[petsc-users] Coordinate format internal reordering
Enrico degregori at dkrz.de
Thu Oct 19 05:51:39 CDT 2023
Hello,
if I create an application ordering using AOCreateBasic, should I
provide the same array for const PetscInt myapp[] and const PetscInt
mypetsc[] in order to get the same ordering of the application within PETSC?
And once I define the ordering so that the local vector and matrix are
defined in PETSC as in my application, how can I use it to create the
actual vector and matrix?
Thanks in advance for the help.
Cheers,
Enrico
On 18/10/2023 13:39, Matthew Knepley wrote:
> On Wed, Oct 18, 2023 at 5:55 AM Enrico <degregori at dkrz.de
> <mailto:degregori at dkrz.de>> wrote:
>     Hello,
>     I'm trying to use Petsc to solve a linear system in an application. I'm
>     using the coordinate format to define the matrix and the vector (it
>     should work better on GPU but at the moment every test is on CPU).
>     After
>     the call to VecSetValuesCOO, I've noticed that the vector is storing
>     the
>     data in a different way from my application. For example with two
>     processes in the application
>     process 0 owns cells 2, 3, 4
>     process 1 owns cells 0, 1, 5
>     But in the vector data structure of Petsc
>     process 0 owns cells 0, 1, 2
>     process 1 owns cells 3, 4, 5
>     This is in principle not a big issue, but after solving the linear
>     system I get the solution vector x and I want to get the values in the
>     correct processes. Is there a way to get vector values from other
>     processes or to get a mapping so that I can do it myself?
> By definition, PETSc vectors and matrices own contiguous row blocks. If
> you want to have another,
> global ordering, we support that with
> https://petsc.org/main/manualpages/AO/
> <https://petsc.org/main/manualpages/AO/>
>    Thanks,
>       Matt
>     Cheers,
>     Enrico Degregori
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
