de>> wrote:
>     Sorry but I don't want another partition, Petsc internally is changing
>     the partition. I would like to have the same partition that I have in
>     the application. Is the example not clear?
> "Petsc internally is changing the partition" This is not correct. PETSc does
> not prescribe partitions. I refer to the documentation for the creation
> of Vec:
> https://petsc.org/main/manualpages/Vec/VecCreateMPI/
> <https://petsc.org/main/manualpages/Vec/VecCreateMPI/>
> Here the user sets the local and global sizes. Since data is contiguous,
> these
> completely define the vector, and are under user control.
>    Thanks,
>       Matt
>     On 19/10/2023 19:43, Matthew Knepley wrote:
>      > On Thu, Oct 19, 2023 at 1:00 PM Enrico <degregori at dkrz.de
>      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
>      >     Here is a very very simple reproducer of my problem. It is a
>     fortran
>      >     program and it has to run with 2 processes.
>      > You seem to be saying that you start with one partition of your
>     data,
>      > but you would like
>      > another partition. For this, you have to initially communicate.
>     For this
>      > I would use VecScatter.
>      > However, since most data is generated, I would consider not
>     generating
>      > my data in that initial
>      > distribution.
>      > There are many examples in the repository. In the discretization
>     of a
>      > PDE, we first divide the domain,
>      > then number up each piece, then assemble the linear algebra objects.
>      >    Thanks,
>      >        Matt
>      >     The output is:
>      >        process             0 : xx_v(            1 ) =
>       0.000000000000000
>      >        process             0 : xx_v(            2 ) =
>       1.000000000000000
>      >        process             0 : xx_v(            3 ) =
>       2.000000000000000
>      >        process             1 : xx_v(            1 ) =
>       3.000000000000000
>      >        process             1 : xx_v(            2 ) =
>       4.000000000000000
>      >        process             1 : xx_v(            3 ) =
>       5.000000000000000
>      >     and I would like to have:
>       2.000000000000000
>       3.000000000000000
>       4.000000000000000
>       0.000000000000000
>       1.000000000000000
>       5.000000000000000
>      >     How can I do that?
>      >     program main
>      >     #include <petsc/finclude/petscksp.h>
>      >           use petscksp
>      >           implicit none
>      >           PetscErrorCode ierr
>      >           PetscInt  :: Psize = 6
>      >           integer  :: Lsize
>      >           PetscInt  :: work_size
>      >           PetscInt  :: work_rank
>      >           Vec :: b
>      >           integer, allocatable, dimension(:) :: glb_index
>      >           double precision, allocatable, dimension(:) :: array
>      >           PetscScalar, pointer :: xx_v(:)
>      >           integer :: i
>      >           PetscCount :: csize
>      >           CALL PetscInitialize(ierr)
>      >           Lsize = 3
>      >           csize = Lsize
>      >           allocate(glb_index(0:Lsize-1), array(0:Lsize-1))
>      >           CALL MPI_Comm_size(PETSC_COMM_WORLD, work_size, ierr);
>      >           CALL MPI_Comm_rank(PETSC_COMM_WORLD, work_rank, ierr);
>      >           if (work_rank == 0) then
>      >             glb_index(0) = 2
>      >             glb_index(1) = 3
>      >             glb_index(2) = 4
>      >             array(0) = 2
>      >             array(1) = 3
>      >             array(2) = 4
>      >           else if (work_rank == 1) then
>      >             glb_index(0) = 0
>      >             glb_index(1) = 1
>      >             glb_index(2) = 5
>      >             array(0) = 0
>      >             array(1) = 1
>      >             array(2) = 5
>      >           end if
>      >           ! Create and fill rhs vector
>      >           CALL VecCreate(PETSC_COMM_WORLD, b, ierr);
>      >           CALL VecSetSizes(b, Lsize, Psize, ierr);
>      >           CALL VecSetType(b, VECMPI, ierr);
>      >           CALL VecSetPreallocationCOO(b, csize, glb_index, ierr)
>      >           CALL VecSetValuesCOO(b, array, INSERT_VALUES, ierr)
>      >           CALL VecGetArrayReadF90(b, xx_v, ierr)
>      >           do i=1,Lsize
>      >             write(*,*) 'process ', work_rank, ': xx_v(',i,') = ',
>     xx_v(i)
>      >           end do
>      >           CALL VecRestoreArrayReadF90(b, xx_v, ierr)
>      >           deallocate(glb_index, array)
>      >           CALL VecDestroy(b,ierr)
>      >           CALL PetscFinalize(ierr)
>      >     end program main
>      >     On 19/10/2023 17:36, Matthew Knepley wrote:
>      >      > On Thu, Oct 19, 2023 at 11:33 AM Enrico <degregori at dkrz.de
>      >      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>> wrote:
>      >      >     The layout is not poor, just the global indices are not
>      >     contiguous,this
>      >      >     has nothing to do with the local memory layout which
>     is extremely
>      >      >     optimized for different architectures. I can not
>     change the
>      >     layout
>      >      >     anyway because it's a climate model with a million
>     lines of code.
>      >      >     I don't understand why Petsc is doing all this MPI
>      >     communication under
>      >      >     the hood.
>      >      > I don't think we are communicating under the hood.
>      >      >     I mean, it is changing the layout of the application
>     and doing
>      >      >     a lot of communication.
>      >      > We do not create the layout. The user creates the data layout
>      >     when they
>      >      > create a vector or matrix.
>      >      >     Is there no way to force the same layout and
>      >      >     provide info about how to do the halo exchange? In
>     this way I
>      >     can have
>      >      >     the same memory layout and there is no communication
>     when I
>      >     fill or
>      >      >     fetch the vectors and the matrix.
>      >      > Yes, you tell the vector/matrix your data layout when you
>     create it.
>      >      >    Thanks,
>      >      >        Matt
>      >      >     Cheers,
>      >      >     Enrico
>      >      >     On 19/10/2023 17:21, Matthew Knepley wrote:
>      >      >      > On Thu, Oct 19, 2023 at 10:51 AM Enrico
>     <degregori at dkrz.de <mailto:degregori at dkrz.de>
>      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de> <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>> wrote:
>      >      >      >     In the application the storage is contiguous
>     but the
>      >     global
>      >      >     indexing is
>      >      >      >     not. I would like to use AO as a translation
>     layer but
>      >     I don't
>      >      >      >     understand it.
>      >      >      > Why would you choose to index differently from your
>     storage?
>      >      >      >     My case is actually simple even if it is in a large
>      >      >     application, I have
>      >      >      >     Mat A, Vec b and Vec x
>      >      >      >     After calling KSPSolve, I use
>     VecGetArrayReadF90 to get a
>      >      >     pointer to
>      >      >      >     the
>      >      >      >     data and they are in the wrong ordering, so for
>      >     example the first
>      >      >      >     element of the solution array on process 0
>     belongs to
>      >     process
>      >      >     1 in the
>      >      >      >     application.
>      >      >      > Again, this seems to be a poor choice of layout.
>     What we
>      >      >     typically do is
>      >      >      > to partition
>      >      >      > the data into chunks owned by each process first.
>      >      >      >     Is it at this point that I should use the AO
>     translation
>      >      >     layer? This
>      >      >      >     would be quite bad, it means to build Mat A and
>     Vec b
>      >     there
>      >      >     is MPI
>      >      >      >     communication and also to get the data of Vec x
>     back
>      >     in the
>      >      >     application.
>      >      >      > If you want to store data that process i updates on
>     process j,
>      >      >     this will
>      >      >      > need communication.
>      >      >      >     Anyway, I've tried to use
>      >     AOPetscToApplicationPermuteReal on the
>      >      >      >     solution array but it doesn't work as I would
>     like. Is
>      >     this
>      >      >     function
>      >      >      >     suppose to do MPI communication between
>     processes and
>      >     fetch
>      >      >     the values
>      >      >      >     of the application ordering?
>      >      >      > There is no communication here. That function call just
>      >     changes one
>      >      >      > integer into another.
>      >      >      > If you want to update values on another process, we
>      >     recommend using
>      >      >      > VecScatter() or
>      >      >      > MatSetValues(), both of which take global indices
>     and do
>      >      >     communication
>      >      >      > if necessary.
>      >      >      >    Thanks,
>      >      >      >      Matt
>      >      >      >     Cheers,
>      >      >      >     Enrico
>      >      >      >     On 19/10/2023 15:25, Matthew Knepley wrote:
>      >      >      >      > On Thu, Oct 19, 2023 at 8:57 AM Enrico
>      >      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>>> wrote:
>      >      >      >      >     Maybe I wasn't clear enough. I would like to
>      >      >     completely get
>      >      >      >     rid of
>      >      >      >      >     Petsc
>      >      >      >      >     ordering because I don't want extra
>      >      >      >     processes to
>      >      >      >      >     construct the vector and the matrix (since I
>      >     have to fill
>      >      >      >     them every
>      >      >      >      >     time step because I'm just using the
>     linear solver
>      >      >     with a Mat
>      >      >      >     and a Vec
>      >      >      >      >     data structure). I don't understand how
>     I can
>      >     do that.
>      >      >      >      > Any program you write to do linear algebra
>     will have
>      >      >     contiguous
>      >      >      >     storage
>      >      >      >      > because it
>      >      >      >      > is so much faster. Contiguous indexing makes
>     sense for
>      >      >     contiguous
>      >      >      >      > storage. If you
>      >      >      >      > want to use non-contiguous indexing for
>     contiguous
>      >      >     storage, you
>      >      >      >     would
>      >      >      >      > need some
>      >      >      >      > translation layer. The AO is such a translation,
>      >     but you
>      >      >     could do
>      >      >      >     this
>      >      >      >      > any way you want.
>      >      >      >      >    Thanks,
>      >      >      >      >       Matt
>      >      >      >      >     My initial idea was to create another
>     global index
>      >      >     ordering
>      >      >      >     within my
>      >      >      >      >     application to use only for the Petsc
>     interface
>      >     but then I
>      >      >      >     think that
>      >      >      >      >     the ghost cells are wrong.
>      >      >      >      >     On 19/10/2023 14:50, Matthew Knepley wrote:
>      >      >      >      >      > On Thu, Oct 19, 2023 at 6:51 AM Enrico
>      >      >     <degregori at dkrz.de <mailto:degregori at dkrz.de>
>      >      >      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>>>> wrote:
>      >      >      >      >      >     Hello,
>      >      >      >      >      >     if I create an application
>     ordering using
>      >      >      >     AOCreateBasic, should I
>      >      >      >      >      >     provide the same array for const
>     PetscInt
>      >      >     myapp[] and
>      >      >      >     const
>      >      >      >      >     PetscInt
>      >      >      >      >      >     mypetsc[] in order to get the same
>      >     ordering of the
>      >      >      >     application
>      >      >      >      >      >     within PETSC?
>      >      >      >      >      > Are you asking if the identity
>     permutation
>      >     can be
>      >      >     constructed
>      >      >      >      >     using the
>      >      >      >      >      > same array twice? Yes.
>      >      >      >      >      >     And once I define the ordering so
>     that
>      >     the local
>      >      >      >     vector and
>      >      >      >      >     matrix are
>      >      >      >      >      >     defined in PETSC as in my
>     application,
>      >     how can
>      >      >     I use it to
>      >      >      >      >     create the
>      >      >      >      >      >     actual vector and matrix?
>      >      >      >      >      > The vectors and matrices do not
>     change. The
>      >     AO is a
>      >      >      >     permutation.
>      >      >      >      >     You can
>      >      >      >      >      > use it to permute
>      >      >      >      >      > a vector into another order, or to
>     convert
>      >     on index to
>      >      >      >     another.
>      >      >      >      >      >    Thanks,
>      >      >      >      >      >        Matt
>      >      >      >      >      >     Thanks in advance for the help.
>      >      >      >      >      >     Cheers,
>      >      >      >      >      >     Enrico
>      >      >      >      >      >     On 18/10/2023 13:39, Matthew
>     Knepley wrote:
>      >      >      >      >      >      > On Wed, Oct 18, 2023 at
>     5:55 AM Enrico
>      >      >      >     <degregori at dkrz.de <mailto:degregori at dkrz.de>
>      >      >      >      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>>>>> wrote:
>      >      >      >      >      >      >     Hello,
>      >      >      >      >      >      >     I'm trying to use Petsc to
>     solve
>      >     a linear
>      >      >      >     system in an
>      >      >      >      >      >     application. I'm
>      >      >      >      >      >      >     using the coordinate format to
>      >     define the
>      >      >      >     matrix and the
>      >      >      >      >      >     vector (it
>      >      >      >      >      >      >     should work better on GPU
>     but at
>      >     the moment
>      >      >      >     every test
>      >      >      >      >     is on
>      >      >      >      >      >     CPU).
>      >      >      >      >      >      >     After
>      >      >      >      >      >      >     the call to
>     VecSetValuesCOO, I've
>      >      >     noticed that the
>      >      >      >      >     vector is
>      >      >      >      >      >     storing
>      >      >      >      >      >      >     the
>      >      >      >      >      >      >     data in a different way
>     from my
>      >      >     application. For
>      >      >      >      >     example with two
>      >      >      >      >      >      >     processes in the application
>      >      >      >      >      >      >     process 0 owns cells 2, 3, 4
>      >      >      >      >      >      >     process 1 owns cells 0, 1, 5
>      >      >      >      >      >      >     But in the vector data
>     structure
>      >     of Petsc
>      >      >      >      >      >      >     process 0 owns cells 0, 1, 2
>      >      >      >      >      >      >     process 1 owns cells 3, 4, 5
>      >      >      >      >      >      >     This is in principle not a
>     big issue,
>      >      >     but after
>      >      >      >      >     solving the
>      >      >      >      >      >     linear
>      >      >      >      >      >      >     system I get the solution
>     vector
>      >     x and I
>      >      >     want
>      >      >      >     to get the
>      >      >      >      >      >     values in the
>      >      >      >      >      >      >     correct processes. Is
>     there a way
>      >     to get
>      >      >     vector
>      >      >      >     values
>      >      >      >      >     from other
>      >      >      >      >      >      >     processes or to get a
>     mapping so
>      >     that I
>      >      >     can do
>      >      >      >     it myself?
>      >      >      >      >      >      > By definition, PETSc vectors and
>      >     matrices own
>      >      >      >     contiguous row
>      >      >      >      >      >     blocks. If
>      >      >      >      >      >      > you want to have another,
>      >      >      >      >      >      > global ordering, we support
>     that with
>      > https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>
>     <https://petsc.org/main/manualpages/AO/>>
>      >      >     <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>
>      >      >      >     <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>>
>      >      >      >      >     <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>>>
>     <https://petsc.org/main/manualpages/AO/>>>>>>
>     <https://petsc.org/main/manualpages/AO/>>>>>>>
>      >      >      >      >      >      >    Thanks,
>      >      >      >      >      >      >       Matt
>      >      >      >      >      >      >     Cheers,
>      >      >      >      >      >      >     Enrico Degregori
>      >      >      >      >      >      > What most experimenters take for
>      >     granted before
>      >      >      >     they begin
>      >      >      >      >     their
>      >      >      >      >      >      > experiments is infinitely more
>      >     interesting
>      >      >     than any
>      >      >      >      >     results to which
>      >      >      >      >      >      > their experiments lead.
>      >      >      >      >      >      > -- Norbert Wiener
>     https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>
>     <https://www.cse.buffalo.edu/~knepley/>>
>      >      >     <https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>>>
>      >      >      >     <https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>>>>
>      >      >      >      >     <https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>>>>>
>     <https://www.cse.buffalo.edu/~knepley/>>>>>>
>       <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
>     <http://www.cse.buffalo.edu/~knepley/>>
>      >      >     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>>>
>      >      >      >     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>>>>
>      >      >      >      >     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>>>>>
>     <http://www.cse.buffalo.edu/~knepley/>>>>>>>
>     granted before
>      >      >     they begin
>      >      >      >     their
>     interesting
>      >     than any
>      >      >      >      >      > https://www.cse.buffalo.edu/~knepley/
>      >      >      >      > What most experimenters take for granted before
>      >     they begin
>      >      >     their
>      >      >      >      > experiments is infinitely more interesting
>     than any
>      >      >     results to which
>     they begin
>      >     their
>      >      >      > experiments is infinitely more interesting than any
>      >     results to which
>      >      > What most experimenters take for granted before they begin
>     their
>     results to which
>      >      > -- Norbert Wiener
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
