[petsc-users] MUMPS valgrind error
Alexander Lindsay alexlindsay239 at gmail.com
Mon Nov 20 15:22:11 CST 2023
This is from a MOOSE test. If I find the same error on something simpler I
will let you know
On Mon, Nov 20, 2023 at 12:56 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> Can you provide us a test code that reveals this error?
> Hong
> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
> Alexander Lindsay <alexlindsay239 at gmail.com>
> *Sent:* Monday, November 20, 2023 2:48 PM
> *To:* PETSc <petsc-users at mcs.anl.gov>
> *Subject:* [petsc-users] MUMPS valgrind error
> I recently ran into some parallel crashes and valgrind suggests the issue
> is with MUMPS. Has anyone else run into something similar recently?
> ==4022024== Invalid read of size 4
> ==4022024==    at 0xF961266: dmumps_dr_assemble_local (dsol_distrhs.F:301)
> ==4022024==    by 0xF961266: dmumps_scatter_dist_rhs_ (dsol_distrhs.F:169)
> ==4022024==    by 0xF952669: dmumps_solve_driver_ (dsol_driver.F:3677)
> ==4022024==    by 0xF8CA64A: dmumps_ (dmumps_driver.F:2035)
> ==4022024==    by 0xF85E12B: dmumps_f77_ (dmumps_f77.F:291)
> ==4022024==    by 0xF85C30E: dmumps_c (mumps_c.c:485)
> ==4022024==    by 0xEBA8E56: MatSolve_MUMPS (mumps.c:1493)
> ==4022024==    by 0xEE85D97: MatSolve (matrix.c:3631)
> ==4022024==    by 0xF31B060: PCApply_LU (lu.c:169)
> ==4022024==    by 0xF50FD3B: PCApply (precon.c:486)
> ==4022024==    by 0xF511204: PCApplyBAorAB (precon.c:756)
> ==4022024==    by 0xF51C5F0: KSP_PCApplyBAorAB (kspimpl.h:443)
> ==4022024==    by 0xF51C5F0: KSPGMRESCycle (gmres.c:146)
> ==4022024==    by 0xF51C5F0: KSPSolve_GMRES (gmres.c:227)
> ==4022024==    by 0xF5F339D: KSPSolve_Private (itfunc.c:910)
> ==4022024==  Address 0x308b338c is 4 bytes before a block of size 1
> alloc'd
> ==4022024==    at 0x4C37135: malloc (vg_replace_malloc.c:381)
> ==4022024==    by 0xF960E93: dmumps_scatter_dist_rhs_ (dsol_distrhs.F:139)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231120/44a493bf/attachment-0001.html>
