[petsc-users] DMGetCoordinatesLocal and DMPlexGetCellCoordinates in PETSc > 3.18
Berend van Wachem berend.vanwachem at ovgu.de
Wed May 17 13:01:22 CDT 2023
Dear Matt,
I tried it, but it doesn't seem to work.
Attached is a very small working example illustrating the problem.
I create a DMPlexBox Mesh, periodic in the Y direction. I then scale the Y coordinates with a factor 10, and add 1.0 to it. Both
DMGetCoordinatesLocal and DMGetCellCoordinatesLocal.
Then I evaluate the coordinates with DMPlexGetCellCoordinates. Most of the Y coordinates are correct, but not all of them - for
instance, the minimum Y coordinate is 0.0, and this should be 1.0.
Am I doing something wrong?
Thanks and best regards,
Berend.
On 5/17/23 17:58, Matthew Knepley wrote:
> On Wed, May 17, 2023 at 11:20 AM Berend van Wachem <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
>     Dear Matt,
>     Is there a way to 'redo' the DMLocalizeCoordinates() ? Or to undo it?
>     Alternatively, can we make the calling of DMLocalizeCoordinates() in the  DMPlexCreate...() routines optional?
>     Otherwise, we would have to copy all arrays of coordinates from DMGetCoordinatesLocal() and DMGetCellCoordinatesLocal() before
>     scaling them.
> I am likely not being clear. I think all you have to do is the following:
>    DMGetCoordinatesLocal(dm, &xl);
>    VecScale(xl, scale);
>    DMSetCoordinatesLocal(dm, xl);
>    DMGetCellCoordinatesLocal(dm, &xl);
>    DMSetCellCoordinatesLocal(dm, xl);
> Does this not work?
>    Thanks,
>       Matt
>     Best regards, Berend.
>     On 5/17/23 16:35, Matthew Knepley wrote:
>      > On Wed, May 17, 2023 at 10:21 AM Berend van Wachem <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>
>     <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>>> wrote:
>      >     Dear Matt,
>      >     Thanks for getting back to me so quickly.
>      >     If I scale each of the coordinates of the mesh (say, I want to cube each
>      >     co-ordinate), and I do this for both:
>      >     DMGetCoordinatesLocal();
>      >     DMGetCellCoordinatesLocal();
>      >     How do I know I am not cubing one coordinate multiple times?
>      > Good question. Right now, the only connection between the two sets of coordinates is DMLocalizeCoordinates(). Since
>     sometimes
>      > people want to do non-trivial things to
>      > coordinates, I prefer not to push in an API for "just" scaling, but I could be convinced
>      > the other way.
>      >    Thanks,
>      >       Matt
>      >     Thanks, Berend.
>      >     On 5/17/23 16:10, Matthew Knepley wrote:
>      >      > On Wed, May 17, 2023 at 10:02 AM Berend van Wachem
>      >      > <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de> <mailto:berend.vanwachem at ovgu.de
>     <mailto:berend.vanwachem at ovgu.de>> <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>
>      >     <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>>>> wrote:
>      >      >     Dear PETSc Team,
>      >      >     We are using DMPlex, and we create a mesh using
>      >      >     DMPlexCreateBoxMesh (.... );
>      >      >     and get a uniform mesh. The mesh is periodic.
>      >      >     We typically want to "scale" the coordinates (vertices) of the mesh,
>      >      >     and
>      >      >     to achieve this, we call
>      >      >     DMGetCoordinatesLocal(dm, &coordinates);
>      >      >     and scale the entries in the Vector coordinates appropriately.
>      >      >     and then
>      >      >     DMSetCoordinatesLocal(dm, coordinates);
>      >      >     After this, we localise the coordinates by calling
>      >      >     DMLocalizeCoordinates(dm);
>      >      >     This worked fine up to PETSc 3.18, but with versions after this, the
>      >      >     coordinates we get from the call
>      >      >     DMPlexGetCellCoordinates(dm, CellID, &isDG, &CoordSize,
>      >      >     &ArrayCoordinates, &Coordinates);
>      >      >     are no longer correct if the mesh is periodic. A number of the
>      >      >     coordinates returned from calling DMPlexGetCellCoordinates are wrong.
>      >      >     I think, this is because DMLocalizeCoordinates is now automatically
>      >      >     called within the routine DMPlexCreateBoxMesh.
>      >      >     So, my question is: How should we scale the coordinates from a periodic
>      >      >     DMPlex mesh so that they are reflected correctly when calling both
>      >      >     DMGetCoordinatesLocal and DMPlexGetCellCoordinates, with PETSc versions
>      >      >       >= 3.18?
>      >      > I think we might have to add an API function. For now, when you scale
>      >      > the coordinates,
>      >      > can you scale both copies?
>      >      >    DMGetCoordinatesLocal()
>      >      >    DMGetCellCoordinatesLocal();
>      >      > and then set them back.
>      >      >    Thanks,
>      >      >       Matt
>      >      >     Many thanks, Berend.
>      >      > What most experimenters take for granted before they begin their
>      >      > experiments is infinitely more interesting than any results to which
>      >      > their experiments lead.
>      >      > -- Norbert Wiener
>      >      > https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/>
>     <https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/>> <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
>      >     <http://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>>>
>      > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any
>     results to
>      > which their experiments lead.
>      > -- Norbert Wiener
>      > https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/> <http://www.cse.buffalo.edu/~knepley/
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230517/9b11cbf9/attachment.bin>
