[petsc-users] Understanding index sets for PCGASM
Leonardo Mutti leonardo.mutti01 at universitadipavia.it
Thu May 18 20:20:01 CDT 2023
Many thanks for the hint. As for your last two sentences, I am in a similar
situation. So, let me mention some last thoughts, in case they help locate
the issue. If not, I will embark on the debugging adventure with Windows
debuggers.
Consider again the 4x4 matrix (represented by the IS [0,1,2,3], with rows
0,1 on rank 0 and 2,3 on rank 1). If I create the non-inflated IS [0,1,2],
[3],  with inflated IS [0,1,2], [1,2,3], no problems arise.
Here is a comparison with the non-working case:
   - works:            non-inflated IS: [0,1,2], [3], inflated IS: [0,1,2],
   [1,2,3]
   - doesn't work: non-inflated IS: [0,1], [2,3], inflated IS: [0,1],
   [1,2,3]
One difference is that in the working case, the non-inflating subdomain
[0,1,2], is not on a single process.
Moreover, is it possible that the issue has something to do with
PetscObjectReference  as seen in /src/ksp/pc/impls/gasm/gasm.c line 1732,
PCGASMCreateSubdomains2D?
Thanks again
Il giorno gio 18 mag 2023 alle ore 04:26 Barry Smith <bsmith at petsc.dev> ha
scritto:
>   Yikes. Such huge numbers usually come from integer overflow or memory
> corruption.
> The code to decide on the memory that needs allocating is straightforward
> PetscErrorCode MatCreateSubMatrices_MPIAIJ(Mat C, PetscInt ismax, const IS
> isrow[], const IS iscol[], MatReuse scall, Mat *submat[])
>   PetscInt     nmax, nstages = 0, i, pos, max_no, nrow, ncol, in[2],
> out[2];
>   PetscBool    rowflag, colflag, wantallmatrix = PETSC_FALSE;
>   Mat_SeqAIJ  *subc;
>   Mat_SubSppt *smat;
>   PetscFunctionBegin;
>   /* Check for special case: each processor has a single IS */
>   if (C->submat_singleis) { /* flag is set in PCSetUp_ASM() to skip
> MPI_Allreduce() */
>     PetscCall(MatCreateSubMatrices_MPIAIJ_SingleIS(C, ismax, isrow, iscol,
> scall, submat));
>     C->submat_singleis = PETSC_FALSE; /* resume its default value in case
> C will be used for non-single IS */
>     PetscFunctionReturn(PETSC_SUCCESS);
>   /* Collect global wantallmatrix and nstages */
>   if (!C->cmap->N) nmax = 20 * 1000000 / sizeof(PetscInt);
>   else nmax = 20 * 1000000 / (C->cmap->N * sizeof(PetscInt));
>   if (!nmax) nmax = 1;
>   if (scall == MAT_INITIAL_MATRIX) {
>     if (ismax == 1 && C->rmap->N == C->cmap->N) {
>       PetscCall(ISIdentity(*isrow, &rowflag));
>       PetscCall(ISIdentity(*iscol, &colflag));
>       PetscCall(ISGetLocalSize(*isrow, &nrow));
>       PetscCall(ISGetLocalSize(*iscol, &ncol));
>       if (rowflag && colflag && nrow == C->rmap->N && ncol == C->cmap->N) {
>         wantallmatrix = PETSC_TRUE;
>         PetscCall(PetscOptionsGetBool(((PetscObject)C)->options,
> ((PetscObject)C)->prefix, "-use_fast_submatrix", &wantallmatrix, NULL));
>     /* Determine the number of stages through which submatrices are done
>        Each stage will extract nmax submatrices.
>        nmax is determined by the matrix column dimension.
>        If the original matrix has 20M columns, only one submatrix per
> stage is allowed, etc.
>     nstages = ismax / nmax + ((ismax % nmax) ? 1 : 0); /* local nstages */
>     in[0] = -1 * (PetscInt)wantallmatrix;
>     in[1] = nstages;
>     PetscCall(MPIU_Allreduce(in, out, 2, MPIU_INT, MPI_MAX,
> PetscObjectComm((PetscObject)C)));
>     wantallmatrix = (PetscBool)(-out[0]);
>     nstages       = out[1]; /* Make sure every processor loops through the
> global nstages */
>   } else { /* MAT_REUSE_MATRIX */
>     if (ismax) {
>       subc = (Mat_SeqAIJ *)(*submat)[0]->data;
>       smat = subc->submatis1;
>     } else { /* (*submat)[0] is a dummy matrix */
>       smat = (Mat_SubSppt *)(*submat)[0]->data;
>     if (!smat) {
>       /* smat is not generated by
> MatCreateSubMatrix_MPIAIJ_All(...,MAT_INITIAL_MATRIX,...) */
>     } else if (smat->singleis) {
> iscol, scall, submat));
>     } else {
>       nstages = smat->nstages;
>   if (wantallmatrix) {
>     PetscCall(MatCreateSubMatrix_MPIAIJ_All(C, MAT_GET_VALUES, scall,
> submat));
>   /* Allocate memory to hold all the submatrices and dummy submatrices */
>   if (scall == MAT_INITIAL_MATRIX) PetscCall(PetscCalloc1(ismax + nstages,
> submat));
>   for (i = 0, pos = 0; i < nstages; i++) {
>     if (pos + nmax <= ismax) max_no = nmax;
>     else if (pos >= ismax) max_no = 0;
>     else max_no = ismax - pos;
>     PetscCall(MatCreateSubMatrices_MPIAIJ_Local(C, max_no, isrow + pos,
> iscol + pos, scall, *submat + pos));
>     if (!max_no) {
>       if (scall == MAT_INITIAL_MATRIX) { /* submat[pos] is a dummy matrix
>         smat          = (Mat_SubSppt *)(*submat)[pos]->data;
>         smat->nstages = nstages;
>       pos++; /* advance to next dummy matrix if any */
>     } else pos += max_no;
>   if (ismax && scall == MAT_INITIAL_MATRIX) {
>     /* save nstages for reuse */
> The easiest way to debug would be to put a breakpoint in
> MatCreateSubMatrices_MPIAIJ on MPI rank zero and next through the
> subroutine to see where the crazy number appears that gets passed down in
> the line if (scall == MAT_INITIAL_MATRIX) PetscCall(PetscCalloc1(ismax +
> nstages, submat)); where either ismax or nstages has a crazy value.
> If you are using the GNU compilers you can use the command line options
> -start_in_debugger noxterm -debugger_ranks 0 to start the Gnu debugger. If
> you are using the Microsoft Windows compilers you will need to use their
> debugger, I don't know how to do that (and shudder at the thought :-).
> On May 17, 2023, at 7:51 PM, Leonardo Mutti <
> leonardo.mutti01 at universitadipavia.it> wrote:
> Thanks for the reply. Even without Valgrind (which I can't use since I'm
> on Windows), by further simplifying the example, I was able to have PETSc
> display a more informative message.
> What I am doing wrong and what should be done differently, this is still
> unclear to me.
> The simplified code runs on 2 processors, I built a 4x4 matrix.
> The subdomains are now given by [0,1] and [2,3], with [2,3] inflating to
> [0,1,2,3].
> Thank you again.
> Error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Out of memory. This could be due to allocating
> [0]PETSC ERROR: too large an object or bleeding by not properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated 0 Memory used by process 0
> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_view for info.
> [0]PETSC ERROR: Memory requested 9437902811936987136
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-pc_gasm_view_subdomains value: 1
> source: code
> [0]PETSC ERROR:   Option left: name:-sub_ksp_type value: gmres source: code
> [0]PETSC ERROR:   Option left: name:-sub_pc_type value: none source: code
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.19.1-234-g43977f8d16
>  GIT Date: 2023-05-08 14:50:03 +0000
> [0]PETSC ERROR: #1 PetscMallocAlign() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\sys\memory\mal.c:66
> [0]PETSC ERROR: #2 PetscMallocA() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\sys\memory\mal.c:411
> [0]PETSC ERROR: #3 MatCreateSubMatrices_MPIAIJ() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\mat\impls\aij\mpi\mpiov.c:2025
> [0]PETSC ERROR: #4 MatCreateSubMatricesMPI_MPIXAIJ() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\mat\impls\aij\mpi\mpiov.c:3136
> [0]PETSC ERROR: #5 MatCreateSubMatricesMPI_MPIAIJ() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\mat\impls\aij\mpi\mpiov.c:3208
> [0]PETSC ERROR: #6 MatCreateSubMatricesMPI() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\mat\INTERF~1\matrix.c:7071
> [0]PETSC ERROR: #7 PCSetUp_GASM() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\ksp\pc\impls\gasm\gasm.c:556
> [0]PETSC ERROR: #8 PCSetUp() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\ksp\pc\INTERF~1\precon.c:994
> [0]PETSC ERROR: #9 KSPSetUp() at
> ...\Sources\Git\Test-FV\PETSC-~1\src\ksp\ksp\INTERF~1\itfunc.c:406
> Code, the important bit is after ! GASM, SETTING SUBDOMAINS:
>       Mat   :: A
>       Vec   :: b
>       PetscInt :: M,N_blocks,block_size,NSub,I
>       PetscErrorCode :: ierr
>       PetscScalar :: v
>       KSP            :: ksp
>       PC             :: pc
>       IS :: subdomains_IS(2), inflated_IS(2)
>       PetscInt            :: NMPI,MYRANK,IERMPI
>       INTEGER  :: start
>       call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
>       call PetscLogDefaultBegin(ierr)
>       call MPI_COMM_SIZE(MPI_COMM_WORLD, NMPI, IERMPI)
>       CALL MPI_COMM_RANK(MPI_COMM_WORLD, MYRANK,IERMPI)
>       N_blocks = 2
>       block_size = 2
>       M = N_blocks * block_size
>       ! INTRO: create matrix and right hand side, create IS
>       call MatCreateAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>      & M, M, PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,
>      & PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,A, ierr)
>       call VecCreate(PETSC_COMM_WORLD,b,ierr)
>       call VecSetSizes(b, PETSC_DECIDE, M,ierr)
>       call VecSetFromOptions(b,ierr)
>       DO I=(MYRANK*(M/NMPI)),((MYRANK+1)*(M/NMPI)-1)
>          ! Set matrix
>          v=1
>          call MatSetValue(A, I, I, v, INSERT_VALUES, ierr)
>          IF (I-block_size .GE. 0) THEN
>             v=-1
>             call MatSetValue(A, I, I-block_size, v, INSERT_VALUES, ierr)
>          ENDIF
>          ! Set rhs
>          v = I
>          call VecSetValue(b,I,v, INSERT_VALUES,ierr)
>       END DO
>       call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>       call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>       call VecAssemblyBegin(b,ierr)
>       call VecAssemblyEnd(b,ierr)
>       ! FIRST KSP/PC SETUP
>       call KSPCreate(PETSC_COMM_WORLD, ksp, ierr)
>       call KSPSetOperators(ksp, A, A, ierr)
>       call KSPSetType(ksp, 'preonly', ierr)
>       call KSPGetPC(ksp, pc, ierr)
>       call PCSetType(pc, PCGASM, ierr)
>       if (myrank == 0) then
>          call ISCreateStride(PETSC_COMM_SELF, 2, 0, 1, subdomains_IS(1),
> ierr)
>          call ISCreateStride(PETSC_COMM_WORLD, 0, 0, 1, subdomains_IS(2),
> ierr)
>          call ISCreateStride(PETSC_COMM_SELF, 2, 0, 1, inflated_IS(1),
> ierr)
>          call ISCreateStride(PETSC_COMM_WORLD, 2, 0, 1, inflated_IS(2),
> ierr)
>          start = 1
>          NSub = 2
>       else
>          call ISCreateStride(PETSC_COMM_WORLD, 2, 2, 1, subdomains_IS(2),
> ierr)
>          call ISCreateStride(PETSC_COMM_WORLD, 2, 2, 1, inflated_IS(2),
> ierr)
>          start = 2
>          NSub = 1
>       endif
>       call
> PCGASMSetSubdomains(pc,NSub,subdomains_IS(start:2),inflated_IS(start:2),ierr)
>       call
> PCGASMDestroySubdomains(NSub,subdomains_IS(start:2),inflated_IS(start:2),ierr)
>       ! GASM: SET SUBSOLVERS
>       call PetscOptionsSetValue(PETSC_NULL_OPTIONS,"-sub_ksp_type",
> "gmres", ierr)
>       call PetscOptionsSetValue(PETSC_NULL_OPTIONS,"-sub_pc_type", "none",
> ierr)
>       call
> PetscOptionsSetValue(PETSC_NULL_OPTIONS,"-pc_gasm_view_subdomains", "1",
> ierr)
>       call KSPSetUp(ksp, ierr)
>       call PCSetUp(pc, ierr)
>       call KSPSetFromOptions(ksp, ierr)
>       call PCSetFromOptions(pc, ierr)
>       call KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD, ierr)
>       call MatDestroy(A, ierr)
>       call PetscFinalize(ierr)
> Il giorno mer 17 mag 2023 alle ore 21:55 Barry Smith <bsmith at petsc.dev>
> ha scritto:
>> On May 17, 2023, at 11:10 AM, Leonardo Mutti <
>> Dear developers, let me kindly ask for your help again.
>> In the following snippet, a bi-diagonal matrix A is set up. It measures
>> 8x8 blocks, each block is 2x2 elements. I would like to create the
>> correct IS objects for PCGASM.
>> The non-overlapping IS should be: [*0,1*], [*2,3*],[*4,5*], ..., [*14,15*
>> ]. The overlapping IS should be: [*0,1*], [0,1,*2,3*], [2,3,*4,5*], ...,
>> [12,13,*14,15*]
>> I am running the code with 4 processors. For some reason, after calling PCGASMDestroySubdomains
>> the code crashes with severe (157): Program Exception - access violation.
>> A visual inspection of the indices using ISView looks good.
>>   Likely memory corruption or use of an object or an array that was
>> already freed. Best to use Valgrind to find the exact location of the mess.
>> Thanks again,
>> Leonardo
>>       Mat   :: A
>>       Vec   :: b
>>       PetscInt ::
>> M,N_blocks,block_size,I,J,NSub,converged_reason,srank,erank,color,subcomm
>>       PetscMPIInt :: size
>>       PetscScalar :: v
>>       KSP            :: ksp
>>       PC             :: pc
>>       IS,ALLOCATABLE :: subdomains_IS(:), inflated_IS(:)
>>       INTEGER  :: IS_counter, is_start, is_end
>>       N_blocks = 8
>>       block_size = 2
>>       ALLOCATE(subdomains_IS(N_blocks))
>>       ALLOCATE(inflated_IS(N_blocks))
>>       ! ASSUMPTION: no block spans more than one rank (the inflated
>> blocks can)
>>       ! How many inflated blocks span more than one rank? NMPI-1 !
>>          ! Set matrix
>>          v=1
>>             v=-1
>>          ENDIF
>>          ! Set rhs
>>          v = I
>>       END DO
>>       !! GASM, SETTING SUBDOMAINS
>>       DO IS_COUNTER=1,N_blocks
>>          srank = MAX(((IS_COUNTER-2)*block_size)/(M/NMPI),0) ! start
>> rank reached by inflated block
>>          erank = MIN(((IS_COUNTER-1)*block_size)/(M/NMPI),NMPI-1) ! end
>> rank reached by inflated block. Coincides with rank containing non-inflated
>> block
>>    ! Create subcomms
>>    color = MPI_UNDEFINED
>>    IF (myrank == srank .or. myrank == erank) THEN
>>       color = 1
>>    ENDIF
>>    call MPI_Comm_split(MPI_COMM_WORLD,color,MYRANK,subcomm,ierr)
>>          ! Create IS
>>          IF (srank .EQ. erank) THEN   ! Block and overlap are on the
>> same rank
>>             IF (MYRANK .EQ. srank) THEN
>>                call
>> ISCreateStride(PETSC_COMM_SELF,block_size,(IS_COUNTER-1)*block_size,1,subdomains_IS(IS_COUNTER),ierr)
>>                IF (IS_COUNTER .EQ. 1) THEN  ! the first block is not
>> inflated
>>                    call
>> ISCreateStride(PETSC_COMM_SELF,block_size,(IS_COUNTER-1)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>>                ELSE
>>                   call
>> ISCreateStride(PETSC_COMM_SELF,2*block_size,(IS_COUNTER-2)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>>                ENDIF
>>             ENDIF
>>          else ! Block and overlap not on the same rank
>>             if (myrank == erank) then  ! the block
>>                call  ISCreateStride
>> (subcomm,block_size,(IS_COUNTER-1)*block_size,1,subdomains_IS(IS_COUNTER),ierr)
>>                call  ISCreateStride
>> (subcomm,block_size,(IS_COUNTER-1)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>>             endif
>>             if (myrank == srank) then  ! the overlap
>>                call  ISCreateStride
>> (subcomm,block_size,(IS_COUNTER-2)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>>                call  ISCreateStride
>> (subcomm,0,(IS_COUNTER-1)*block_size,1,subdomains_IS(IS_COUNTER),ierr)
>>             endif
>>          endif
>>          call MPI_Comm_free(subcomm, ierr)
>>       END DO
>>       ! Set the domains/subdomains
>>       NSub = N_blocks/NMPI
>>       is_start = 1 + myrank * NSub
>>       is_end = min(is_start + NSub, N_blocks)
>>       if (myrank + 1 < NMPI) then
>>          NSub = NSub + 1
>>       endif
>>       call
>> PCGASMSetSubdomains(pc,NSub,subdomains_IS(is_start:is_end),inflated_IS(is_start:is_end),ierr)
>>       call
>> PCGASMDestroySubdomains(NSub,subdomains_IS(is_start:is_end),inflated_IS(is_start:is_end),ierr)
>> "gmres", ierr)
>> "none", ierr)
>>       call
>> ierr)
>> Il giorno mer 10 mag 2023 alle ore 03:02 Barry Smith <bsmith at petsc.dev>
>> ha scritto:
>>> On May 9, 2023, at 4:58 PM, LEONARDO MUTTI <
>>> In my notation diag(1,1) means a diagonal 2x2 matrix with 1,1 on the
>>> diagonal, submatrix in the 8x8 diagonal matrix diag(1,1,2,2,...,2).
>>> Am I then correct that the IS representing diag(1,1) is 0,1, and that
>>> diag(2,2,...,2) is represented by 2,3,4,5,6,7?
>>> I believe so
>>> Thanks,
>>> Leonardo
>>> Il mar 9 mag 2023, 20:45 Barry Smith <bsmith at petsc.dev> ha scritto:
>>>>   It is simplier than you are making it out to be. Each IS[] is a list
>>>> of rows (and columns) in the sub (domain) matrix. In your case with the
>>>> matrix of 144 by 144 the indices will go from 0 to 143.
>>>>   In your simple Fortran code you have a completely different problem.
>>>> A matrix with 8 rows and columns. In that case if you want the first IS to
>>>> represent just the first row (and column) in the matrix then it should
>>>> contain only 0. The second submatrix which is all rows (but the first)
>>>> should have 1,2,3,4,5,6,7
>>>>   I do not understand why your code has
>>>> indices_first_domain = [0,1,8,9] ! corresponds to diag(1,1)
>>>> it should just be 0
>>>> On May 9, 2023, at 12:44 PM, LEONARDO MUTTI <
>>>> Partial typo: I expect 9x(16+16) numbers to be stored in subdomain_IS :
>>>> # subdomains x (row indices of the submatrix + col indices of the
>>>> submatrix).
>>>> Il giorno mar 9 mag 2023 alle ore 18:31 LEONARDO MUTTI <
>>>> leonardo.mutti01 at universitadipavia.it> ha scritto:
>>>>> ---------- Forwarded message ---------
>>>>> Da: LEONARDO MUTTI <leonardo.mutti01 at universitadipavia.it>
>>>>> Date: mar 9 mag 2023 alle ore 18:29
>>>>> Subject: Re: [petsc-users] Understanding index sets for PCGASM
>>>>> To: Matthew Knepley <knepley at gmail.com>
>>>>> Thank you for your answer, but I am still confused, sorry.
>>>>> Consider
>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tests/ex71f.F90 on
>>>>> one processor.
>>>>> Let M=12 for the sake of simplicity, i.e. we deal with a 12x12 2D
>>>>> grid, hence, a  144x144 matrix.
>>>>> Let NSubx = 3, so that on the grid we do 3 vertical and 3 horizontal
>>>>> subdivisions.
>>>>> We should obtain 9 subdomains that are grids of 4x4 nodes each, thus
>>>>> corresponding to 9 submatrices of size 16x16.
>>>>> In my run I obtain NSub = 9 (great) and subdomain_IS(i), i=1,...,9,
>>>>> reads:
>>>>> *IS Object: 1 MPI process*
>>>>> *  type: general*
>>>>> *Number of indices in set 16*
>>>>> *0 0*
>>>>> *1 1*
>>>>> *2 2*
>>>>> *3 3*
>>>>> *4 12*
>>>>> *5 13*
>>>>> *6 14*
>>>>> *7 15*
>>>>> *8 24*
>>>>> *9 25*
>>>>> *10 26*
>>>>> *11 27*
>>>>> *12 36*
>>>>> *13 37*
>>>>> *14 38*
>>>>> *15 39*
>>>>> *  type: general*
>>>>> *0 4*
>>>>> *1 5*
>>>>> *2 6*
>>>>> *3 7*
>>>>> *4 16*
>>>>> *5 17*
>>>>> *6 18*
>>>>> *7 19*
>>>>> *8 28*
>>>>> *9 29*
>>>>> *10 30*
>>>>> *11 31*
>>>>> *12 40*
>>>>> *13 41*
>>>>> *14 42*
>>>>> *15 43*
>>>>> *  type: general*
>>>>> *0 8*
>>>>> *1 9*
>>>>> *2 10*
>>>>> *3 11*
>>>>> *4 20*
>>>>> *5 21*
>>>>> *6 22*
>>>>> *7 23*
>>>>> *8 32*
>>>>> *9 33*
>>>>> *10 34*
>>>>> *11 35*
>>>>> *12 44*
>>>>> *13 45*
>>>>> *14 46*
>>>>> *15 47*
>>>>> *  type: general*
>>>>> *0 48*
>>>>> *1 49*
>>>>> *2 50*
>>>>> *3 51*
>>>>> *4 60*
>>>>> *5 61*
>>>>> *6 62*
>>>>> *7 63*
>>>>> *8 72*
>>>>> *9 73*
>>>>> *10 74*
>>>>> *11 75*
>>>>> *12 84*
>>>>> *13 85*
>>>>> *14 86*
>>>>> *15 87*
>>>>> *  type: general*
>>>>> *0 52*
>>>>> *1 53*
>>>>> *2 54*
>>>>> *3 55*
>>>>> *4 64*
>>>>> *5 65*
>>>>> *6 66*
>>>>> *7 67*
>>>>> *8 76*
>>>>> *9 77*
>>>>> *10 78*
>>>>> *11 79*
>>>>> *12 88*
>>>>> *13 89*
>>>>> *14 90*
>>>>> *15 91*
>>>>> *  type: general*
>>>>> *0 56*
>>>>> *1 57*
>>>>> *2 58*
>>>>> *3 59*
>>>>> *4 68*
>>>>> *5 69*
>>>>> *6 70*
>>>>> *7 71*
>>>>> *8 80*
>>>>> *9 81*
>>>>> *10 82*
>>>>> *11 83*
>>>>> *12 92*
>>>>> *13 93*
>>>>> *14 94*
>>>>> *15 95*
>>>>> *  type: general*
>>>>> *0 96*
>>>>> *1 97*
>>>>> *2 98*
>>>>> *3 99*
>>>>> *4 108*
>>>>> *5 109*
>>>>> *6 110*
>>>>> *7 111*
>>>>> *8 120*
>>>>> *9 121*
>>>>> *10 122*
>>>>> *11 123*
>>>>> *12 132*
>>>>> *13 133*
>>>>> *14 134*
>>>>> *15 135*
>>>>> *  type: general*
>>>>> *0 100*
>>>>> *1 101*
>>>>> *2 102*
>>>>> *3 103*
>>>>> *4 112*
>>>>> *5 113*
>>>>> *6 114*
>>>>> *7 115*
>>>>> *8 124*
>>>>> *9 125*
>>>>> *10 126*
>>>>> *11 127*
>>>>> *12 136*
>>>>> *13 137*
>>>>> *14 138*
>>>>> *15 139*
>>>>> *  type: general*
>>>>> *0 104*
>>>>> *1 105*
>>>>> *2 106*
>>>>> *3 107*
>>>>> *4 116*
>>>>> *5 117*
>>>>> *6 118*
>>>>> *7 119*
>>>>> *8 128*
>>>>> *9 129*
>>>>> *10 130*
>>>>> *11 131*
>>>>> *12 140*
>>>>> *13 141*
>>>>> *14 142*
>>>>> *15 143*
>>>>> As you said, no number here reaches 144.
>>>>> But the number stored in subdomain_IS are 9x16= #subdomains x 16,
>>>>> whereas I would expect, also given your latest reply, 9x16x16x2=#subdomains
>>>>> x submatrix height x submatrix width x length of a (row,column) pair.
>>>>> It would really help me if you could briefly explain how the output
>>>>> above encodes the subdivision into subdomains.
>>>>> Many thanks again,
>>>>> Leonardo
>>>>> Il giorno mar 9 mag 2023 alle ore 16:24 Matthew Knepley <
>>>>> knepley at gmail.com> ha scritto:
>>>>>> On Tue, May 9, 2023 at 10:05 AM LEONARDO MUTTI <
>>>>>>> Great thanks! I can now successfully run
>>>>>>> Going forward with my experiments, let me post a new code snippet
>>>>>>> (very similar to  ex71f.F90) that I cannot get to work, probably I must be
>>>>>>> setting up the IS objects incorrectly.
>>>>>>> I have an 8x8 matrix A=diag(1,1,2,2,...,2) and a
>>>>>>> vector  b=(0.5,...,0.5). We have only one processor, and I want to solve
>>>>>>> Ax=b using GASM. In particular, KSP is set to preonly, GASM is the
>>>>>>> preconditioner and it uses on each submatrix an lu direct solver (sub_ksp =
>>>>>>> preonly, sub_pc = lu).
>>>>>>> For the GASM algorithm, I divide A into diag(1,1) and
>>>>>>> diag(2,2,...,2). For simplicity I set 0 overlap. Now I want to use GASM to
>>>>>>> solve Ax=b. The code follows.
>>>>>>> #include <petsc/finclude/petscmat.h>
>>>>>>> #include <petsc/finclude/petscksp.h>
>>>>>>> #include <petsc/finclude/petscpc.h>
>>>>>>>       USE petscmat
>>>>>>>       USE petscksp
>>>>>>>       USE petscpc
>>>>>>>       USE MPI
>>>>>>>       Mat   :: A
>>>>>>>       Vec   :: b, x
>>>>>>>       PetscInt :: M, I, J, ISLen, NSub
>>>>>>>       PetscMPIInt :: size
>>>>>>>       PetscScalar :: v
>>>>>>>       KSP            :: ksp
>>>>>>>       PC             :: pc
>>>>>>>       PetscInt,DIMENSION(4) :: indices_first_domain
>>>>>>>       PetscInt,DIMENSION(36) :: indices_second_domain
>>>>>>>       call MPI_Comm_size(PETSC_COMM_WORLD, size, ierr)
>>>>>>>       WRITE(*,*) "Assembling A,b"
>>>>>>>       M = 8
>>>>>>>       DO I=1,M
>>>>>>>          DO J=1,M
>>>>>>>             IF ((I .EQ. J) .AND. (I .LE. 2 )) THEN
>>>>>>>                v = 1
>>>>>>>             ELSE IF ((I .EQ. J) .AND. (I .GT. 2 )) THEN
>>>>>>>                v = 2
>>>>>>>             ELSE
>>>>>>>                v = 0
>>>>>>>             ENDIF
>>>>>>>             call MatSetValue(A, I-1, J-1, v, INSERT_VALUES, ierr)
>>>>>>>          END DO
>>>>>>>       END DO
>>>>>>>       do I=1,M
>>>>>>>          v = 0.5
>>>>>>>          call VecSetValue(b,I-1,v, INSERT_VALUES,ierr)
>>>>>>>       end do
>>>>>>>       WRITE(*,*) "KSP/PC first setup"
>>>>>>>       WRITE(*,*) "Setting GASM subdomains"
>>>>>>>       ! Let's create the subdomain IS and inflated_IS
>>>>>>>       ! They are equal if no overlap is present
>>>>>>>       ! They are 1: 0,1,8,9
>>>>>>>       !          2: 10,...,15,18,...,23,...,58,...,63
>>>>>>>       do I=0,5
>>>>>>>          do J=0,5
>>>>>>>             indices_second_domain(I*6+1+J) = 18 + J + 8*I !
>>>>>>> corresponds to diag(2,2,...,2)
>>>>>>>             !WRITE(*,*) I*6+1+J, 18 + J + 8*I
>>>>>>>          end do
>>>>>>>       end do
>>>>>>>       ! Convert into IS
>>>>>>>       ISLen = 4
>>>>>>>       call
>>>>>>> ISCreateGeneral(PETSC_COMM_WORLD,ISLen,indices_first_domain,
>>>>>>>      & PETSC_COPY_VALUES, subdomains_IS(1), ierr)
>>>>>>>       call
>>>>>>>      & PETSC_COPY_VALUES, inflated_IS(1), ierr)
>>>>>>>       ISLen = 36
>>>>>>>       call
>>>>>>> ISCreateGeneral(PETSC_COMM_WORLD,ISLen,indices_second_domain,
>>>>>>>      & PETSC_COPY_VALUES, subdomains_IS(2), ierr)
>>>>>>>       call
>>>>>>>      & PETSC_COPY_VALUES, inflated_IS(2), ierr)
>>>>>>>       NSub = 2
>>>>>>>       call PCGASMSetSubdomains(pc,NSub,
>>>>>>>      & subdomains_IS,inflated_IS,ierr)
>>>>>>>       call PCGASMDestroySubdomains(NSub,
>>>>>>>       WRITE(*,*) "Setting subsolvers for GASM"
>>>>>>>       call PCSetUp(pc, ierr) ! should I add this?
>>>>>>>      & "-sub_pc_type", "lu", ierr)
>>>>>>>      & "-sub_ksp_type", "preonly", ierr)
>>>>>>>       ! DUMMY SOLUTION: DID IT WORK?
>>>>>>>       WRITE(*,*) "Solve"
>>>>>>>       call VecDuplicate(b,x,ierr)
>>>>>>>       call KSPSolve(ksp,b,x,ierr)
>>>>>>>       call KSPDestroy(ksp, ierr)
>>>>>>> This code is failing in multiple points. At  call PCSetUp(pc, ierr)
>>>>>>> it produces:
>>>>>>> *[0]PETSC ERROR: Argument out of range*
>>>>>>> *[0]PETSC ERROR: Scatter indices in ix are out of range*
>>>>>>> *[0]PETSC ERROR: #1 VecScatterCreate() at
>>>>>>> ***\src\vec\is\sf\INTERF~1\vscat.c:736*
>>>>>>> *[0]PETSC ERROR: #2 PCSetUp_GASM() at
>>>>>>> ***\src\ksp\pc\impls\gasm\gasm.c:433*
>>>>>>> *[0]PETSC ERROR: #3 PCSetUp() at
>>>>>>> ***\src\ksp\pc\INTERF~1\precon.c:994*
>>>>>>> And at call KSPSolve(ksp,b,x,ierr) it produces:
>>>>>>> *forrtl: severe (157): Program Exception - access violation*
>>>>>>> The index sets are setup coherently with the outputs of e.g.
>>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tests/output/ex71f_1.out:
>>>>>>> in particular each element of the matrix A corresponds to a number from 0
>>>>>>> to 63.
>>>>>> This is not correct, I believe. The indices are row/col indices, not
>>>>>> indices into dense blocks, so for
>>>>>> your example, they are all in [0, 8].
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Note that each submatrix does not represent some physical subdomain,
>>>>>>> the subdivision is just at the algebraic level.
>>>>>>> I thus have the following questions:
>>>>>>>    - is this the correct way of creating the IS objects, given my
>>>>>>>    objective at the beginning of the email? Is the ordering correct?
>>>>>>>    - what am I doing wrong that is generating the above errors?
>>>>>>> Thanks for the patience and the time.
>>>>>>> Best,
>>>>>>> Leonardo
>>>>>>> Il giorno ven 5 mag 2023 alle ore 18:43 Barry Smith <
>>>>>>>>   Added in *barry/2023-05-04/add-pcgasm-set-subdomains *see also
>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/6419
>>>>>>>>   Barry
>>>>>>>> On May 4, 2023, at 11:23 AM, LEONARDO MUTTI <
>>>>>>>> Thank you for the help.
>>>>>>>> Adding to my example:
>>>>>>>> *      call PCGASMSetSubdomains(pc,NSub, subdomains_IS,
>>>>>>>> inflated_IS,ierr)      call
>>>>>>>> PCGASMDestroySubdomains(NSub,subdomains_IS,inflated_IS,ierr)*
>>>>>>>> results in:
>>>>>>>> *      Error LNK2019 unresolved external symbol
>>>>>>>> PCGASMDESTROYSUBDOMAINS referenced in function ...  *
>>>>>>>> *      Error LNK2019 unresolved external symbol PCGASMSETSUBDOMAINS
>>>>>>>> I'm not sure if the interfaces are missing or if I have a
>>>>>>>> compilation problem.
>>>>>>>> Thank you again.
>>>>>>>> Best,
>>>>>>>> Leonardo
>>>>>>>> Il giorno sab 29 apr 2023 alle ore 20:30 Barry Smith <
>>>>>>>>>    Thank you for the test code. I have a fix in the branch
>>>>>>>>> barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>>>>>> <https://gitlab.com/petsc/petsc/-/commits/barry/2023-04-29/fix-pcasmcreatesubdomains2d> with
>>>>>>>>> merge request https://gitlab.com/petsc/petsc/-/merge_requests/6394
>>>>>>>>>    The functions did not have proper Fortran stubs and interfaces
>>>>>>>>> so I had to provide them manually in the new branch.
>>>>>>>>>    Use
>>>>>>>>>    git fetch
>>>>>>>>>    git checkout barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>>>>>>    ./configure etc
>>>>>>>>>    Your now working test code is in src/ksp/ksp/tests/ex71f.F90  I
>>>>>>>>> had to change things slightly and I updated the error handling for the
>>>>>>>>> latest version.
>>>>>>>>>    Please let us know if you have any later questions.
>>>>>>>>>   Barry
>>>>>>>>> On Apr 28, 2023, at 12:07 PM, LEONARDO MUTTI <
>>>>>>>>> Hello. I am having a hard time understanding the index sets to
>>>>>>>>> feed PCGASMSetSubdomains, and I am working in Fortran (as a PETSc novice).
>>>>>>>>> To get more intuition on how the IS objects behave I tried the following
>>>>>>>>> minimal (non) working example, which should tile a 16x16 matrix into 16
>>>>>>>>> square, non-overlapping submatrices:
>>>>>>>>>       USE petscmat
>>>>>>>>>       USE petscksp
>>>>>>>>>       USE petscpc
>>>>>>>>>       Mat   :: A
>>>>>>>>>       PetscInt :: M, NSubx, dof, overlap, NSub
>>>>>>>>>       INTEGER :: I,J
>>>>>>>>>       PetscScalar :: v
>>>>>>>>>       KSP            :: ksp
>>>>>>>>>       PC             :: pc
>>>>>>>>>       IS :: subdomains_IS, inflated_IS
>>>>>>>>>       call PetscInitialize(PETSC_NULL_CHARACTER , ierr)
>>>>>>>>> !-----Create a dummy matrix
>>>>>>>>>       M = 16
>>>>>>>>>       call MatCreateAIJ(MPI_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>>>>>>>>      & M, M,
>>>>>>>>>      & A, ierr)
>>>>>>>>>       DO I=1,M
>>>>>>>>>          DO J=1,M
>>>>>>>>>             v = I*J
>>>>>>>>>             CALL MatSetValue (A,I-1,J-1,v,
>>>>>>>>>      &                     INSERT_VALUES , ierr)
>>>>>>>>>          END DO
>>>>>>>>>       END DO
>>>>>>>>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>>>>>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>>>>>> !-----Create KSP and PC
>>>>>>>>>       call KSPCreate(PETSC_COMM_WORLD,ksp, ierr)
>>>>>>>>>       call KSPSetOperators(ksp,A,A, ierr)
>>>>>>>>>       call KSPSetType(ksp,"bcgs",ierr)
>>>>>>>>>       call KSPGetPC(ksp,pc,ierr)
>>>>>>>>>       call PCSetType(pc,PCGASM, ierr)
>>>>>>>>>       call PCSetUp(pc , ierr)
>>>>>>>>> !-----GASM setup
>>>>>>>>>       NSubx = 4
>>>>>>>>>       dof = 1
>>>>>>>>>       overlap = 0
>>>>>>>>>       call PCGASMCreateSubdomains2D(pc,
>>>>>>>>>      &      M, M,
>>>>>>>>>      &      NSubx, NSubx,
>>>>>>>>>      &      dof, overlap,
>>>>>>>>>      &      NSub, subdomains_IS, inflated_IS, ierr)
>>>>>>>>>       call ISView(subdomains_IS, PETSC_VIEWER_STDOUT_WORLD, ierr)
>>>>>>>>> Running this on one processor, I get NSub = 4.
>>>>>>>>> If PCASM and PCASMCreateSubdomains2D are used instead, I get NSub
>>>>>>>>> = 16 as expected.
>>>>>>>>> Moreover, I get in the end "forrtl: severe (157): Program
>>>>>>>>> Exception - access violation". So:
>>>>>>>>> 1) why do I get two different results with ASM, and GASM?
>>>>>>>>> 2) why do I get access violation and how can I solve this?
>>>>>>>>> In fact, in C, subdomains_IS, inflated_IS should pointers to IS
>>>>>>>>> objects. As I see on the Fortran interface, the arguments to
>>>>>>>>> PCGASMCreateSubdomains2D are IS objects:
>>>>>>>>>        subroutine PCGASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,j,z)
>>>>>>>>>        import tPC,tIS
>>>>>>>>>        PC a ! PC
>>>>>>>>>        PetscInt b ! PetscInt
>>>>>>>>>        PetscInt c ! PetscInt
>>>>>>>>>        PetscInt d ! PetscInt
>>>>>>>>>        PetscInt e ! PetscInt
>>>>>>>>>        PetscInt f ! PetscInt
>>>>>>>>>        PetscInt g ! PetscInt
>>>>>>>>>        PetscInt h ! PetscInt
>>>>>>>>>        IS i ! IS
>>>>>>>>>        IS j ! IS
>>>>>>>>>        PetscErrorCode z
>>>>>>>>>        end subroutine PCGASMCreateSubdomains2D
>>>>>>>>> Thus:
>>>>>>>>> 3) what should be inside e.g., subdomains_IS? I expect it to
>>>>>>>>> contain, for every created subdomain, the list of rows and columns defining
>>>>>>>>> the subblock in the matrix, am I right?
>>>>>>>>> Context: I have a block-tridiagonal system arising from space-time
>>>>>>>>> finite elements, and I want to solve it with GMRES+PCGASM preconditioner,
>>>>>>>>> where each overlapping submatrix is on the diagonal and of size 3x3 blocks
>>>>>>>>> (and spanning multiple processes). This is PETSc 3.17.1 on Windows.
>>>>>>>>> Thanks in advance,
>>>>>>>>> Leonardo
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230519/b807f888/attachment-0001.html>
