[petsc-users] msh4 geenerated from neper
Sharan Roongta s.roongta at mpie.de
Tue Nov 28 07:38:09 CST 2023
Hello,
I have problem loading the msh4 file generated from neper. The mesh format is 4.1
The error is:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Unexpected data in file
[0]PETSC ERROR: File is not a valid Gmsh file, expecting $Entities
[0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could be the program crashed before they were used or a spelling mistake, etc!
[0]PETSC ERROR: Option left: name:-g value: test.msh4
[0]PETSC ERROR: Option left: name:-l value: tensionX.load
[0]PETSC ERROR: Option left: name:-m value: material.yaml
[0]PETSC ERROR: Option left: name:-n value: numerics.yaml
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.18.5, unknown
[0]PETSC ERROR: DAMASK_mesh on a gfortran named mamc57x by work Mon Nov 27 21:50:06 2023
[0]PETSC ERROR: Configure options --with-mpi-f90module-visibility=0 --download-hdf5 --with-hdf5-fortran-bindings=1 --download-fftw --download-mpich --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=1 --download-ml --download-mumps --download-scalapack --download-hypre --download-zlib
[0]PETSC ERROR: #1 GmshExpect() at /home/work/petsc/src/dm/impls/plex/plexgmsh.c:270
[0]PETSC ERROR: #2 DMPlexCreateGmsh() at /home/work/petsc/src/dm/impls/plex/plexgmsh.c:1548
[0]PETSC ERROR: #3 DMPlexCreateGmshFromFile() at /home/work/petsc/src/dm/impls/plex/plexgmsh.c:1433
[0]PETSC ERROR: #4 DMPlexCreateFromFile() at /home/work/petsc/src/dm/impls/plex/plexcreate.c:5207
[0]PETSC ERROR: #5 /home/work/DAMASK/src/mesh/discretization_mesh.f90:112
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: No error traceback is available, the problem could be in the main program.
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
The file does contain the $Entities section (file attached).
Has anyone encountered this before?
Sharan
P.S Sorry for the earlier mail that was sent to the incorrect mailing list.
Max-Planck-Institut für Eisenforschung GmbH
Max-Planck-Straße 1
D-40237 Düsseldorf
Handelsregister B 2533
Amtsgericht Düsseldorf
Geschäftsführung
Prof. Dr. Gerhard Dehm
Prof. Dr. Jörg Neugebauer
Prof. Dr. Dierk Raabe
Dr. Kai de Weldige
Ust.-Id.-Nr.: DE 11 93 58 514
Steuernummer: 105 5891 1000
Please consider that invitations and e-mails of our institute are
only valid if they end with ... at mpie.de.
If you are not sure of the validity please contact rco at mpie.de
Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
aus unserem Haus nur mit der Endung ... at mpie.de gültig sind.
In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
Stay up to date and follow us on LinkedIn, Twitter and YouTube.
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
only valid if they end with …@mpie.de.
aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231128/553ce7b8/attachment.html>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231128/553ce7b8/attachment.bin>
