[petsc-users] VecNorm causes program to hang
Thu Nov 16 19:27:21 CST 2023
On Thu, Nov 16, 2023 at 6:19 PM Sreeram R Venkat <srvenkat at utexas.edu>
wrote:
> I have a program which reads a vector from file into an array, and then
> uses that array to create a PETSc Vec object. The Vec is defined on the
> global communicator, but not all processes actually contain entries of it.
> For example, suppose we have 4 processors, and the vector is of size 10.
> Rank 0 will contain entries 0-4 and Rank 1 will contain entries 5-9. Ranks
> 2 and 3 will not have any entries of the Vec.
> This Vec is then used as an input to other parts of the code, and those
> work fine. However, if I try to take the norm of the Vec with VecNorm(), I
> get the error
> `MPI_Allreduce() called in different locations (code lines) on different
> processors`
> The stack trace shows that ranks 0 and 1 (from the above example) are
> still in the VecNorm() function while ranks 2 and 3 have moved on to a
> later part of the code. If I add a PetscBarrier() after the VecNorm(), I
> find that the program hangs.
> The funny thing is that part of the code duplicates the Vec with
> VecDuplicate() and assigns to the duplicated vector the result of some
> computations. The duplicated Vec has the same layout as the original Vec,
> but taking VecNorm() on the duplicated Vec works fine. If I use VecCopy(),
> however, the copied Vec also causes VecNorm() to hang. I've printed out the
> original Vec, and there are no corrupted/NaN entries.
> I have a temporary workaround where I perturb the original Vec slightly
> before copying it to another Vec. This causes the program to successfully
> terminate.
> Any advice on how to get VecNorm() working with the original Vec?
Vecs with empty layouts work fine, so it must be something else about how
it is created.
In order to track it down, I would first make a short program that just
creates the Vec as you say and see if it hangs. If so, just send it and we
will debug it. If not, I would systematically cut down your program until
you get something that hangs that you can send to us.
     Matt
> Thanks,
> Sreeram
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231116/bc4a6d14/attachment-0001.html>
