[petsc-users] [petsc-maint] Error during compile
Joauma Marichal joauma.marichal at uclouvain.be
Wed May 31 05:34:09 CDT 2023
Hello,
Thanks a lot, it worked. However my code does not compile anymore (I haven’t changed anything since yesterday and it worked then). I get the following error:
 -L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current -lpetsc -lHYPRE -lflapack -lfblas -lc++ -lmpifort -lmpi -lpmpi -lgfortran -lemutls_w -lquadmath -lc++
ld: warning: directory not found for option '-L/opt/homebrew/Cellar/mpich/4.1/lib'
ld: warning: directory not found for option '-L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc/aarch64-apple-darwin22/12'
ld: warning: directory not found for option '-L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current/gcc'
ld: warning: directory not found for option '-L/opt/homebrew/Cellar/gcc/12.2.0/lib/gcc/current'
ld: library not found for -lgfortran
clang: error: linker command failed with exit code 1 (use -v to see invocation)
I attach the complete log file.
Thanks a lot for your help.
Best regards,
Joauma
De : Matthew Knepley <knepley at gmail.com>
Date : mercredi, 31 mai 2023 à 12:03
À : Joauma Marichal <joauma.marichal at uclouvain.be>
Cc : PETSc <petsc-maint at mcs.anl.gov>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-maint] Error during compile
On Wed, May 31, 2023 at 5:25 AM Joauma Marichal <joauma.marichal at uclouvain.be<mailto:joauma.marichal at uclouvain.be>> wrote:
Hello,
I am writing to you as I am trying to compile petsc on my mac.
I used:
$ export PATH=/opt/homebrew/bin:/opt/homebrew/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/TeX/texbin:/usr/local/munki
$ ./configure --download-fblaslapack --download-hypre --prefix=../marha/lib_petsc
This is a bug in make 4.4.1. Either upgrade to the latest PETSc release or
  make OMAKE_PRINTDIR=make all
     Matt
Which has worked previously but today, I get:
**************************ERROR*************************************
  Error during compile, check arch-darwin-c-debug/lib/petsc/conf/make.log
  Send it and arch-darwin-c-debug/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>
I attach the files.
Best regards,
Joauma
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230531/ee6e1d2f/attachment-0001.html>
Desc: log_make
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230531/ee6e1d2f/attachment-0001.obj>
