[petsc-users] DMGetCoordinatesLocal and DMPlexGetCellCoordinates in PETSc > 3.18
Wed May 17 09:10:23 CDT 2023
On Wed, May 17, 2023 at 10:02 AM Berend van Wachem <berend.vanwachem at ovgu.de>
wrote:
> Dear PETSc Team,
> We are using DMPlex, and we create a mesh using
> DMPlexCreateBoxMesh (.... );
> and get a uniform mesh. The mesh is periodic.
> We typically want to "scale" the coordinates (vertices) of the mesh, and
> to achieve this, we call
> DMGetCoordinatesLocal(dm, &coordinates);
> and scale the entries in the Vector coordinates appropriately.
> and then
> DMSetCoordinatesLocal(dm, coordinates);
> After this, we localise the coordinates by calling
> DMLocalizeCoordinates(dm);
> This worked fine up to PETSc 3.18, but with versions after this, the
> coordinates we get from the call
> DMPlexGetCellCoordinates(dm, CellID, &isDG, &CoordSize,
> &ArrayCoordinates, &Coordinates);
> are no longer correct if the mesh is periodic. A number of the
> coordinates returned from calling DMPlexGetCellCoordinates are wrong.
> I think, this is because DMLocalizeCoordinates is now automatically
> called within the routine DMPlexCreateBoxMesh.
> So, my question is: How should we scale the coordinates from a periodic
> DMPlex mesh so that they are reflected correctly when calling both
> DMGetCoordinatesLocal and DMPlexGetCellCoordinates, with PETSc versions
>  >= 3.18?
I think we might have to add an API function. For now, when you scale the
coordinates,
can you scale both copies?
  DMGetCoordinatesLocal()
  DMGetCellCoordinatesLocal();
and then set them back.
     Matt
> Many thanks, Berend.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230517/564c20e4/attachment.html>
