[petsc-users] Multiple points constraint in parallel
YuSh Lo ysjosh.lo at gmail.com
Wed May 31 00:24:55 CDT 2023
I have some multiple points constraint input as follows,
A_1 a_4
B_2 b_5
C_3 c_6
each columns are stored in different IS.
After dmplex distribute, they will be renumbered and distribution to
certain processors.
I have two questions:
(1) I need both complete ISs are all the processors. Can I just do
ISALLGather()?
(2) Although renumbered, will the original order remain(ABC and abc)?
If the number is the node number, after distribution and I do an
ISALLGather()
will I have the following on each processor?
A_3 a_1
B_4 b_2
C_6 c_5
(I randomly renumber them)
This is what I can come up with now. Is there any better way to do it?
Josh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230531/ef960c13/attachment.html>
