[petsc-users] Using dmplexdistribute do parallel FEM code.
neil liu liufield at gmail.com
Wed May 17 17:58:20 CDT 2023
Dear Petsc developers,
I am writing my own code to calculate the FEM matrix. The following is my
general framework,
DMPlexCreateGmsh();
MPI_Comm_rank (Petsc_comm_world, &rank);
DMPlexDistribute (.., .., &dmDist);
dm = dmDist;
//This can create separate dm s for different processors. (reordering.)
MatCreate (Petsc_comm_world, &A)
// Loop over every tetrahedral element to calculate the local matrix for
each processor. Then we can get a local matrix A for each processor.
*My question is : it seems we should build a global matrix B (assemble all
the As for each partition) and then transfer B to KSP. KSP will do the
parallelization correctly, right? *
If that is right, I should define a whole domain matrix B before the
partitioning (MatCreate (Petsc_comm_world, &B); ), and then use
localtoglobal (which petsc function should I use? Do you have any
examples.) map to add A to B at the right positions (MatSetValues) ?
Does that make sense?
Xiaodong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230517/0f9b78ab/attachment-0001.html>
