[petsc-users] Nested field split
Alexander Lindsay alexlindsay239 at gmail.com
Wed May 17 14:22:52 CDT 2023
Awesome, thanks Barry!
On Wed, May 17, 2023 at 11:59 AM Barry Smith <bsmith at petsc.dev> wrote:
>   Absolutely, that is fundamental to the design.
>   In the simple case where all the degrees of freedom exist at the same
> grid points, hence storage is like  u,v,t,p   in the vector the nesting is
> trivial. You indicate the fields without using IS (don't even need to
> change any code)
> -pc_fieldsplit_0_fields 0,1,2
> -fieldsplit_pc_fieldsplit_0_fields  0,1
> Listing the two complimentary fields
> pc_fieldsplit_1_fields 3
> -fieldsplit_pc_fieldsplit_1_fields  2
> should be optional (I can't remember if it is smart enough to allow not
> listing them)
> If you have a staggered grid then indicating the fields is trickery (since
> you don't have the simple u,v,t,p layout of the degrees of freedom)
> > On May 17, 2023, at 12:47 PM, Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
> > I've seen threads in the archives about nested field split but I'm not
> sure they match what I'm asking about.
> > I'm doing a Schur field split for a porous version of incompressible
> Navier-Stokes. In addition to pressure and velocity fields, we have fluid
> and solid temperature fields. I plan to put all primal variables in one
> split and the pressure obviously in the Schur split. Now within the "primal
> variable split" a user is wondering whether we can do a further split, e.g.
> perhaps an additive split with the solid temperature split out from the
> velocities and fluid temperature (the former is almost pure conduction
> whereas the latter may be advection dominated). Is this possible?
> > Alex
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230517/04fbe100/attachment-0001.html>
