[petsc-users] MPI barrier issue using MatZeroRows
Barry Smith bsmith at petsc.dev
Wed Nov 29 12:50:37 CST 2023
   What PETSc version are you using?
> On Nov 29, 2023, at 1:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 29, 2023 at 12:30 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>> Ok, I added both, but it still hangs. Here, is bt from all three tasks:
> It looks like two processes are calling AllReduce, but one is not. Are all procs not calling MatZeroRows?
>   Thanks,
>      Matt
>> Task 1:
>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44691
>> (lldb) process attach --pid 44691
>> Process 44691 stopped
>> * thread #1, queue = 'com.apple.main-thread', stop reason = signal SIGSTOP
>>     frame #0: 0x000000018a2d750c libsystem_kernel.dylib`__semwait_signal + 8
>> libsystem_kernel.dylib`:
>> ->  0x18a2d750c <+8>:  b.lo   0x18a2d752c               ; <+40>
>>     0x18a2d7510 <+12>: pacibsp
>>     0x18a2d7514 <+16>: stp    x29, x30, [sp, #-0x10]!
>>     0x18a2d7518 <+20>: mov    x29, sp
>> Target 0: (fo_acoustic_streaming_solver_2d) stopped.
>> Executable module set to "/Users/amneetb/Softwares/IBAMR-Git/objs-dbg/tests/IBTK/fo_acoustic_streaming_solver_2d".
>> Architecture set to: arm64-apple-macosx-.
>> (lldb) cont
>> Process 44691 resuming
>>     frame #0: 0x000000010ba40b60libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release + 752
>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release:
>> ->  0x10ba40b60 <+752>: add    w8, w8, #0x1
>>     0x10ba40b64 <+756>: ldr    w9, [x22]
>>     0x10ba40b68 <+760>: cmp    w8, w9
>>     0x10ba40b6c <+764>: b.lt <http://b.lt/>   0x10ba40b4c               ; <+732>
>> (lldb) bt
>>   * frame #0: 0x000000010ba40b60libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release + 752
>>     frame #1: 0x000000010ba48528libpmpi.12.dylib`MPIDI_POSIX_mpi_allreduce_release_gather + 1088
>>     frame #2: 0x000000010ba47964libpmpi.12.dylib`MPIDI_Allreduce_intra_composition_gamma + 368
>>     frame #3: 0x000000010ba35e78 libpmpi.12.dylib`MPIR_Allreduce + 1588
>>     frame #4: 0x0000000103f587dc libmpi.12.dylib`MPI_Allreduce + 2280
>>     frame #5: 0x0000000106d67650libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x0000000105846470, N=1, rows=0x000000016dbfa9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at mpiaij.c:827:3
>>     frame #6: 0x0000000106aadfaclibpetsc.3.17.dylib`MatZeroRows(mat=0x0000000105846470, numRows=1, rows=0x000000016dbfa9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at matrix.c:5935:3
>>     frame #7: 0x00000001023952d0fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016dc04168, omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4, u_bc_coefs=0x000000016dc04398, data_time=NaN, num_dofs_per_proc=size=3, u_dof_index_idx=27, p_dof_index_idx=28, patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016dbfcec0, mu_interp_type=VC_HARMONIC_INTERP) at AcousticStreamingPETScMatUtilities.cpp:799:36
>>     frame #8: 0x00000001023acb8cfo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016dc04018, x=0x000000016dc05778, (null)=0x000000016dc05680) at FOAcousticStreamingPETScLevelSolver.cpp:149:5
>>     frame #9: 0x000000010254a2dcfo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016dc04018, x=0x000000016dc05778, b=0x000000016dc05680) at PETScLevelSolver.cpp:340:5
>>     frame #10: 0x0000000102202e5c fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016dc07450) at fo_acoustic_streaming_solver.cpp:400:22
>>     frame #11: 0x0000000189fbbf28 dyld`start + 2236
>> (lldb)
>> Task 2:
>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44692
>> (lldb) process attach --pid 44692
>> Process 44692 stopped
>> (lldb) cont
>> Process 44692 resuming
>>     frame #0: 0x000000010e5a022clibpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 516
>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather:
>> ->  0x10e5a022c <+516>: ldr    x10, [x19, #0x4e8]
>>     0x10e5a0230 <+520>: cmp    x9, x10
>>     0x10e5a0234 <+524>: b.hs   0x10e5a0254               ; <+556>
>>     0x10e5a0238 <+528>: add    w8, w8, #0x1
>> (lldb) bt
>>   * frame #0: 0x000000010e5a022clibpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 516
>>     frame #1: 0x000000010e59fd14 libpmpi.12.dylib`MPIDI_SHM_mpi_barrier + 224
>>     frame #2: 0x000000010e59fb60libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
>>     frame #3: 0x000000010e585490 libpmpi.12.dylib`MPIR_Barrier + 900
>>     frame #4: 0x0000000106ac5030 libmpi.12.dylib`MPI_Barrier + 684
>>     frame #5: 0x0000000108e62638libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=1140850688, comm_out=0x00000001408ae4b0, first_tag=0x00000001408ae4e4) at tagm.c:235:5
>>     frame #6: 0x0000000108e6a910libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x00000001408ae470, classid=1211228, class_name="KSP", descr="Krylov Method", mansec="KSP", comm=1140850688, destroy=(libpetsc.3.17.dylib`KSPDestroy at itfunc.c:1418), view=(libpetsc.3.17.dylib`KSPView at itcreate.c:113)) at inherit.c:62:3
>>     frame #7: 0x000000010aa28010 libpetsc.3.17.dylib`KSPCreate(comm=1140850688, inksp=0x000000016b0a4160) at itcreate.c:679:3
>>     frame #8: 0x00000001050aa2f4fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016b0a4018, x=0x000000016b0a5778, b=0x000000016b0a5680) at PETScLevelSolver.cpp:344:12
>>     frame #9: 0x0000000104d62e5c fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016b0a7450) at fo_acoustic_streaming_solver.cpp:400:22
>>     frame #10: 0x0000000189fbbf28 dyld`start + 2236
>> (lldb)
>> Task 3:
>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44693
>> (lldb) process attach --pid 44693
>> Process 44693 stopped
>> (lldb) cont
>> Process 44693 resuming
>>     frame #0: 0x000000010e59c68clibpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather + 952
>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather:
>> ->  0x10e59c68c <+952>: ldr    w9, [x21]
>>     0x10e59c690 <+956>: cmp    w8, w9
>>     0x10e59c694 <+960>: b.lt <http://b.lt/>   0x10e59c670               ; <+924>
>>     0x10e59c698 <+964>: bl     0x10e59ce64               ; MPID_Progress_test
>> (lldb) bt
>>   * frame #0: 0x000000010e59c68clibpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather + 952
>>     frame #1: 0x000000010e5a44bclibpmpi.12.dylib`MPIDI_POSIX_mpi_allreduce_release_gather + 980
>>     frame #2: 0x000000010e5a3964libpmpi.12.dylib`MPIDI_Allreduce_intra_composition_gamma + 368
>>     frame #3: 0x000000010e591e78 libpmpi.12.dylib`MPIR_Allreduce + 1588
>>     frame #4: 0x0000000106ab47dc libmpi.12.dylib`MPI_Allreduce + 2280
>>     frame #5: 0x00000001098c3650libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x0000000136862270, N=1, rows=0x000000016b09e9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at mpiaij.c:827:3
>>     frame #6: 0x0000000109609faclibpetsc.3.17.dylib`MatZeroRows(mat=0x0000000136862270, numRows=1, rows=0x000000016b09e9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at matrix.c:5935:3
>>     frame #7: 0x0000000104ef12d0fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016b0a8168, omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4, u_bc_coefs=0x000000016b0a8398, data_time=NaN, num_dofs_per_proc=size=3, u_dof_index_idx=27, p_dof_index_idx=28, patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016b0a0ec0, mu_interp_type=VC_HARMONIC_INTERP) at AcousticStreamingPETScMatUtilities.cpp:799:36
>>     frame #8: 0x0000000104f08b8cfo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016b0a8018, x=0x000000016b0a9778, (null)=0x000000016b0a9680) at FOAcousticStreamingPETScLevelSolver.cpp:149:5
>>     frame #9: 0x00000001050a62dcfo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016b0a8018, x=0x000000016b0a9778, b=0x000000016b0a9680) at PETScLevelSolver.cpp:340:5
>>     frame #10: 0x0000000104d5ee5c fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016b0ab450) at fo_acoustic_streaming_solver.cpp:400:22
>> (lldb)
>> On Wed, Nov 29, 2023 at 7:22 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>> On Nov 29, 2023, at 1:16 AM, Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>> BTW, I think you meant using MatSetOption(mat, MAT_NO_OFF_PROC_ZERO_ROWS, PETSC_TRUE)
>>> Yes
>>>>  instead ofMatSetOption(mat, MAT_NO_OFF_PROC_ENTRIES, PETSC_TRUE) ??
>>>   Please try setting both flags.
>>>>  However, that also did not help to overcome the MPI Barrier issue.
>>>   If there is still a problem please trap all the MPI processes when they hang in the debugger and send the output from using bt on all of them. This way
>>> we can see the different places the different MPI processes are stuck at.
>>>> On Tue, Nov 28, 2023 at 9:57 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>> I added that option but the code still gets stuck at the same call MatZeroRows with 3 processors.
>>>>> On Tue, Nov 28, 2023 at 7:23 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>>> On Tue, Nov 28, 2023 at 6:42 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>>>   for (int comp = 0; comp < 2; ++comp)
>>>>>>>                     for (Box<NDIM>::Iterator bc(bc_coef_box); bc; bc++)
>>>>>>>                         if (IBTK::abs_equal_eps(b, 0.0))
>>>>>>>                             const double diag_value = a;
>>>>>>>                             ierr = MatZeroRows(mat, 1, &u_dof_index, diag_value, NULL, NULL);
>>>>>>>                             IBTK_CHKERRQ(ierr);
>>>>>>> In general, this code will not work because each process calls MatZeroRows a different number of times, so it cannot match up with all the processes.
>>>>>>> If u_dof_index is always local to the current process, you can call MatSetOption(mat, MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE) above the for loop and
>>>>>>> the MatZeroRows will not synchronize across the MPI processes (since it does not need to and you told it that).
>>>>>> Yes, u_dof_index is going to be local and I put a check on it a few lines before calling MatZeroRows.
>>>>>> Can MatSetOption() be called after the matrix has been assembled?
>>>>>>> If the u_dof_index will not always be local, then you need, on each process, to list all the u_dof_index for each process in an array and then call MatZeroRows()
>>>>>>> once after the loop so it can exchange the needed information with the other MPI processes to get the row indices to the right place.
>>>>>>> Barry
>>>>>>>> On Nov 28, 2023, at 6:44 PM, Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>>>>> Hi Folks,
>>>>>>>> I am using MatZeroRows() to set Dirichlet boundary conditions. This works fine for the serial run and the solver produces correct results (verified through analytical solution). However, when I run the case in parallel, the simulation gets stuck at MatZeroRows(). My understanding is that this function needs to be called after the MatAssemblyBegin{End}() has been called, and should be called by all processors. Here is that bit of the code which calls MatZeroRows() after the matrix has been assembled
>>>>>>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L724-L801
>>>>>>>> I ran the parallel code (on 3 processors) in the debugger (-start_in_debugger). Below is the call stack from the processor that gets stuck
>>>>>>>> amneetb at APSB-MBP-16:~$ lldb  -p 4307
>>>>>>>> (lldb) process attach --pid 4307
>>>>>>>> Process 4307 stopped
>>>>>>>> (lldb) cont
>>>>>>>> Process 4307 resuming
>>>>>>>>     frame #0: 0x0000000109d281b8libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
>>>>>>>> ->  0x109d281b8 <+400>: ldr    w9, [x24]
>>>>>>>>     0x109d281bc <+404>: cmp    w8, w9
>>>>>>>>     0x109d281c0 <+408>: b.lt <http://b.lt/>   0x109d281a0               ; <+376>
>>>>>>>>     0x109d281c4 <+412>: bl     0x109d28e64               ; MPID_Progress_test
>>>>>>>> (lldb) bt
>>>>>>>>   * frame #0: 0x0000000109d281b8libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
>>>>>>>>     frame #1: 0x0000000109d27d14 libpmpi.12.dylib`MPIDI_SHM_mpi_barrier + 224
>>>>>>>>     frame #2: 0x0000000109d27b60libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
>>>>>>>>     frame #3: 0x0000000109d0d490 libpmpi.12.dylib`MPIR_Barrier + 900
>>>>>>>>     frame #4: 0x000000010224d030 libmpi.12.dylib`MPI_Barrier + 684
>>>>>>>>     frame #5: 0x00000001045ea638libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=-2080374782, comm_out=0x000000010300bcb0, first_tag=0x000000010300bce4) at tagm.c:235:5
>>>>>>>>     frame #6: 0x00000001045f2910libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x000000010300bc70, classid=1211227, class_name="PetscSF", descr="Star Forest", mansec="PetscSF", comm=-2080374782, destroy=(libpetsc.3.17.dylib`PetscSFDestroy at sf.c:224), view=(libpetsc.3.17.dylib`PetscSFView at sf.c:841)) at inherit.c:62:3
>>>>>>>>     frame #7: 0x00000001049cf820libpetsc.3.17.dylib`PetscSFCreate(comm=-2080374782, sf=0x000000016f911a50) at sf.c:62:3
>>>>>>>>     frame #8: 0x0000000104cd3024libpetsc.3.17.dylib`MatZeroRowsMapLocal_Private(A=0x00000001170c1270, N=1, rows=0x000000016f912cb4, nr=0x000000016f911df8, olrows=0x000000016f911e00) at zerorows.c:36:5
>>>>>>>>     frame #9: 0x000000010504ea50libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x00000001170c1270, N=1, rows=0x000000016f912cb4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at mpiaij.c:768:3
>>>>>>>>     frame #10: 0x0000000104d95faclibpetsc.3.17.dylib`MatZeroRows(mat=0x00000001170c1270, numRows=1, rows=0x000000016f912cb4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at matrix.c:5935:3
>>>>>>>>     frame #11: 0x000000010067d320fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016f91c178, omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4, u_bc_coefs=0x000000016f91c3a8, data_time=NaN, num_dofs_per_proc=size=3, u_dof_index_idx=27, p_dof_index_idx=28, patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016f914ed0, mu_interp_type=VC_HARMONIC_INTERP) at AcousticStreamingPETScMatUtilities.cpp:794:36
>>>>>>>>     frame #12: 0x0000000100694bdcfo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016f91c028, x=0x000000016f91d788, (null)=0x000000016f91d690) at FOAcousticStreamingPETScLevelSolver.cpp:149:5
>>>>>>>>     frame #13: 0x000000010083232cfo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016f91c028, x=0x000000016f91d788, b=0x000000016f91d690) at PETScLevelSolver.cpp:340:5
>>>>>>>>     frame #14: 0x00000001004eb230fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016f91f460) at fo_acoustic_streaming_solver.cpp:400:22
>>>>>>>>     frame #15: 0x0000000189fbbf28 dyld`start + 2236
>>>>>>>> Any suggestions on how to avoid this barrier? Here are all MAT options I am using (in the debug mode), if that is helpful:
>>>>>>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L453-L458
>>>>>>>> Thanks,
>>>>>>>> --Amneet
>>>>> --Amneet
>>>> --Amneet
>> --Amneet
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231129/9c2b1060/attachment-0001.html>
