[petsc-users] Build Error
Barry Smith bsmith at petsc.dev
Fri May 26 09:39:57 CDT 2023
  PETSc configure is suppose to handle this cleanly. Please send configure.log to petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>  as we need more context to understand why it is not working.
  PETSc configure looks for libgtoolize (which is what brew names it) and uses it for  libtoolize
  You can use --with-libtoolize-exec=pathtolibtoolize  (or --with-libtoolize=pathtolibtoolize for older versions of PETSc) to select the executable PETSc uses
> On May 25, 2023, at 1:35 PM, SENECA, MICHAEL via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi all,
> I have been attempting to install cardinal on my new MacBook M2 Pro chip but I have run into some errors when attempting to build petsc, the script attempts to access
> /usr/bin/libtoolize
> which does not exist on my MacBook. I have libtoolize installed via homebrew and have made a link from the homebrew installation to
> usr/local/bin/libtoolize
> But the script does not look in the local directory. From what I have gathered online, the /usr/bin/ should not be edited as it is managed by macOS and its system software which can lead to system instability. Do any of you know of a way around to get the petsc script to just look for libtoolize from my path and not /usr/bin/libtoolize?
> Best regards,
> Michael Seneca
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230526/4b8be74c/attachment-0001.html>
