[petsc-users] Interpolation between nodal and elemental field
K. Wu wuktsinghua at gmail.com
Tue May 16 10:12:09 CDT 2023
Hi Matt,
I am using two PETSc DM, one for vertices (nodes), and one for cells
(elements).
I want to do the following operation:
x is a global vector generated from DM vertices, with length Nn. y is a
global vector generated from DM cells, with length Ne. I want to generate a
sparse matrix A with size Ne x Nn, so that y = A*x.
The entry of A is set to a constant value, e.g., 1/4, if the corresponding
vertex belongs to the cell.
Hope I make it clear, thanks!
Kai
Matthew Knepley <knepley at gmail.com> 于2023年5月16日周二 16:29写道:
> On Tue, May 16, 2023 at 10:27 AM K. Wu <wuktsinghua at gmail.com> wrote:
>> Hi all,
>> Good day!
>> I am currently working on interploating the nodal field vector I obtained
>> to its corresponding elemental field vector. I am doing it in a simple way
>> by using structured mesh, the element value is just the average of its
>> corresponding nodal values.
>> Is it possible to generate a connectivity matrix to implement this
>> function? I also need this matrix later on to do a reverse transformation.
>> I am wondering is there a way in PETSc to generate this connectivity
>> matrix between nodal and elemental mesh. Or is there any better way to
>> accomplish this?
>> Thanks for your kind help!
> 1. Are you using a PETSc DM, or your own mesh?
> 2. In order to define what you mean, you have to attach function spaces
> (or something equivalent) to the
>     two representations. Do you mean linear interpolation between vertices
> and constants on cells?
>   Thanks,
>      Matt
>> Best regards,
>> Kai
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230516/9c41a20a/attachment-0001.html>
