[petsc-users] Multiple points constraint in parallel
YuSh Lo ysjosh.lo at gmail.com
Wed May 31 12:53:45 CDT 2023
Hi Matthew,
Matthew Knepley <knepley at gmail.com> 於 2023年5月31日 週三 上午5:08寫道:
> On Wed, May 31, 2023 at 1:25 AM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>> Hi,
>> I have some multiple points constraint input as follows,
>> A_1 a_4
>> B_2 b_5
>> C_3 c_6
>> each columns are stored in different IS.
> So one IS lists the capital letter and one lists the lowercase?
       Yes.
>> After dmplex distribute, they will be renumbered and distribution to
>> certain processors.
> Plex does normally renumber and send ISes, so you are doing this yourself?
     No, Plex does the distribution.
>> I have two questions:
>> (1) I need both complete ISs are all the processors. Can I just do
>> ISALLGather()?
> I think so. I cannot tell what you want to do.
>> (2) Although renumbered, will the original order remain(ABC and abc)?
>> If the number is the node number, after distribution and I do an
>> ISALLGather()
>> will I have the following on each processor?
>> A_3 a_1
>> B_4 b_2
>> C_6 c_5
>> (I randomly renumber them)
>> This is what I can come up with now. Is there any better way to do it?
> Can you tell me what you want to use this for? Maybe there is an easier
> way. For example,
> if we want to impose a constraint on a mesh point, usually I mark that
> point with a DMLabel.
> These are propagated during distribution so you do not have to think about
> it.
    So I have to impose constraint between two nodes. The upper case node
is controlled by the lower case node, and there can be many pairs of
constraint. When looping over elements if one node is controlled by the
other then the corresponding entry has to be added to a different location
e.x. [an index][A_3] to [an index][a_1]. I know how to use DMLabel, but I
have used it on one node at a time only. I used DMLabel to mark those nodes
with BCs. Now I must know the info of two nodes at the same time. The
operations only have to done in assembling and calculating the element
stiffness matrix of the elements that contain the upper case node, but I
must know the info of the corresponding lower case node so I know where to
assemble the entry.
Josh
>   Thanks,
>      Matt
>> Thanks,
>> Josh
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230531/5f2bdb3d/attachment.html>
