[petsc-users] MPI_Iprobe Error with MUMPS Solver on Multi-Nodes
Zongze Yang yangzongze at gmail.com
Tue May 23 07:23:05 CDT 2023
On Tue, 23 May 2023 at 20:09, Yann Jobic <yann.jobic at univ-amu.fr> wrote:
> If i may, you can use the command line option "-mat_mumps_icntl_4 2"
> MUMPS then gives infomations about the factorization step, such as the
> estimated needed memory.
> Thank you for your suggestion!
Best wishes,
Zongze
Best regards,
> Yann
> Le 5/23/2023 à 11:59 AM, Matthew Knepley a écrit :
> > On Mon, May 22, 2023 at 10:42 PM Zongze Yang <yangzongze at gmail.com
> > <mailto:yangzongze at gmail.com>> wrote:
> >     On Tue, 23 May 2023 at 05:31, Stefano Zampini
> >     <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>>
> wrote:
> >         If I may add to the discussion, it may be that you are going OOM
> >         since you are trying to factorize a 3 million dofs problem, this
> >         problem goes undetected and then fails at a later stage
> >     Thank you for your comment. I ran the problem with 90 processes
> >     distributed across three nodes, each equipped with 500G of memory.
> >     If this amount of memory is sufficient for solving the matrix with
> >     approximately 3 million degrees of freedom?
> > It really depends on the fill. Suppose that you get 1% fill, then
> >    (3e6)^2 * 0.01 * 8 = 1e12 B
> > and you have 1.5e12 B, so I could easily see running out of memory.
> >    Thanks,
> >       Matt
> >     Thanks!
> >     Zongze
> >         Il giorno lun 22 mag 2023 alle ore 20:03 Zongze Yang
> >         <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> ha scritto:
> >             Thanks!
> >             Zongze
> >             Matthew Knepley <knepley at gmail.com
> >             <mailto:knepley at gmail.com>>于2023年5月23日 周二00:09写道:
> >                 On Mon, May 22, 2023 at 11:07 AM Zongze Yang
> wrote:
> >                     Hi,
> >                     I hope this letter finds you well. I am writing to
> >                     seek guidance regarding an error I encountered while
> >                     solving a matrix using MUMPS on multiple nodes:
> >                 Iprobe is buggy on several MPI implementations. PETSc
> >                 has an option for shutting it off for this reason.
> >                 I do not know how to shut it off inside MUMPS however. I
> >                 would mail their mailing list to see.
> >                    Thanks,
> >                       Matt
> >                     ```bash
> >                     Abort(1681039) on node 60 (rank 60 in comm 240):
> >                     Fatal error in PMPI_Iprobe: Other MPI error, error
> >                     stack:
> >                     PMPI_Iprobe(124)..............:
> >                     MPI_Iprobe(src=MPI_ANY_SOURCE, tag=MPI_ANY_TAG,
> >                     comm=0xc4000026, flag=0x7ffc130f9c4c,
> >                     status=0x7ffc130f9e80) failed
> >                     MPID_Iprobe(240)..............:
> >                     MPIDI_iprobe_safe(108)........:
> >                     MPIDI_iprobe_unsafe(35).......:
> >                     MPIDI_OFI_do_iprobe(69).......:
> >                     MPIDI_OFI_handle_cq_error(949): OFI poll failed
>  (ofi_events.c:951:MPIDI_OFI_handle_cq_error:Input/output error)
> >                     Assertion failed in file
> >                     src/mpid/ch4/netmod/ofi/ofi_events.c at line 125: 0
> >                     The matrix in question has a degree of freedom (dof)
> >                     of 3.86e+06. Interestingly, when solving
> >                     smaller-scale problems, everything functions
> >                     perfectly without any issues. However, when
> >                     attempting to solve the larger matrix on multiple
> >                     nodes, I encounter the aforementioned error.
> >                     The complete error message I received is as follows:
> >                     ```bash
> >                     stack:
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(MPL_backtrace_show+0x26)
> [0x7f6076063f2c]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x41dc24)
> [0x7f6075fc5c24]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x49cc51)
> [0x7f6076044c51]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x49f799)
> [0x7f6076047799]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x451e18)
> [0x7f6075ff9e18]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x452272)
> [0x7f6075ffa272]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x2ce836)
> [0x7f6075e76836]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x2ce90d)
> [0x7f6075e7690d]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x48137b)
> [0x7f607602937b]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x44d471)
> [0x7f6075ff5471]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(+0x407acd)
> [0x7f6075fafacd]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(MPIR_Err_return_comm+0x10a)
> [0x7f6075fafbea]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpi.so.12(MPI_Iprobe+0x312)
> [0x7f6075ddd542]
>  /nfs/opt/cascadelake/linux-centos7-cascadelake/gcc-9.4.0/mpich-3.4.2-qgtz76gekvjzuacy7wq5a26rqlewoxfc/lib/libmpifort.so.12(pmpi_iprobe+0x2f)
> [0x7f606e08f19f]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(__zmumps_load_MOD_zmumps_load_recv_msgs+0x142)
> [0x7f60737b194d]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_try_recvtreat_+0x34)
> [0x7f60738ab735]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(__zmumps_fac_par_m_MOD_zmumps_fac_par+0x991)
> [0x7f607378bcc8]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_fac_par_i_+0x240)
> [0x7f6073881d36]
> >                     Abort(805938831) on node 51 (rank 51 in comm 240):
> >                     stack:
> >                     comm=0xc4000017, flag=0x7ffe20e1402c,
> >                     status=0x7ffe20e14260) failed
> >                     MPID_Iprobe(244)..............:
> >                     progress_test(100)............:
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_fac_b_+0x1463)
> [0x7f60738831a1]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_fac_driver_+0x6969)
> [0x7f60738446c9]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_+0x2d83)
> [0x7f60738bf9cf]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_f77_+0x178c)
> [0x7f60738c33bc]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/mumps-5.5.1-gb7wlwxwbalf5rw5vkp6gtkhfkdqpntz/lib/libzmumps.so(zmumps_c+0x8f8)
> [0x7f60738baacb]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(+0x894560)
> [0x7f6077297560]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(MatLUFactorNumeric+0x32e)
> [0x7f60773bb1e6]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(+0xf51665)
> [0x7f6077954665]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(PCSetUp+0x64b)
> [0x7f60779c77e0]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(KSPSetUp+0xfb6)
> [0x7f6077ac2d53]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(+0x10c1c28)
> [0x7f6077ac4c28]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(KSPSolve+0x13)
> [0x7f6077ac8070]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(+0x11249df)
> [0x7f6077b279df]
>  /nfs/home/zzyang/opt/software/linux-centos7-cascadelake/gcc-9.4.0/petsc-develop-5wrc3y6lyelr3iyrlm3sr2jlh2wxif3k/lib/libpetsc.so.3.019(SNESSolve+0x10df)
> [0x7f6077b676c6]
> >                     Abort(1) on node 60: Internal error
> >                     Abort(1007265423) on node 65 (rank 65 in comm 240):
> >                     stack:
> >                     comm=0xc4000017, flag=0x7fff4d82827c,
> >                     status=0x7fff4d8284b0) failed
> >                     Abort(941205135) on node 32 (rank 32 in comm 240):
> >                     stack:
> >                     comm=0xc4000017, flag=0x7fff715ba3fc,
> >                     status=0x7fff715ba630) failed
> >                     Abort(470941839) on node 75 (rank 75 in comm 0):
> >                     Fatal error in PMPI_Test: Other MPI error, error
> stack:
> >                     PMPI_Test(188)................:
> >                     MPI_Test(request=0x7efe31e03014,
> >                     flag=0x7ffea65d673c, status=0x7ffea65d6760) failed
> >                     MPIR_Test(73).................:
> >                     MPIR_Test_state(33)...........:
> >                     Abort(805946511) on node 31 (rank 31 in comm 256):
> >                     Fatal error in PMPI_Probe: Other MPI error, error
> stack:
> >                     PMPI_Probe(118)...............:
> >                     MPI_Probe(src=MPI_ANY_SOURCE, tag=7,
> >                     comm=0xc4000015, status=0x7fff9538b7a0) failed
> >                     MPID_Probe(159)...............:
> >                     Abort(1179791) on node 73 (rank 73 in comm 0): Fatal
> >                     error in PMPI_Test: Other MPI error, error stack:
> >                     MPI_Test(request=0x5b638d4, flag=0x7ffd755119cc,
> >                     status=0x7ffd755121b0) failed
> >                     Thank you very much for your time and consideration.
> >                     Best wishes,
> >                     Zongze
> >                 What most experimenters take for granted before they
> >                 begin their experiments is infinitely more interesting
> >                 than any results to which their experiments lead.
> >                 -- Norbert Wiener
> >                 https://www.cse.buffalo.edu/~knepley/
> >                 <http://www.cse.buffalo.edu/~knepley/>
> >             Best wishes,
> >             Zongze
> >         Stefano
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230523/75f17364/attachment-0001.html>
