[petsc-users] Galerkin projection using petsc4py
Pierre Jolivet pierre at joliv.et
Wed Oct 11 00:18:10 CDT 2023
I disagree with what Mark and Matt are saying: your code is fine, the error message is fine, petsc4py is fine (in this instance).
It’s not a typical use case of MatPtAP(), which is mostly designed for MatAIJ, not MatDense.
On the one hand, in the MatDense case, indeed there will be a mismatch between the number of columns of A and the number of rows of P, as written in the error message.
On the other hand, there is not much to optimize when computing C = P’ A P with everything being dense.
I would just write this as B = A P and then C = P’ B (but then you may face the same issue as initially reported, please let us know then).
Pierre
> On 11 Oct 2023, at 2:42 AM, Mark Adams <mfadams at lbl.gov> wrote:
> This looks like a false positive or there is some subtle bug here that we are not seeing.
> Could this be the first time parallel PtAP has been used (and reported) in petsc4py?
> Mark
> On Tue, Oct 10, 2023 at 8:27 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Tue, Oct 10, 2023 at 5:34 PM Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>> Hi all,
>>> Revisiting my code and the proposed solution from Pierre, I realized this works only in sequential. The reason is that PETSc partitions those matrices only row-wise, which leads to an error due to the mismatch between number of columns of A (non-partitioned) and the number of rows of Phi (partitioned).
>> Are you positive about this? P^T A P is designed to run in this scenario, so either we have a bug or the diagnosis is wrong.
>>   Thanks,
>>      Matt
>>> """Experimenting with PETSc mat-mat multiplication"""
>>> import time
>>> import numpy as np
>>> from colorama import Fore
>>> from firedrake import COMM_SELF, COMM_WORLD
>>> from firedrake.petsc import PETSc
>>> from mpi4py import MPI
>>> from numpy.testing import assert_array_almost_equal
>>> from utilities import Print
>>> nproc = COMM_WORLD.size
>>> rank = COMM_WORLD.rank
>>> def create_petsc_matrix(input_array, sparse=True):
>>>     """Create a PETSc matrix from an input_array
>>>     Args:
>>>         input_array (np array): Input array
>>>         partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
>>>         sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
>>>     Returns:
>>>         PETSc mat: PETSc mpi matrix
>>>     # Check if input_array is 1D and reshape if necessary
>>>     assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
>>>     global_rows, global_cols = input_array.shape
>>>     size = ((None, global_rows), (global_cols, global_cols))
>>>     # Create a sparse or dense matrix based on the 'sparse' argument
>>>     if sparse:
>>>         matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
>>>     else:
>>>         matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
>>>     matrix.setUp()
>>>     local_rows_start, local_rows_end = matrix.getOwnershipRange()
>>>     for counter, i in enumerate(range(local_rows_start, local_rows_end)):
>>>         # Calculate the correct row in the array for the current process
>>>         row_in_array = counter + local_rows_start
>>>         matrix.setValues(
>>>             i, range(global_cols), input_array[row_in_array, :], addv=False
>>>     # Assembly the matrix to compute the final structure
>>>     matrix.assemblyBegin()
>>>     matrix.assemblyEnd()
>>>     return matrix
>>> # EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc matrix Phi
>>> #  A' = Phi.T * A * Phi
>>> # [k x k] <- [k x m] x [m x m] x [m x k]
>>> m, k = 100, 7
>>> # Generate the random numpy matrices
>>> np.random.seed(0)  # sets the seed to 0
>>> A_np = np.random.randint(low=0, high=6, size=(m, m))
>>> Phi_np = np.random.randint(low=0, high=6, size=(m, k))
>>> # TEST: Galerking projection of numpy matrices A_np and Phi_np
>>> Aprime_np = Phi_np.T @ A_np @ Phi_np
>>> Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
>>> Print(f"{Aprime_np}")
>>> # Create A as an mpi matrix distributed on each process
>>> A = create_petsc_matrix(A_np, sparse=False)
>>> # Create Phi as an mpi matrix distributed on each process
>>> Phi = create_petsc_matrix(Phi_np, sparse=False)
>>> # Create an empty PETSc matrix object to store the result of the PtAP operation.
>>> # This will hold the result A' = Phi.T * A * Phi after the computation.
>>> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
>>> # Perform the PtAP (Phi Transpose times A times Phi) operation.
>>> # In mathematical terms, this operation is A' = Phi.T * A * Phi.
>>> # A_prime will store the result of the operation.
>>> A_prime = A.ptap(Phi)
>>> Here is the error
>>> MATRIX mpiaij A [100x100]
>>> Assembled
>>> Partitioning for A:
>>>   Rank 0: Rows [0, 34)
>>>   Rank 1: Rows [34, 67)
>>>   Rank 2: Rows [67, 100)
>>> MATRIX mpiaij Phi [100x7]
>>> Assembled
>>> Partitioning for Phi:
>>> Traceback (most recent call last):
>>>   File "/Users/boutsitron/work/galerkin_projection.py", line 87, in <module>
>>>   File "petsc4py/PETSc/Mat.pyx", line 1525, in petsc4py.PETSc.Mat.ptap
>>> petsc4py.PETSc.Error: error code 60
>>> [0] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
>>> [0] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
>>> [0] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
>>> [0] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
>>> [0] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
>>> [0] Nonconforming object sizes
>>> [0] Matrix local dimensions are incompatible, Acol (0, 100) != Prow (0,34)
>>> Abort(1) on node 0 (rank 0 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 0
>>> Any thoughts?
>>> Thanks,
>>> Thanos
>>>> On 5 Oct 2023, at 14:23, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>> This works Pierre. Amazing input, thanks a lot!
>>>>> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>> Not a petsc4py expert here, but you may to try instead:
>>>>> Thanks,
>>>>> Pierre
>>>>>> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>> Thanks Pierre! So I tried this and got a segmentation fault. Is this supposed to work right off the bat or am I missing sth?
>>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>>>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>>>> [0]PETSC ERROR: to get more information on the crash.
>>>>>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>>>>>> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>> import time
>>>>>> import numpy as np
>>>>>> from utilities import (
>>>>>>     Print,
>>>>>>     create_petsc_matrix,
>>>>>>     print_matrix_partitioning,
>>>>>> m, k = 11, 7
>>>>>> Phi.PtAP(A, A_prime)
>>>>>>> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>>>> How about using ptap which will use MatPtAP?
>>>>>>> It will be more efficient (and it will help you bypass the issue).
>>>>>>> Thanks,
>>>>>>> Pierre
>>>>>>>> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>> Sorry, forgot function create_petsc_matrix()
>>>>>>>> def create_petsc_matrix(input_array sparse=True):
>>>>>>>>     Args:
>>>>>>>>     Returns:
>>>>>>>>         PETSc mat: PETSc matrix
>>>>>>>>     if sparse:
>>>>>>>>     else:
>>>>>>>>     matrix.setUp()
>>>>>>>>         matrix.setValues(
>>>>>>>>     return matrix
>>>>>>>>> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>>>>>>> Hi everyone,
>>>>>>>>> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A, A1) work. The error is
>>>>>>>>>   File "petsc4py/PETSc/Mat.pyx", line 1514, in petsc4py.PETSc.Mat.transposeMatMult
>>>>>>>>> petsc4py.PETSc.Error: error code 56
>>>>>>>>> [0] MatTransposeMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
>>>>>>>>> [0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
>>>>>>>>> [0] No support for this operation for this object type
>>>>>>>>> [0] Call MatProductCreate() first
>>>>>>>>> Do you know if these exposed to petsc4py or maybe there is another way? I cannot get the MFE to work (neither in sequential nor in parallel)
>>>>>>>>> import time
>>>>>>>>> import numpy as np
>>>>>>>>>     Print,
>>>>>>>>> m, k = 11, 7
>>>>>>>>> A = create_petsc_matrix(A_np)
>>>>>>>>> Phi = create_petsc_matrix(Phi_np)
>>>>>>>>> A1 = create_petsc_matrix(np.zeros((k, m)))
>>>>>>>>> # Now A1 contains the result of Phi^T * A
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/327a2f93/attachment-0001.html>
