[petsc-users] Get global offset in global vector for the points not owned by this processor.
Mon May 29 19:40:05 CDT 2023
On Mon, May 29, 2023 at 5:47 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
> Hi,
> How to get the offset in global vector for the points not owned by this
> processor?
> I have a parallel DMPlex and a section assigned to it.
> GetSectionGetOffset with a global section returns -1 for the points not
The easiest way to get it is to use DMGetLocalToGlobalMapping() to map the
local offset. This is
constructed from the global section, because it stores the global offset as
-(offset+1).
     Matt
> Thanks,
> Josh
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230529/1acba051/attachment.html>
