[petsc-users] Using SNESSHELL as a wrapper for a CFD solver.
Wed May 31 17:21:14 CDT 2023
On Wed, May 31, 2023 at 5:51 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Sorry, I wrote to quickly in my last email. You will need to create a
> SNESSHELL its solve simply calls your solver (for its one iteration)
> SNESNRICHARSON handles the rest.
Yes, this is a great suggestion. It should work with your current SNESSHELL.
I would also point out that we have the SNESMS, which is the multistage
solver from Jameson. You can
use this as a residual smooth with FAS to do something similar to what you
have, although I do not know
what Mach number preconditioning is (Jed probably knows).
    Matt
> On May 31, 2023, at 4:16 PM, Kenneth C Hall <kenneth.c.hall at duke.edu>
> wrote:
> Matt,
> Thanks for your quick reply.  I think what you say makes sense.
> You asked what my code does. The MySolver program performs one iteration
> of a CFD iteration. The CFD scheme is an explicit scheme that uses
> multigrid, Mach number preconditioning, and residual smoothing.  Typically,
> I have to call MySolver on the order of 40 to 100 times to get acceptable
> convergence.
> And in fact, I have another version of this Petsc code that uses
> SNESNGMRES to solve the problem with MySolver providing the residuals as R
> =  N(x) - x.  But I would like a version where I am using just MySolver,
> without any other operations applied to it.  So I am trying to plug
> MySolver into the PETSc system to provide monitoring and other features,
> and for consistency and comparison to these other (more appropriate!) uses
> of PETSc.
> Thanks.
> Kenneth
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Wednesday, May 31, 2023 at 3:48 PM
> *To: *Kenneth C Hall <kenneth.c.hall at duke.edu>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Using SNESSHELL as a wrapper for a CFD
> solver.
> On Wed, May 31, 2023 at 3:21 PM Kenneth C Hall <kenneth.c.hall at duke.edu>
> wrote:
> Hi,
> I am doing a number of problems using PETSc/SLEPc, but I also work on some
> non-PETSc/SLEPc flow solvers.   I would like to use PETSc as a wrapper for
> this non-PETSc flow solver for compatibility,  so I can use the tolerance
> monitoring, options, viewers, and for direct comparison to PETSc methods I
> am using.
> Here is what I am trying to do… I have a CFD solver that iterates with a
> nonlinear iterator of the form x := N(x).  This can be expressed in a
> fortran routine of the form,
> SUBROUTINE MySolver(x)
> or
> SUBROUTINE MySolver(x,y)
> In the first case, x is over written. In the second, y = N(x).  In any
> event, I want to do something like what is shown in the subroutine at the
> bottom of this email.
> The code below “works” in the sense that MySolver is called, but it is
> called exactly **once**. But MyMonitor and MyConverged are **not**
> called. Again, I want to iterate so MySolver should be called many times,
> as should MyMonitor and MyConverged.
> The SNESolve() method is called once per nonlinear solve, just as
> KSPSolve() is called once per linear solve. There may be iteration inside
> the method, but that is handled inside the particular implementation. For
> example, both Newton's method and Nonlinear Conjugate Gradient iterate, but
> the iteration is internal to both, and they both call the monitor and
> convergence test at each internal iterate.
> So, if your nonlinear solver should iterate, it should happen inside the
> SNESSolve call for the SNESSHELL object. Does this make sense? What does
> your solver do?
>   Thanks,
>      Matt
> The SNESView before and after SNESSolve looks like this:
> SNES Object: 1 MPI process
>   type: shell
>   SNES has not been set up so information may be incomplete
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-50, absolute=1e-10, solution=1e+06
>   total number of function evaluations=0
>   norm schedule ALWAYS
>   type: shell
> Any suggestions on how to do what I am trying to accomplish?
> Thanks.
> Kenneth Hall
> *#include <petsc/finclude/petsc.h>*
> *#include "macros.h"*
>    *MODULE* SolveWithSNESShell_module
>       *USE* MyPetscModule
>    *CONTAINS*
>    *SUBROUTINE* MySolver(snes, x, ierr)
>       *USE* MyPetscModule
>       *IMPLICIT* *NONE*
> !.... declared passed variables
>       SNES     :: snes
>       Vec      :: x
>       PetscErrorCode :: ierr
> !.... code to find residual  x := N(x)
> !.... (or alternatively      y := N(x))
>    *END* *SUBROUTINE* MySolver
>    *SUBROUTINE* MyMonitor(snes, its, rnorm, ierr)
>       *USE* MyPetscModule
>       *IMPLICIT* *NONE*
> !.... Declare passed variables
>       SNES           :: snes
>       PetscInt       :: its
>       PetscReal      :: rnorm
> !.... Code to print out convergence history
>    *END* *SUBROUTINE* MyMonitor
>    *SUBROUTINE* MyConverged(snes, it, xnorm, ynorm, znorm, reason, ierr)
>       *USE* MyPetscModule
>       *IMPLICIT* *NONE*
>       SNES     :: snes
>       PetscInt :: it,ctx
>       PetscReal :: xnorm, ynorm, znorm
>       KSPConvergedReason :: reason
> !      ... add convergence test here ...
> !      set reason to a positive value if convergence has been achieved
>    *END* *SUBROUTINE* MyConverged
>    *END* *MODULE* SolveWithSNESShell_module
>    *SUBROUTINE* SolveWithSNESShell
>       *USE* SolveWithSNESShell_module
>       *IMPLICIT* *NONE*
>       *INTEGER*            :: level_tmp
> !.... Declare local variables
>       *INTEGER*            :: iz
>       *INTEGER*            :: imax
>       *INTEGER*            :: jmax
>       *INTEGER*            :: kmax
>       SNES               :: snes
>       KSP                :: ksp
>       Vec                :: x
>       Vec                :: y
>       PetscViewer        :: viewer
>       PetscReal          :: rtol   = 1.0D-10   !! relative tolerance
>       PetscReal          :: atol   = 1.0D-50   !! absolute tolerance
>       PetscReal          :: dtol   = 1.0D+06   !! divergence tolerance
>       PetscInt           :: maxits = 50
>       PetscInt           :: maxf   = 10000
>       *character*(*len*=1000):: args
> !.... count the number of degrees of freedom.
>       level = level_tmp
>       n = 0
>       *DO* iz = 1, hb(level)%nzone
>          imax = hb(level)%zone(iz)%imax - 1
>          jmax = hb(level)%zone(iz)%jmax - 1
>          kmax = hb(level)%zone(iz)%kmax - 1
>          n = n + imax * jmax * kmax
>       *END* *DO*
>       n = n * neqn
> !.... Initialize PETSc
>       PetscCall(PetscInitialize(PETSC_NULL_CHARACTER, ierr))
> !.... Log
>       PetscCall(PetscLogDefaultBegin(ierr))
> !.... Hard-wired options.
> !     PetscCall(PetscOptionsInsertString(PETSC_NULL_OPTIONS, "command line
> style option here" , ierr))
> !.... Command line options.
>       *call* *GET_COMMAND*(args)
>       PetscCall(PetscOptionsInsertString(PETSC_NULL_OPTIONS, args, ierr))
> !.... view command line table
>       PetscCall(PetscViewerASCIIOpen(PETSC_COMM_SELF,
> PETSC_VIEWER_STDOUT_SELF, viewer, ierr))
>       PetscCall(PetscOptionsView(PETSC_NULL_OPTIONS, viewer, ierr))
>       PetscCall(PetscViewerDestroy(viewer, ierr))
> !.... Create PETSc vectors
>       PetscCall(VecCreateSeq(PETSC_COMM_SELF, n, x, ierr))
>       PetscCall(VecCreateSeq(PETSC_COMM_SELF, n, y, ierr))
>       PetscCall(VecSet(x, 0.0d0, ierr))
>       PetscCall(VecSet(y, 0.0d0, ierr))
> !.... SNES context
>       PetscCall(SNESCreate(PETSC_COMM_SELF, snes, ierr))
>       PetscCall(SNESSetType(snes, SNESSHELL, ierr))
>       PetscCall(SNESShellSetSolve(snes, MySolver, ierr))
> !!!!  PetscCall(SNESSetFunction(snes, x, MySolver, PETSC_NULL_INTEGER,
> ierr))
> !!!!  this line causes a segmentation error if uncommented.
>       PetscCall(SNESSetConvergenceTest(snes, MyConverged, 0,
> PETSC_NULL_FUNCTION, ierr))
> !.... Set SNES options
>       PetscCall(SNESSetFromOptions(snes, ierr))
> !.... Set tolerances
>       PetscCall(SNESSetTolerances(snes, rtol, atol, dtol, maxits, maxf,
> ierr))
> !.... SNES montior
>       PetscCall(SNESMonitorSet(snes, MyMonitor, PETSC_NULL_INTEGER,
> PETSC_NULL_FUNCTION,ierr))
> !.... Set the initial solution
>       *CALL* HBToVecX(x)
> !.... View snes context
>       PetscCall(SNESView(snes, viewer, ierr))
> !.... Solve SNES problem
>       PetscCall(SNESSolve(snes, PETSC_NULL_VEC, x, ierr))
> !.... dump the logs
> !     call PetscLogDump(ierr)  ! Why does this cause error
> !.... Destroy PETSc objects
>       PetscCall(SNESDestroy(snes, ierr))
>       PetscCall(VecDestroy(x, ierr))
>       PetscCall(VecDestroy(y, ierr))
> !.... Finish
>       PetscCall(PetscFinalize(ierr))
>    *END* *SUBROUTINE* SolveWithSNESShell
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http:/www.cse.buffalo.edu/*knepley/__;fg!!OToaGQ!sE2W1qI_dqcEHL1dOCnJ3Rdv9TATFVDBiBqx_tlQsOnjvGF7StDjsmVcm9Qkfe4XcTFOBtVjtFl5om07Rdjw$>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230531/8b6434ea/attachment-0001.html>
