[petsc-users] Compute integral using DMPlexComputeIntegralFEM
David Andrs andrsd at gmail.com
Thu Oct 5 15:59:58 CDT 2023
Hi Matt!
Thanks for getting back to this.  I found a mistake in my hand calculation
- I used wrong shape functions (pretty stupid mistake :face_palm:).
Thanks again for your help,
David
On Wed, Oct 4, 2023 at 10:13 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 8, 2023 at 6:26 PM David Andrs <andrsd at gmail.com> wrote:
>> Hi all!
>> I am trying to use DMPlexComputeIntegralFEM to compute an integral
>> $\int_\Omega u d\Omega$. My domain is a square (-1, 1)^2 (2x2 QUAD4
>> elements), I add first order Lagrange FE field on it, set the solution
>> vector (computed by a previous simulation).
>> The value I am seeing computed by PETSc is -4, but the hand-calculated
>> value of this integral is -4.6. I also checked this in paraview using the
>> ‘Integrate Variables’ filter and it also returns -4.6 (this was to double
>> check that my hand-calculated value is correct).
> Sorry it took so long. You caught me at a bad time.
> Something must be wrong with your analytic integrals. Here is me doing
> them by hand. You have a 3x3 vertex arrangement with coefficients
>    1  0 -3
>   -2 -1 -2
>   -3  0  1
> From the symmetry, the integrals of the cells along each diagonal must be
> equal. Now, the shape functions for Q_1 are
>      (1 - x) y            x y
>   (1 - x)(1 - y)     x (1 - y)
> Thus the integral for the lower left cell is
>   \int^1_0 dx \int^1_0 dy -3 + 3 x + y - 2 xy = -3 + 3/2 + 1/2 - 2/4 = -1.5
> which is also the upper right cell. The integral for the lower right cell
> is
>   \int^1_0 dx \int^1_0 dy x - y - 2 xy = 1/2 - 1/2 - 2/4 = -1/2
> which is also the upper left cell. Thus we get -1.5 - 1.5 - 0.5 - 0.5 =
> -4, which is what Plex gets.
>   THanks,
>     Matt
> So, I must be missing something obvious in my code. Attached is the
>> minimal PETSc code to show what I am doing. This is against PETSc 3.19.4.
>> Thanks in advance for your help,
>> David
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231005/9694cce5/attachment.html>
