[petsc-users] FEM Implementation of NS with SUPG Stabilization
Brandon Denton bldenton at buffalo.edu
Tue Oct 10 22:54:11 CDT 2023
My initial plan was to write a new code using only PETSc. However, I don't see how to do what I want within the point-wise residual function. Am I missing something?
Yes. I would be interested in collaborating on the ceed-fluids. I took a quick look at the links you provided and it looks interesting. I'll warn you though. I'm a Mechanical Engineer by trade/training. The calculus and programming sometimes take me a little while to wrap my head around. Let me know how I can help. In the meantime, I'll continue to review the information you sent over.
Sent: Tuesday, October 10, 2023 10:18 PM
To: Brandon Denton <bldenton at buffalo.edu>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] FEM Implementation of NS with SUPG Stabilization
Do you want to write a new code using only PETSc or would you be up for collaborating on ceed-fluids, which is a high-performance compressible SUPG solver based on DMPlex with good GPU support? It uses the metric to compute covariant length for stabilization. We have YZƁ shock capturing, though it hasn't been tested much beyond shock tube experiments. (Most of our work has been low Mach.)
https://libceed.org/en/latest/examples/fluids/
https://github.com/CEED/libCEED/blob/main/examples/fluids/qfunctions/stabilization.h#L76
On Tue, Oct 10, 2023, at 7:34 PM, Brandon Denton via petsc-users wrote:
Good Evening,
I am looking to implement a form of Navier-Stokes with SUPG Stabilization and shock capturing using PETSc's FEM infrastructure. In this implementation, I need access to the cell's shape function gradients and natural coordinate gradients for calculations within the point-wise residual calculations. How do I get these quantities at the quadrature points? The signatures for fo and f1 don't seem to contain this information.
Thank you in advance for your time.
Brandon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/c33ed43d/attachment-0001.html>
