[petsc-users] Understanding index sets for PCGASM
Leonardo Mutti leonardo.mutti01 at universitadipavia.it
Wed May 17 18:51:58 CDT 2023
Thanks for the reply. Even without Valgrind (which I can't use since I'm on
Windows), by further simplifying the example, I was able to have PETSc
display a more informative message.
What I am doing wrong and what should be done differently, this is still
unclear to me.
The simplified code runs on 2 processors, I built a 4x4 matrix.
The subdomains are now given by [0,1] and [2,3], with [2,3] inflating to
[0,1,2,3].
Thank you again.
Error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Out of memory. This could be due to allocating
[0]PETSC ERROR: too large an object or bleeding by not properly
[0]PETSC ERROR: destroying unneeded objects.
[0]PETSC ERROR: Memory allocated 0 Memory used by process 0
[0]PETSC ERROR: Try running with -malloc_dump or -malloc_view for info.
[0]PETSC ERROR: Memory requested 9437902811936987136
[0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
be the program crashed before they were used or a spelling mistake, etc!
[0]PETSC ERROR:   Option left: name:-pc_gasm_view_subdomains value: 1
source: code
[0]PETSC ERROR:   Option left: name:-sub_ksp_type value: gmres source: code
[0]PETSC ERROR:   Option left: name:-sub_pc_type value: none source: code
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.19.1-234-g43977f8d16
 GIT Date: 2023-05-08 14:50:03 +0000
[0]PETSC ERROR: #1 PetscMallocAlign() at
...\Sources\Git\Test-FV\PETSC-~1\src\sys\memory\mal.c:66
[0]PETSC ERROR: #2 PetscMallocA() at
...\Sources\Git\Test-FV\PETSC-~1\src\sys\memory\mal.c:411
[0]PETSC ERROR: #3 MatCreateSubMatrices_MPIAIJ() at
...\Sources\Git\Test-FV\PETSC-~1\src\mat\impls\aij\mpi\mpiov.c:2025
[0]PETSC ERROR: #4 MatCreateSubMatricesMPI_MPIXAIJ() at
...\Sources\Git\Test-FV\PETSC-~1\src\mat\impls\aij\mpi\mpiov.c:3136
[0]PETSC ERROR: #5 MatCreateSubMatricesMPI_MPIAIJ() at
...\Sources\Git\Test-FV\PETSC-~1\src\mat\impls\aij\mpi\mpiov.c:3208
[0]PETSC ERROR: #6 MatCreateSubMatricesMPI() at
...\Sources\Git\Test-FV\PETSC-~1\src\mat\INTERF~1\matrix.c:7071
[0]PETSC ERROR: #7 PCSetUp_GASM() at
...\Sources\Git\Test-FV\PETSC-~1\src\ksp\pc\impls\gasm\gasm.c:556
[0]PETSC ERROR: #8 PCSetUp() at
...\Sources\Git\Test-FV\PETSC-~1\src\ksp\pc\INTERF~1\precon.c:994
[0]PETSC ERROR: #9 KSPSetUp() at
...\Sources\Git\Test-FV\PETSC-~1\src\ksp\ksp\INTERF~1\itfunc.c:406
Code, the important bit is after ! GASM, SETTING SUBDOMAINS:
      Mat   :: A
      Vec   :: b
      PetscInt :: M,N_blocks,block_size,NSub,I
      PetscErrorCode :: ierr
      PetscScalar :: v
      KSP            :: ksp
      PC             :: pc
      IS :: subdomains_IS(2), inflated_IS(2)
      PetscInt            :: NMPI,MYRANK,IERMPI
      INTEGER  :: start
      call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
      call PetscLogDefaultBegin(ierr)
      call MPI_COMM_SIZE(MPI_COMM_WORLD, NMPI, IERMPI)
      CALL MPI_COMM_RANK(MPI_COMM_WORLD, MYRANK,IERMPI)
      N_blocks = 2
      block_size = 2
      M = N_blocks * block_size
      ! INTRO: create matrix and right hand side, create IS
      call MatCreateAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
     & M, M, PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,
     & PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,A, ierr)
      call VecCreate(PETSC_COMM_WORLD,b,ierr)
      call VecSetSizes(b, PETSC_DECIDE, M,ierr)
      call VecSetFromOptions(b,ierr)
      DO I=(MYRANK*(M/NMPI)),((MYRANK+1)*(M/NMPI)-1)
         ! Set matrix
         v=1
         call MatSetValue(A, I, I, v, INSERT_VALUES, ierr)
         IF (I-block_size .GE. 0) THEN
            v=-1
            call MatSetValue(A, I, I-block_size, v, INSERT_VALUES, ierr)
         ENDIF
         ! Set rhs
         v = I
         call VecSetValue(b,I,v, INSERT_VALUES,ierr)
      END DO
      call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
      call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
      call VecAssemblyBegin(b,ierr)
      call VecAssemblyEnd(b,ierr)
      ! FIRST KSP/PC SETUP
      call KSPCreate(PETSC_COMM_WORLD, ksp, ierr)
      call KSPSetOperators(ksp, A, A, ierr)
      call KSPSetType(ksp, 'preonly', ierr)
      call KSPGetPC(ksp, pc, ierr)
      call PCSetType(pc, PCGASM, ierr)
      if (myrank == 0) then
         call ISCreateStride(PETSC_COMM_SELF, 2, 0, 1, subdomains_IS(1),
ierr)
         call ISCreateStride(PETSC_COMM_WORLD, 0, 0, 1, subdomains_IS(2),
ierr)
         call ISCreateStride(PETSC_COMM_SELF, 2, 0, 1, inflated_IS(1), ierr)
         call ISCreateStride(PETSC_COMM_WORLD, 2, 0, 1, inflated_IS(2),
ierr)
         start = 1
         NSub = 2
      else
         call ISCreateStride(PETSC_COMM_WORLD, 2, 2, 1, subdomains_IS(2),
ierr)
         call ISCreateStride(PETSC_COMM_WORLD, 2, 2, 1, inflated_IS(2),
ierr)
         start = 2
         NSub = 1
      endif
      call
PCGASMSetSubdomains(pc,NSub,subdomains_IS(start:2),inflated_IS(start:2),ierr)
      call
PCGASMDestroySubdomains(NSub,subdomains_IS(start:2),inflated_IS(start:2),ierr)
      ! GASM: SET SUBSOLVERS
      call PetscOptionsSetValue(PETSC_NULL_OPTIONS,"-sub_ksp_type",
"gmres", ierr)
      call PetscOptionsSetValue(PETSC_NULL_OPTIONS,"-sub_pc_type", "none",
ierr)
      call
PetscOptionsSetValue(PETSC_NULL_OPTIONS,"-pc_gasm_view_subdomains", "1",
ierr)
      call KSPSetUp(ksp, ierr)
      call PCSetUp(pc, ierr)
      call KSPSetFromOptions(ksp, ierr)
      call PCSetFromOptions(pc, ierr)
      call KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD, ierr)
      call MatDestroy(A, ierr)
      call PetscFinalize(ierr)
Il giorno mer 17 mag 2023 alle ore 21:55 Barry Smith <bsmith at petsc.dev> ha
scritto:
> On May 17, 2023, at 11:10 AM, Leonardo Mutti <
> leonardo.mutti01 at universitadipavia.it> wrote:
> Dear developers, let me kindly ask for your help again.
> In the following snippet, a bi-diagonal matrix A is set up. It measures
> 8x8 blocks, each block is 2x2 elements. I would like to create the
> correct IS objects for PCGASM.
> The non-overlapping IS should be: [*0,1*], [*2,3*],[*4,5*], ..., [*14,15*
> ]. The overlapping IS should be: [*0,1*], [0,1,*2,3*], [2,3,*4,5*], ...,
> [12,13,*14,15*]
> I am running the code with 4 processors. For some reason, after calling PCGASMDestroySubdomains
> the code crashes with severe (157): Program Exception - access violation.
> A visual inspection of the indices using ISView looks good.
>   Likely memory corruption or use of an object or an array that was
> already freed. Best to use Valgrind to find the exact location of the mess.
> Thanks again,
> Leonardo
>       Mat   :: A
>       Vec   :: b
>       PetscInt ::
> M,N_blocks,block_size,I,J,NSub,converged_reason,srank,erank,color,subcomm
>       PetscMPIInt :: size
>       PetscScalar :: v
>       KSP            :: ksp
>       PC             :: pc
>       IS,ALLOCATABLE :: subdomains_IS(:), inflated_IS(:)
>       INTEGER  :: IS_counter, is_start, is_end
>       N_blocks = 8
>       block_size = 2
>       ALLOCATE(subdomains_IS(N_blocks))
>       ALLOCATE(inflated_IS(N_blocks))
>       ! ASSUMPTION: no block spans more than one rank (the inflated blocks
> can)
>       ! How many inflated blocks span more than one rank? NMPI-1 !
>          ! Set matrix
>          v=1
>             v=-1
>          ENDIF
>          ! Set rhs
>          v = I
>       END DO
>       !! GASM, SETTING SUBDOMAINS
>       DO IS_COUNTER=1,N_blocks
>          srank = MAX(((IS_COUNTER-2)*block_size)/(M/NMPI),0) ! start rank
> reached by inflated block
>          erank = MIN(((IS_COUNTER-1)*block_size)/(M/NMPI),NMPI-1) ! end
> rank reached by inflated block. Coincides with rank containing non-inflated
> block
>    ! Create subcomms
>    color = MPI_UNDEFINED
>    IF (myrank == srank .or. myrank == erank) THEN
>       color = 1
>    ENDIF
>    call MPI_Comm_split(MPI_COMM_WORLD,color,MYRANK,subcomm,ierr)
>          ! Create IS
>          IF (srank .EQ. erank) THEN   ! Block and overlap are on the same
> rank
>             IF (MYRANK .EQ. srank) THEN
>                call
> ISCreateStride(PETSC_COMM_SELF,block_size,(IS_COUNTER-1)*block_size,1,subdomains_IS(IS_COUNTER),ierr)
>                IF (IS_COUNTER .EQ. 1) THEN  ! the first block is not
> inflated
>                    call
> ISCreateStride(PETSC_COMM_SELF,block_size,(IS_COUNTER-1)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>                ELSE
>                   call
> ISCreateStride(PETSC_COMM_SELF,2*block_size,(IS_COUNTER-2)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>                ENDIF
>             ENDIF
>          else ! Block and overlap not on the same rank
>             if (myrank == erank) then  ! the block
>                call  ISCreateStride
> (subcomm,block_size,(IS_COUNTER-1)*block_size,1,subdomains_IS(IS_COUNTER),ierr)
>                call  ISCreateStride
> (subcomm,block_size,(IS_COUNTER-1)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>             endif
>             if (myrank == srank) then  ! the overlap
>                call  ISCreateStride
> (subcomm,block_size,(IS_COUNTER-2)*block_size,1,inflated_IS(IS_COUNTER),ierr)
>                call  ISCreateStride
> (subcomm,0,(IS_COUNTER-1)*block_size,1,subdomains_IS(IS_COUNTER),ierr)
>             endif
>          endif
>          call MPI_Comm_free(subcomm, ierr)
>       END DO
>       ! Set the domains/subdomains
>       NSub = N_blocks/NMPI
>       is_start = 1 + myrank * NSub
>       is_end = min(is_start + NSub, N_blocks)
>       if (myrank + 1 < NMPI) then
>          NSub = NSub + 1
>       endif
>       call
> PCGASMSetSubdomains(pc,NSub,subdomains_IS(is_start:is_end),inflated_IS(is_start:is_end),ierr)
>       call
> PCGASMDestroySubdomains(NSub,subdomains_IS(is_start:is_end),inflated_IS(is_start:is_end),ierr)
> "gmres", ierr)
> ierr)
>       call
> ierr)
> Il giorno mer 10 mag 2023 alle ore 03:02 Barry Smith <bsmith at petsc.dev>
> ha scritto:
>> On May 9, 2023, at 4:58 PM, LEONARDO MUTTI <
>> In my notation diag(1,1) means a diagonal 2x2 matrix with 1,1 on the
>> diagonal, submatrix in the 8x8 diagonal matrix diag(1,1,2,2,...,2).
>> Am I then correct that the IS representing diag(1,1) is 0,1, and that
>> diag(2,2,...,2) is represented by 2,3,4,5,6,7?
>> I believe so
>> Thanks,
>> Leonardo
>> Il mar 9 mag 2023, 20:45 Barry Smith <bsmith at petsc.dev> ha scritto:
>>>   It is simplier than you are making it out to be. Each IS[] is a list
>>> of rows (and columns) in the sub (domain) matrix. In your case with the
>>> matrix of 144 by 144 the indices will go from 0 to 143.
>>>   In your simple Fortran code you have a completely different problem. A
>>> matrix with 8 rows and columns. In that case if you want the first IS to
>>> represent just the first row (and column) in the matrix then it should
>>> contain only 0. The second submatrix which is all rows (but the first)
>>> should have 1,2,3,4,5,6,7
>>>   I do not understand why your code has
>>> indices_first_domain = [0,1,8,9] ! corresponds to diag(1,1)
>>> it should just be 0
>>> On May 9, 2023, at 12:44 PM, LEONARDO MUTTI <
>>> Partial typo: I expect 9x(16+16) numbers to be stored in subdomain_IS :
>>> # subdomains x (row indices of the submatrix + col indices of the
>>> submatrix).
>>> Il giorno mar 9 mag 2023 alle ore 18:31 LEONARDO MUTTI <
>>> leonardo.mutti01 at universitadipavia.it> ha scritto:
>>>> ---------- Forwarded message ---------
>>>> Da: LEONARDO MUTTI <leonardo.mutti01 at universitadipavia.it>
>>>> Date: mar 9 mag 2023 alle ore 18:29
>>>> Subject: Re: [petsc-users] Understanding index sets for PCGASM
>>>> To: Matthew Knepley <knepley at gmail.com>
>>>> Thank you for your answer, but I am still confused, sorry.
>>>> Consider
>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tests/ex71f.F90 on
>>>> one processor.
>>>> Let M=12 for the sake of simplicity, i.e. we deal with a 12x12 2D grid,
>>>> hence, a  144x144 matrix.
>>>> Let NSubx = 3, so that on the grid we do 3 vertical and 3 horizontal
>>>> subdivisions.
>>>> We should obtain 9 subdomains that are grids of 4x4 nodes each, thus
>>>> corresponding to 9 submatrices of size 16x16.
>>>> In my run I obtain NSub = 9 (great) and subdomain_IS(i), i=1,...,9,
>>>> reads:
>>>> *IS Object: 1 MPI process*
>>>> *  type: general*
>>>> *Number of indices in set 16*
>>>> *0 0*
>>>> *1 1*
>>>> *2 2*
>>>> *3 3*
>>>> *4 12*
>>>> *5 13*
>>>> *6 14*
>>>> *7 15*
>>>> *8 24*
>>>> *9 25*
>>>> *10 26*
>>>> *11 27*
>>>> *12 36*
>>>> *13 37*
>>>> *14 38*
>>>> *15 39*
>>>> *  type: general*
>>>> *0 4*
>>>> *1 5*
>>>> *2 6*
>>>> *3 7*
>>>> *4 16*
>>>> *5 17*
>>>> *6 18*
>>>> *7 19*
>>>> *8 28*
>>>> *9 29*
>>>> *10 30*
>>>> *11 31*
>>>> *12 40*
>>>> *13 41*
>>>> *14 42*
>>>> *15 43*
>>>> *  type: general*
>>>> *0 8*
>>>> *1 9*
>>>> *2 10*
>>>> *3 11*
>>>> *4 20*
>>>> *5 21*
>>>> *6 22*
>>>> *7 23*
>>>> *8 32*
>>>> *9 33*
>>>> *10 34*
>>>> *11 35*
>>>> *12 44*
>>>> *13 45*
>>>> *14 46*
>>>> *15 47*
>>>> *  type: general*
>>>> *0 48*
>>>> *1 49*
>>>> *2 50*
>>>> *3 51*
>>>> *4 60*
>>>> *5 61*
>>>> *6 62*
>>>> *7 63*
>>>> *8 72*
>>>> *9 73*
>>>> *10 74*
>>>> *11 75*
>>>> *12 84*
>>>> *13 85*
>>>> *14 86*
>>>> *15 87*
>>>> *  type: general*
>>>> *0 52*
>>>> *1 53*
>>>> *2 54*
>>>> *3 55*
>>>> *4 64*
>>>> *5 65*
>>>> *6 66*
>>>> *7 67*
>>>> *8 76*
>>>> *9 77*
>>>> *10 78*
>>>> *11 79*
>>>> *12 88*
>>>> *13 89*
>>>> *14 90*
>>>> *15 91*
>>>> *  type: general*
>>>> *0 56*
>>>> *1 57*
>>>> *2 58*
>>>> *3 59*
>>>> *4 68*
>>>> *5 69*
>>>> *6 70*
>>>> *7 71*
>>>> *8 80*
>>>> *9 81*
>>>> *10 82*
>>>> *11 83*
>>>> *12 92*
>>>> *13 93*
>>>> *14 94*
>>>> *15 95*
>>>> *  type: general*
>>>> *0 96*
>>>> *1 97*
>>>> *2 98*
>>>> *3 99*
>>>> *4 108*
>>>> *5 109*
>>>> *6 110*
>>>> *7 111*
>>>> *8 120*
>>>> *9 121*
>>>> *10 122*
>>>> *11 123*
>>>> *12 132*
>>>> *13 133*
>>>> *14 134*
>>>> *15 135*
>>>> *  type: general*
>>>> *0 100*
>>>> *1 101*
>>>> *2 102*
>>>> *3 103*
>>>> *4 112*
>>>> *5 113*
>>>> *6 114*
>>>> *7 115*
>>>> *8 124*
>>>> *9 125*
>>>> *10 126*
>>>> *11 127*
>>>> *12 136*
>>>> *13 137*
>>>> *14 138*
>>>> *15 139*
>>>> *  type: general*
>>>> *0 104*
>>>> *1 105*
>>>> *2 106*
>>>> *3 107*
>>>> *4 116*
>>>> *5 117*
>>>> *6 118*
>>>> *7 119*
>>>> *8 128*
>>>> *9 129*
>>>> *10 130*
>>>> *11 131*
>>>> *12 140*
>>>> *13 141*
>>>> *14 142*
>>>> *15 143*
>>>> As you said, no number here reaches 144.
>>>> But the number stored in subdomain_IS are 9x16= #subdomains x 16,
>>>> whereas I would expect, also given your latest reply, 9x16x16x2=#subdomains
>>>> x submatrix height x submatrix width x length of a (row,column) pair.
>>>> It would really help me if you could briefly explain how the output
>>>> above encodes the subdivision into subdomains.
>>>> Many thanks again,
>>>> Leonardo
>>>> Il giorno mar 9 mag 2023 alle ore 16:24 Matthew Knepley <
>>>> knepley at gmail.com> ha scritto:
>>>>> On Tue, May 9, 2023 at 10:05 AM LEONARDO MUTTI <
>>>>>> Great thanks! I can now successfully run
>>>>>> Going forward with my experiments, let me post a new code snippet
>>>>>> (very similar to  ex71f.F90) that I cannot get to work, probably I must be
>>>>>> setting up the IS objects incorrectly.
>>>>>> I have an 8x8 matrix A=diag(1,1,2,2,...,2) and a
>>>>>> vector  b=(0.5,...,0.5). We have only one processor, and I want to solve
>>>>>> Ax=b using GASM. In particular, KSP is set to preonly, GASM is the
>>>>>> preconditioner and it uses on each submatrix an lu direct solver (sub_ksp =
>>>>>> preonly, sub_pc = lu).
>>>>>> For the GASM algorithm, I divide A into diag(1,1) and
>>>>>> diag(2,2,...,2). For simplicity I set 0 overlap. Now I want to use GASM to
>>>>>> solve Ax=b. The code follows.
>>>>>> #include <petsc/finclude/petscmat.h>
>>>>>> #include <petsc/finclude/petscksp.h>
>>>>>> #include <petsc/finclude/petscpc.h>
>>>>>>       USE petscmat
>>>>>>       USE petscksp
>>>>>>       USE petscpc
>>>>>>       USE MPI
>>>>>>       Mat   :: A
>>>>>>       Vec   :: b, x
>>>>>>       PetscInt :: M, I, J, ISLen, NSub
>>>>>>       PetscMPIInt :: size
>>>>>>       PetscScalar :: v
>>>>>>       KSP            :: ksp
>>>>>>       PC             :: pc
>>>>>>       PetscInt,DIMENSION(4) :: indices_first_domain
>>>>>>       PetscInt,DIMENSION(36) :: indices_second_domain
>>>>>>       call MPI_Comm_size(PETSC_COMM_WORLD, size, ierr)
>>>>>>       WRITE(*,*) "Assembling A,b"
>>>>>>       M = 8
>>>>>>       DO I=1,M
>>>>>>          DO J=1,M
>>>>>>             IF ((I .EQ. J) .AND. (I .LE. 2 )) THEN
>>>>>>                v = 1
>>>>>>             ELSE IF ((I .EQ. J) .AND. (I .GT. 2 )) THEN
>>>>>>                v = 2
>>>>>>             ELSE
>>>>>>                v = 0
>>>>>>             ENDIF
>>>>>>             call MatSetValue(A, I-1, J-1, v, INSERT_VALUES, ierr)
>>>>>>          END DO
>>>>>>       END DO
>>>>>>       do I=1,M
>>>>>>          v = 0.5
>>>>>>          call VecSetValue(b,I-1,v, INSERT_VALUES,ierr)
>>>>>>       end do
>>>>>>       WRITE(*,*) "KSP/PC first setup"
>>>>>>       WRITE(*,*) "Setting GASM subdomains"
>>>>>>       ! Let's create the subdomain IS and inflated_IS
>>>>>>       ! They are equal if no overlap is present
>>>>>>       ! They are 1: 0,1,8,9
>>>>>>       !          2: 10,...,15,18,...,23,...,58,...,63
>>>>>>       do I=0,5
>>>>>>          do J=0,5
>>>>>>             indices_second_domain(I*6+1+J) = 18 + J + 8*I !
>>>>>> corresponds to diag(2,2,...,2)
>>>>>>             !WRITE(*,*) I*6+1+J, 18 + J + 8*I
>>>>>>          end do
>>>>>>       end do
>>>>>>       ! Convert into IS
>>>>>>       ISLen = 4
>>>>>>       call
>>>>>> ISCreateGeneral(PETSC_COMM_WORLD,ISLen,indices_first_domain,
>>>>>>      & PETSC_COPY_VALUES, subdomains_IS(1), ierr)
>>>>>>       call
>>>>>>      & PETSC_COPY_VALUES, inflated_IS(1), ierr)
>>>>>>       ISLen = 36
>>>>>>       call
>>>>>> ISCreateGeneral(PETSC_COMM_WORLD,ISLen,indices_second_domain,
>>>>>>      & PETSC_COPY_VALUES, subdomains_IS(2), ierr)
>>>>>>       call
>>>>>>      & PETSC_COPY_VALUES, inflated_IS(2), ierr)
>>>>>>       NSub = 2
>>>>>>       call PCGASMSetSubdomains(pc,NSub,
>>>>>>      & subdomains_IS,inflated_IS,ierr)
>>>>>>       call PCGASMDestroySubdomains(NSub,
>>>>>>       WRITE(*,*) "Setting subsolvers for GASM"
>>>>>>       call PCSetUp(pc, ierr) ! should I add this?
>>>>>>      & "-sub_pc_type", "lu", ierr)
>>>>>>      & "-sub_ksp_type", "preonly", ierr)
>>>>>>       ! DUMMY SOLUTION: DID IT WORK?
>>>>>>       WRITE(*,*) "Solve"
>>>>>>       call VecDuplicate(b,x,ierr)
>>>>>>       call KSPSolve(ksp,b,x,ierr)
>>>>>>       call KSPDestroy(ksp, ierr)
>>>>>> This code is failing in multiple points. At  call PCSetUp(pc, ierr)
>>>>>> it produces:
>>>>>> *[0]PETSC ERROR: Argument out of range*
>>>>>> *[0]PETSC ERROR: Scatter indices in ix are out of range*
>>>>>> *[0]PETSC ERROR: #1 VecScatterCreate() at
>>>>>> ***\src\vec\is\sf\INTERF~1\vscat.c:736*
>>>>>> *[0]PETSC ERROR: #2 PCSetUp_GASM() at
>>>>>> ***\src\ksp\pc\impls\gasm\gasm.c:433*
>>>>>> *[0]PETSC ERROR: #3 PCSetUp() at ***\src\ksp\pc\INTERF~1\precon.c:994*
>>>>>> And at call KSPSolve(ksp,b,x,ierr) it produces:
>>>>>> *forrtl: severe (157): Program Exception - access violation*
>>>>>> The index sets are setup coherently with the outputs of e.g.
>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tests/output/ex71f_1.out:
>>>>>> in particular each element of the matrix A corresponds to a number from 0
>>>>>> to 63.
>>>>> This is not correct, I believe. The indices are row/col indices, not
>>>>> indices into dense blocks, so for
>>>>> your example, they are all in [0, 8].
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Note that each submatrix does not represent some physical subdomain,
>>>>>> the subdivision is just at the algebraic level.
>>>>>> I thus have the following questions:
>>>>>>    - is this the correct way of creating the IS objects, given my
>>>>>>    objective at the beginning of the email? Is the ordering correct?
>>>>>>    - what am I doing wrong that is generating the above errors?
>>>>>> Thanks for the patience and the time.
>>>>>> Best,
>>>>>> Leonardo
>>>>>> Il giorno ven 5 mag 2023 alle ore 18:43 Barry Smith <bsmith at petsc.dev>
>>>>>> ha scritto:
>>>>>>>   Added in *barry/2023-05-04/add-pcgasm-set-subdomains *see also
>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/6419
>>>>>>>   Barry
>>>>>>> On May 4, 2023, at 11:23 AM, LEONARDO MUTTI <
>>>>>>> Thank you for the help.
>>>>>>> Adding to my example:
>>>>>>> *      call PCGASMSetSubdomains(pc,NSub, subdomains_IS,
>>>>>>> inflated_IS,ierr)      call
>>>>>>> PCGASMDestroySubdomains(NSub,subdomains_IS,inflated_IS,ierr)*
>>>>>>> results in:
>>>>>>> *      Error LNK2019 unresolved external symbol
>>>>>>> PCGASMDESTROYSUBDOMAINS referenced in function ...  *
>>>>>>> *      Error LNK2019 unresolved external symbol PCGASMSETSUBDOMAINS
>>>>>>> I'm not sure if the interfaces are missing or if I have a
>>>>>>> compilation problem.
>>>>>>> Thank you again.
>>>>>>> Best,
>>>>>>> Leonardo
>>>>>>> Il giorno sab 29 apr 2023 alle ore 20:30 Barry Smith <
>>>>>>>>    Thank you for the test code. I have a fix in the branch
>>>>>>>> barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>>>>> <https://gitlab.com/petsc/petsc/-/commits/barry/2023-04-29/fix-pcasmcreatesubdomains2d> with
>>>>>>>> merge request https://gitlab.com/petsc/petsc/-/merge_requests/6394
>>>>>>>>    The functions did not have proper Fortran stubs and interfaces
>>>>>>>> so I had to provide them manually in the new branch.
>>>>>>>>    Use
>>>>>>>>    git fetch
>>>>>>>>    git checkout barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>>>>>    ./configure etc
>>>>>>>>    Your now working test code is in src/ksp/ksp/tests/ex71f.F90  I
>>>>>>>> had to change things slightly and I updated the error handling for the
>>>>>>>> latest version.
>>>>>>>>    Please let us know if you have any later questions.
>>>>>>>>   Barry
>>>>>>>> On Apr 28, 2023, at 12:07 PM, LEONARDO MUTTI <
>>>>>>>> Hello. I am having a hard time understanding the index sets to feed
>>>>>>>> PCGASMSetSubdomains, and I am working in Fortran (as a PETSc novice). To
>>>>>>>> get more intuition on how the IS objects behave I tried the following
>>>>>>>> minimal (non) working example, which should tile a 16x16 matrix into 16
>>>>>>>> square, non-overlapping submatrices:
>>>>>>>>       USE petscmat
>>>>>>>>       USE petscksp
>>>>>>>>       USE petscpc
>>>>>>>>       Mat   :: A
>>>>>>>>       PetscInt :: M, NSubx, dof, overlap, NSub
>>>>>>>>       INTEGER :: I,J
>>>>>>>>       PetscScalar :: v
>>>>>>>>       KSP            :: ksp
>>>>>>>>       PC             :: pc
>>>>>>>>       IS :: subdomains_IS, inflated_IS
>>>>>>>>       call PetscInitialize(PETSC_NULL_CHARACTER , ierr)
>>>>>>>> !-----Create a dummy matrix
>>>>>>>>       M = 16
>>>>>>>>       call MatCreateAIJ(MPI_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>>>>>>>      & M, M,
>>>>>>>>      & A, ierr)
>>>>>>>>       DO I=1,M
>>>>>>>>          DO J=1,M
>>>>>>>>             v = I*J
>>>>>>>>             CALL MatSetValue (A,I-1,J-1,v,
>>>>>>>>      &                     INSERT_VALUES , ierr)
>>>>>>>>          END DO
>>>>>>>>       END DO
>>>>>>>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>>>>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>>>>> !-----Create KSP and PC
>>>>>>>>       call KSPCreate(PETSC_COMM_WORLD,ksp, ierr)
>>>>>>>>       call KSPSetOperators(ksp,A,A, ierr)
>>>>>>>>       call KSPSetType(ksp,"bcgs",ierr)
>>>>>>>>       call KSPGetPC(ksp,pc,ierr)
>>>>>>>>       call PCSetType(pc,PCGASM, ierr)
>>>>>>>>       call PCSetUp(pc , ierr)
>>>>>>>> !-----GASM setup
>>>>>>>>       NSubx = 4
>>>>>>>>       dof = 1
>>>>>>>>       overlap = 0
>>>>>>>>       call PCGASMCreateSubdomains2D(pc,
>>>>>>>>      &      M, M,
>>>>>>>>      &      NSubx, NSubx,
>>>>>>>>      &      dof, overlap,
>>>>>>>>      &      NSub, subdomains_IS, inflated_IS, ierr)
>>>>>>>>       call ISView(subdomains_IS, PETSC_VIEWER_STDOUT_WORLD, ierr)
>>>>>>>> Running this on one processor, I get NSub = 4.
>>>>>>>> If PCASM and PCASMCreateSubdomains2D are used instead, I get NSub =
>>>>>>>> 16 as expected.
>>>>>>>> Moreover, I get in the end "forrtl: severe (157): Program Exception
>>>>>>>> - access violation". So:
>>>>>>>> 1) why do I get two different results with ASM, and GASM?
>>>>>>>> 2) why do I get access violation and how can I solve this?
>>>>>>>> In fact, in C, subdomains_IS, inflated_IS should pointers to IS
>>>>>>>> objects. As I see on the Fortran interface, the arguments to
>>>>>>>> PCGASMCreateSubdomains2D are IS objects:
>>>>>>>>        subroutine PCGASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,j,z)
>>>>>>>>        import tPC,tIS
>>>>>>>>        PC a ! PC
>>>>>>>>        PetscInt b ! PetscInt
>>>>>>>>        PetscInt c ! PetscInt
>>>>>>>>        PetscInt d ! PetscInt
>>>>>>>>        PetscInt e ! PetscInt
>>>>>>>>        PetscInt f ! PetscInt
>>>>>>>>        PetscInt g ! PetscInt
>>>>>>>>        PetscInt h ! PetscInt
>>>>>>>>        IS i ! IS
>>>>>>>>        IS j ! IS
>>>>>>>>        PetscErrorCode z
>>>>>>>>        end subroutine PCGASMCreateSubdomains2D
>>>>>>>> Thus:
>>>>>>>> 3) what should be inside e.g., subdomains_IS? I expect it to
>>>>>>>> contain, for every created subdomain, the list of rows and columns defining
>>>>>>>> the subblock in the matrix, am I right?
>>>>>>>> Context: I have a block-tridiagonal system arising from space-time
>>>>>>>> finite elements, and I want to solve it with GMRES+PCGASM preconditioner,
>>>>>>>> where each overlapping submatrix is on the diagonal and of size 3x3 blocks
>>>>>>>> (and spanning multiple processes). This is PETSc 3.17.1 on Windows.
>>>>>>>> Thanks in advance,
>>>>>>>> Leonardo
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230518/95f6de7a/attachment-0001.html>
